My partner and I are using the OMAP-L137/TMS320C6747 EVM board. Currently, we are trying to setup a simple ADC to DAC application in Simulink as a test project with the board. However, after we build the project in the Simulink window, we receive an error output in CCS of:
"c6747evm_aic31.c", line 138: error: identifier "Mcasp_BufferFormat_1SER_1SLOT" is undefined
Could someone clarify the source of this error and any possible solution?
CSUB DSP
The line in question is highlighted below.
A copy/paste of the c6747evm_aic31.c file is as follows:
* $Revision: 1.1.6.5 $
* $Date: 2010/06/10 19:36:40 $
* Copyright 2009-2010 The MathWorks, Inc.
#include <std.h>
#include <mem.h>
#include <assert.h>
#include <gio.h>
#include <stdio.h>
#include "soc_C6747.h"
#include "cslr.h"
#include "cslr_syscfg_C6747.h"
#include "ti/pspiom/psc/Psc.h"
#include "ti/pspiom/mcasp/Mcasp.h"
#include "ti/pspiom/platforms/codec/Aic31.h"
#include "ti/pspiom/platforms/evm6747/audio/Audio.h"
#include "ti/sdo/edma3/drv/edma3_drv.h"
#include "c6747evm_aic31.h"
#include "MW_c6xxx_csl.h"
// Imported data
extern Int edma3init(void);
extern EDMA3_DRV_Handle hEdma;
extern int32_T SDRAM;
#define NUM_CHANNELS (2u)
#define NUM_AUDIO_BUFFERS (3u)
#define MW_BUFFALIGN (128u)
#define KICK0_UNLOCK_CODE (0x83E70B13u)
#define KICK1_UNLOCK_CODE (0x95A4F1E0u)
#define PSC_MCASP1_LPSC (8)
#if (NUM_AUDIO_BUFFERS != 3)
#error "Number of audio buffers must be 3."
#endif
enum{
AIC31_8KHZ = 0,
AIC31_11KHz,
AIC31_16KHZ,
AIC31_22KHZ,
AIC31_24KHZ,
AIC31_32KHZ,
AIC31_44KHZ,
AIC31_48KHZ,
AIC31_96KHZ,
AIC31_NUM_FREQ
} AIC31_FREQ;
static Uint32 freq[AIC31_NUM_FREQ] = {
8000,
11025,
16000,
22050,
24000,
32000,
44100,
48000,
96000
// AIC31 configuration structures
// Note that the name of the configuration
// structure must match TCI file entry.
Mcasp_HwSetupData mcaspRcvSetup = {
/* .rmask = */ 0xFFFFFFFF, /* All the data bits are to be used */
/* .rfmt = */ 0x000080F0, /*
* 0 bit delay from frame sync
* MSB first
* No extra bit padding
* Padding bit (ignore)
* slot Size is 32
* Reads from DMA port
* NO rotation
/* .afsrctl = */ 0x00000000, /* burst mode,
* Frame sync is one bit
* Rising edge is start of frame
* externally generated frame sync
/* .rtdm = */ 0x00000001, /* slot 1 is active (DSP) */
/* .rintctl = */ 0x00000003, /* sync error and overrun error */
/* .rstat = */ 0x000001FF, /* reset any existing status bits */
/* .revtctl = */ 0x00000000, /* DMA request is enabled or disabled */
/* .aclkrctl = */ 0x00000000,
/* .ahclkrctl = */ 0x00000000,
/* .rclkchk = */ 0x00000000
Mcasp_HwSetupData mcaspXmtSetup = {
/* .xmask = */ 0xFFFFFFFF, /* All the data bits are to be used */
/* .xfmt = */ 0x000080F0, /*
* 0 bit delay from framsync
* MSB first
* slot Size is 32
* NO rotation
/* .afsxctl = */ 0x00000000, /* burst mode,
/* .xtdm = */ 0x00000001, /* slot 1 is active (DSP) */
/* .xintctl = */ 0x00000007, /* sync error,overrun error,clK error */
/* .xstat = */ 0x000001FF, /* reset any existing status bits */
/* .xevtctl = */ 0x00000000, /* DMA request is enabled or disabled */
/* .aclkxctl = */ 0x00000000,
/* .ahclkxctl = */ 0x00000000,
/* .xclkchk = */ 0x00000000
// McASP channel parameters
Mcasp_ChanParams mcasp_chanparam[Audio_NUM_CHANS]=
0x0001,
{Mcasp_SerializerNum_0, },
&mcaspRcvSetup,
TRUE,
Mcasp_OpMode_TDM,
Mcasp_WordLength_32,
NULL,
0,
NULL,
NULL,
1,
Mcasp_BufferFormat_1SER_1SLOT,
TRUE,
TRUE
0x0001,
{Mcasp_SerializerNum_5,},
