Vidéo loopback and RTC clock
Other Parts Discussed in Thread: SYSBIOS, OMAPL138
Hello !!
I would display video and in the some time print the current time in the terminal. For this I use videoloopback and rtc clock examples given in the drivers folder with C6748.
At the beginning when I used the two project. When the time is printed the video not work. So i said that i need to make 2 threads 1 for printing time ans 1 for displaying video.
For this i used the facedect project and i did many changes. At the begining the 2 threads work but when the interrupt of rtc clock began the stopped the thread of video display.
I think i need to enable the interrupt for rtc clock in the main but i don"t know how to do this. I'm a beginner in sys bios. Could anyone help me to resolve the problem.
I attached the project.
6675.facedetect_lcdk.c
 * facedetect_lcdk.c
 * This file contains face detection demo code for LCDK.
 * Copyright (C) 2009 Texas Instruments Incorporated - http://www.ti.com/
 *  Redistribution and use in source and binary forms, with or without
 *  modification, are permitted provided that the following conditions
 *  are met:
 *    Redistributions of source code must retain the above copyright
 *    Redistributions in binary form must reproduce the above copyright
 *    documentation and/or other materials provided with the
 *    distribution.
 *    Neither the name of Texas Instruments Incorporated nor the names of
 *  THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
 *  "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
 *  LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
 *  A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
 *  OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
 *  SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
 *  LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
 *  DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
 *  THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
 *  (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
 *  OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
 *  \file   facedetect_lcdk.c
 *  \brief  This file contains the face detection demo code for LCDK.
 *          This application captures the live camera input which is then
 * 			passed to the DSP. The DSP runs the face detection algorithm
 * 			provided by OpenCV and draws a rectangular box around the
 * 			detected face. The output is displayed over LCDC.
/*                          INCLUDE FILES                                     */
#include <xdc/std.h>
#include <xdc/runtime/Error.h>
#include <xdc/runtime/System.h>
#include <ti/sysbios/BIOS.h>
#include <ti/sysbios/knl/Clock.h>
#include <ti/sysbios/knl/Task.h>
#include <ti/sysbios/knl/Semaphore.h>
#include <ti/sysbios/family/c64p/Hwi.h>
#include <stdio.h>
#include "psc.h"
#include "vpif.h"
#include "raster.h"
#include "interrupt.h"
#include "lcdkC6748.h"
#include "soc_C6748.h"
#include "hw_psc_C6748.h"
#include "adv7343.h"
#include "tvp5147.h"
#include "cdce913.h"
#include "codecif.h"
#include "i2cgpio.h"
#include "string.h"
#include "uartStdio.h"
#include "uart.h"
#include "rtc.h"
**                      INTERNAL MACROS
#define MSTPRI1									(0x01C14114)
#define MSTPRI2									(0x01C14118)
#define CAPTURE_IMAGE_WIDTH					 	(720)
#define CAPTURE_IMAGE_HEIGHT				 	(576)
#define DISPLAY_IMAGE_WIDTH						(640)
#define DISPLAY_IMAGE_HEIGHT					(480)
#define CLASSIFIER_CASCADE_SIZE      			(52519)
#define REFERENCE_LOCATION_1         			(0xC30011B0)
#define REFERENCE_LOCATION_2		 			(0xC303464B)
#define CV_DEFAULT_IMAGE_ROW_ALIGN   			(8)
#define I2C_SLAVE_CODEC_ADV7343                 (0x2Au)
#define I2C_SLAVE_CODEC_TVP5147_1_SVIDEO    	(0x5Cu)
#define I2C_SLAVE_CODEC_TVP5147_2_COMPOSITE    	(0x5Du)
#define I2C_SLAVE_CDCE913      					(0x65u)
#define I2C_SLAVE_UI_EXPANDER	      			(0x20u)
#define INT_CHANNEL_I2C                       	(0x2u)
#define OFFSET1									((CAPTURE_IMAGE_HEIGHT - DISPLAY_IMAGE_HEIGHT)/2)
#define OFFSET2									((CAPTURE_IMAGE_WIDTH - DISPLAY_IMAGE_WIDTH)/2)
#define OFFSET 									(CAPTURE_IMAGE_WIDTH * OFFSET1 + OFFSET2)
#define MASK_HOUR            					(0xFF000000u)
#define MASK_MINUTE          					(0x00FF0000u)
#define MASK_SECOND          					(0x0000FF00u)
#define MASK_MERIDIEM        					(0x000000FFu)
