C6748 Secure Boot Device
Other Parts Discussed in Thread: OMAPL138
Is there a software method to tell if a particular C6748 is a secure boot version?  I would like to be able to tell at run time if I am running on a secure boot C6748 vs. a regular C6748.
I have checked the DEVIDR0 register, but it is the same on both devices.  There appears to be a difference between the two device's DIEIDR1 registers, but I have seen elsewhere that that register is not documented and is for internal use only.
What about the undocumented DSP Security ID (0x01811000 - 0x01811FFF) or DSP Revision ID (0x01812000 - 0x01812FFF) areas?  The regular C6748 seem to alias the DSP Security ID area while the secure boot version has some, what appear to be, fixed values.  Is there any documentation available for those areas?
Jerry