&mcaspXmtSetup,
TRUE,
Mcasp_OpMode_TDM,
NULL,
0,
NULL,
NULL,
1,
TRUE,
TRUE
Audio_ChannelConfig audioChanParamsIN =
(Ptr)&mcasp_chanparam[0],
44100,
0,
0x00,
0x00
Audio_ChannelConfig audioChanParamsOUT =
(Ptr)&mcasp_chanparam[1],
44100,
70,
0x00,
0x00
Mcasp_Params audioMcaspParams;
Aic31_Params audioAic31Params;
Audio_Params audioParams;
static SEM_Obj semRx, semTx;
static GIO_Handle inChan, outChan;
static GIO_AppCallback appReadCb, appWriteCb;
static volatile Ptr rxBuff[NUM_AUDIO_BUFFERS];
static volatile Ptr txBuff[NUM_AUDIO_BUFFERS];
static volatile int32_T postRxReq = 0;
static volatile int32_T postTxReq = 0;
// callback for buffer capture completion
static Void rxCallback(Ptr arg, Int status, Ptr bufp, Uns size)
static int32_T rxIndx = 0;
if (postRxReq)
Ptr tmp;
postRxReq = 0;
tmp = rxBuff[rxIndx];
rxBuff[rxIndx] = rxBuff[NUM_AUDIO_BUFFERS-1];
rxBuff[NUM_AUDIO_BUFFERS-1] = tmp;
SEM_post(&semRx);
GIO_submit(inChan, IOM_READ, rxBuff[rxIndx], &size, &appReadCb);
rxIndx ^= 1;
// Callback for buffer transfer completion
static Void txCallback(Ptr arg, Int status, Ptr bufp, Uns size)
static int32_T txIndx = 0;
if (postTxReq)
Ptr tmp;
postTxReq = 0;
tmp = txBuff[txIndx];
txBuff[txIndx] = txBuff[NUM_AUDIO_BUFFERS-1];
txBuff[NUM_AUDIO_BUFFERS-1] = tmp;
SEM_post(&semTx);
GIO_submit(outChan, IOM_WRITE, txBuff[txIndx], &size, &appWriteCb);
txIndx ^= 1;
// AIC31 initialization function
void MW_aic31Init(void)
Aic31_init();
audioAic31Params = Aic31_PARAMS;
audioAic31Params.acCtrlBusName = "/i2c0";
// Mcasp init function called when creating the driver.
void MW_mcAspInit()
CSL_SyscfgRegsOvly sysCfgRegs = (CSL_SyscfgRegsOvly) CSL_SYSCFG_0_REGS;
// Unlock SYSCFG module
sysCfgRegs->KICK0R = KICK0_UNLOCK_CODE;
sysCfgRegs->KICK1R = KICK1_UNLOCK_CODE;
// Enable McASP1
CSL_FINST(sysCfgRegs->PINMUX8, SYSCFG_PINMUX8_PINMUX8_27_24, AXR1_11);
CSL_FINST(sysCfgRegs->PINMUX8, SYSCFG_PINMUX8_PINMUX8_23_20, AXR1_10);
CSL_FINST(sysCfgRegs->PINMUX11, SYSCFG_PINMUX11_PINMUX11_31_28, AFSX1);
CSL_FINST(sysCfgRegs->PINMUX11, SYSCFG_PINMUX11_PINMUX11_27_24, ACLKX1);
CSL_FINST(sysCfgRegs->PINMUX11, SYSCFG_PINMUX11_PINMUX11_23_20, AHCLKX1);
CSL_FINST(sysCfgRegs->PINMUX12, SYSCFG_PINMUX12_PINMUX12_31_28, AXR1_3);
CSL_FINST(sysCfgRegs->PINMUX12, SYSCFG_PINMUX12_PINMUX12_27_24, AXR1_2);
CSL_FINST(sysCfgRegs->PINMUX12, SYSCFG_PINMUX12_PINMUX12_23_20, AXR1_1);
CSL_FINST(sysCfgRegs->PINMUX12, SYSCFG_PINMUX12_PINMUX12_19_16, AXR1_0);
CSL_FINST(sysCfgRegs->PINMUX12, SYSCFG_PINMUX12_PINMUX12_15_12, AMUTE1);
CSL_FINST(sysCfgRegs->PINMUX12, SYSCFG_PINMUX12_PINMUX12_11_8, AFSR1);
CSL_FINST(sysCfgRegs->PINMUX12, SYSCFG_PINMUX12_PINMUX12_7_4, ACLKR1);
CSL_FINST(sysCfgRegs->PINMUX12, SYSCFG_PINMUX12_PINMUX12_3_0, AHCLKR1);
CSL_FINST(sysCfgRegs->PINMUX13, SYSCFG_PINMUX13_PINMUX13_23_20, AXR1_9);
CSL_FINST(sysCfgRegs->PINMUX13, SYSCFG_PINMUX13_PINMUX13_19_16, AXR1_8);
CSL_FINST(sysCfgRegs->PINMUX13, SYSCFG_PINMUX13_PINMUX13_15_12, AXR1_7);
CSL_FINST(sysCfgRegs->PINMUX13, SYSCFG_PINMUX13_PINMUX13_11_8, AXR1_6);
CSL_FINST(sysCfgRegs->PINMUX13, SYSCFG_PINMUX13_PINMUX13_7_4, AXR1_5);
CSL_FINST(sysCfgRegs->PINMUX13, SYSCFG_PINMUX13_PINMUX13_3_0, AXR1_4);
// Lock SYSCFG module
sysCfgRegs->KICK0R = 0x0;
// Power on McASP
Psc_ModuleClkCtrl(Psc_DevId_1, PSC_MCASP1_LPSC, TRUE);
// Init McASP driver
Mcasp_init();
audioMcaspParams = Mcasp_PARAMS;
audioMcaspParams.hwiNumber = 8;
// Audio init function called when creating the driver.
