• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Digital Signal Processors (DSP) » C6000 Single Core DSP » C67x Single Core DSP Forum » Ti Processor TMS320C6748 is not able to boot from SPI based Flash
Share
  • Forums
  • Announcements
Options
  • Subscribe via RSS
This question is not answered
Sandeep Nayak
Posted by Sandeep Nayak
on Apr 20 2012 05:10 AM
Prodigy200 points
We have a Custom Built Board with TI Processor TMS320C6748 & SPI Flash memory M25P64.
We are using AISGEN to flash our program. In the Hardware we have connected ‘EN’ Pin of of Processor to ‘CS’ pin  of Flash.
We made changes in ‘device_spi.c’ and re compiled the Sipwriter program. We have a new compiled SpiWriter.out file (we didn’t use Cgywin as suggested by a wiki link).
Howe ever, when we executed the ‘SpiWriter.out’ program we were able to erase and program the flash successfully. However the Boot is not happening. We used a DEBUG.gel file and got the following message.
‘ROM Status Code: 0x00000009
Description:C674X_0: GEL Output: Invalid AIS keyword’
We are not able to know where we are making the mistake. Can you help us in solving the Boot issue involving TMS320C6748 and SPI based  M25P64 flash.
Sandeep Nayak
Sandy
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • RandyP
    Posted by RandyP
    on Apr 22 2012 09:33 AM
    Guru59970 points
    Sandeep,
    You have a new board and have made changes to the software examples. So many changes at one time make remote debug difficult. This is one reason that many users prefer to use the exact same components as are on our DSK boards. But that is not always possible.
    The error message is telling you that there is something wrong in the data seen by the bootloader when it tries to read the contents of the SPI Flash. So you must narrow down to which AIS keyword is not correct.
    My advice is to read the entire SPI back, maybe using a small modification to your SpiWriter.out program for verification. Then reduce the data file manually to test a reduced load image. Maybe create a very small load image and see if you can load just that.
    Also, it would make sense to re-examine the changes you made in device_spi.c, and try changing some of the values in there to see if you may have changed something so that the image would not work.
    RandyP
    Search for answers, Ask a question, click  Verify  when complete, Help others, Learn more.
    Report Abuse
    • Reply
  • Sandeep Nayak
    on Apr 23 2012 03:44 AM
    Prodigy200 points
    Hello Randy,
    The image that we are trying to load is 28kb only.
    From the debug Gel file I got the following info:
    C674X_0: GEL Output: ---------------------------------------------
    C674X_0: GEL Output: |               BOOTROM Info                |
    C674X_0: GEL Output: ROM ID: d800k006
    C674X_0: GEL Output: Silicon Revision 2.0
    C674X_0: GEL Output: Boot pins: 10
    C674X_0: GEL Output: Boot Mode: SPI0 Flash
    Program Counter (PC) = 0x800044E0
    C674X_0: GEL Output: |              Clock Information             |
    C674X_0: GEL Output: PLLs configured to utilize crystal.
    C674X_0: GEL Output: ASYNC3 = PLL0_SYSCLK2
    C674X_0: GEL Output: NOTE:  All clock frequencies in following PLL sections are based
    C674X_0: GEL Output: off OSCIN = 24 MHz.  If that value does not match your hardware
    C674X_0: GEL Output: you should change the #define in the top of the gel file, save it,
    C674X_0: GEL Output: and then reload.
    I checked out the gpio.BIN in Hex format. The Start address has the following value 54 49 50 41 ... Is it correct considering that the First few bytes represent the magic number of the Flash. In our case the flash used is M25P64. Can you draw any conclusion out of this?
    What does this ROM Status Code 0x00000009 Signify?
    Can there be any Hardware Problem which we have overlooked? Few have mentioned about similar problem and said the problem lies between the reset signal and the boot_disable signal. Can you look into our Schematic and ascertain its correctness? The Schematic is attached along with this mail.2260.digital board.pdf
    Sandy
    Report Abuse
    • Reply
  • Sandeep Nayak
    on Apr 24 2012 01:03 AM
    Prodigy200 points
    Hello Randy,
    I connected UART1of TI processor  to the RS323 port CPU to see the status & error report during Boot. I got the following Message :
    AIS Parse): Waiting for BOOTME... (power on or reset target now)
    (Serial Port): Read error! (The operation has timed out.)