#define HOUR_SHIFT           					(24)
#define MINUTE_SHIFT         					(16)
#define SECOND_SHIFT         					(8)
#define MASK_DAY             					(0xFF000000u)
#define MASK_MONTH           					(0x00FF0000u)
#define MASK_YEAR            					(0x0000FF00u)
#define MASK_DOTW            					(0x000000FFu)
#define DAY_SHIFT            					(24)
#define MONTH_SHIFT          					(16)
#define YEAR_SHIFT           					(8)
**                      GLOBAL FUNCTION PROTOTYPES
extern void cbcr422sp_to_rgb565_c(const unsigned char * restrict, unsigned int,
		unsigned int, const short*, const unsigned char *restrict,
		unsigned int, unsigned short *restrict, unsigned int, unsigned);
**                      INTERNAL FUNCTION PROTOTYPES
static void SetUpVPIFRx(void);
static void SetUpLCD(void);
static void CalendarResolve(unsigned int calendarValue);
static unsigned char ASCIIToInt(unsigned char byte);
static unsigned int intToASCII(unsigned char byte);
static void TimeResolve(unsigned int timeValue);
static void Delay(volatile unsigned int count);
static unsigned int UserCalendarInfoGet(void);
static unsigned int UserTimeInfoGet(void);
static void ConfigureIntRTC(void);
static void SetupInt(void);
static void RTCIsr(void);
Void VPIFIsr(UArg arg);
Void LCDIsr(UArg arg);
Void colorconvertTask(UArg arg0, UArg arg1);
Void facedetectTask(UArg arg0, UArg arg1);
Void clockHandler(UArg arg);
**                      INTERNAL VARIABLE DEFINITIONS
unsigned int            i,pingpong=1, buffcount=0, buffcount2, display_buff_1=0;
int 					facedetect_complete=1, buffer_ready=0;
volatile unsigned int   changed=1, updated=3, processed=1;
unsigned char 			*buff_luma[2], *buff_chroma[2];
unsigned char			buff_luma1[CAPTURE_IMAGE_WIDTH * CAPTURE_IMAGE_HEIGHT];
unsigned char			buff_luma2[CAPTURE_IMAGE_WIDTH * CAPTURE_IMAGE_HEIGHT];
unsigned char			buff_chroma1[CAPTURE_IMAGE_WIDTH * CAPTURE_IMAGE_HEIGHT];
unsigned char			buff_chroma2[CAPTURE_IMAGE_WIDTH * CAPTURE_IMAGE_HEIGHT];
unsigned char			proc_buff_luma[DISPLAY_IMAGE_WIDTH * DISPLAY_IMAGE_HEIGHT];
unsigned char           *videoTopY, *videoTopC, *proc_buff_ptr;
unsigned short          *videoTopRgb1, *videoTopRgb2;
unsigned short          Rgb_buffer1[DISPLAY_IMAGE_WIDTH*DISPLAY_IMAGE_HEIGHT + 16];
unsigned short			Rgb_buffer2[DISPLAY_IMAGE_WIDTH*DISPLAY_IMAGE_HEIGHT + 16];
const short             ccCoeff[5] = {0x2000, 0x2BDD, -0x0AC5, -0x1658, 0x3770};
Semaphore_Handle 			sem1;
Semaphore_Handle 			sem2;
**                       FUNCTION DEFINITIONS
Void main()
	Hwi_Params 		params;
	Hwi_Handle 		Hwi1, Hwi2;
	Task_Params 	taskParams;
	Task_Handle 	task1, task2;
	Clock_Params 	clockParams;
	Clock_Handle 	Clk;
	Error_Block 	eb;
    /* Create a Semaphore object to be use as a resource lock */
    sem1 = Semaphore_create(0, NULL, NULL);
    sem2 = Semaphore_create(0, NULL, NULL);
	/* Create the Color Convert Task */
    Error_init(&eb);
	Task_Params_init(&taskParams);
	taskParams.priority = 1;
	taskParams.stackSize = 10000;
	task1 = Task_create(colorconvertTask, &taskParams, &eb);
	if (task1 == NULL)
		System_printf("Task_create() failed for Color Conversion!\n");
		BIOS_exit(0);
	/* Create the FaceDetect Task*/
	task2 = Task_create(facedetectTask, &taskParams, &eb);
	if (task2 == NULL)
		System_printf("Task_create() failed for Face Detection!\n");
		BIOS_exit(0);
	/* Create the VPIF Interrupt*/
	Hwi_Params_init(&params);
	params.eventId = 95;
	params.enableInt = FALSE;
	Hwi1 = Hwi_create(8, &VPIFIsr, &params, &eb);
	if (Hwi1 == NULL)
		System_printf("Hwi_create() failed for VPIF!\n");
		BIOS_exit(0);
	/* Create the LCDC Interrupt*/
	params.eventId = 73;
	Hwi2 = Hwi_create(9, &LCDIsr, &params, &eb);
	if (Hwi2 == NULL)
		System_printf("Hwi_create() failed for LCDC!\n");
		BIOS_exit(0);
	/* Create a clock that would go off every 1 Clock tick*/
	Clock_Params_init(&clockParams);
	clockParams.period = 1;
	clockParams.startFlag = TRUE;
	Clk = Clock_create((Clock_FuncPtr)clockHandler, 4, &clockParams, &eb);
	if (Clk == NULL) {
	System_abort("Clock0 create failed");
	/* Setting the Master priority for LCD DMA controller to highest level */
	*((volatile uint32_t *) MSTPRI2) = *((volatile uint32_t *) MSTPRI2) & 0x0FFFFFFF;
	BIOS_start(); /* enable interrupts and start SYS/BIOS */
** ClockHandler
	/* Call Task_yield every 1 ms */
	Task_yield();
