Need information about the reset signal, is it include pull down resistor? What is the value of this resistor?
Asi
Asi
Please advise when we will get a feedback to this query - customer is waiting...
Asi Eizer
Is the device has an internal pull down resistor on the reset input ? What is the value of the resistor if has.
Thanks Bill.
Can you say what would be the range of this internal resistor - you said it is varied across process, so do you have any statistic to share?
Asi
Hi Asi,
The resistance value is not characterized. The only definition that I have seen is that it has a 'wide range' but is sufficient to hold an unconnected pin in a known state.
Regards, Bill
