• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Digital Signal Processors (DSP) » C6000 Single Core DSP » C67x Single Core DSP Forum » Cannot find CSR and IER
Share
  • Forums
  • Announcements
Options
  • Subscribe via RSS
This question is answered
Sean Bedford
Posted by Sean Bedford
on Jun 18 2012 03:47 AM
Intellectual830 points
Good morning,
I have two projects loaded into code composer the both reference these registers but one works and one reports unresolved symbols which relates to CSR and IER.
I know this is more than likley something simple and I am missing a define or include path in the project but I have been tearing my hair out looking for it for a couple of days so if someone could please point me in the right direction I would be very grateful.
Sean
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • RandyP
    Posted by RandyP
    on Jun 18 2012 09:30 AM
    Guru60220 points
    Sean,
    Compare your #includes between the two. The first one should be <c6x.h>.
    RandyP
    Search for answers, Ask a question, click  Verify  when complete, Help others, Learn more.
    Report Abuse
    • Reply
  • Sean Bedford
    on Jun 18 2012 10:23 AM
    Hi Randy,
    All the included that are in the working project are also in the one that isn't working.  c6x.h isnt actually in either of them but I put it in to see and it made no diffrence.
    Sean
    Report Abuse
    • Reply
  • Rahul Prabhu
    Posted by Rahul Prabhu
    on Jun 18 2012 10:28 AM
    Genius15575 points
    Sean,
    Unresolved Symbols sounds like a link time error, rather than compile time error,  Can you confirm?
    If yes then you are missing some library in your second project.
    Rahul
    Please click the
    Verify Answer button on this post if it answers your question.
    Report Abuse
    • Reply
  • Sean Bedford
    on Jun 18 2012 10:49 AM
    yes sorry for not being clear it happens in the linking part of the build below is what appears in the console.
    Sean
    <Linking>
    undefined first referenced
    symbol in file
    _PIC_SPI_Rx ./14ducfg.obj
    _PIC_SPI_Tx ./14ducfg.obj
    error #10234-D: unresolved symbols remain
    error #10010: errors encountered during linking; "14du.out" not built
    >> Compilation failure
    gmake: *** [14du.out] Error 1
    gmake: Target `all' not remade because of errors.
    **** Build Finished ****
    Report Abuse
    • Reply
  • Rahul Prabhu
    on Jun 18 2012 10:54 AM
    Genius15575 points
    Sean,
    Please confirm that all the libraries linked in the first project are same as the ones being linked in second project. Check the project settings as well as linker command files. Also please specify the device you are using, and if you are using BIOS so that we can help you locate the appropriate library that needs to be linked
    Rahul
    Please click the
    Report Abuse
    • Reply
  • Sean Bedford
    on Jun 18 2012 11:08 AM
    yes it is all the same.  I am using a C6713B and I am using the BIOS.
    Sean
    Report Abuse
    • Reply
  • RandyP
    Posted by RandyP
    on Jun 18 2012 11:28 AM
    Guru60220 points
    Sean,
    Which version of CCS and which version of BIOS are you using?
    Your error message above does not have any mention of CSR and IER. Is this a new problem, or a different problem? If not, what am I missing in understanding this?
    RandyP
    Report Abuse
    • Reply
  • Sean Bedford
    on Jun 19 2012 03:11 AM
    I am using CCS v , Compiler v7.3.1 and DSP/BIOS v5.41.11.38 and yes the same libraries are included in both.
    "Symbol 'CSR' could not be resolved" and "Symbol 'IER' could not be resolved" are displayed in the problem window and have errors next to them in the code.  It doesn't say say what the symbols are in the console (this would be sensible) but i can only assume it is IER and CSR as that is what is reported int he problems window.
    Sean
    Report Abuse
    • Reply
  • Sean Bedford
    on Jun 19 2012 03:43 AM
    I have gone to an old backed up version which builds and I will re do the changes as it looks like it is going to be by far the easier option.
    Sean
    Report Abuse
    • Reply
  • RandyP
    Posted by RandyP
    on Jun 19 2012 06:24 AM
    Guru60220 points
    Sean,
    Your CCS version did not come through in the post, but it is probably v5.x, and the x could be relevant - probably not but it could be.
    Sean Bedford
    symbol            in file
    The message above says the undefined symbols are _PIC_SPI_Rx and _PIC_SPI_Tx, and that they were referenced in your BIOS Config file. Perhaps there is a typo in the name of an ISR?
    These are not related to the CSR and IER errors. Usually the errors that show up in Problems also show up in the console window during the compile step at which they occur.
    RandyP
    Report Abuse
    • Reply
  • Douglas Gwyn
    Posted by Douglas Gwyn
    on Jun 22 2012 02:44 AM
    Verified Answer
    Verified by Sean Bedford
    Expert2060 points
    As Randy said, the two unresolved _SPI_* symbols is a different problem from unresolved 'CSR' and 'IER'.  It would be either a spelling problem (upper vs. lower case really does matter) or a failure to include the necessary library (not normally a problem if you let CCS configure BIOS for you).
    A similar message about 'CSR' and 'IER' would occur if they were used without a suitable preceding declaration in *some* source file (C using EABI, if they really don't start with an underscore).  Usually you should get these declared by #include <c6x.h> (that header is in the compiler's usual "include" directory).  For most purposes, that is the best way, but instead you can manually declare them:
    extern cregister volatile unsigned int CSR; extern cregister volatile unsigned int IER;
    If you're using "strict ANSI" mode (which is somewhat unlikely), then change cregister to __cregister.
    Another possibility might be if you used them incorrectly in an assembly-language file.  The control registers can only be used with the MVC operator, *not* with MOV, AND, etc.
    About those other symbols, you can search for them in the source files.  On Windows, you can use the findstr command from a command ("DOS") window: open the window by typing "cmd" in the "Run..." or "Search programs and files" box, use "cd {pathname}" to navigate to the folder where your source files are, then type "findstr {target_pattern} *.c".  On Unix or Linux, use "grep" instead of "findstr".
    Report Abuse
    • Reply
  • Sean Bedford
    on Jun 22 2012 03:08 AM
    Thanks for the responces.  When loaded an old backed up project the CSR and IER problem went away but the other remained and it was down to a spelling mistake.
    Thank you for your help.
    Sean
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
