• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Embedded Software » Android » Android forum » USB Camera issue with Android 2.3.4 Devkit 2.1
Share
Android
  • Forum
Options
  • Subscribe via RSS
This question is not answered
Vinayaka Hegde
Posted by Vinayaka Hegde
on Aug 16 2012 05:30 AM
Intellectual260 points
I am trying to integrate USB Camera(logitec) on AM37x (mistral) EVM using Android 2.3.4 Devkit 2.1, but not able to get the Camera working. Here is my log details, you can see I have highlighted the camera related log details. And after all these I am getting error in the function "Int V4L2Camera::Open()" (in file v4l2camera.cpp), where "videoIn->cap.capabilities" value is 0x4000002. I checked this value in the file (videodev2.h) and it says that device is " a video output device" , but it supposed to be  "a video capture device". What may be the problem with the code/settings. I have enabled the UVC class drivers in the kernel and no other changes done.
Please note that I am able to use the same camera with Android Froyo Devkit and it is working fine on this (AM37x Mistral) EVM.
Does anyone has idea why this error is comming for me? Has anyone integrated the USB camera in Android 2.3.4?
Kernel Log details:
<6>[    0.195404] RPC: Registered tcp NFSv4.1 backchannel transport module.
<4>[    0.195617] NetWinder Floating Point Emulator V0.97 (double precision)
<6>[    0.202545] omap3evm camera init done successfully...
<6>[    0.202850] omap-iommu omap-iommu.0: isp registered
<6>[    0.203155] AM37x/DM37x  Linux PSP version 04.02.00.07 (OMAP3EVM)
<6>[    3.327331] tvp514x 3-005c: tvp5146m2 (Version - 0x03) found at 0xb8 (OMAP I2C adapter)
<6>[    3.343811] usbcore: registered new interface driver uvcvideo
<6>[    3.349884] USB Video Class driver (v1.0.0)
<4>[    3.354400] omap_device: omap_wdt.-1: new worst case activate latency 0: 30517
<6>[    4.345123] uvcvideo: Found UVC 1.00 device <unnamed> (046d:0809)
<6>[    4.386657] input: UVC Camera (046d:0809) as /devices/platform/ehci-omap.0/usb1/1-2/1-2.4/1-2.4:1.0/input/input3
<6>[    4.918365] set resolution quirk: cval->res = 384
<6>[    5.022613] EXT3-fs: barriers not enabled
-VH
USB camera Android 2.3.4
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Satish Patel
    Posted by Satish Patel
    on Aug 17 2012 00:34 AM
    Expert4350 points
    Hi Vinayaka,
    For USB camera, kindly go to the function CameraHardware:CameraHardware() - CameraHardware.cpp file..
    And mkae the version=0 after check of KERNEL version....
    1. Idea here is to use standart camera framework for USB camera  and use a media framework for other cameras...
    2. So I would advise make the version as zero, so that it will take standard path
    I hope this will solve your problem.
    satish
    Kindly click the verify answer button on this post if it answer your question.
    Report Abuse
    • Reply
  • Vinayaka Hegde
    on Aug 17 2012 03:00 AM
    Satish,
    Thanks for the input. I tried this and no success with this change as well. I had removed some of the prints, so unable to see is this crossed the above error or not. I will try that and update you on exactly where it is giving error (I mean same place mentioned above or not). Mean time can you give some more inputs on this? I want camera to be up on Gingerbread or ICS. But I don't want to try on both - all experiment I can do it only one (I mean GB or ICS). If you have any suggestion please give it.
    I have connected the USB (logitech) camera through a USB hub (external powered), even tried by connecting directly but the result was same earlier, but I have not tried with your suggested change.
    -VH
    Report Abuse
    • Reply
  • Satish Patel
    on Aug 19 2012 23:17 PM
    Expert4350 points
    Hi Vinayaka,
    1. As I mentioned earlier, you have to take normal V4L2 path for USB camera not the media framerwork path.
    2. After doing the changes suggessted by me kindly post both kernel logs ( dmesg) and android logs ( logcat) for more analysis
    BR,
    satish
    Report Abuse
    • Reply
  • Vinayaka Hegde
    on Aug 21 2012 05:50 AM
    0652.kernel_21aug2012.txt4544.logcat_21Aug2012.txt
    Satish,
    I have attached both the logcat and kernel messages with this post. Please note that I have copied the log only after connecting the USB camera to the board.
    Some of the prints in the kernel are added by me to find the problem location.
    VH
    Report Abuse
    • Reply
  • Satish Patel
    on Aug 22 2012 01:58 AM
    Expert4350 points
    Hi Vinayaka,
    Your logcat file is not opening.. Could you resend the same. ?
    BR,
    satish
    Report Abuse
    • Reply
  • Vinayaka Hegde
    on Aug 22 2012 07:36 AM
    You can find below
    01-01 00:03:02.382: I/EventHub(1254): New keyboard: device->id=0x20003 devname='UVC Camera (046d:0809)' propName='hw.keyboards.131075.devname' keylayout='/system/usr/keylayout/qwerty.kl'
    01-01 00:03:02.382: I/EventHub(1254): New device: path=/dev/input/event3 name=UVC Camera (046d:0809) id=0x20003 (of 0x4) index=4 fd=34 classes=0x1
    01-01 00:03:02.382: I/InputReader(1254): Device added: id=0x20003, name=UVC Camera (046d:0809), sources=00000101
    01-01 00:03:02.382: I/InputManager-Callbacks(1254): No input device calibration properties found for device UVC Camera (046d:0809).
    Let me know if you need more details about log & dmsg.
    -VH
    Report Abuse
    • Reply
  • Vinayaka Hegde
    on Aug 24 2012 04:46 AM
    0535.logcat_23Aug2012.txt
    2474.dmesg_23Aug2012.txt
    Satish,
    Please find more detailed log cat & dmesg attached with this post. In this dmesg some of my debug prints have been removed
    Please help me in resolving this issue. Is there a way to debug this issue using CCSv5 (or which forum is best for CCSv5 related question)?
    -VH
    Report Abuse
    • Reply
  • Vinayaka Hegde
    on Sep 05 2012 04:46 AM
    Satish,
    Any update on this?
    -VH
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
