I am trying to get the DSP working withdsp bridge on a linux kernel 3.5.7 running on my DM3730. I used this guide:
Under the section: Building the user space binaries, there is a link on a repository, with which you can build your own dsp and gpp binaries. I tested the ping-sample. It nearly works, but the error "Create node failed" comes up. With this warning, that allocating the node works! I had the same result when using teh dsp-for-dummies sample:
There, I had to change the API-Level from 1 to 2. But I cant figure out how to to something similar in the upper sample. I think it has something todo with the tconf - configuration, but I do not completly understand what tconf does.
Is there anybody else working with the dsp at the moment?
Michael