** ColorconvertTask - This would color convert the captured frames and make it available for the LCDC display.
** Also, if the facedetect algorithm has finished working on the frame provided, it would provide a new frame.
Void colorconvertTask(UArg a0, UArg a1)
	/* Allocate pointers to buffers */
	buff_luma[0] = buff_luma1;
	buff_luma[1] = buff_luma2;
	buff_chroma[0] = buff_chroma1;
	buff_chroma[1] = buff_chroma2;
	proc_buff_ptr = proc_buff_luma;
	/* Initializing palette for first buffer */
	*Rgb_buffer1 = 0x4000;
	for (i = 1; i < 16; i++)
		*(Rgb_buffer1 +i) = 0x0000;
	videoTopRgb1 = Rgb_buffer1 + i;
	/* Initializing palette for second buffer */
	*Rgb_buffer2 = 0x4000;
		*(Rgb_buffer2 + i) = 0x0000;
	videoTopRgb2 = Rgb_buffer2 + i;
	/* Power on VPIF */
	PSCModuleControl(SOC_PSC_1_REGS, HW_PSC_VPIF, PSC_POWERDOMAIN_ALWAYS_ON,
			PSC_MDCTL_NEXT_ENABLE);
	/* Initialize I2C and program UI GPIO expander, TVP5147, and ADV7343 via I2C */
	I2CPinMuxSetup(0);
	/*Initialize the TVP5147 to accept composite video */
	I2CCodecIfInit(SOC_I2C_0_REGS, INT_CHANNEL_I2C,
			I2C_SLAVE_CODEC_TVP5147_2_COMPOSITE);
	TVP5147CompositeInit(SOC_I2C_0_REGS);
	/* Setup VPIF pinmux */
	VPIFPinMuxSetup();
	/* Setup LCD */
	SetUpLCD();
	/* Initialize VPIF */
	SetUpVPIFRx();
	VPIFDMARequestSizeConfig(SOC_VPIF_0_REGS, VPIF_REQSIZE_ONE_TWENTY_EIGHT);
	VPIFEmulationControlSet(SOC_VPIF_0_REGS, VPIF_HALT);
	/* Initialize buffer addresses for 1st frame*/
	VPIFCaptureFBConfig(SOC_VPIF_0_REGS, VPIF_CHANNEL_0, VPIF_TOP_FIELD,
			VPIF_LUMA, (unsigned int) buff_luma[0], CAPTURE_IMAGE_WIDTH*2);
			VPIF_CHROMA, (unsigned int) buff_chroma[0], CAPTURE_IMAGE_WIDTH*2);
	VPIFCaptureFBConfig(SOC_VPIF_0_REGS, VPIF_CHANNEL_0, VPIF_BOTTOM_FIELD,
			VPIF_LUMA, (unsigned int) (buff_luma[0] + CAPTURE_IMAGE_WIDTH), CAPTURE_IMAGE_WIDTH*2);
			VPIF_CHROMA, (unsigned int) (buff_chroma[0] + CAPTURE_IMAGE_WIDTH), CAPTURE_IMAGE_WIDTH*2);
	/* Configuring the base ceiling */
	RasterDMAFBConfig(SOC_LCDC_0_REGS, (unsigned int) Rgb_buffer2,
			(unsigned int) (Rgb_buffer2 + DISPLAY_IMAGE_WIDTH * DISPLAY_IMAGE_HEIGHT + 15), 0);
			(unsigned int) (Rgb_buffer2 + DISPLAY_IMAGE_WIDTH * DISPLAY_IMAGE_HEIGHT + 15), 1);
	/* Enable interrupts */
	Hwi_enable();
	Hwi_enableInterrupt(8);
	Hwi_enableInterrupt(9);
	/* Enable capture */
	VPIFCaptureChanenEnable(SOC_VPIF_0_REGS, VPIF_CHANNEL_0);
	/* Enable VPIF interrupt */
	VPIFInterruptEnable(SOC_VPIF_0_REGS, VPIF_FRAMEINT_CH0);
	VPIFInterruptEnableSet(SOC_VPIF_0_REGS, VPIF_FRAMEINT_CH0);
	/* Enable End of frame interrupt */
	RasterEndOfFrameIntEnable(SOC_LCDC_0_REGS);
	/* Enable raster */
	RasterEnable(SOC_LCDC_0_REGS);
	buffcount++;
	buffcount2 = buffcount - 1;
	/* Run forever */
	while (1)
		/* Wait here till a new frame is not captured */
		Semaphore_pend(sem1, BIOS_WAIT_FOREVER);
		/* Process the next buffer only when both the raster buffers
		 * are pointing to the current buffer to avoid jitter effect
		Semaphore_pend(sem2, BIOS_WAIT_FOREVER);
		processed = 0;
		changed = 0;
		updated = 0;
	    /* Convert the buffer from CBCR422 semi-planar to RGB565,
	     *  Set the flag for the buffer to be displayed on the LCD (which would be the processed buffer)
	     *  and notify the LCD of availability of a processed buffer.
