To whom may it concern,
I have question of TMDXLCDK6748 <TMS320C6748 DSP Development Kit (LCDK)>.
It has 'Composite Video IN Port' and 'VGA Video Out Port'.
How can I change it VGA Video Output to Composite Video Output?
I know THS8315 (Triple 10-Bit 240MSPS Video DAC with Tri-Level Sync & Video (ITU-R.BT601)-Compliant Full Scale Range) generate a Standard Video Output.
TMDXLCDK6748 VGA Output is 640x480 60Hz non-interlaced(alternatively referred to as noninterlaced scanning).
So I found TVP6000 solution in THS8200 web-page.
Its ITU-R.BT656 output port could be used to connect to an NTSC/PAL video encoder, such as the Texas Instruments TVP6000, for regular composite/S-video output.
but THS6000 is obsolete from TI's....
How can I convert THS8135 Standard VGA Output to NTSC/PAL Composite signal?
Can someone please answer my questions?
Thank you.
BR.
