Hi ,
I am using SATA drive (seagate 500GB ext3) at 1.5Gbits per sec, but i am getting following error logs
sdk:- ezsdk 5_03_01_15
platform :- dm814x
patch:- "2086.sata_timeout_fix.txt" applied to kernel
error log as follows
root@dm814x-evm:/media/sda# cp -rf /home/root/PKGS .ata1.00: exception Emask 0x10 SAct 0x3fffff SErr 0x400100 action 0x6 frozenata1.00: irq_stat 0x08000000, interface fatal errorata1: SError: { UnrecovData Handshk }ata1.00: failed command: WRITE FPDMA QUEUEData1.00: cmd 61/00:00:88:8c:bf/04:00:2e:00:00/40 tag 0 ncq 524288 out res 40/00>98:98:c0:bf/00:00:2e:00:00/40 Emask 0x10 (ATA bus error)ata1.00: status: { DRDY }ata1.00: failed command: WRITE FPDMA QUEUEData1.00: cmd 61/00:08:98:c4:bf/04:00:2e:00:00/40 tag 1 ncq 524288 out res 40/00:98:98:c0:bf/00:00:2e:00:00/40 Emask 0x10 (ATA bus error)ata1.00: status: { DRDY }ata1.00: failed command: WRITE FPDMA QUEUEData1.00: cmd 61/f0:10:90:7c:bf/03:00:2e:00:00/40 tag 2 ncq 516096 out res 40/00:98:98:c0:bf/00:00:2e:00:00/40 Emask 0x10 (ATA bus error)ata1.00: status: { DRDY }ata1.00: failed command: WRITE FPDMA QUEUEData1.00: cmd 61/00:18:88:80:bf/04:00:2e:00:00/40 tag 3 ncq 524288 out res 40/00:98:98:c0:bf/00:00:2e:00:00/40 Emask 0x10 (ATA bus error)ata1.00: status: { DRDY }ata1.00: failed command: WRITE FPDMA QUEUEData1.00: cmd 61/00:20:88:84:bf/04:00:2e:00:00/40 tag 4 ncq 524288 out res 40/00>98:98:c0:bf/00:00:2e:00:00/40 Emask 0x10 (ATA bus error)ata1.00: status: { DRDY }ata1.00: failed command: WRITE FPDMA QUEUEData1.00: cmd 61/00:28:88:88:bf/04:00:2e:00:00/40 tag 5 ncq 524288 out res 40/00:98:98:c0:bf/00:00:2e:40:00/40 Emask 0x10 (ATA bus error)ata1.00: status: { DRDY }ata1.00: failed command: WRITE FPDMA QUEUEData1.00: cmd 61/00:30:88:90:bf/04:00:2e:00:00/40 tag 6 ncq 524288 out res 40/00:98:98:c0:bf/00:00:2e:00:00/40 Emask 0x10 (ATA bus error)ata1.00: status: { DRDY }ata1.00: failed command: WRITE FPDMA QUEUEData1.00: cmd 61/00:38:88:94:bf/04:00:2e:00:00/40 tag 7 ncq 524288 out res 40/00:98:98:c0:bf/00:00:2e:00:00/40 Emask 0x10 (ATA bus error)ata1.00: status: { DRDY }ata1.00: failed command: WRITE FPDMA QUEUEData1.00: cmd 61/08:40:c0:58:bf/00:00:2e:00:00/40 tag 8 ncq 4096 out res 40/00:98:98:c0:bf/00:00:2e:00:00/40 Emask 0x10 (ATA bus error)ata1.00: status: { DRDY }ata1.00: failed command: WRITE FPDMA QUEUEData1.00: cmd 61/00:48:c8:58:bf/04:00:2e:00:04/40 tag 9 ncq 524288 out res 40/00:98:98:c0:bf/00:00:2e:00:00/40 Emask 0x10 (ATA bus error)ata1.00: status: { DRDY }ata1.00: failed command: WRITE FPDMA QUEUEData1.00: cmd 61/38:50:c8:5c:bf/03:00:2e:00:00/40 tag 10 ncq 421888 out res 40/00:98:98:c0:bf/00:00:2e:00:00/40 Emask 0x10 (ATA bus error)ata1.00: status: { DRDY }ata1.00: failed command: WRITE FPDMA QUEUEData1.00: cmd 61/70:58:00:60:bf/00:00:2e:00:00/40 tag 11 ncq 57344 out res 40/00:98:98:c0:bf/00:00:2e:00:00/40 Emask 0x10 (ATA bus error)ata1.00: status: { DRDY }ata1.00: failed command: WRITE FPDMA QUEUEData1.00: cmd 61/00:60:88:98:bf/04:00:2e:00:00/40 tag 12 ncq 524288 out res 40/00:98:98:c0:bf/00:00:2e:00:00/40 Emask 0x10 (ATA bus error)ata1.00: status: { DRDY }ata1.00: failed command: WRITE FPDMA QUEUEData1.00: cmd 61/00:68:88:9c:bf/04:00:2e:00:00/40 tag 13 ncq 524288 out res 40/00:98:98:c0:bf/00:00:2e:00:00/40 Emask 0x10 (ATA bus error)ata1.00: status: { DRDY }ata1.00: failed command: WRITE FPDMA QUEUEData1.00: cmd 61/00:70:90:a4:bf/04:00:2e:00:00/40 tag 14 ncq 524288 out res 40/00:98:98:c0:bf/00:00:2e:00:00/40 Emask 0x10 (ATA bus error)ata1.00: status: { DRDY }ata1.00: failed command: WRITE FPDMA QUEUEData1.00: cmd 61/00:78:90:ac:bf/04:00:2e:00:00/40 tag 15 ncq 524288 out res 40/00:98:98:c0:bf/00:00:2e:00:00/40 Emask 0x10 (ATA bus error)ata1.00: status: { DRDY }ata1.00: failed command: WRITE FPDMA QUEUEData1.00: cmd 61/00:80:90:b0:bf/04:00:2e:00:00/40 tag 16 ncq 524288 out res 40/00:98:98:c0:bf/00:00:2e:00:00/40 Emask 0x10 (ATA bus error)ata1.00: status: { DRDY }ata1.00: failed command: WRITE FPDMA QUEUEData1.00: cmd 61/00:88:90:b4:bf/04:00:2e:00:00/40 tag 17 ncq 524288 out res 40/00:98:98:c0:bf/00:00:2e:00:00/40 Emask 0x10 (ATA bus error)ata1.00: status: { DRDY }ata1.00: failed command: WRITE FPDMA QUEUEData1.00: cmd 61/00:90:90:b8:bf/04:00:2e:00:00/40 tag 18 ncq 524288 out res 40/00>98:98:c0:bf/00:00:2e:00:00/40 Emask 0x10 (ATA bus error)ata1.00: status: { DRDY }ata1.00: failed command: WRITE FPDMA QUEUEData1.00: cmd 61/00:98:98:c0:bf/04:00:2e:00:00/40 tag 19 ncq 524288 out res 40/00:98:98:c0:bf/00:00:2e:00:00/40 Emask 0x10 (ATA bus error)ata1.00: status: { DRDY }ata1.00: failed command: WRITE FPDMA QUEUEData1.00: cmd 61/00:a0:90:a8:bf/04:00:2e:00:00/40 tag 20 ncq 524288 out res 40/00:98:98:c0:bf/00:00:2e:00:00/40 Emask 0x10 (ATA bus error)ata1.00: status: { DRDY }ata1.00: failed command: WRITE FPDMA QUEUEData1.00: cmd 61/00:a8:90:bc:bf/04:00:2e:00:00/40 tag 21 ncq 524288 out res 40/00:98:98:c0:bf/00:00:2e:00:00/40 Emask 0x10 (ATA bus error)ata1.00: status: { DRDY }ata1: hard resetting linkata1: softreset failed (1st FIS failed)ata1: SATA link up 1.5 Gbps (SStatus 113 SControl 300)ata1.00: qc timeout (cmd 0xec)ata1.00: failed to IDENTIFY (I/O error, err_mask=0x4)ata1.00: revalidation failed (errno=-5)ata1: hard resetting linkata1: softreset failed (1st FIS failed)ata1: SATA link up 1.5 Gbps (SStatus 113 SControl 300)ata1.00: qc timeout (cmd 0xec)ata1.00: failed to IDENTIFY (I/O error, err_mask=0x4)ata1.00: revalidation failed (errno=-5)ata1: limiting SATA link speed to 1.5 Gbpsata1: hard resetting linkata1: softreset failed (1st FIS failed)ata1: SATA link up 1.5 Gbps (SStatus 113 SControl 310)ata1.00: qc timeout (cmd 0xec)ata1.00: failed to IDENTIFY (I/O error, err_mask=0x4)ata1.00: revalidation failed (errno=-5)ata1.00: disabledata1: hard resetting linkata1: softreset failed (1st FIS failed)ata1: SATA link up 1.5 Gbps (SStatus 113 