	     *  The output buffers are ping-ponged each time.
		if (pingpong)
					(const unsigned char *) (videoTopC + OFFSET),
					DISPLAY_IMAGE_HEIGHT, CAPTURE_IMAGE_WIDTH, ccCoeff,
					(const unsigned char *) (videoTopY + OFFSET),
					CAPTURE_IMAGE_WIDTH, videoTopRgb1, DISPLAY_IMAGE_WIDTH,
					DISPLAY_IMAGE_WIDTH);
			display_buff_1 = 1;
		else
					CAPTURE_IMAGE_WIDTH, videoTopRgb2, DISPLAY_IMAGE_WIDTH,
			display_buff_1 = 0;
		pingpong = !pingpong;
		processed = 1;
		changed = 1;
** FacedetectTask - Runs the Face Detection Algorithm on the frame provided to it
Void facedetectTask(UArg a0, UArg a1)
	unsigned int UserTime = 0, UserCalendar = 0;
	    UARTStdioInit();
	    RTCPinMuxSetup(FALSE);
	    /* Disabling Write Protection for RTC registers.*/
	    RTCWriteProtectDisable(SOC_RTC_0_REGS);
	    /* Performing a Software Reset and Enabling the RTC module. */
	    RTCEnable(SOC_RTC_0_REGS);
	    /* Delay further operations by a minimum of three 32KHz clock times. */
	    Delay(0xFFFF);
	    UARTPuts("StarterWare RTC Demo Application.\r\n", -2);
	    UserTime = UserTimeInfoGet();
	    UserCalendar = UserCalendarInfoGet();
	    RTCCalendarSet(SOC_RTC_0_REGS, UserCalendar);
	    RTCTimeSet(SOC_RTC_0_REGS, UserTime);
	    RTCRun(SOC_RTC_0_REGS);
	    UARTPuts("\r\n\r\n", -2);
	    UARTPuts("Current Time And Date:\r\n", -1);
	    /* Enabling interrupts.*/
	    SetupInt();
	    ConfigureIntRTC();
	    /* Enabling RTC interrupts. Configuring RTC to interrupt every second.*/
	    RTCIntTimerEnable(SOC_RTC_0_REGS, RTC_INT_EVERY_SECOND);
 * Initialize capture
	/* Disable interrupts */
	VPIFInterruptDisable(SOC_VPIF_0_REGS, VPIF_FRAMEINT_CH1);
	VPIFInterruptDisable(SOC_VPIF_0_REGS, VPIF_FRAMEINT_CH0);
	/* Disable capture ports */
	VPIFCaptureChanenDisable(SOC_VPIF_0_REGS, VPIF_CHANNEL_1);
	VPIFCaptureChanenDisable(SOC_VPIF_0_REGS, VPIF_CHANNEL_0);
	/* Interrupt after capturing the bottom field of every frame */
	VPIFCaptureIntframeConfig(SOC_VPIF_0_REGS, VPIF_CHANNEL_0, VPIF_FRAME_INTERRUPT_BOTTOM);
	/* Y/C interleaved capture over 8-bit bus */
	VPIFCaptureYcmuxModeSelect(SOC_VPIF_0_REGS, VPIF_CHANNEL_0, VPIF_YC_MUXED);
	/* Capturing 480I (SD NTSC) */
	//VPIFCaptureModeConfig(SOC_VPIF_0_REGS, VPIF_480I, VPIF_CHANNEL_0, 0, (struct vbufParam *) 0);
	VPIFCaptureModeConfig(SOC_VPIF_0_REGS, VPIF_PAL, VPIF_CHANNEL_0, 0, (struct vbufParam *) 0);
 * Configures raster to display image
    PSCModuleControl(SOC_PSC_1_REGS, HW_PSC_LCDC, PSC_POWERDOMAIN_ALWAYS_ON,
    LCDPinMuxSetup();
    /* disable raster */
    RasterDisable(SOC_LCDC_0_REGS);
    /* configure the pclk */
    RasterClkConfig(SOC_LCDC_0_REGS, 25000000, 150000000);
    /* configuring DMA of LCD controller */
    RasterDMAConfig(SOC_LCDC_0_REGS, RASTER_DOUBLE_FRAME_BUFFER,
                    RASTER_BURST_SIZE_16, RASTER_FIFO_THRESHOLD_8,
                    RASTER_BIG_ENDIAN_DISABLE);
    /* configuring modes(ex:tft or stn,color or monochrome etc) for raster controller */
    RasterModeConfig(SOC_LCDC_0_REGS, RASTER_DISPLAY_MODE_TFT,
                     RASTER_PALETTE_DATA, RASTER_COLOR, RASTER_RIGHT_ALIGNED);
    /* frame buffer data is ordered from least to Most significant bye */
    RasterLSBDataOrderSelect(SOC_LCDC_0_REGS);
    /* disable nibble mode */
    RasterNibbleModeDisable(SOC_LCDC_0_REGS);
     /* configuring the polarity of timing parameters of raster controller */
    RasterTiming2Configure(SOC_LCDC_0_REGS, RASTER_FRAME_CLOCK_LOW |
