Part Number: TMDXLCDK6748
I want to make my c6748 lcdk output the date and time. Can i do such a thing? Is there and API's that i can find?
Rabah
Rabah
Hello Rabah,
Please refer to the attached RTC example. The application receives time and calendar information from the user, sets those values in the RTC registers, periodically reads them and displays their current values in the serial communication console of the external device.
/** * \file rtcClock.c * * \brief This is a RTC application file. This application receives the * time and calendar information from the user, sets those values * in the RTC registers, periodically reads them and displays their * current values in the serial communication console of the external * device. */ /* * Copyright (C) 2012 Texas Instruments Incorporated - http://www.ti.com/ * * Redistribution and use in source and binary forms, with or without * modification, are permitted provided that the following conditions * are met: * * Redistributions of source code must retain the above copyright * notice, this list of conditions and the following disclaimer. * * Redistributions in binary form must reproduce the above copyright * notice, this list of conditions and the following disclaimer in the * documentation and/or other materials provided with the * distribution. * * Neither the name of Texas Instruments Incorporated nor the names of * its contributors may be used to endorse or promote products derived * from this software without specific prior written permission. * * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS * "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT * LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR * A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT * OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, * SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT * LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, * DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY * THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT * (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE * OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. */ #include "soc_OMAPL138.h" #include "interrupt.h" #include "lcdkOMAPL138.h" #include "uartStdio.h" #include "hw_types.h" #include "uart.h" #include "rtc.h" /***************************************************************************** ** LOCAL MACRO DEFINITIONS *****************************************************************************/ #define MASK_HOUR (0xFF000000u) #define MASK_MINUTE (0x00FF0000u) #define MASK_SECOND (0x0000FF00u) #define MASK_MERIDIEM (0x000000FFu) #define HOUR_SHIFT (24) #define MINUTE_SHIFT (16) #define SECOND_SHIFT (8) #define MASK_DAY (0xFF000000u) #define MASK_MONTH (0x00FF0000u) #define MASK_YEAR (0x0000FF00u) #define MASK_DOTW (0x000000FFu) #define DAY_SHIFT (24) #define MONTH_SHIFT (16) #define YEAR_SHIFT (8) /****************************************************************************** ** LOCAL FUNCTION PROTOTYPES ******************************************************************************/ static void CalendarResolve(unsigned int calendarValue); static unsigned char ASCIIToInt(unsigned char byte); static unsigned int intToASCII(unsigned char byte); static void TimeResolve(unsigned int timeValue); static void Delay(volatile unsigned int