• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Embedded Software » Android » Android forum » Android ICS AM35x problem: No android ICS support for the SGX graphics of the AM3517EVM
Share
Android
  • Forum
Options
  • Subscribe via RSS
This question is not answered
gal Shalif
Posted by gal Shalif
on Feb 16 2012 04:09 AM
Prodigy50 points
Problem description
Android ICS can not be build for the AM3517EVM board because there is no SGX graphics for the AM35x with the ti_sgx_sdk-ddk_1.8
Note: The rowboat ICS sources (see reference below) for the AM37x (i.e. BeagleBoard xM) are used as a base for my modifications for the AM3517EVM
Question
When will be an ICS support (i.e. DDK 1.8 or later) for the SGX-530 graphics of the AM35x?
References
  • TI AM37x Android ICS 4.0 Guide - http://processors.wiki.ti.com/index.php/TI-AM37x-Android-4.0-Guide
  • Android ICS SGX without AM35x support - http://gitorious.org/rowboat/hardware-ti-sgx/trees/ti_sgx_sdk-ddk_1.8
    • Release notes - http://processors.wiki.ti.com/index.php/ANDROID_RN_4_06_00_01
  • Android Gingerbread SGX with AM35x - http://gitorious.org/rowboat/hardware-ti-sgx/trees/ti_sgx_sdk-ddk_1.7
    • Release notes - http://processors.wiki.ti.com/index.php/ANDROID_RN_4_04_00_0
AM3517EVM rowboat ICS Android SGX
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Pankaj Bharadiya
    Posted by Pankaj Bharadiya
    on Feb 16 2012 13:08 PM
    Expert4320 points
    There is no plan yet to support AM35x SGX in 1.8 DDK.
    Right now devices supported are: AM335x, AM37x, AM389x and AM387x
    Pankaj Bharadiya
    PS: Please mark this post as answered via the Verify Answer button below if you think it answers your question.  Thanks!
    Report Abuse
    • Reply
  • gal Shalif
    on Feb 16 2012 19:13 PM
    Prodigy50 points
    Thanks for the information.
    And a follow-up - is there a plan for an Android ICS support for the AM3517EVM - maybe with the SGX AM35x drivers from the older DDK 1.7 (or even the SGX kernel drivers from the Linaro ICS code of the Panda board that also provide a CONFIG_SGX_REV121 for the SGX-530 revision 1.2.1 of the AM35x)?
    Report Abuse
    • Reply
  • gal Shalif
    on Feb 19 2012 07:36 AM
    Prodigy50 points
    And some references:
    • Power VR SGX AM35x drivers from the older DDK 1.7 -  https://gitorious.org/rowboat/hardware-ti-sgx/trees/ti_sgx_sdk-ddk_1.7
    • Power VR SGX Linux kernel sources for AM35x and friends -  https://launchpad.net/ubuntu/+source/powervr-omap3
    Report Abuse
    • Reply
  • rfc2217
    Posted by rfc2217
    on Feb 24 2012 09:58 AM
    Expert1375 points
    I've tried to build rowboat ICS with SGX 1.7 and build succeded. Unfortunately I got following error during the boot:
    I/SurfaceFlinger(26372): SurfaceFlinger is starting
    I/SurfaceFlinger(26372): SurfaceFlinger's main thread ready to run. Initializing
     graphics H/W...
    E/FramebufferNativeWindow(
    26372): couldn't open framebuffer HAL (No such device)E/SurfaceFlinger(26372): Display subsystem failed to initialize. check logs. exiting...
    Any idea what's wrong and where to look?
    Yegor
    Report Abuse
    • Reply
  • Pankaj Bharadiya
    on Feb 24 2012 12:26 PM
    Expert4320 points
    Hi Yegor,
    SGX 1.7 DDK may not work on ics directly since 1.7 DDK binaries and shared object files are not compatible with Android 4.0.
    You may have to use SGX 1.8 ddk and modify it for AM35x platform.
    Pankaj Bharadiya
    Report Abuse
    • Reply
  • gal Shalif
    on Feb 26 2012 06:29 AM
    Prodigy50 points
    Had already followed Pankaj's advice - but after modifying the DDK 1.8 for the AM3517EVM - I got a kernel crash when the Android ICS was loading the SGX kernel modules that where compiled by the DDK 1.8 :-(
    Report Abuse
    • Reply
  • Aditya Nellutla
    Posted by Aditya Nellutla
    on Feb 26 2012 23:47 PM
    Intellectual1205 points
    Though you might be able to build the kernel modules, above approach of modifying DDK1.8 for AM3517EVM won't work because the SGX binaries available in the release are build for different SGX Core rev (125).
    Aditya
    Report Abuse
    • Reply
  • rfc2217
    Posted by rfc2217
    on Feb 27 2012 02:33 AM
    Expert1375 points
    Hi Aditya,
    so what is the solution of this problem? Where and when do we get 1.8 SGX drivers for am3517?
    Yegor
    Report Abuse
    • Reply
  • Aditya Nellutla
    on Feb 27 2012 08:07 AM
    Hi Yoger,
             I don't think we have plans for ics on am3517 at present. Hopefully you may expect the support some time next quarter.
    Aditya
    Report Abuse
    • Reply
  • rfc2217
    Posted by rfc2217
    on Apr 10 2012 04:58 AM
    Expert1375 points
    Hi Aditya,
    I've seen this release:
    http://processors.wiki.ti.com/index.php/RN_4_06_00_01
    But seems to be only 1.7 + bugfixes. Any news on 1.8 stuff for am3517?
    Yegor
    Report Abuse
    • Reply
  • Aditya Nellutla
    on Apr 10 2012 09:07 AM
    Hi Yegor,
           I think that release page points to Linux Graphics SDK.
    Currently  am3517 is not under the priority list, however I may
    be in a position to update you about the release plans some time
    next week.
    Aditya
    Report Abuse
    • Reply
  • rfc2217
    Posted by rfc2217
    on Apr 10 2012 09:34 AM
    Expert1375 points
    Hi Aditya,
    thanks for the info. I'm looking forward to hear from you.
    FYI: am3517 has built-in CAN controller and this makes it really interesting for industrial applications. With Android 4.0 on-board you have a flexible and configurable platform for GUI-based applications. ICS version of rowboat provides built-in Ethernet support (configuration GUI), in addition it brings ip utility to configure CAN interfaces. I've blogged about CAN support in Android (http://libbits.wordpress.com/2012/03/27/controller-area-network-can-support-in-android/) and ICS is the version that comes very close to enabling this support. One more goody is on-screen navigation bar, that makes hardware buttons obsolete.
    Without 2D acceleration the handling is not responsive and it takes ages to open a new "window" compared to Gingerbread. So please keep this in mind, if discussing the priority of SGX implementation.
    Yegor
    Report Abuse
    • Reply
  • Aditya Nellutla
    on Apr 20 2012 08:13 AM
    Hi Yegor,
          I would like to update you that the support for ICS on am35x might be available in a couple of weeks.
    Aditya
    Report Abuse
    • Reply
  • rfc2217
    Posted by rfc2217
    on Apr 20 2012 08:31 AM
    Expert1375 points
    Hi Aditya,
    that's a good news! Thanks.
    Yegor
    Report Abuse
    • Reply
  • Avihai Shabtai
    Posted by Avihai Shabtai
    on May 17 2012 09:26 AM
    Prodigy30 points
    Does the support for ICS on am35x available now?
    Avihai
    Report Abuse
    • Reply
12
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
