• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Digital Signal Processors (DSP) » C6000 Single Core DSP
Share
  • Forums
  • Announcements
Browse by Tags
Welcome to the C6000 Single Core DSP Section of the TI E2E Support Community. Ask questions, share knowledge, explore ideas, and help solve problems with fellow engineers. To post a question, click on the forum tab then "New Post".
Sign In to Post
Tags
You have subscribed to this tag. To view or manage your tag subscriptions, click here.   Close
You have unsubscribed from this tag. To view or manage your tag subscriptions, click here.   Close
You are currently viewing:
6437
  • BIOS C64x EDMA
  • BIOS/DSP
  • c6000
  • C64+
  • C64x
  • C64x Single Core DSP Forum
  • C64x+
  • cache
  • CCS v3.3
  • compiler
  • CSL
  • DDR2
  • DM642
  • DM6437
  • DMA
  • DSP BIOS
  • DSP/BIOS interrupt processing
  • EDMA
  • EDMA3
  • EDMA3 Transfer Controller in TMS320C6455 pocessor
  • omap35x
  • TMS320C64x
  • UART
Related Posts
  • Forum Post: C6437 + UART (DSP/BIOS Interrupt) Example
    ephraim oved ephraim oved
    Hi. I need some example of connecting the EVM6437 to UART0 with a DSP/BIOS routine. Please Advise.
    on Jul 13, 2009
  • Forum Post: Is OMAP35x EDMA3 compatible with DM6437 EDMA3?
    LinceE2C LinceE2C
    Hello, I use the DM6437 EDMA3 and now I need to migrated it to OMAP3530. I looks the sheets and I discover than they are very similars but at http://software-dl.ti.com/dsps/dsps_registered_sw/sdo_sb/targetcontent/psp/edma3_lld/index.html I saw that there are one different version for each one. This...
    on Dec 9, 2009
  • Forum Post: Issue faced while using QDMA
    Abhi44810 Abhi44810
    Use Case of QDMA: QDMA is used to single data transfer of 6K from external memory to internal memory. Configuration/setting carried out to get QDMA in effect: 1. EDMA driver initialisation 2. By using handle of EDMA driver, QDMA channel is created/initialised. Provided the callback function...
    on Aug 4, 2010
  • Forum Post: Problems with porting project to DSP/BIOS
    John Kofod John Kofod
    I'm porting my working project to DSP/BIOS and it's resulting in some strange behavior. When I write values to a large array, which I've placed in my extern memory DDR2, and afterwards view them in the memory map, I can see that they are shattered and wrongly placed with zeros and random...
    on Sep 23, 2010
  • Forum Post: EDMA3 not working
    Gurudath Amritapura Gurudath Amritapura
    Hello, I am using DM6437. I have created a project based on the Video loopback example. We are trying to transfer data from DDR2 to L1 Cache without using interrupt in loop. First we tried the data transfer from DDR2 to L1 by running the EDMA3TEST example project. When we run the example project...
    on Apr 27, 2011
  • Forum Post: CSL DAT: Problem using DAT_fill
    chrigima chrigima
    Hi I'm trying to use the CSL_DAT module to quickly transpose an array for a 2D FFT. To get into this, I want to run a simple application that fills an array with a constant value. My developpment environement: CCS V3.3 bios_5_41_10_36 dvsdk_1_11_00_00 edma3_lld_01_10_00_01 => im using the...
    on Jun 13, 2011
  • Forum Post: C calls Assemble problem!
    an chen an chen
    Calling assembler in C, the program pointer is to go videocfg.s62 file HWI_Obj HWI_RESET function always, follow example: videocfg.s62 ;; ======== HWI_Obj HWI_RESET ======== ;; defines function for the RESET ISR ;; ;; HWI_Obj HWI_RESET (function, monitor, addr, dataType, operation, client, iUseDispatcher...
    on Jul 8, 2011
  • Forum Post: I need to know the details of speed encoder in TMS320DM6437 DSP Content
    Abhinaw Shree Abhinaw Shree
    Hi, I have just started using DM6437, and going through its examples codes given in TMS320DM6437 DSP Content.. There is an example code of speech encoder.I need to know following details about it: 1) Which compression technique is being used in this speech encoder 2)The final output is mono...
    on Feb 23, 2012
  • Forum Post: Backward compatibility of DSP processors
    Robert Smith Robert Smith
    I have DSP application which run on DM642 processor. That application is developed in CCS 3.3 environment and linked to the library which I have no sources, so I can't recompile it. My question is whether I can recompile and run the same application on the newer DSP such as DM6441, DM6443, DM6446...
    on Mar 21, 2012
  • Forum Post: How configure CCS 3.3 for DM6437 EVM board?
    I have troubles to connect from CCS 3.3 to TMS320DM6437 EVM board. I am using Blackhawk USB560BP JTAG emulator. I think I didn't configure CCS properly for TMS320DM6437 EVM board or missing Blackhawk driver for this board. When I was configuring CCS I didn't see DM6437 in available options...
    on Apr 9, 2012
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
