• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Embedded Software » Android » Android forum » Can no longer build Froyo root file system
Share
Android
  • Forum
Options
  • Subscribe via RSS
This question is answered
Chris Westervelt
Posted by Chris Westervelt
on Mar 05 2012 10:41 AM
Intellectual430 points
I have been trying to re-compile my changes to the Port of Froyo Rowboat I have built in the past with no success.  The errors I am receiving are in code that built before that has never been changed.  I have gone back to a fresh copy of Froyo from the repo and It stops in the same place.  Has anyone verified that Froyo will still build and if so what is the platform they are building on?  Here is the output I am seeing the failure in:
target Java: PackageInstaller (out/target/common/obj/APPS/PackageInstaller_intermediates/classes)
packages/apps/SoundRecorder/gen/com/android/soundrecorder/R.java:10: duplicate class: com.android.soundrecorder.R
public final class R {
Note: packages/apps/SoundRecorder/src/com/android/soundrecorder/SoundRecorder.java uses or overrides a deprecated API.
Note: Recompile with -Xlint:deprecation for details.
1 error
Note: Some input files use or override a deprecated API.
Note: Some input files use unchecked or unsafe operations.
Note: Recompile with -Xlint:unchecked for details.
make: *** [out/target/common/obj/APPS/SoundRecorder_intermediates/classes-full-debug.jar] Error 41
make: *** Waiting for unfinished jobs....
Created JAR file out/host/common/obj/JAVA_LIBRARIES/temp_layoutlib_intermediates/javalib.jar
am3517 android rowboat froyo
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Chris Westervelt
    on Mar 05 2012 10:43 AM
    BTW I'm building on currently updated 10.04 Ubuntu.
    Report Abuse
    • Reply
  • Arun Joseph
    Posted by Arun Joseph
    on Mar 05 2012 11:43 AM
    Verified Answer
    Verified by Chris Westervelt
    Intellectual2250 points
    Hi Chris,
    Looks like the directory packages/apps/SoundRecorder is not clean.
    Can you try the following
    $cd <android source directory>
    $rm -r packages/apps/SoundRecorder
    $repo sync packages/apps/SoundRecorder
    Then build complete android again.
    Arun
    If this post answers your query, consider clicking the Verify Answer button.
    Report Abuse
    • Reply
  • Chris Westervelt
    on Mar 05 2012 13:55 PM
    That did the trick.  What caused this because if you went through a fresh checkout of the project (at least a day ago) you got the same results?  Did you have to fix up the source repo?
    Report Abuse
    • Reply
  • Arun Joseph
    on Mar 05 2012 22:41 PM
    Hi Chris,
    Do not know any such things happened to rowboat-froyo. We were in the process of pushing rowboat-ics repositories..
    Arun
    Report Abuse
    • Reply
  • Prashanthi Shivapooja
    Posted by Prashanthi Shivapooja
    on Aug 02 2012 06:33 AM
    Intellectual315 points
    Hi Arun,
                  We successfully ported android Froyo on AM1808. Now iam getting problem with com port. Actually my task is to retrieve continuous data from serial port using android application. I downloaded serial port api apk file from link http://code.google.com/p/android-serialport-api/  but when i open that file in our device we are getting force close error.
    whereas i can retrieve data from device in Linux system using commands cat  /dev/ttyS1... but i cannot get through application.
    Please suggest me in this issue. Thanks in advance.
    Pooja.
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
