• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Digital Signal Processors (DSP) » C6000 Single Core DSP » C67x Single Core DSP Forum » SD card vs NAND flash
Share
  • Forums
  • Announcements
Options
  • Subscribe via RSS
This question is not answered
cobsonchael
Posted by cobsonchael
on Jul 23 2012 16:47 PM
Expert1970 points
so for our future C6748 product we want a great big pool of nonvolatile flash with a file system.  we have the option, obviously, of SD card or NAND flash since the 6748 supports both of those memory types.
we got the LCDK and we were able to get the FATfs PSP driver project to work for the SD card project and the NAND flash project.
so far they seem to be the same project with a few different basic calls.
So i was tasked with asking the experts: Which is better?  we don't plan on removing this thing from the unit (the SD card will just stay on the board forever) so that would suggest the NAND flash (it doesn't hurt that it is also cheaper) so i would think that that is the obvious choice. however we would really like to know if there are known issues or something we are not thinking about with NAND.  are there some extreme advantages to using an SD card instead?  do the NAND drivers have issues? do the SD cards handle bad blocks and wear better?  the PSP projects seem to be pretty much the same thing so it seems like they are about the same amount of effort to get working.
any help would be appreciated.
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • David Engineer
    Posted by David Engineer
    on Jul 23 2012 17:11 PM
    Intellectual320 points
    Cobsonchael,
    I just went through this same process! SD cards have processors in them that handle bad blocks, wear leveling, etc., if you choose NAND flash YOU are the one that needs to take care of these issues. In my opinion, it comes down to either sacrificing writing time or time spent coding your own wear leveling code. I ended up using NAND flash for my project and I think I would have used an SD card if I had to do it over. I am no expert, but this has been my experience so far. A good place to learn about NAND is the Wikipedia article in the link below. Good luck.
    http://en.wikipedia.org/wiki/Flash_memory
    Report Abuse
    • Reply
  • Mukul Bhatnagar
    Posted by Mukul Bhatnagar
    on Jul 23 2012 17:40 PM
    Mastermind24450 points
    You will find the following article by my colleagues useful too
    http://www.eetimes.com/design/memory-design/4216897/Software-and-hardware-challenges-due-to-the-dynamic-raw-NAND-market
    Will try to address your queries further, as needed in coming days.
    Things like level of wear tear expected, product life cycle, product volume and if 4bit ECC on OMAPL138 for NAND can be a limitation from your NAND vendor would be additional things to consider.
    Mukul
    Don't forget to verify answers to your forum questions by using the green "Verify Answer" button.
    Report Abuse
    • Reply
  • cobsonchael
    on Jul 24 2012 09:28 AM
    Expert1970 points
    well from what i am reading the drivers handle the error correction and wear handling.  are you saying that the drivers only do a mediocre job and that the SD card would do a much better/reliable job than the drivers?
    Report Abuse
    • Reply
  • Renjith Thomas
    Posted by Renjith Thomas
    on Aug 12 2012 13:56 PM
    Guru23890 points
    Cobsonchael,
    What David and Mukul's articles mention is correct. The firmware inside the card is having better algorithms over the NAND. But the flip side is that it might be using MLC/TLC NAND instead of SLC NAND. SLC NAND is more reliable and less prone to bit errors when compared to others. But higher density is not really possible.
    Have you explored the options of eMMC(MoviNAND) and SATA for the design? What is the read/write throughput that you are targeting for your device? What is the size of non-volatile storage required for your design?
    -Renjith | www.pathpartnertech.com | Verify the answer if you think your query is resolved
    Report Abuse
    • Reply
  • Chris Barlow
    Posted by Chris Barlow
    on Aug 13 2012 02:30 AM
    Prodigy10 points
    I've just been looking at  ST's NAND08GAH0A & NAND16GAH0D devices which claim to have in-built error handling, wear leveling and garbage collection. These look very tempting.
    I'm taking over the embedded side of a large vehicle data logging project soon. The device sits and listens to 4 CAN buses and needs to store selected data on some sort of FLASH memory. In the past they have used micro SD cards, but these have proven unreliable, presumably due to the extremely heavy read-write traffic that they are subjected to. I'm interested to know what high (circa 2GB) capacity solutions there are that would be robust enough to be used in a vehicle with perhaps 12 hours a day constant reading and writing.