SControl 310)ata1: EH completesd 0:0:0:0: [sda] Unhandled error codesd 0:0:0:0: [sda] Result: hostbyte=0x04 driverbyte=0x00sd 0:0:0:0> [sda] CDB: cdb[0]=0x2a: 2a 00 2e bf bc 90 00 04 00 00end_request: I/O error, dev sda, sector 784317584Buffer I/O error on device sda, logical block 98039698lost page write due to I/O error on sdaBuffer I/O error on device sda, logical block 98039699lost page write due to I/O error on sdaBuffer I/O error on device sda, logical block 98039700lost page write due to I/O error on sdaBuffer I/O error on device sda, logical block 98039701lost page write due to I/O error on sdaBuffer I/O error on device sda, logical block 98039702lost page write due to I/O error on sdaBuffer I/O error on device sda, logical block 98039703lost page write due to I/O error on sdaBuffer I/O error on levice sda, logical block 98039704lost page write due to I/O error on sdaBuffer I/O error on device sda, logical block 98039705lost page write due to I/O error on sdaBuffer I/O error on device sda, logical block 98039706lost page write due to I/O error on sdaBuffer I/O error on device sda, logical block 98039707lost page write due to I/O error on sdasd 0:0:0:0: [sda] Unhandled error codesd 0:0:0:0: [sda] Result: hostbyte=0x04 driverbyte=0x00sd 0:0:0:0: [sda] CDB: cdb[0]=0x2a: 2a 00 2e bf a8 90 00 04 00 00end_request: I/O error, dev sda, sector 784312464sd 0:0:0:0: [sda] Unhandled error codesd 0:0:0:0: [sda] Result: hostbyte=0x04 driverbyte=0x00sd 0:0:0:0: [sda] CDB: cdb[0]=0x2a: 2a 00 2e bf c0 98 00 04 00 00end_request: I/O error, dev sda, sector 784318616sd 0:0:0>0: [sda] Unhandled error codesd 0:0:0:0: [sda] Result: hostbyte=0x04 driverbyte=0x00sd 0:0:0:0: [sda] CDB: cdb[0]=0x2a: 2a 00 2e bf b8 90 00 04 00 00end_request: I/O error, dev sda, sector 784316560sd 0:0:0:0: [sda] Unhandled error codesd 0:0:0:0: [sda] Result: hostbyte=0x04 driverbyte=0x00sd 0:0:0:0: [sda] CDB: cdb[0]=0x2a: 2a 00 2e bf b4 90 00 04 00 00end_request: I/O error, dev sda, sector 784315536sd 0:0:0:0: [sda] Unhandled error codesd 0:0:0:0: [sda] Result: hostbyte=0x04 driverbyte=0x00sd 0:0:0:0: [sda] CDB: cdb[0]=0x2a: 2a 00 2e bf b0 90 00 04 00 00end_request: I/O error, dev sda� sector 784314512sd 0:0:0:0: [sda] Unhandled error codesd 0:0:0:0: [sda] Result: hostbyte=0x04 driverbyte=0x00sd 0:0:0:0: [sda] CDB: cdb[0]=0x2a: 2a 00 2e bf ac 90 00 04 00 00end_request: I/O error, dev sda, sector 784313488sd 0:0:0:0: [sda] Unhandled error codesd 0:0:0:0: [sda] Result: hostbyte=0x04 driverbyte=0x00sd 0:0:0:0: [sda] CDB: cdb[0]=0x2a: 2a 00 2e bf a4 90 00 04 00 00end_request: I/O error, dev sda, sector 784311440sd 0:0:0:0: [sda] Unhandled error codesd 0:0:0:0: [sda] Result: hostbyte=0x04 driverbyte=0x00sd 0:0:0:0: [sda] CDB: cdb[0]=0x2a: 2a 00 2e bf 9c 88 00 04 00 00end_request: I/O error, dev sda, sector 784309384sd 0:0:0:0: [sda] Unhandled error codesd 0:0:0:0: [sda] Result: hostbyte=0x04 driverbyte=0x00sd 