count); static unsigned int UserCalendarInfoGet(void); static unsigned int UserTimeInfoGet(void); static void ConfigureIntRTC(void); static void SetupInt(void); static void RTCIsr(void); /****************************************************************************** ** LOCAL FUNCTION DEFINITIONS ******************************************************************************/ /* ** Main function. */ int main(void) { unsigned int UserTime = 0, UserCalendar = 0; UARTStdioInit(); RTCPinMuxSetup(FALSE); /* Disabling Write Protection for RTC registers.*/ RTCWriteProtectDisable(SOC_RTC_0_REGS); /* Performing a Software Reset and Enabling the RTC module. */ RTCEnable(SOC_RTC_0_REGS); /* Delay further operations by a minimum of three 32KHz clock times. */ Delay(0xFFFF); UARTPuts("StarterWare RTC Demo Application.\r\n", -2); UserTime = UserTimeInfoGet(); UserCalendar = UserCalendarInfoGet(); RTCCalendarSet(SOC_RTC_0_REGS, UserCalendar); RTCTimeSet(SOC_RTC_0_REGS, UserTime); RTCRun(SOC_RTC_0_REGS); UARTPuts("\r\n\r\n", -2); UARTPuts("Current Time And Date:\r\n", -1); /* Enabling interrupts.*/ SetupInt(); ConfigureIntRTC(); /* Enabling RTC interrupts. Configuring RTC to interrupt every second.*/ RTCIntTimerEnable(SOC_RTC_0_REGS, RTC_INT_EVERY_SECOND); while(1); } /* ** This function receives time related information from the user. */ static unsigned int UserTimeInfoGet() { unsigned char hour[2] = {0}, minute[2] = {0}, second[2] = {0}; unsigned int hourTime = 0, minTime = 0, secTime = 0; unsigned int time = 0; int i = 0; UARTPuts("\n\nEnter the time in 24 hour format.\r\n", -1); UARTPuts("Example (hh:mm:ss) 20:15:09\r\n", -1); UARTPuts("\r\nEnter Hours: \r\n", -2); do { hour[i] = UARTGetc(); UARTPutc(hour[i]); i++; }while((i < 2) && (hour[i-1] != '\r')); UARTPuts("\r\nEnter Minutes:\r\n", -2); i = 0; do { minute[i] = UARTGetc(); UARTPutc(minute[i]); i++; }while((i < 2) && (minute[i-1] != '\r')); UARTPuts("\r\nEnter Seconds:\r\n", -1); i = 0; do { second[i] = UARTGetc(); UARTPutc(second[i]); i++; }while((i < 2) && (second[i-1] != '\r')); if(hour[0] != '\r') { hourTime = (ASCIIToInt(hour[0]) << 0x04); if(hour[1] != '\r') { hourTime |= ASCIIToInt(hour[1]); } else { hourTime = hourTime >> 0x04; } } if(minute[0] != '\r') { minTime = (ASCIIToInt(minute[0]) << 0x04); if(minute[1] != '\r') { minTime |= ASCIIToInt(minute[1]); } else { minTime = minTime >> 0x04; } } if(second[0] != '\r') { secTime = (ASCIIToInt(second[0]) << 0x04); if(second[1] != '\r') { secTime |= ASCIIToInt(second[1]); } else { secTime = secTime >> 0x04; } } time = (hourTime << HOUR_SHIFT); time |= (minTime << MINUTE_SHIFT); time |= (secTime << SECOND_SHIFT); return time; } /* ** This function receives calendar related information from the user. */ static unsigned int UserCalendarInfoGet() { unsigned int calendar = 0; unsigned char dayOfMonth[2] = {0}, monthArr[2] = {0}, yearArr[2] = {0}; unsigned char dotwArr[2] = {0}; unsigned int dom = 0, month = 0, year = 0, dotw = 0; int j = 0; UARTPuts("\r\n\r\nEnter the calendar information.