Hi Champs,
I've got C674x DSPLIB FFT benchmarks below on LCDKC6748. It seems that the results depend on a parameter MAXN in DSPF_sp_fftSPxSP_d.c.
Is that correct? Is there anything else I should do for the benchmarking?
o Case 1: MAXN is set to 256 (default)
DSPF_sp_fftSPxSP Iter#: 1 Result Successful N = 8 radix = 2 natC: 283 optC: 171
DSPF_sp_fftSPxSP Iter#: 2 Result Successful N = 16 radix = 4 natC: 388 optC: 188
DSPF_sp_fftSPxSP Iter#: 3 Result Successful N = 32 radix = 2 natC: 891 optC: 342
DSPF_sp_fftSPxSP Iter#: 4 Result Successful N = 64 radix = 4 natC: 1635 optC: 538
DSPF_sp_fftSPxSP Iter#: 5 Result Successful N = 128 radix = 2 natC: 4122 optC: 1221
DSPF_sp_fftSPxSP Iter#: 6 Result Successful N = 256 radix = 4 natC: 8140 optC: 2239
o Case 2: MAXN is set to 512
DSPF_sp_fftSPxSP Iter#: 1 Result Successful N = 8 radix = 2 natC: 297 optC: 187
DSPF_sp_fftSPxSP Iter#: 2 Result Successful N = 16 radix = 4 natC: 387 optC: 188
DSPF_sp_fftSPxSP Iter#: 7 Result Successful N = 512 radix = 2 natC: 20099 optC: 5358
o Case 3: MAXN is set to 1024
DSPF_sp_fftSPxSP Iter#: 1 Result Successful N = 8 radix = 2 natC: 306 optC: 191
DSPF_sp_fftSPxSP Iter#: 3 Result Successful N = 32 radix = 2 natC: 890 optC: 343
DSPF_sp_fftSPxSP Iter#: 4 Result Successful N = 64 radix = 4 natC: 1637 optC: 538
DSPF_sp_fftSPxSP Iter#: 5 Result Successful N = 128 radix = 2 natC: 4169 optC: 1294
DSPF_sp_fftSPxSP Iter#: 6 Result Successful N = 256 radix = 4 natC: 8262 optC: 2425
DSPF_sp_fftSPxSP Iter#: 7 Result Successful N = 512 radix = 2 natC: 20328 optC: 5667
DSPF_sp_fftSPxSP Iter#: 8 Result Successful N = 1024 radix = 4 natC: 40677 optC: 10976
o Case 4: MAXN is set to 2048
DSPF_sp_fftSPxSP Iter#: 1 Result Successful N = 8 radix = 2 natC: 301 optC: 191
DSPF_sp_fftSPxSP Iter#: 3 Result Successful N = 32 radix = 2 natC: 900 optC: 343
DSPF_sp_fftSPxSP Iter#: 4 Result Successful N = 64 radix = 4 natC: 1669 optC: 598
DSPF_sp_fftSPxSP Iter#: 5 Result Successful N = 128 radix = 2 natC: 4271 optC: 1411
DSPF_sp_fftSPxSP Iter#: 6 Result Successful N = 256 radix = 4 natC: 8384 optC: 2711
DSPF_sp_fftSPxSP Iter#: 7 Result Successful N = 512 radix = 2 natC: 20724 optC: 6429
DSPF_sp_fftSPxSP Iter#: 8 Result Successful N = 1024 radix = 4 natC: 41544 optC: 12425
DSPF_sp_fftSPxSP Iter#: 9 Result Successful N = 2048 radix = 2 natC: 98854 optC: 28673
The below is my tools and settings.
- C674x DSPLIB: v3.4.0.0
- CCS : v7.2.0.00012
- CGTools : v7.4.21
- L2 : 256KB SRAM
- L1P: 32KB Cache
- L1D: 32KB Cache
- Build Configurations: Release
And I attached the cmd file.
-c
-heap 0x1000
-stack 0x1000
-lC:/ti/dsplib_c674x_3_4_0_0/packages/ti/dsplib/lib/dsplib.lib
-lC:/ti/dsplib_c674x_3_4_0_0/packages/ti/dsplib/lib/dsplib_cn.lib
/* MODULE MEM */
MEMORY
L2SRAM (RWX) : origin = 0x800000, len = 0x40000
SECTIONS
.kernel: {
*.obj (.text:optimized) { SIZE(_kernel_size) }
.text: load >> L2SRAM
.text:touch: load >> L2SRAM
GROUP (NEAR_DP)
.neardata
.rodata
.bss
} load > L2SRAM
.far: load >> L2SRAM
.fardata: load >> L2SRAM
.data: load >> L2SRAM
.switch: load >> L2SRAM
.stack: load > L2SRAM
.args: load > L2SRAM align = 0x4, fill = 0 {_argsize = 0x200; }
.sysmem: load > L2SRAM
.cinit: load > L2SRAM
.const: load > L2SRAM START(const_start) SIZE(const_size)
.pinit: load > L2SRAM
.cio: load >> L2SRAM
xdc.meta: load >> L2SRAM, type = COPY
.init_array: load > L2SRAM
j-breeze