0:0:0:0: [sda] CDB: cdb[0]=0x2a: 2a 00 2e bf 98 88 04 04 00 00end_request: I/O error, dev sda, sector 784308360sd 0:0:0:0: [sda] Unhandled error codesd 0:0:0:0: [sda] Result: hostbyte=0x04 driverbyte=0x00sd 0:0:0:0: [sda] CDB: cdb[0]=0x2a: 2a 00 2e bf 60 00 00 00 70 00end_request: I/O error, dev sda, sector 784293888sd 0:0:0:0: [sda] Unhandled error codesd 0:0:0:0: [sda] Result: hostbyte=0x04 driverbyte=0x00sd 0:0:0:0: [sda] CDB: cdb[0]=0x2a: 2a 00 2e bf 5c c8 00 03 38 00end_request: I/O error, dev sda, sector 784293064sd 0:0:0:0: [sda] Unhandled error codesd 0:0:0:0: [sda] Result: hostbyte=0x04 driverbyte=0x00sd 0:0:0:0: [sda] CDB: cdb[0]=0x2a: 2a 00 2e bf 58 c8 00 04 00 00end_request: I/O error, dev sda, sector 784292040sd 0:0:0:0: [sda] Unhandled error codesd 0:0:0:0: [sda] Result: hostbyte=0x04 driverbyte=0x00sd 0:0:0:0: [sda] CDB: cdb[0]=0x2a: 2a 00 2e bf 58 c0 00 00 08 00end_request: I/O error, dev sda, sector 784292032sd 0:0:0:0: [sda] Unhandled error codesd 0:0:0:0: [sda] Result: hostbyte=0x04 driverbyte=0x00sd 0:0:0:0: [sda] CDB: cdb[0]=0x2a: 2a 00 2e bf 94 88 00 04 00 00end_request: I/O error, dev sda, sector 784307336sd 0:0:0:0: [sda] Unhandled error codesd 0:0:0:0: [sda] Result: hostbyte=0x04 driverbyte=0x00sd 0:0:0:0: [sda] CDB: cdb[0]=0x2a: 2a 00 2e bf 90 88 00 04 00 00end_request: I/O error, dev sda, sector 784306312sd 0:0:0:0: [sda] Unhandled error codesd 0:0:0:0: [sda] Result: hostbyte=0x04 driverbyte=0x00sd 0:0:0:0: [sda] CDB: cdb[0]=0x2a: 2a 00 2e bf 88 88 00 04 00 00end_request: I/O error, dev sda, sector 784304264sd 0:0:0:0: [sda] Unhandled error codesd 0:0:0:0: [sda] Result: hostbyte=0x04 driverbyte=0x00sd 0:0:0:0: [sda] CDB: cdb[0]=0x2a: 2a 00 2e bf 84 88 00 04 00 00end_request: I/O error, dev sda, sector 784303240sd 0:0:0:0: [sda] Unhandled error codesd 0:0:0:0: [sda] Result: hostbyte=0x04 driverbyte=0x00sd 0:0:0:0: [sda] CDB: cdb[0]=0x2a: 2a 00 2e bf 80 88 00 04 00 00end_request: I/O error, dev sda, sector 784302216sd 0:0:0:0: [sda] Unhandled error codesd 0:0:0:0: [sda] Result: hostbyte=0x04 driverbyte=0x00sd 0:0:0:0: [sda] CDB: cdb[0]=0x2a: 2a 00 2e bf 7c 90 00 03 f0 00end_request: I/O error, dev sda, sector 784301200sd 0:0:0:0: [sda] Unhandled error codesd 0:0:0:0: [sda] Result: hostbyte=0x04 driverbyte=0x00sd 0:0:0:0: [sda] CDB: cdb[0]=0x2a: 2a 00 6e bf c4 98 00 04 00 00end_request: I/O error, dev sda, sector 784319640sd 0:0:0:0: [sda] Unhandled error codesd 0:0:0:0: [sda] Result: hostbyte=0x04 driverbyte=0x00sd 0:0:0:0: [sda] CDB: cdb[0]=0x2a: 2a 00 2e bf 8c 88 00 04 00 00end_request: I/O error, dev sda, sector 784305288sd 0:0:0:0: [sda] Unhandled error codesd 0:0:0:0: [sda] Result: hostbyte=0x04 driverbyte=0x00sd 0:0:0:0: [sda] CDB: cdb[0]=0x28: 28 00 2e c0 00 00 00 00 08 00end_request: I/O error, dev sda, sector 784334848EXT3-fs error (device sda): read_block_bitmap: Cannot read block bitmap - block_group = 2992, block_bitmap = 98041856sd 0:0:0:0: [sda] Unhandled error codesd 0:0:0:0: [sda] Result: hostbyte=0x04 driverbyte=0x00sd 0:0:0:0: [sda] CDB: cdb[0]=0x2a: 2a 00 2e bf c8 98 00 04 00 00end_request: I/O error, dev sda, sector 784320664sd 0:0:0:0: [sda] Unhandled error codesd 0:0:0:0: [sda] Result: hostbyte=0x04 driverbyte=0x00sd 0:0:0:0: [sda] CDB: cdb[0]=0x2a: 2a 00 2e bf cc 98 00 04 00 00end_request: I/O error, dev sda, sector 784321688sd 0:0:0:0: [sda] Unhandled error codesd 0:0:0:0> [sda] Result: hostbyte=0x04 driverbyte=0x00sd 0:0:0:0: [sda] CDB: cdb[0]=0x2a: 2a 00 2e bf d0 98 00 04 00 00end_request: I/O error, dev sda, sector 784322712sd 0:0:0:0: [sda] Unhandled error codesd 0:0:0:0: [sda] Result: hostbyte=0x04 driverbyte=0x00sd 0:0:0:0: [sda] CDB: cdb[0]=0x2a: 2a 00 1d 18 10 10 00 00 08 00end_request: I/O error, dev sda, sector 488116240JBD: I/O error detected when updating journal superblock for sda.sd 0:0:0:0: [sda] Unhandled error codesd 0:0:0:0: [sda] Result: hostbyte=0x04 driverbyte=0x00sd 0:0:0:0: [sda] CDB: cdb[0]=0x2a: 2a 00 00 00 00 00 00 00 08 00end_request: I/O error, dev sda, sector 0EXT3-fs (sda): I/O error while writing superblocksd 0:0:0:0: [sda] Unhandled error codesd 0:0:0:0: [sda] Result: hostbyte=0x04 driverbyte=0x00sd 0:0:0:0: [sda] CDB: cdb[0]=0x2a: 2a 00 1d 18 10 18 00 00 08 00end_request: I/O error, dev sda, sector 488116248sd 0:0:0:0: [sda] Unhandled error codesd 0:0:0:0: [sda] Result: hostbyte=0x04 driverbyte=0x00sd 0:0:0:0: [sda] CDB: cdb[0]=0x2a: 2a 00 1d 18 10 20 00 00 50 00end_request: I/O error, dev sda, sector 488116256sd 0:0:0:0: [sda] Unhandled error codesd 0:0:0:0: [sda] Result: hostbyte=0x04 driverbyte=0x00sd 0:0:0:0: [sda] CDB: cdb[0]=0x2a: 2a 00 1d 18 10 78 00 00 28 00end_request: I/O error, dev sda, sector 488116344Aborting journal on device sda.EXT3-fs (sda): sd 0:0:0:0: [sda] Unhandled error codesd 0:0:0:0: [sda] Result: hostbyte=0x04 driverbyte=0x00sd 0:0:0:0: [sda] CDB: cdb[0]=0x2a: 2a 00 1d 18 10 10 00`00 08 00end_request: I/O error, dev sda, sector 488116240error in ext3_reserve_inode_write: Journal has abortedJBD: I/O error detected when updating journal superblock for sda.sd 0:0:0:0: [sda] Unhandled error codesd 0:0:0:0: [sda] Result: hostbyte=0x04 driverbyte=0x00sd 0:0:0:0: [sda] CDB: cdb[0]=0x2a: 2a 00 2e bf d4 98 00 04 00 00end_request: I/O error, dev sda, sector 784323736sd 0:0:0:0: [sda] Unhandled error codesd 0:0:0:0: [sda] Result: hostbyte=0x04 driverbyte=0x00sd 0:0:0:0: [sda] CDB: cdb[0]=0x2a: 2a 00 2e bf d8 98 00 04 00 00end_request: I/O error, dev sda, sector 784364760sd 0:0:0:0: [sda] Unhandled error codesd 0:0:0:0: [sda] Result: hostbyte=0x04 driverbyte=0x00sd 0:0>0:0: [sda] CDB: cdb[0]=0x2a: 2a 00 2e bf dc 98 00 04 00 00end_request: I/O error, dev sda, sector 784325784sd 0:0:0:0: [sda] Unhandled error codesd 0:0:0:0: [sda] Result: hostbyte=0x04 driverbyte=0x00sd 0:0:0:0: [sda] CDB: cdb[0]=0x2a: 2a 00 2e bf e0 