How to use both line in and Mic in to read the 2 different audio samples at the same time.
Navaneeth
Navaneeth
Hi Navaneeth,
Welcome to E2E Forum.
I think you have to configure TLV320AIC23B codec, But you can't use both LINE IN and MIC IN at the same time.
Kindly go through its datasheet below.
www.ti.com/.../tlv320aic23b.pdf
You need to configure the TLV320AIC23B codec control registers in the code to enable MIC IN and LINE IN support.
In the above doc., please check the register details (page no. 21)
Power Down Control (Address: 0000110), in which kindly check D0(LINE) and D1(MIC). By default both D0 & D1 are turned off.
You can turn them on by writing 0 .
Analog Audio Path Control (Address: 0000100) , in which kindly check D2(INSEL), which by default is selected for LINE IN , you can change it for MIC IN by writing 1 to it.
Hello Navaneeth,
You can develop your own daughter card with another codec for MIC IN. The external codec can be interfaced through J3 connector in C6713 DSK kit.
Senthil
