I would like to use Aptina MT9M034 color sensor for capturing video and still images.
- Resolution: 1280 x 960pixels
- Parallel 12 bit progressive output, bayern pattern
- If buffers are setup correctly
- If VPIF is configured correctly in SetUpVPIFRx
/* * Created on: 29.11.2012 * Author: Andres Vahter */ #include "psc.h" #include "vpif.h" #include "interrupt.h" #include "evmC6748.h" #include "soc_C6748.h" #include "hw_psc_C6748.h" #include "vpiftransfer.h" #define HORIZONTAL_PIXEL_COUNT 1280 #define VERTICAL_PIXEL_COUNT 960 #define VBUF_SIZE (HORIZONTAL_PIXEL_COUNT * VERTICAL_PIXEL_COUNT) #define VBUF_ALIGN (8) unsigned char chromaTop[VBUF_SIZE]__attribute__((aligned(VBUF_ALIGN))); unsigned char chromaBottom[VBUF_SIZE]__attribute__((aligned(VBUF_ALIGN))); unsigned char lumaTop[VBUF_SIZE]__attribute__((aligned(VBUF_ALIGN))); unsigned char lumaBottom[VBUF_SIZE]__attribute__((aligned(VBUF_ALIGN))); void VPIF_init(void) { // Power on VPIF PSCModuleControl(SOC_PSC_1_REGS, HW_PSC_VPIF, PSC_POWERDOMAIN_ALWAYS_ON, PSC_MDCTL_NEXT_ENABLE); // Initializing DSP INTC SetupIntc(); // Setup VPIF pinmux & Initialize VPIF VPIFPinMuxSetup(); SetUpVPIFRx(); VPIFDMARequestSizeConfig(SOC_VPIF_0_REGS, VPIF_REQSIZE_ONE_TWENTY_EIGHT); VPIFEmulationControlSet(SOC_VPIF_0_REGS, VPIF_FREE); // Initialize buffer address for 1st frame VPIFCaptureFBConfig(SOC_VPIF_0_REGS, VPIF_CHANNEL_0, VPIF_TOP_FIELD, VPIF_LUMA, (unsigned int)&lumaTop[0], HORIZONTAL_PIXEL_COUNT); VPIFCaptureFBConfig(SOC_VPIF_0_REGS, VPIF_CHANNEL_0, VPIF_TOP_FIELD, VPIF_CHROMA, (unsigned int)&chromaTop[0], HORIZONTAL_PIXEL_COUNT); VPIFCaptureFBConfig(SOC_VPIF_0_REGS, VPIF_CHANNEL_0, VPIF_BOTTOM_FIELD, VPIF_LUMA, (unsigned int)&lumaBottom[0], HORIZONTAL_PIXEL_COUNT); VPIFCaptureFBConfig(SOC_VPIF_0_REGS, VPIF_CHANNEL_0, VPIF_BOTTOM_FIELD, VPIF_CHROMA, (unsigned int)&chromaBottom[0], HORIZONTAL_PIXEL_COUNT); } void VPIF_enable_capture(void) { // Enable capture VPIFCaptureChanenEnable(SOC_VPIF_0_REGS, VPIF_CHANNEL_0); VPIFInterruptEnable(SOC_VPIF_0_REGS, VPIF_FRAMEINT_CH0); VPIFInterruptEnableSet(SOC_VPIF_0_REGS, VPIF_FRAMEINT_CH0); } // Initialize capture static void SetUpVPIFRx(void) { // Disable interrupts VPIFInterruptDisable(SOC_VPIF_0_REGS, VPIF_FRAMEINT_CH1); VPIFInterruptDisable(SOC_VPIF_0_REGS, VPIF_FRAMEINT_CH0); // Disable capture ports VPIFCaptureChanenDisable(SOC_VPIF_0_REGS, VPIF_CHANNEL_1); VPIFCaptureChanenDisable(SOC_VPIF_0_REGS, VPIF_CHANNEL_0); // Interrupt after capturing the bottom field of every frame VPIFCaptureIntframeConfig(SOC_VPIF_0_REGS, VPIF_CHANNEL_0, VPIF_FRAME_INTERRUPT_BOTTOM); // RAW mode VPIFCaptureCapmodeModeSelect(SOC_VPIF_0_REGS, VPIF_CHANNEL_0, VPIF_CAPTURE_RAW); VPIFCaptureModeConfig(SOC_VPIF_0_REGS, VPIF_RAW, VPIF_CHANNEL_0, 0, (VPIFVbufParam*) 0); // 12 bit data VPIFCaptureRawDatawidthConfig(SOC_VPIF_0_REGS, VPIF_RAW_TWELVE_BPS); // Progressive capture VPIFCaptureIntrprogModeSelect(SOC_VPIF_0_REGS, VPIF_CHANNEL_0, VPIF_CAPTURE_PROGRESSIVE); } // Configures DSP interrupt controller to generate frame interrupt static void SetupIntc(void) { // Initialize the DSP interrupt controller IntDSPINTCInit(); // Register ISR to vector table IntRegister(C674X_MASK_INT5, VPIFIsr); // Map system interrupt to DSP maskable interrupt IntEventMap(C674X_MASK_INT5, SYS_INT_VPIF_INT); // Enable DSP maskable interrupt IntEnable(C674X_MASK_INT5); // Enable DSP interrupts IntGlobalEnable(); } // Interrupt service routine. static void VPIFIsr(void) { unsigned int status; IntEventClear(SYS_INT_VPIF_INT); status = VPIFInterruptStatus(SOC_VPIF_0_REGS, VPIF_ERROR_INT | VPIF_FRAMEINT_CH1 | VPIF_FRAMEINT_CH0); VPIFCaptureFBConfig(SOC_VPIF_0_REGS, VPIF_CHANNEL_0, VPIF_TOP_FIELD, VPIF_LUMA, (unsigned int)&lumaTop[0], HORIZONTAL_PIXEL_COUNT); VPIFCaptureFBConfig(SOC_VPIF_0_REGS, VPIF_CHANNEL_0, VPIF_TOP_FIELD, VPIF_CHROMA, (unsigned int)&chromaTop[0], HORIZONTAL_PIXEL_COUNT); VPIFCaptureFBConfig(SOC_VPIF_0_REGS, VPIF_CHANNEL_0, VPIF_BOTTOM_FIELD, VPIF_LUMA, (unsigned int)&lumaBottom[0], HORIZONTAL_PIXEL_COUNT); VPIFCaptureFBConfig(SOC_VPIF_0_REGS, VPIF_CHANNEL_0, VPIF_BOTTOM_FIELD, VPIF_CHROMA, (unsigned int)&chromaBottom[0], HORIZONTAL_PIXEL_COUNT); // clear interrupt VPIFInterruptStatusClear(SOC_VPIF_0_REGS, VPIF_FRAMEINT_CH0); // if error interrupt occurs, report error if ((status & VPIF_ERROR_INT)) { // what to do? } }