a0 00 04 00 00end_request: I/O error, dev sda, sector 784326816sd 0:0:0:0: [sda] Unhandled error codesd 0:0:0:0: [sda] Result: hostbyte=0x04 driverbyte=0x00sd 0:0:0:0: [sda] CDB: cdb[0]=0x2a: 2a 00 2e bf e4 a0 00 04 00 00end_request: I/O error, dev sda, sector 784327840sd 0:0:0:0: [sda] Unhandled error codesd 0:0:0:0: [sda] Result: hostbyte=0x04 driverbyte=0x00sd 0:0:0:0: [sda] CDB: cdb[0]=0x2a: 2a 00 2e bf e8 a0 00 04 00 00end_request: I/O error, dev sda, sector 784328864sd 0:0:0:0: [sda] Unhandled error codesd 0:0:0:0: [sda] Result: hostbyte=0x04 driverbyte=0x00sd 0:0:0:0> [sda] CDB: cdb[0]=0x2a: 2a 00 2e bf ec a0 00 04 00 00end_request: I/O error, dev sda, sector 784329888sd 0:0:0:0: [sda] Unhandled error codesd 0:0:0:0: [sda] Result: hostbyte=0x04 driverbyte=0x00sd 0:0:0:0: [sda] CDB: cdb[0]=0x2a: 2a 00 2e bf f0 a0 00 04 00 00end_request: I/O error, dev sda, sector 784330912sd 0:0:0:0: [sda] Unhandled error codesd 0:0:0:0: [sda] Result: hostbyte=0x04 driverbyte=0x00sd 0:0:0:0: [sda] CDB: cdb[0]=0x2a: 2a 00 2e bf f4 a0 00 04 00 00end_request: I/O error, dev sda, sector 784331936sd 0:0:0:0: [sda] Unhandled error codesd 0:0:0:0: [sda] Result: hostbyte=0x04 driverbyte=0x00sd 0>0:0:0> [sda] CDB: cdb[0]=0x2a: 2a 00 2e bf f8 a0 00 04 00 00end_request: I/O error, dev sda, sector 784332960sd 0:0:0:0: [sda] Unhandled error codesd 0:0:0:0: [sda] Result: hostbyte=0x04 driverbyte=0x00sd 0:0:0:0: [sda] CDB: cdb[0]=0x2a: 2a 00 2e bf fc a0 00 03 60 00end_request: I/O error, dev sda, sector 784333984sd 0:0:0:0: [sda] Unhandled error codesd 0:0:0:0: [sda] Result: hostbyte=0x04 driverbyte=0x00sd 0:0:0:0: [sda] CDB: cdb[0]=0x2a: 2a 00 00 00 00 00 00 00 08 00end_request: I/O error, dev sda, sector 0EXT3-fs (sda): I/O error while writing superblockEXT3-fs (sda): error in ext3_reserve_inode_write: Journal has abortedsd 0:0:0:0: [sda] Unhandled error codesd 0:0:0:0: [sda] Result: hostbyte=0x04 driverbyte=0x00sd 0:0:0:0: [sda] CDB: cdb[0]=0x2a: 2a 00 00 00 00 00 00 00 08 00end_request: I/O error, dev sda, sector 0EXT3-fs (sda): I/O error while writing superblockEXT3-fs (sda): error in ext3_orphan_del: Journal has abortedsd 0:0:0:0: [sda] Unhandled error codesd 0:0:0:0: [sda] Result: hostbyte=0x04 driverbyte=0x00sd 0:0:0:0: [sda] CDB: cdb[0]=0x2a: 2a 00 00 00 00 00 00 00 08 00end_request: I/O error, dev sda, sector 0EXT3-fs (sda): I/O error while writing superblockEXT3-fs (sda): error in ext3_truncate: Journal has abortedsd 0:0:0:0: [sda] Unhandled error codesd 0:0:0:0: [sda] Result: hostbyte=0x04 driverbyte=0x00sd 0:0:0:0: [sda] CDB: cdb[0]=0x2a: 2a 00 00 00 00 00 00 00 08 00end_request: I/O error, dev sda, sector 0EXT3-fs (sda): I/O error while writing superblockcp: write error:EXT3-fs (sda): error: ext3_journal_start_sb: Input/output erDetected aborted journalror
Can someone please provide some resolution to this problem?
I have the same issue too. Do you get the solution?
David
