Dear Champs,
I created pdkproject in pdk_omapl13x_1_0_0 directory and build it using CCSv7.1.0, and am analyzing its memory usage now to estimate final memory size of customer's application.
I found total memory usage of this example was 514KB(525,835 Bytes), but can not select exactly which component should be used and what is expected memory size except application code.
And also customer requested to explain each component. I got below information from map file.
Could you please let me know which components will be used in real product in normal?
Could you please your estimated memory size of customer's system except application?
Especially I want to know what is cfg(audiosample_pe674.oe674) and if this will be needed in real product.
Below table is memory size of each module.
attached map file for reference.
MCASP_Audio_evmOMAPL137_c674xExampleProject_rel_map.txt
Thanks and Best Regards,
SI.
Module | Memory size(code/ro/rw) | production |
aic31.obj audioSample_io.obj aic3106_if.obj mcasp_soc.obj codec_if.obj I2C_soc.obj audioSample_main.obj mcasp_cfg.obj audio_evmInit.obj |
16,879 | 16,879 |
\pdk_omapl13x_1_0_0\packages\MyExampleProjects\MCASP_Audio_evmOMAPL137_c674xExampleProject\Release\configPkg\package\cfg\ | ||
audiosample_pe674.oe674 | 230,678 | |
\bios_6_46_04_53\packages\ti\targets\rts6000\lib\boot.ae674 | ||
autoinit.oe674 boot.oe674 |
480 | 480 |
\bios_6_46_04_53\packages\ti\targets\rts6000\lib\ti.targets.rts6000.ae674 | ||
System.oe674 Text.oe674 Error.oe674 Core-mem.oe674 Startup.oe674 Memory.oe674 Core-smem.oe674 LoggerBuf.oe674 SysStd.oe674 Assert.oe674 Core-label.oe674 Core-params.oe674 SysMin.oe674 Gate.oe674 Registry.oe674 xdc_noinit.oe674 |
9,729 | |
\edma3_lld_2_12_03_27\packages\ti\sdo\edma3\drv\lib\674\debug\edma3_lld_drv.ae674 | ||
edma3_drv_init.oe674 edma3_drv_basic.oe674 edma3_drv_adv.oe674 |
69,758 | 69,758 |
\edma3_lld_2_12_03_27\packages\ti\sdo\edma3\drv\sample\lib\omapl137-evm\674\debug\edma3_lld_drv_sample.ae674 | ||
sample_omapl137_cfg.oe674 sample_cs.oe674 sample_omapl137_int_reg.oe674 sample_init.oe674 |
4,012 | |
\edma3_lld_2_12_03_27\packages\ti\sdo\edma3\rm\lib\omapl137-evm\674\debug\edma3_lld_rm.ae674 | ||
edma3resmgr.oe674 edma3_rm_gbl_data.oe674 edma3_omapl137_cfg.oe674 |
77,674 | |
\pdk_omapl13x_1_0_0\packages\ti\board\lib\evmOMAPL137\c674\release\ti.board.ae674 | ||
evmOMAPL137_clock.oe674 evmOMAPL137_pinmux.oe674 evmOMAPL137_pll.oe674 evmOMAPL137.oe674 evmOMAPL137_ddr.oe674 evmOMAPL137_lld_init.oe674 |
2,560 | 2,560 |
\pdk_omapl13x_1_0_0\packages\ti\csl\lib\omapl137\c674\release\ti.csl.ae674 | ||
mcasp.oe674 uart.oe674 i2c.oe674 csl_chip.oe674 |
4,448 | 4,448 |
\pdk_omapl13x_1_0_0\packages\ti\drv\i2c\lib\omapl137\c674\release\ti.drv.i2c.ae674 | ||
I2C_v0.oe674 I2C_drv.oe674 |
6,824 | 6,824 |
\pdk_omapl13x_1_0_0\packages\ti\drv\mcasp\example\evmOMAPL137\c674\bios\src\sysbios\sysbios.ae674 | ||
BIOS.obj c64p_Hwi_disp_always.obj c64p_Exception_asm.obj c62_TaskSupport_asm.obj c64p_Hwi_asm_switch.obj c64p_Hwi_asm.obj |
34,984 | 34,984 |
\pdk_omapl13x_1_0_0\packages\ti\drv\mcasp\lib\omapl137\c674\release\ti.drv.mcasp.ae674 | ||
mcasp_drv.oe674 mcasp_edma.oe674 mcasp_ioctl.oe674 |
34,750 | 34,750 |
\pdk_omapl13x_1_0_0\packages\ti\drv\uart\lib\omapl137\c674\release\ti.drv.uart.ae674 | ||
UART_v0.oe674 UART_stdio.oe674 UART_soc.oe674 UART_drv.oe674 |
10,808 | 10,808 |
\pdk_omapl13x_1_0_0\packages\ti\osal\lib\tirtos\omapl137\c674\release\ti.osal.ae674 | ||
RegisterIntr_tirtos.oe674 EventCombinerP_tirtos.oe674 SemaphoreP_tirtos.oe674 HwiP_tirtos.oe674 Utils_tirtos.oe674 MuxIntcP_tirtos.oe674 Queue_tirtos.oe674 CacheP_tirtos.oe674 |
3,316 | 3,316 |
\ti-cgt-c6000_8.1.3\lib\rts6740_elf.lib | ||
trgdrv.obj lowlev.obj fputs.obj defs.obj imath64.obj fputc.obj setvbuf.obj trgmsg.obj fflush.obj fclose.obj copy_decompress_rle.obj fseek.obj _io_perm.obj exit.obj divi.obj llshift.obj memset.obj divu.obj tls.obj fopen.obj memcpy64.obj remu.obj _lock.obj args_main.obj assert.obj strasg.obj copy_decompress_none.obj copy_zero_init.obj |
10,776 | |
stack | 4,096 | 4,096 |
linker generated | 4,063 | 4,063 |
total | 525,835 | 192,966 |
