• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Embedded Software » Android » Android forum » Blank Display with Beaglebone, LCD7 Cape and TI_Android_ICS_4_0_3_DevKit_3_0_1
Share
Android
  • Forum
Options
  • Subscribe via RSS
This question is not answered
Edgar Schroeder
Posted by Edgar Schroeder
on May 12 2012 00:14 AM
Prodigy80 points
Hi All,
I have a blank display using the  Beaglebone A5  with an LCD7 Cape and TI_Android_ICS_4_0_3_DevKit_3_0_1.
The display works with Angstrom image 04-22-12, and the Android installation works with VNC.
Does anybody know why this might be?   Am I missing something about the setup?
Ed Schoeder
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Trunes Beer
    Posted by Trunes Beer
    on Jul 15 2012 12:22 PM
    Prodigy40 points
    I have the same problem, using a BeagleBone (Rev. A5), a LCD7 Cape (Rev. A1) and TI_Android_ICS_4_0_3_DevKit_3_0_1
    I think the problem is the detection of the LCD7 Cape:
    [ 1.181945] omap_i2c omap_i2c.3: bus 3 rev2.4.0 at 100 kHz
    [ 1.188476] at24 3-0054: 32768 byte 24c256 EEPROM, writable, 64 bytes/write
    [ 1.195861] IN : bone_setup_daughter_board
    [ 1.208679] Detected a daughter card on BeagleBone..
    [ 1.213714] IN : dvi_init
    [ 1.217224] da8xx_lcdc.0: alias fck already exists
    [ 1.222656] da8xx_lcdc da8xx_lcdc.0: GLCD: Found 1024x768@60 panel
    [ 1.242462] Setup DVI display
    [ 1.246917] mtdoops: mtd device (mtddev=name/number) must be supplied
    [ 1.253967] omap2-nand driver initializing
    [ 1.258331] OneNAND driver initializing
    I have found this article:
    https://groups.google.com/forum/#!topic/rowboat/9UC0za1flwk
    But i dont know how to solve this problem!
    Trunes
    Report Abuse
    • Reply
  • Satish Patel
    Posted by Satish Patel
    on Jul 16 2012 01:01 AM
    Expert4350 points
    Could you try out below patch ? ( from matthias)
    https://groups.google.com/forum/?fromgroups#!topic/rowboat/9mXkAN-uNJ0
    There was a changes in LCD configuration after revision A2.
    BR,
    satish
    Kindly click the verify answer button on this post if it answer your question.
    Report Abuse
    • Reply
  • Trunes Beer
    on Jul 19 2012 16:19 PM
    Prodigy40 points
    Thank you very much!
    The LCD is now working, but the touchscreen is inverted (left = right, right = left) and the buttons don't work (home, return etc.).
    Only the button to shut down is working...
    BR
    Trunes
    Report Abuse
    • Reply
  • Trunes Beer
    on Jul 21 2012 05:09 AM
    Prodigy40 points
    The touchscreen is now working:
    i changed following in the ti_tscadc.c file:
    old:
    if (cur_diff_x < prev_diff_x) {
      prev_diff_x = cur_diff_x;
    new:
      val_x = AM335X_TS_XMAX - readx1;
    Now im looking to get the buttons to work...
    BR, Trunes
    Report Abuse
    • Reply
  • Georgi Todorov
    Posted by Georgi Todorov
    on Jul 29 2012 17:36 PM
    Prodigy10 points
    Trunes,
    Any luck with the buttons?
    Cheers, Georgi
    Report Abuse
    • Reply
  • Trunes Beer
    on Jul 30 2012 14:07 PM
    Prodigy40 points
    Hello Georgi!
    Yes, the buttons are working now :)
    I changed the GPIO-Pin numbers in the "board-am335evm.c" to following numbers:
    /* Configure GPIOs for Volume Keys */
    static struct gpio_keys_button lcd_cape_gpio_buttons[] = {
     .code = KEY_MENU,
     .gpio = GPIO_TO_PIN(1, 17),
     .active_low = true,
     .desc = "menu",
     .type = EV_KEY,
     .wakeup = 1,
     .code = KEY_POWER,
     .gpio = GPIO_TO_PIN(1, 19),
     .active_low = true,
     .desc = "power",
     .type = EV_KEY,
     .wakeup = 1,
     .code = KEY_BACK,
     .gpio = GPIO_TO_PIN(1, 16),
     .active_low = true,
     .desc = "back",
     .type = EV_KEY,
     .wakeup = 1,
    Now the LCD 7 Cape works perfect with Android 4.0.3 ;-)
    BR Trunes
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