void MW_audioInit(void)
Audio_init();
audioParams = Audio_PARAMS;
audioParams.adDevType = Audio_DeviceType_McASP;
audioParams.adDevName = "/mcasp1";
audioParams.acNumCodecs = 1;
audioParams.acDevName[0] = "/aic310";
// Common initialization function for ADC and DAC modules
static void adcDacCommonInit(Uint32 samplingRate)
static boolean_T firstTime = true;
if (firstTime) {
if (hEdma == NULL) {
// Init EDMA engine
edma3init();
mcasp_chanparam[0].edmaHandle = hEdma;
mcasp_chanparam[1].edmaHandle = hEdma;
// Set sampling rate
assert((samplingRate > 0) && (samplingRate <= AIC31_NUM_FREQ));
audioChanParamsIN.acChannelConfig[0].samplingRate = freq[samplingRate-1];
audioChanParamsOUT.acChannelConfig[0].samplingRate = freq[samplingRate-1];
// Create channel handles
inChan = GIO_create("/audio0", IOM_INPUT, NULL, (Ptr)(&audioChanParamsIN), NULL);
outChan = GIO_create("/audio0", IOM_OUTPUT, NULL, (Ptr)(&audioChanParamsOUT), NULL);
if ((inChan == NULL) || (outChan == NULL)) {
fprintf(stderr, "Channel creation FAILED.");
SYS_exit(-1);
firstTime = false;
// Allocate ADC/DAC buffers for GIO exchanges
static void allocBuffers
GIO_Handle *hChannel,
Int cmd,
Uns numSamples,
volatile Ptr *buffArray,
GIO_AppCallback *appCb
int i;
Uns buffSize = NUM_CHANNELS * numSamples * sizeof(Int16);
// Allocate buffers for the GIO buffer exchanges
for(i = 0; i < NUM_AUDIO_BUFFERS; i++)
buffArray[i] = (Ptr) MEM_calloc(SDRAM,
(buffSize + MW_BUFFALIGN - 1) & ~(MW_BUFFALIGN - 1),
MW_BUFFALIGN);
if(buffArray[i] == NULL) {
fprintf(stderr, "Memory allocation for audio ADC/DAC failed.");
SYS_exit(-1);
// Pass allocated buffer to GIO manager
if (i != (NUM_AUDIO_BUFFERS-1)) {
if (GIO_submit(*hChannel, cmd, buffArray[i], &buffSize, appCb) < 0) {
fprintf(stderr, "Error issuing buffer to the audio stream.");
SYS_exit(-1);
// ADC initialization
void c6747evmAic31AdcInit(Uint32 samplingRate, Uint32 numSamples)
// Initialize ADC related parameters
appReadCb.fxn = rxCallback;
SEM_new(&semRx, 0);
// Call common initialization function
adcDacCommonInit(samplingRate);
allocBuffers(&inChan, IOM_READ, numSamples, rxBuff, &appReadCb);
// DAC initialization
void c6747evmAic31DacInit(Uint32 samplingRate, Int32 numSamples)
// Initialize DAC related parameters
appWriteCb.fxn = txCallback;
SEM_new(&semTx, 1);
allocBuffers(&outChan, IOM_WRITE, numSamples, txBuff, &appWriteCb);
// Receive audio samples from capture buffer and pass them
// to application. Split interleaved audio samples to left & right
// samples.
void c6747evmAic31AdcRecv(Int16 *y1, Int32 numSamples)
int i;
Int16 *p;
// Wait for buffer completion event from McASP driver
postRxReq = 1;
SEM_pend(&semRx, SYS_FOREVER);
// De-interleave audio samples
p = (Int16 *) rxBuff[NUM_AUDIO_BUFFERS-1];
for (i = 0; i < numSamples; i++) {
*y1 = *p++;
*(y1 + numSamples) = *p++;
y1++;
// Receive audio samples from application and pass them
// to the audio transmit buffer. Interleave audio samples
// in the process.
void c6747evmAic31DacXmt(Int16 *u1, Int32 numSamples)
int i;
Int16 *p;
SEM_pend(&semTx, SYS_FOREVER);
// Interleave audio samples
p = (Int16 *) txBuff[NUM_AUDIO_BUFFERS-1];;
*p++ = *u1;
*p++ = *(u1 + numSamples);
u1++;
postTxReq = 1;
