• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Digital Signal Processors (DSP) » C6000 Single Core DSP » C67x Single Core DSP Forum » c6713 EXT_INT5 interrupt question
Share
  • Forums
  • Announcements
Options
  • Subscribe via RSS
This question is not answered
firephenix405
Posted by firephenix405
on Apr 26 2012 05:11 AM
Prodigy100 points
I am writing a program to use EXT_INT5 interrupt.  However, it seems not work.  Here is my code:
; Vectors_intr.asm Vector file for interrupt INT11
   .global _vectors    ;global symbols
   .global _c_int00
   .global _vector1
   .global _vector2
   .global _vector3
   .global _vector4
   .global _vector5  ; for INT 5
   .global _vector6
   .global _vector7
   .global _vector8
   .global _vector9
   .global _vector10
   .global _isrDetection
   .global _vector12
   .global _vector13
   .global _vector14
   .global _vector15
   .ref _c_int00    ;entry address
VEC_ENTRY .macro addr   ;macro for ISR
    STW   B0,*--B15
    MVKL  addr,B0
    MVKH  addr,B0
    B     B0
    LDW   *B15++,B0
    NOP   2
    NOP
    NOP
   .endm
_vec_dummy:
  B    B3
  NOP  5
 .sect ".vectors"    ;aligned IST section
 .align 1024
_vectors:
_vector0:   VEC_ENTRY _c_int00    ;RESET
_vector1:   VEC_ENTRY _vec_dummy   ;NMI
_vector2:   VEC_ENTRY _vec_dummy   ;RSVD
_vector3:   VEC_ENTRY _vec_dummy
_vector4:   VEC_ENTRY _vec_dummy
_vector5:   VEC_ENTRY _vec_dummy          ;ISR address
_vector6:   VEC_ENTRY _vec_dummy
_vector7:   VEC_ENTRY _vec_dummy
_vector8:   VEC_ENTRY _vec_dummy
_vector9:   VEC_ENTRY _vec_dummy
_vector10:  VEC_ENTRY _vec_dummy
_vector11:  VEC_ENTRY _isrDetection
_vector12:  VEC_ENTRY _vec_dummy
_vector13:  VEC_ENTRY _vec_dummy
_vector14:  VEC_ENTRY _vec_dummy
_vector15:  VEC_ENTRY _vec_dummy
In the main() program,  the codes looks like:
 GPIO_Config  GPIOcfg={
  GPIO_FMKS(GPGC,  GP0M,   GPIOMODE)     |
  GPIO_FMKS(GPGC,  GPINT0M, PASSMODE)    |
  GPIO_FMKS(GPGC,  GPINTPOL, LOGICTRUE)  |
  GPIO_FMKS(GPGC,  LOGIC,   ORMODE)      |
  GPIO_FMKS(GPGC,  GPINTDV, DELTAMODE),
  GPIO_FMKS(GPEN,  GPXEN,  OF(0)),
  GPIO_FMKS(GPDIR, GPXDIR, OF(0)),
  GPIO_FMKS(GPVAL, GPXVAL, OF(0)),
  GPIO_FMKS(GPDH,  GPXDH,  OF(0x00)),
  GPIO_FMKS(GPHM,  GPXHM,  OF(0x00)),
  GPIO_FMKS(GPLM,  GPXLM,  OF(0x0)),
  GPIO_FMKS(GPPOL, GPINTXPOL, OF(0))
  hGpio = GPIO_open(GPIO_DEV0, GPIO_OPEN_RESET);
 GPIO_config(hGpio, &GPIOcfg);
 IRQ_setVecs(vectors);
 IRQ_globalDisable();
 IRQ_globalEnable();       /* Globally enable interrupts       */
 for(i=0;i<32;i++)
     IRQ_disable(i);   /* Disable and clear all IRQ events    */
     IRQ_clear(i);     /* except reset and NMI interrupts     */
    IRQ_map(IRQ_EVT_EXTINT4, 11);
    IRQ_reset(IRQ_EVT_EXTINT4);
    IRQ_enable(IRQ_EVT_EXTINT4);
 I've enabled the interrupt individually, also set up the interrupt in the vectors_intr.asm file. The program gets compiled with no errors.   Did I configured the GPIO incorrectly?
I am very grateful for your any advice or help?
6713 gpio interrupt ext_int5
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Sam Kuzbary
    Posted by Sam Kuzbary
    on Apr 26 2012 13:47 PM
    Expert2655 points
    Greetings,
    You will need not to use this macro for the reset vector.  Please read the following thread http://e2e.ti.com/support/dsp/tms320c6000_high_performance_dsps/f/115/p/153708/581922.aspx#581922
    Good Luck,
    Sam
    Report Abuse
    • Reply
  • RandyP
    Posted by RandyP
    on Apr 26 2012 22:57 PM
    Guru61605 points
    Do you have example code that came with the DSK6713?
    Have you connected CCS and the emulator on the board to do any debug?
    firephenix405
    You need to figure out a lot more about what is not working so that you can debug this, or to be able to describe the problem for someone to offer help. Take it slow and consider each step between reset and main().
    It would be interesting to know where you got examples or found information that led you to the code example you have above. Please let us know.
    RandyP
    Search for answers, Ask a question, click  Verify  when complete, Help others, Learn more.
    Report Abuse
    • Reply
  • turboscrew
    Posted by turboscrew
    on Apr 27 2012 05:17 AM
    Intellectual685 points
    Out of curiosity...
    Does:
        STW   B0,*--B15
        MVKL  addr,B0
        MVKH  addr,B0
        B     B0
    work?
    Is it the B0 before MVKL that goes into the stack?
    Is MVKH ready before B B0?
    Another thing, does this work:
    _vec_dummy:
      B    B3
      NOP  5
    Is the interrupt return address in B3 in this device?
    In C6482 the interrupt return address goes to megamodule IRP register.
    Report Abuse
    • Reply
  • firephenix405
    on Apr 27 2012 20:57 PM
    Prodigy100 points
    I referred to the vector.asm  from the book "DSP and application with C6713 and C6416 DSK".
    I take your guys advice and working on what's wrong with my codes.  I'll let you know the results.
    Report Abuse
    • Reply
  • Sam Kuzbary
    on Apr 28 2012 08:27 AM
    Expert2655 points
    Greetings,
    In thread I pointed you to, there is a viable solution for your problem.
    Reset vector can not use such a macro because the DSP just got released from reset and its B15 (SP) contain unknown value, and when you push the unknown value of B0 onto memory pointed to by B15, you get unknown results.
    Use the following
     _vector0:                           ; RESET
      MVKL _c_int00, B0
      MVKH _c_int00, B0
      B B0
     NOP
      NOP
      NOP
      NOP
      NOP
     _vector1:   VEC_ENTRY _vec_dummy    ; NMI
     _vector2:   VEC_ENTRY _vec_dummy    ; RSVD
     _vector3:   VEC_ENTRY _vec_dummy    ; RSVD
    Good Luck,
    Sam
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
