My c6748 based electronics will be used in an environment where power from outside will switch off without warning. Internally I control incoming voltage and will get an interrupt to DSP. I've equipped the board with a large set of capacitors, but I need to save most of the stored energy for SSD- chip to do a controlled flush and shutdown to save file system.
So when power fail interrupt signal activates interrupt server routine, I need to senf "flush" through SATA to SSD and then minimize DSP's power consumption, could you please assist me what would be most effective way to do it?
risto