\r\n", -2); UARTPuts("Example (DD:MM:YY) 31:03:73\r\n", -2); UARTPuts("\r\nEnter the day of the month: \r\n", -2); do { dayOfMonth[j] = UARTGetc(); UARTPutc(dayOfMonth[j]); j++; }while((j < 2) && (dayOfMonth[j-1] != '\r')); j = 0; UARTPuts("\r\nEnter the month (Jan=01, Dec=12):\r\n", -2); do { monthArr[j] = UARTGetc(); UARTPutc(monthArr[j]); j++; }while((j < 2) && (monthArr[j-1] != '\r')); j = 0; UARTPuts("\r\nEnter the year (Ex: 2010=10, 1987=87:):\r\n", -1); do { yearArr[j] = UARTGetc(); UARTPutc(yearArr[j]); j++; }while((j < 2) && (yearArr[j-1] != '\r')); j = 0; UARTPuts("\r\nEnter the Day of the Week (Ex:Sun=00, Sat=06):\r\n", -3); do { dotwArr[j] = UARTGetc(); UARTPutc(dotwArr[j]); j++; }while((j < 2) && (dotwArr[j-1] != '\r')); if(dayOfMonth[0] != '\r') { dom = (ASCIIToInt(dayOfMonth[0]) << 0x04); if(dayOfMonth[1] != '\r') { dom |= ASCIIToInt(dayOfMonth[1]); } else { dom = dom >> 0x04; } } if(monthArr[0] != '\r') { month = (ASCIIToInt(monthArr[0]) << 0x04); if(monthArr[1] != '\r') { month |= ASCIIToInt(monthArr[1]); } else { month = month >> 0x04; } } if(yearArr[0] != '\r') { year = (ASCIIToInt(yearArr[0]) << 0x04); if(yearArr[1] != '\r') { year |= ASCIIToInt(yearArr[1]); } else { year = year >> 0x04; } } if(dotwArr[0] != '\r') { dotw = (ASCIIToInt(dotwArr[0]) << 0x04); if(dotwArr[1] != '\r') { dotw |= ASCIIToInt(dotwArr[1]); } else { dotw = dotw >> 0x04; } } calendar = dom << DAY_SHIFT; calendar |= month << MONTH_SHIFT; calendar |= year << YEAR_SHIFT; calendar |= dotw; return calendar; } /* ** This function prints the current time read from the RTC registers. */ static void TimeResolve(unsigned int timeValue) { unsigned char timeArray[3] = {0}; unsigned char bytePrint[2] = {0}; unsigned int count = 0, i = 0; unsigned int asciiTime = 0; timeArray[0] = (unsigned char)((timeValue & MASK_HOUR) >> HOUR_SHIFT); timeArray[1] = (unsigned char)((timeValue & MASK_MINUTE) >> MINUTE_SHIFT); timeArray[2] = (unsigned char)((timeValue & MASK_SECOND) >> SECOND_SHIFT); while(count < 3) { i = 0; asciiTime = intToASCII(timeArray[count]); bytePrint[0] = (unsigned char)((asciiTime & 0x0000FF00) >> 0x08); bytePrint[1] = (unsigned char)(asciiTime & 0x000000FF); while(i < 2) { UARTPutc(bytePrint[i]); i++; } count++; if(count != 3) { UARTPutc(':'); } else { UARTPutc(' '); } } } /* ** This function prints the calendar information read from the RTC registers. */ static void CalendarResolve(unsigned int calendarValue) { unsigned char calendarArray[3] = {0}; unsigned int asciiCalendar = 0; unsigned int count = 0, j = 0; unsigned int dotwValue = 0; char bytePrint[2] = {0}; char dotwString[4] = {0}; calendarArray[0] = (unsigned char)((calendarValue & MASK_DAY) >> DAY_SHIFT); calendarArray[1] = (unsigned char)((calendarValue & MASK_MONTH) >> MONTH_SHIFT); calendarArray[2] = (unsigned char)((calendarValue & MASK_YEAR) >> YEAR_SHIFT); dotwValue = (calendarValue & MASK_DOTW); switch(dotwValue) { case 0x00: dotwString[0] = 'S'; dotwString[1] = 'u'; dotwString[2] = 'n'; dotwString[3] = '\0'; break; case 0x01: dotwString[0] = 'M'; dotwString[1] = 'o'; dotwString[2] = 'n'; dotwString[3] = '\0'; break; case 0x02: dotwString[0] = 'T'; dotwString[1] = 'u'; dotwString[2] = 'e'; dotwString[3] = '\0'; break; case 0x03: dotwString[0] = 'W'; dotwString[1] = 'e'; dotwString[2] = 'd'; dotwString[3] = '\0'; break; case 0x04: dotwString[0] = 'T'; dotwString[1] = 'h'; dotwString[2] = 'u'; dotwString[3] = '\0'; break; case 0x05: dotwString[0] = 'F'; dotwString[1] = 'r'; dotwString[2] = 'i'; dotwString[3] = '\0'; break; case 0x06: dotwString[0] = 'S'; dotwString[1] = 'a'; dotwString[2] = 't'; dotwString[3] = '\0'; default: break; } while(count < 3) { j = 