Hi TI expert,
Please le me confirm the following question.
[QUestion]
Would you please teach me the specification of undershoot ??
Also would you please teach me the time limitation of overshoot and undershoot?
Best regards.
Kaka
Hi TI expert,
[QUestion]
Best regards.
Kaka
Hi Yordan
Thank you for response.
I know that data sheet provide this speculation but I could not understand the mean of description on.
According to the data sheet , the overshoot undershoot is the Dvdd +20%. Does this mean the 3.3V + 0.66V when DVDD is 3.3V? It seems that the it is exceeded the aboslute maximum rating of device(3.6V or 3.8V). What do think? How about undershoot? I could not find the spec of this. Would you please show me the value of undershoot if the vdd is 3.3V?
Also, would you please teach me how should we consider the time limitation? I could not understand the mean of "up to 20% of Signal Period".
If the period was 1s, will the time limitation be 200ms?
Best regards.
Kaka
Hi Senthil,
Thank you for your response. I got it for the different.
So, you mean that the undershoot range is from -0.66V to 3.96V when DVDD is 3.3V, right? I would like to know the minimum voltage value.
By the way, I also referred the following post.
If the signal was DC signal(not period signal), what is undershoot/overshoot of the maximum limitation time? Should customer follow the value of "-0.3V to DVDD + 0.3V"?
Best regards.
Kaka