    Report Abuse
    • Reply
  • Renjith Thomas
    on Aug 13 2012 02:48 AM
    Guru23890 points
    You might want to check the ST's NANDs you mentioned above will be supported by BOOT ROM during bootup.
    Reliability wise, you SLC NAND will be better than MLC/TLC NANDs. Managed NANDs like eMMC, SD/MMC etc use MLC mostly.
    1. What is your requirement for Capacity? > 2GB?
    2. What is the throughput required that you need for your application?
    3. If the data is less, and it is mostly read/erase/write continuously, have you taken into account of the wear leveling in NAND?
    4 . How critical is the data? Is couple of bit errors acceptable (ie, video data) ?
    Report Abuse
    • Reply
  • cobsonchael
    on Aug 13 2012 09:20 AM
    Expert1970 points
    well the requirements for our project haven't entirely been defined yet. but i do know some of the answers to your questions
    1. size: we are unsure what size we will need at this point.
    2: throughput: we will be pulling data when read time is not that big of an issue.  it will mostly be used to just store data for later review. there won't be any real time reading requirements.
    3: we will be doing a bit of writing to the flash and we are aware of the wear leveling required in NAND.
    4) data: the data will be pretty important because it will contain things such as custom file headers, compressed audio, etc so we don't want to mess that stuff up. there will also be parts of just text and bitmaps which will be slightly less important to get 100% right.
    Report Abuse
    • Reply
  • Renjith Thomas
    on Aug 13 2012 09:55 AM
    Guru23890 points
    From whatever little I understand from the requirements, I think the SLC NAND with 4-bit ECC support might be appropriate for you.
    Have you check the Flash File System support on SYS-BIOS? Which is the FFS that you are planning to integrate? If this is a head ache, then MMC/SD/eMMC will be the better options.
    I suggest you to go through this post where the customer is facing issues in NAND after long time.
    http://e2e.ti.com/support/dsp/tms320c6000_high_performance_dsps/f/115/p/206710/734726.aspx
    Report Abuse
    • Reply
  • cobsonchael
    on Aug 13 2012 10:12 AM
    Expert1970 points
    i have looked into the FATFS support with SYS bios. the plan is to use it right now even though it appears to be an incomplete driver with poor support from TI.
    our first prototype board has an SD card.
    i'll look through the post you linked.
    Report Abuse
    • Reply
  • Renjith Thomas
    on Aug 13 2012 10:18 AM
    Guru23890 points
    You won't be able to run FAT on NAND flash directly. It will not work. You need to have a middle layer for Flash File System to be integrated(eg. YAFFS, JFFS, UBI) and FAT will only run on top of that.
    Report Abuse
    • Reply
  • cobsonchael
    on Aug 13 2012 10:21 AM
    Expert1970 points
    well the FATFS drivers using the PSP bulk media interface seem to work fine on the LCDK
    also, we do not plan on booting from NAND so that post you linked doesn't help me.
    Report Abuse
    • Reply
  • Renjith Thomas
    on Aug 13 2012 10:28 AM
    Guru23890 points
    For Bulk media drivers FAT will work as all the accesses are in blocks and there is no spare area involvement.
    Report Abuse
    • Reply
  • Norman Wong
    Posted by Norman Wong
    on Aug 13 2012 10:50 AM
    Guru14970 points
    A question for Renjith. With respect to Linux, I've assumed in the past that I needed a jounalling flash file system like JFFS2 to handle wear-leveling and power fail. Most FFS appear to support NAND on NOR. With NAND though, where are the bad blocks handled? In the NAND driver? Wouldn't a block access still need the spare area to keep track of bad blocks? Is the spare area the same area as the ECC or OOB thing? Sorry not quite up on the terminology yet.
    Report Abuse
    • Reply
  • Renjith Thomas
    on Aug 14 2012 02:56 AM
    Guru23890 points
    Norman,
    FFS will do couple of things.
    1. Manage bad blocks. It can be stored in kernel memory in RAM and finally stored in couple of pages dedicated for this purpose. Or it can be stored in the spare area of flash. Different FFS' has different approaches.
    2. Manage writes while taking care of erase block size. eg, Even if I want to write to a single page of 2k, I need to erase a complete block of 128k. So I need to read and backup the entire block before erasing and then modify the required page and write back the whole block if required.
    3. Wear leveling support
    etc..
    If you use FATFS directly, the above listed operations won't be possible.
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
