• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Embedded Software » Android » Android forum » AM335x No display android UI,logcat show that E/FramebufferNativeWindow( 355): couldn't open framebuffer HAL (Bad address)
Share
Android
  • Forum
Options
  • Subscribe via RSS
This question is answered
nimengyu1 nimengyu1
Posted by nimengyu1 nimengyu1
on Feb 26 2012 20:15 PM
Prodigy105 points
Hi All:
         We do an out AM3359 board , it reference AM335x EVM.
        what difference between TI AM335x EVM and our AM3359 board.
                              TI AM335x EVM         our AM3359 board
        ETH                 may be grmii               MII
       WIFI                 wl127x                            No wifi  No BT
       Audio             McASP1                         McASP0
      other is same.
        And We have run it in linux embeded os.
        But when we  do android os on our AM3359 board,it can show robot, but can't display other after this.
        So I do logcat to an file.
         it show many error,such as :
         E/BatteryService(  355): Could not open /sys/class/power_supply
         I/sysproc (  355): Entered system_init()
         I/sysproc (  355): ServiceManager: 0x7cac0
         I/SurfaceFlinger(  355): SurfaceFlinger is starting
         I/SurfaceFlinger(  355): SurfaceFlinger's main thread ready to run. Initializing graphics H/W...
        I think this error may cause no display Android desktop.
        I do the filesystem follow   TI-Android-GingerBread-2_3_4-DevKit-2_1_1 DeveloperGuide.mht   and TI-Android-GingerBread-2_3_4-DevKit-2_1_1 UserGuide.mht
                                1.  download TI_Android_GingerBread_2_3_4_AM335x_Sources.tar.gz
                                2. cd TI_Android_GingerBread_2_3_4_AM335x_Sources             ./.repo/repo/repo sync --local-only
                                3. make TARGET_PRODUCT=am335xevm OMAPES=4.x -j2
            0624.console-log.txt
                0636.logcat-20120227-0840.txt
        Can you help me , I am very worried. Thank you very much!
        nmy
AM35xx android
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Arun Joseph
    Posted by Arun Joseph
    on Feb 26 2012 23:06 PM
    Intellectual2250 points
    Hi nmy,
    Can you try without the SGX components?
    Easy way to disable SGX is
    1) delete system/bin/sgx/rc.pvr
    2) delete /system/lib/hw/gralloc.omap3.so.*
    The differences you mentioned could not create boot up problems.
    What is your panel size and depth?
    Arun
    If this post answers your query, consider clicking the Verify Answer button.
    Report Abuse
    • Reply
  • Aditya Nellutla
    Posted by Aditya Nellutla
    on Feb 27 2012 00:08 AM
    Intellectual1205 points
    Could you please check whether pvrsrvkm.ko and omaplfb.ko kernel modules are properly inserted on your platform?
    Also there seems to be an issue with the following from the logs, could you please ensure that there are no illegal memory writes -
    # devmem2 0x4830A204
    /dev/mem opened.[  108.236082] Unhandled fault: external abort on non-linefetch (0x1018) at 0x40160204
    Memory mapped at address 0x40160000.
    [  108.358730] Unhandled fault: external abort on non-linefetch (0x1018) at 0x40160204
    [1] + Stopped (s[  108.408710] Unhandled fault: external abort on non-linefetch (0x1018) at 0x40160204
    ignal)        devmem2 0x4830A204
    Aditya
    Report Abuse
    • Reply
  • nimengyu1 nimengyu1
    on Feb 27 2012 01:29 AM
    Prodigy105 points
    Hi Arun:
                 Thank you for your reply.
                 I have test you suggestion,  disable SGX through
                Now it can enter android desktop,see follow picture
             but  this  touchscreen is inaccurate  ,and  response is very slow,
    And attach logcat and console log
    6254.console-log-20120227-1507.txt
    2860.logcat-20120227-1507.txt
    And you can see touchscreen is init ok in console log and  logcat
    [    1.294399] mousedev: PS/2 mouse device common for all mice
    [    1.301228] input: ti-tsc-adcc as /devices/platform/tsc/input/input0
     I/EventHub(  137): New device: path=/dev/input/event0 name=ti-tsc-adcc id=0x10000 (of 0x1) index=1 fd=83 classes=0x4
    E/EventHub(  137): could not get driver version for /dev/input/mouse0, Not a typewriter
    And in logcat , there are much error about alsa,but  I think McASP0 is init ok in console log ,and at android startup ,
    i have listen an sound from earphone.
    [    1.470820] asoc: tlv320aic3x-hifi <-> davinci-mcasp.0 mapping ok
    [    1.478104] ALSA device list:
    [    1.481230]   #0: AM335X EVM
    so could you help me to analyse  those question.
             1. touchscreen  how to calibrate
             2. why it so slow
             3. alsa why so much error
     nmy
    1.If reserve sgx in filesystem , android will stop here
    2.if disable sgx in filesystem ,android enter desktop
    Report Abuse
    • Reply
  • Aditya Nellutla
    on Feb 27 2012 01:41 AM
    The UI response is slow because SGX is disabled on your platform. Can you please re-enable/install SGX and check for the suggestions in my previous post?
    Aditya
    Report Abuse
    • Reply
    on Feb 27 2012 02:03 AM
    Prodigy105 points
    Hi Aditya:
                 Thank your reply!