0; asciiCalendar = intToASCII(calendarArray[count]); bytePrint[0] = (char)((asciiCalendar & 0x0000FF00) >> 0x08); bytePrint[1] = (char)(asciiCalendar & 0x000000FF); while(j < 2) { UARTPutc(bytePrint[j]); j++; } count++; if(count != 3) { UARTPutc('-'); } else { UARTPutc(' '); } } UARTPuts(dotwString, -2); } /* ** This function converts a 8 bit number to its ASCII equivalent value. ** The 8 bit number is passed as a parameter to this function. */ static unsigned int intToASCII(unsigned char byte) { unsigned int retVal = 0; unsigned char lsn = 0, msn = 0; lsn = (byte & 0x0F); msn = (byte & 0xF0) >> 0x04; retVal = (lsn + 0x30); retVal |= ((msn + 0x30) << 0x08); return retVal; } /* ** This function converts the ASCII value of a hexadecimal number to its ** equivalent hexadecimal value. */ static unsigned char ASCIIToInt(unsigned char byte) { unsigned char retVal = 0; /* For numbers from 0x0 to 0x9.*/ if((byte >= 0x30) && (byte <= 0x39)) { retVal = byte - 0x30; } /* For alphabets from A to Z.*/ else if((byte >= 0x41) && (byte <= 0x46)) { retVal = byte - 0x37; } return retVal; } /* ** This function invokes necessary functions to configure the ARM ** processor and ARM Interrupt Controller(AINTC) to receive and ** handle interrupts. */ static void SetupInt(void) { #ifdef _TMS320C6X // Initialize the DSP interrupt controller IntDSPINTCInit(); // Enable DSP interrupts globally IntGlobalEnable(); #else /* Initialize the ARM Interrupt Controller.*/ IntAINTCInit(); /* Enable IRQ in CPSR.*/ IntMasterIRQEnable(); /* Enable the interrupts in GER of AINTC.*/ IntGlobalEnable(); /* Enable the interrupts in HIER of AINTC.*/ IntIRQEnable(); #endif } /* ** This function configures the AINTC to receive the RTC interrupt. */ static void ConfigureIntRTC(void) { #ifdef _TMS320C6X // Register the ISR in the vector table IntRegister(C674X_MASK_INT4, RTCIsr); // Map the system interrupt to the DSP maskable interrupt IntEventMap(C674X_MASK_INT4, SYS_INT_RTC_IRQS); // Enable the DSP maskable interrupt IntEnable(C674X_MASK_INT4); #else /* ** Register the ISR in the Interrupt Vector Table. */ IntRegister(SYS_INT_RTC, RTCIsr); /* Map the RTC system interrupt to channel 2 of AINTC. */ IntChannelSet(SYS_INT_RTC, 2); /* Enable the System Interrupts for AINTC.*/ IntSystemEnable(SYS_INT_RTC); #endif } /* ** This is the Interrupt Service Routine(ISR) for RTC. */ static void RTCIsr(void) { unsigned int timeValue = 0, calendarValue = 0; #ifdef _TMS320C6X IntEventClear(SYS_INT_RTC_IRQS); #else IntSystemStatusClear(SYS_INT_RTC); #endif /* Read the current time from RTC time registers. */ timeValue = RTCTimeGet(SOC_RTC_0_REGS); /* Decode the time in 'timeValue' and display it on console.*/ TimeResolve(timeValue); /* Read the current date from the RTC calendar registers. */ calendarValue = RTCCalendarGet(SOC_RTC_0_REGS); UARTPuts(" ", -2); /* Decode the date in 'calendarValue' and display it on console.*/ CalendarResolve(calendarValue); UARTPuts("\r", -2); } /* ** Delay routine. */ void Delay(volatile unsigned int count) { while(count--); } /****************************** End of file **********************************/
In Processor SDK RTOS, you can also refer to the rtc_test.c example application in \pdk_omapl138_1_0_2\packages\ti\board\diag\rtc\src which outputs the date and time as well.
Please let us know if you have any questions.
Sahin
