hello everyone !
I want know that if someone successful enable android touchscreen on beagle board xm and please show me some information or links
thanks jason_liu
hello everyone !
thanks jason_liu
For information about interfacing LCD/touchscreen onto beagleboard, we suggest you look around at the beagleboard community site www.beagleboard.org
Hi Jason,
Please refer to below thread for more info about touchscreen controller on beagel board.
http://e2e.ti.com/support/embedded/f/509/p/125488/449157.aspx#449157
Thanks and Regards,
Pankaj Bharadiya
Hi Pankaj Bharadiya,
Thanks for your reply! I have make my touchscreen work by modify u-boot.bin and kenel
jason
Hi jason liu81336 can u send me what all the modifications u did in u-boot.bin and in kernel. I m also trying to
enable touch screen on beagleboard extention lcd panel, but not working properly. i tried some modifications in
board-omap3beagle.c n its working partially , means if press one side on screen in the sense it will sense opposite side
of the board.
Thanks in advance
Rohit kumar.
Hi Rohit,
Please see below porting guide for touch screen porting and calibration method.
I hope this helps.
Pankaj Bharadiya
hi Rohit kumar
you should modify the file knrnel/drivers/input/touchscreen/ads7846.c to make your touch screen work properly!
I comment the 137 、144、615、616、617、620 lines in ads7846.c
Thanks for regards
jason_liu
hi jason liu81336,
I do follow but the line seem to be wrong?
137 ifdef CONFIG_MACH_OMAP3EVM
144 #endif
615 ts->pendown = 1;
616 dev_vdbg(&ts->spi->dev, "DOWN\n");
617 }
620 swap(x, y);
Can you give me more detail about this?
Thank you
Dung Tx