                 I have reinstall filesystem,and I found that pvrsrvkm.ko and omaplfb.ko  is in follow folder.
                 system/bin/sgx/omaplfb.ko
                 system/bin/sgx/pvrsrvkm.ko
    After system startup, android stop at robot display.
    And when I do  devmem2 0x4830A204 command, it show follow
    /dev/mem opened.[  241.581112] Unhandled fault: external abort on non-linefetch (0x1018) at 0x40239204
    Memory mapped at address 0x40239000.
    [  241.697857] Unhandled fault: external abort on non-linefetch (0x1018) at 0x40239204
    [  241.755501] Unhandled fault: external abort on non-linefetch (0x1018) at 0x40239204
    [1]   Bus error               devmem2 0x4830A204
    If i don't do this commad,
    Report Abuse
    • Reply
    on Feb 27 2012 02:08 AM
    Prodigy105 points
    Ps:
          My panel is 7 inch, 800*480, 16bit  RGB depth.
          I also saw someone say that bootargs's vram may be cause some problem. Is it bootarg's problem??
    Report Abuse
    • Reply
  • Vaibhav Hiremath
    Posted by Vaibhav Hiremath
    on Feb 27 2012 03:04 AM
    Expert8160 points
    First of all, "vram" in bootargs is not applicable to AM335x devices,  so doesn't have any meaning here.
    Also I did not understand what you want to do with the command "devmem2 0x4830A204"??? Which module are you trying to access here?
    Please note that, LCDC module is mapped at 0x4830_E000.
    Vaibhav
    Report Abuse
    • Reply
    on Feb 27 2012 03:42 AM
    Prodigy105 points
    Hi vaibhav:
                     Thanks for your reply!
                      devmem2 0x4830A204  command, I reference follow web site:
                      http://e2e.ti.com/support/embedded/android/f/509/t/125885.aspx
                     So I unsderstand  we can't do this command.
                     Could you help me analyse  those quetion above.
     nmy
    Report Abuse
    • Reply
  • Aditya Nellutla
    on Feb 27 2012 03:55 AM
    I think you should not run that devmem2 command as above. It was meant to check the silicon rev for Beagle board.
    On your platform when you execute "lsmod " do you see the kernel modules (*.kos) as pointed in the above post?
    if not please execute the "/system/bin/sgx/rc.pvr", that should initialize your platform and boot.
    Aditya
    Report Abuse
    • Reply
    on Feb 27 2012 23:16 PM
    Prodigy105 points
    Hi Aditya:
              Could you help answer other quetion above?
    Report Abuse
    • Reply
  • Arun Joseph
    on Mar 04 2012 23:30 PM
    Hi.
    Can you check the wiki http://processors.wiki.ti.com/index.php/TI-Android-GingerBread-2.3.4-DevKit-2.1.1_PortingGuides#Touchscreen and follow the section on calibration?
             2. why it so slow
    Can you check the following
    1. Check /proc/interrupts to see you are getting interrupts from the touch screen hardware.
    2. See getevent to see you are getting events from the input subsystem, when you are touching
    Are you able to here the audio and is it clear?
    Audio controls shown in logcat are outdated and can be ignored. AM335X audio device use the default controls.
    Arun
    Report Abuse
    • Reply
    on Apr 08 2012 02:30 AM
    Verified Answer
    Verified by nimengyu1 nimengyu1
    Prodigy105 points
    All:
           Thank you all the same!
           We have solve this quetion, based the patch in URL:
            https://gitorious.org/rowboat/kernel/commit/1630f6cf6d67fc3c651e4b0c1f980da17fbd7b07
          Now am335x android work very well!
    Report Abuse
    • Reply
  • Ricardo Gomes
    Posted by Ricardo Gomes
    on Jun 13 2012 05:01 AM
    Prodigy20 points
    I'm having the same trouble with my AM335xevm.
    I'm trying to compile a new Android image but without success.
    I've downloaded the Android source code for this evaluation board from TI website (http://software-dl.ti.com/dsps/dsps_public_sw/sdo_tii/TI_Android_DevKit/TI_Android_GingerBread_2_3_4_DevKit_2_1_1/index_FDS.html) and I've compiled a new image following the guide from TI (http://processors.wiki.ti.com/index.php/TI-Android-GingerBread-2.3.4-DevKit-2.1.1_DeveloperGuide). When the kit is turned on with the new image on a SD card the boot procedure stops with several green robots on screen.
    With the Android image available on TI website everything works fine.
    The steps I've made are:
    1 - Toolchain setup
    2 - Build Bootloader
    3 - Build Android Linux Kernel
    4 - Build Android Filesystem
    5 - Create root filesystem tarball
    6 - Generate SD/MMC card to boot Android
    I've consulted this thread and applied the patch for the da8xx-fb video driver but the result is the same.
    Is there something I'm missing?
    Report Abuse
    • Reply
  • Ricardo Gomes
    on Jun 13 2012 11:05 AM
    Prodigy20 points
    I probably have isolated the problem to the MLO file which is generated at the same time that the u-boot file. If I replace the MLO file from the one who is in the pré-compiled image from TI, the kit starts without problems.
    I made a new Android Image and use the MLO and u-boot files from the pré-compiled image from TI, to confirm, and it worked.
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
