C6455 UART example code
Other Parts Discussed in Thread: SPRC234
Dear Sir,
Do you have UART example code of C6455?
If yes, please share it to me.
  • Moved this thread to correct forum for faster response.
    Thank you.
    Thanks for your post.
    There are CSL for C6455 peripheral programming API modules and you can download from the below:
    http://processors.wiki.ti.com/index.php/Chip_support_library#Chip_Support_Library_for_C6455
    http://www.ti.com/tool/SPRC234
    You can see the entire set of peripheral examples covered on the above resources and from which, you can enhance the code to insert UART API calls to debug & test your desired functionality with appropriate UART baud rate configuration.
    Thanks & regards,
    Sivaraj K
    Please click the Verify Answer button on this post if it answers your question.
  • Hi Chang,
    In C6455, UART peripheral is not available.