    (AIS Parse): Read invalid BOOTME string.
    (AIS Parse): Boot aborted.
    (Serial Port): Closing COM1.
    Sandy
    Report Abuse
    • Reply
  • Rahul Prabhu
    Posted by Rahul Prabhu
    on Apr 30 2012 16:19 PM
    Genius15435 points
    Sandy,
    The ROM is hard coded to use certain pins of the SPI peripheral for boot, and these are documented in the boot loader app note.  For SPI boot, the CS pin is used and the peripheral operates in 4-pin mode (the other pins are of course CLK, SIMO, and SOMI). The EN pin is not used in the SPI boot mode setup.
    The ROM cannot be changed to use the EN pin.  We cannot envision a software solution to this.  Some kind of hardware change will be required in your setup.
    Rahul
    Please click the
    Verify Answer button on this post if it answers your question.
    Report Abuse
    • Reply
  • Dean Hofstetter
    Posted by Dean Hofstetter
    on May 02 2012 15:20 PM
    Expert1110 points
    If you do rev the PCB to fix the hardware, make sure you are aware of the new requirements for the BOOT pins.  See:   C6748 SPI1 FLASH Boot failure on Custom PCB.  Boot pins all high.
    - Dean
    Report Abuse
    • Reply
  • Mukul Bhatnagar
    Posted by Mukul Bhatnagar
    on May 03 2012 13:16 PM
    Mastermind24420 points
    Hi Dean
    The boot pin issue that you struggled with is now a published errata
    http://www.ti.com/lit/er/sprz303f/sprz303f.pdf  (2.1.23)
    Mukul
    Don't forget to verify answers to your forum questions by using the green "Verify Answer" button.
    Report Abuse
    • Reply
  • Sathish
    Posted by Sathish
    on May 09 2012 01:30 AM
    Intellectual1920 points
    Hi Sandy,
    The bootloader doc mentions that the appropriate pin (SPI0_SCS[0] or SPI1_SCS[0]) must be connected to the external SPI device. It doesn't mention about connecting SPIx_ENA pin to CS.
    Since you have connected SPIx_ENA pin instead SPIx_SCS to CS of flash. I would recommend to try once making flash CS pin ground so that flash get selected and work in 3pin mode.
    Mukul/Dean,
    Correct me if I am wrong, does the errata mentioned related to same error?
    Thanks!!
    Sathish
    Report Abuse
    • Reply
  • Sandeep Nayak
    on May 09 2012 07:42 AM
    Prodigy200 points
    Hello Satish,
    We have already tried this out. Infact we have cut the track and pulled the 'CS' line permanently. Still it was not working. We could see clock signal in the 'CLK' line (burst of 8 bits/rising & falling). Still the Processor was not booting.Then we looked into the Data sheet of the 'M25P64'  and we found the following sentece
    'After Power-up, a falling edge on Chip Select (S) is required prior to the start of any instruction [Page number 9 of data sheet M25P64-VME6TG]'.
    So, 'CS' line need a high to low transition before the start of instruction at power ON {because Flash sees the falling edge}.Hence we concluded that pulling the CS line permanently is a big mistake.
     Errata speaks about the logic line of the Boot pins & etc. For our hardware those line are working correctly and we have verified it by using the DEBUG.gel file.
    Sandeep.
    Sandy
    Report Abuse
    • Reply
  • Rahul Prabhu
    on May 09 2012 11:07 AM
    Genius15435 points
    Sandeep,
    Yes, what you noticed is correct. Most Master-Slave SPI Flash interface configurations would expect a high to low transition on CS before communication begins. With the hardware change of using EN instead of CS, the SPI writer can be changed to write the boot image on the flash because it is a modifiable code/configuraton that runs from RAM. But while booting the device, the processor is running the fixed rbl code in its ROM. The ROM code has the processor-SPI Flash slave boot configured in 4 pin mode using the CS. This forces the transition from high to low only on the CS of the processor while booting from SPI flash and not on the enable pin. We have documented all these hard restrictions in chapter 9 of the bootloader app note.
    Unfortunately we do not forsee, a change in the software or a simple workaround to fix this issue. You need to route the upp_SPI_SCS[0] to the SPI_SCS[0] to be able to boot over SPI flash.
    Rahul
    Please click the
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