                                            RASTER_LINE_CLOCK_LOW  |
                                            RASTER_PIXEL_CLOCK_LOW |
                                            RASTER_SYNC_EDGE_RISING|
                                            RASTER_SYNC_CTRL_ACTIVE|
                                            RASTER_AC_BIAS_HIGH     , 0, 255);
    /* configuring horizontal timing parameter */
   RasterHparamConfig(SOC_LCDC_0_REGS, DISPLAY_IMAGE_WIDTH, 64, 48, 48);
    /* configuring vertical timing parameters */
   RasterVparamConfig(SOC_LCDC_0_REGS, DISPLAY_IMAGE_HEIGHT, 2, 11, 31);
   /* configuring fifo delay to */
   RasterFIFODMADelayConfig(SOC_LCDC_0_REGS, 2);
** VPIF Interrupt service routine.
#ifdef _TMS320C6X
	IntEventClear(SYS_INT_VPIF_INT);
#endif
	/* If previously captured frame is not processed, clear this interrupt and return */
	if (!processed)
		VPIFInterruptStatusClear(SOC_VPIF_0_REGS, VPIF_FRAMEINT_CH0);
		return;
	/* buffcount represents buffer to be given to capture driver and
	 * buffcount2 represents the newly captured buffer to be processed
	processed = 0;
	buffcount++;
	// Currently only two buffers are being used for capture
	if (buffcount == 2)
		buffcount = 0;
	/* Initialize buffer addresses for a new frame*/
			VPIF_LUMA, (unsigned int) buff_luma[buffcount], CAPTURE_IMAGE_WIDTH*2);
			VPIF_CHROMA, (unsigned int) buff_chroma[buffcount], CAPTURE_IMAGE_WIDTH*2);
			VPIF_LUMA, (unsigned int) (buff_luma[buffcount] + CAPTURE_IMAGE_WIDTH), CAPTURE_IMAGE_WIDTH*2);
			VPIF_CHROMA, (unsigned int) (buff_chroma[buffcount] + CAPTURE_IMAGE_WIDTH), CAPTURE_IMAGE_WIDTH*2);
	/* Initialize buffer addresses with the captured frame ready to be processed */
	videoTopC = buff_chroma[buffcount2];
	videoTopY = buff_luma[buffcount2];
	/* clear interrupt */
	Semaphore_post(sem1);
** For each end of frame interrupt base and ceiling is reconfigured
	unsigned int status;
#ifdef _TMS320C6X
	IntEventClear(SYS_INT_LCDC_INT);
#endif
	/* Find which interrupt occurred and clear it */
	status = RasterIntStatus(SOC_LCDC_0_REGS,
			RASTER_END_OF_FRAME0_INT_STAT | RASTER_END_OF_FRAME1_INT_STAT);
	status = RasterClearGetIntStatus(SOC_LCDC_0_REGS, status);
	if(!changed)
		return;
	/* Draw a rectangle from the detected sequence onto the current frame*/
	/* Display the appropriate output buffer on the appropriate raster buffer
	 * and if a new processed buffer is available, let the DSP know that
	 * it has configured the raster buffer to point to the new output buffer
	 * by updating the 'updated' flag
	if (display_buff_1)
		if (status & RASTER_END_OF_FRAME0_INT_STAT)
			RasterDMAFBConfig(SOC_LCDC_0_REGS, (unsigned int) Rgb_buffer1,
					(unsigned int) (Rgb_buffer1 + DISPLAY_IMAGE_WIDTH * DISPLAY_IMAGE_HEIGHT + 15), 0);
				updated = updated | 0x1;
		if (status & RASTER_END_OF_FRAME1_INT_STAT)
					(unsigned int) (Rgb_buffer1 + DISPLAY_IMAGE_WIDTH * DISPLAY_IMAGE_HEIGHT + 15), 1);
				updated = updated | 0x2;
	else
	if(updated==3)
		changed=0;
		Semaphore_post(sem2);
static unsigned int UserTimeInfoGet()
    unsigned char hour[2] = {0}, minute[2] = {0}, second[2] = {0};
    unsigned int hourTime = 0, minTime = 0, secTime = 0;
    unsigned int time = 0;
    int i = 0;
    UARTPuts("\n\nEnter the time in 24 hour format.\r\n", -1);
    UARTPuts("Example (hh:mm:ss) 20:15:09\r\n", -1);
    UARTPuts("\r\nEnter Hours: \r\n", -2);
    do
        hour[i] = UARTGetc();
