can you explain the following assembly instruction?
[A0] STW B11,*B10[0]
Hi Bugra,
Ran is right.
Here, if the value of the register, "A0" is a nonzero, the instruction, "STW B11,*B10[0] " will get executed.
If the value of the register, "A0" is zero, then the instruction, "STW B11,*B10[0] " will NOT get executed.
For conditional operations, Conditional instructions are represented in code by using square brackets, [ ], surrounding the condition
register name. Here , it is represented as "[A0]".
For more info, please visit page no: 68 of "TMS320C64x/C64x+ DSP CPU and Instruction Set".