        UARTPutc(hour[i]);
        i++;
    }while((i < 2) && (hour[i-1] != '\r'));
    UARTPuts("\r\nEnter Minutes:\r\n", -2);
    i = 0;
    do
        minute[i] = UARTGetc();
        UARTPutc(minute[i]);
        i++;
    }while((i < 2) && (minute[i-1] != '\r'));
    UARTPuts("\r\nEnter Seconds:\r\n", -1);
    i = 0;
    do
        second[i] = UARTGetc();
        UARTPutc(second[i]);
        i++;
    }while((i < 2) && (second[i-1] != '\r'));
    if(hour[0] != '\r')
        hourTime = (ASCIIToInt(hour[0]) << 0x04);
        if(hour[1] != '\r')
            hourTime |= ASCIIToInt(hour[1]);
        else
            hourTime = hourTime >> 0x04;
    if(minute[0] != '\r')
        minTime = (ASCIIToInt(minute[0]) << 0x04);
        if(minute[1] != '\r')
            minTime |= ASCIIToInt(minute[1]);
        else
            minTime = minTime >> 0x04;
    if(second[0] != '\r')
        secTime = (ASCIIToInt(second[0]) << 0x04);
        if(second[1] != '\r')
            secTime |= ASCIIToInt(second[1]);
        else
            secTime = secTime >> 0x04;
    time = (hourTime << HOUR_SHIFT);
    time |= (minTime << MINUTE_SHIFT);
    time |= (secTime << SECOND_SHIFT);
    return time;
** This function receives calendar related information from the user.
static unsigned int UserCalendarInfoGet()
    unsigned int calendar = 0;
    unsigned char dayOfMonth[2] = {0}, monthArr[2] = {0}, yearArr[2] = {0};
    unsigned char dotwArr[2] = {0};
    unsigned int dom = 0, month = 0, year = 0, dotw = 0;
    int j = 0;
    UARTPuts("\r\n\r\nEnter the calendar information.\r\n", -2);
    UARTPuts("Example (DD:MM:YY) 31:03:73\r\n", -2);
    UARTPuts("\r\nEnter the day of the month: \r\n", -2);
    do
        dayOfMonth[j] = UARTGetc();
        UARTPutc(dayOfMonth[j]);
        j++;
    }while((j < 2) && (dayOfMonth[j-1] != '\r'));
    j = 0;
    UARTPuts("\r\nEnter the month (Jan=01, Dec=12):\r\n", -2);
    do
        monthArr[j] = UARTGetc();
        UARTPutc(monthArr[j]);
        j++;
    }while((j < 2) && (monthArr[j-1] != '\r'));
    j = 0;
    UARTPuts("\r\nEnter the year (Ex: 2010=10, 1987=87:):\r\n", -1);
    do
        yearArr[j] = UARTGetc();
        UARTPutc(yearArr[j]);
        j++;
    }while((j < 2) && (yearArr[j-1] != '\r'));
    j = 0;
    UARTPuts("\r\nEnter the Day of the Week (Ex:Sun=00, Sat=06):\r\n", -3);
    do
        dotwArr[j] = UARTGetc();
        UARTPutc(dotwArr[j]);
        j++;
    }while((j < 2) && (dotwArr[j-1] != '\r'));
    if(dayOfMonth[0] != '\r')
        dom = (ASCIIToInt(dayOfMonth[0]) << 0x04);
        if(dayOfMonth[1] != '\r')
            dom |= ASCIIToInt(dayOfMonth[1]);
        else
            dom = dom  >> 0x04;
    if(monthArr[0] != '\r')
        month = (ASCIIToInt(monthArr[0]) << 0x04);
        if(monthArr[1] != '\r')
            month |= ASCIIToInt(monthArr[1]);
        else
            month = month >> 0x04;
    if(yearArr[0] != '\r')
        year = (ASCIIToInt(yearArr[0]) << 0x04);
        if(yearArr[1] != '\r')
            year |= ASCIIToInt(yearArr[1]);
        else
            year = year >> 0x04;
    if(dotwArr[0] != '\r')
        dotw = (ASCIIToInt(dotwArr[0]) << 0x04);
        if(dotwArr[1] != '\r')
            dotw |= ASCIIToInt(dotwArr[1]);
        else
            dotw = dotw >> 0x04;
    calendar =  dom << DAY_SHIFT;
    calendar |= month << MONTH_SHIFT;
    calendar |= year << YEAR_SHIFT;
    calendar |= dotw;
    return calendar;
** This function prints the current time read from the RTC registers.
    unsigned char timeArray[3] = {0};
    unsigned char bytePrint[2] = {0};
    unsigned int count = 0, i = 0;
    unsigned int asciiTime = 0;
    timeArray[0] = (unsigned char)((timeValue & MASK_HOUR) >> HOUR_SHIFT);
    timeArray[1] = (unsigned char)((timeValue & MASK_MINUTE) >> MINUTE_SHIFT);
    timeArray[2] = (unsigned char)((timeValue & MASK_SECOND) >> SECOND_SHIFT);
    while(count < 3)
        i = 0;
        asciiTime = intToASCII(timeArray[count]);
        bytePrint[0] = (unsigned char)((asciiTime & 0x0000FF00) >> 0x08);
        bytePrint[1] = (unsigned char)(asciiTime & 0x000000FF);
        while(i < 2)
            UARTPutc(bytePrint[i]);
            i++;
        count++;
        if(count != 3)
            UARTPutc(':');
        else
            UARTPutc(' ');
** This function prints the calendar information read from the RTC registers.
    unsigned char calendarArray[3] = {0};
    unsigned int asciiCalendar = 0;
    unsigned int count = 0, j = 0;
    unsigned int dotwValue = 0;
    char dotwString[4] = {0};
    calendarArray[0] = (unsigned char)((calendarValue & MASK_DAY) >> DAY_SHIFT);
    calendarArray[1] = (unsigned char)((calendarValue & MASK_MONTH) >> MONTH_SHIFT);
    calendarArray[2] = (unsigned char)((calendarValue & MASK_YEAR) >> YEAR_SHIFT);
    dotwValue = (calendarValue & MASK_DOTW);
    switch(dotwValue)
        case 0x00:
             dotwString[0] = 'S';
             dotwString[1] = 'u';
             dotwString[2] = 'n';
             dotwString[3] = '\0';
        break;
        case 0x01:
             dotwString[0] = 'M';
             dotwString[1] = 'o';
        break;
        case 0x02:
             dotwString[0] = 'T';
             dotwString[2] = 'e';
        break;
        case 0x03:
             dotwString[0] = 'W';
             dotwString[1] = 'e';
             dotwString[2] = 'd';
        break;
        case 0x04:
             dotwString[1] = 'h';
             dotwString[2] = 'u';
        break;
        case 0x05:
             dotwString[0] = 'F';
             dotwString[1] = 'r';
             dotwString[2] = 'i';
        break;
        case 0x06:
             dotwString[1] = 'a';
             dotwString[2] = 't';
        default:
        break;
    while(count < 3)
        j = 0;
        asciiCalendar = intToASCII(calendarArray[count]);
        bytePrint[0] = (char)((asciiCalendar & 0x0000FF00) >> 0x08);
        bytePrint[1] = (char)(asciiCalendar & 0x000000FF);
        while(j < 2)
            UARTPutc(bytePrint[j]);
            j++;
        count++;
        if(count != 3)
            UARTPutc('-');
        else
            UARTPutc(' ');
    UARTPuts(dotwString, -2);
** This function converts a 8 bit number to its ASCII equivalent value.
** The 8 bit number is passed as a parameter to this function.
    unsigned int retVal = 0;
    unsigned char lsn = 0, msn = 0;
    lsn = (byte & 0x0F);
    msn = (byte & 0xF0) >> 0x04;
    retVal = (lsn + 0x30);
    retVal |= ((msn + 0x30) << 0x08);
    return retVal;
** This function converts the ASCII value of a hexadecimal number to its
** equivalent hexadecimal value.
    unsigned char retVal = 0;
    /* For numbers from 0x0 to 0x9.*/
    if((byte >= 0x30) && (byte <= 0x39))
        retVal = byte - 0x30;
    /* For alphabets from A to Z.*/
    else if((byte >= 0x41) && (byte <= 0x46))
        retVal = byte - 0x37;
    return retVal;
** This function invokes necessary functions to configure the ARM
** processor and ARM Interrupt Controller(AINTC) to receive and
** handle interrupts.
#ifdef _TMS320C6X
	// Initialize the DSP interrupt controller
	IntDSPINTCInit();
	// Enable DSP interrupts globally
	IntGlobalEnable();
#else
    /* Initialize the ARM Interrupt Controller.*/
    IntAINTCInit();
     /* Enable IRQ in CPSR.*/
    IntMasterIRQEnable();
    /* Enable the interrupts in GER of AINTC.*/
    IntGlobalEnable();
    /* Enable the interrupts in HIER of AINTC.*/
    IntIRQEnable();
#endif
** This function configures the AINTC to receive the RTC interrupt.
#ifdef _TMS320C6X
	// Register the ISR in the vector table
	IntRegister(C674X_MASK_INT4, RTCIsr);
	// Map the system interrupt to the DSP maskable interrupt
	IntEventMap(C674X_MASK_INT4, SYS_INT_RTC_IRQS);
	// Enable the DSP maskable interrupt
	IntEnable(C674X_MASK_INT4);
#else
    ** Register the ISR in the Interrupt Vector Table.
    IntRegister(SYS_INT_RTC, RTCIsr);
    /* Map the RTC system interrupt to channel 2 of AINTC. */
    IntChannelSet(SYS_INT_RTC, 2);
    /* Enable the System Interrupts for AINTC.*/
    IntSystemEnable(SYS_INT_RTC);
#endif
** This is the Interrupt Service Routine(ISR) for RTC.
    unsigned int timeValue = 0, calendarValue = 0;
#ifdef _TMS320C6X
    IntEventClear(SYS_INT_RTC_IRQS);
#else
    IntSystemStatusClear(SYS_INT_RTC);
#endif
    /* Read the current time from RTC time registers. */
    timeValue = RTCTimeGet(SOC_RTC_0_REGS);
    /* Decode the time in 'timeValue' and display it on console.*/
    TimeResolve(timeValue);
    /* Read the current date from the RTC calendar registers. */
    calendarValue = RTCCalendarGet(SOC_RTC_0_REGS);
    UARTPuts("   ", -2);
    /* Decode  the date in 'calendarValue' and display it on console.*/
    CalendarResolve(calendarValue);
    UARTPuts("\r", -2);
** Delay routine.
    while(count--);
/****************************** End of file **********************************/
/***************************** End Of File ************************************/
Thank you for your help
  • Hi Mustapha,
    I presume that you want to print the date & time on video streaming.
    I think we have addressed the same question before.
    I would like to suggest try to run i2c sysbios code (try to port from starterware) on board first then start to integrate the both codes (RTC & video)
    Please elaborate your requirement.
  • Hello !!
    No I would not print time on video. I would just print the time in the terminal in serial port and dsiplay the video in vga port in the some time. Yes i need to do it in sys bios.
    I don't know sys bios i just used with facedetect with changes. could you givea look to my code please.
    Thank you
    I think, The interrupt generation is different in starterware and SYSBIOS, so you have to create new HWI for RTC ISr routine,
    RTC DSP interrupt event is 63,
    Please refer DSP interrupt map in OMAPL138 TRM (pg no : 98)
    I don't know about much on SYSBIOS.
    Some thing like that.
    	/* Create the RTC Interrupt*/
    	params.eventId = 63;
    	Hwi3 = Hwi_create(10, &RTCIsr, &params, &eb);
    	if (Hwi3 == NULL)
    		System_printf("Hwi_create() failed for RTC!\n");
    		BIOS_exit(0);
  • Think you i think we need to do this.
    Think you !!
  • Hello !!
    The two prgrams work separatly. Now i would mix them. I tried to test to enable interrupt as suggested but the isr routine for RTC not work. I enabled interupt for RTC ISR
    Hwi_enable();
    Hwi_enableInterrupt(10);
    I get this error :
    [C674X_0] ti.sysbios.gates.GateMutex: line 97: assertion failure: A_badContext: bad calling context. See GateMutex API doc for details.
    xdc.runtime.Error.raise: terminating execution
    when I keep the isr routine and i enabled interrupt with the following instruction given in RTC example in startweare the time is printed in the signal port but without no video :
    /* Enabling interrupts.*/        SetupInt();        ConfigureIntRTC();
    I attached the project           2112.test multi.zip
    Thank you very much
  • I resolved the problem
    Think you !!
  • Hi Mustapha,
    Sounds good.
    Thanks for your update.
    Could you please provide us the procedure that how did you fix the error so that others also get benefited.
    Please close this post as well below post.
    http://e2e.ti.com/support/dsp/tms320c6000_high_performance_dsps/f/115/t/356438.aspx
  • We need juste to put in the main this declaration :
    3
    4
    5
    6
    7
    8
    9
    10
    if (Hwi3 == NULL)
        BIOS_exit(0);
    in the thread we put :
    Hwi_enable();
    and we delete the instruction to enable interruption in statrtweare and we change the declaration for void RTCIsr to Void RTCIsr (UArg arg) and it works!
    Think you !!
  • Hi Mustapha,
    Thanks for your steps and update.
