hi,
I use am3359 with usb camera with ICS4.0.3 ,but I can't saw the picture ,below is my logcat:
I/ActivityManager( 111): START {act=android.intent.action.MAIN cat=[android.intent.category.LAUNCHER] flg=0x10200000 cmp=co1
D/PermissionCache( 61): checking android.permission.READ_FRAME_BUFFER for uid=1000 => granted (457 us)
W/WindowManager( 111): Failure taking screenshot for (250x150) to layer 21005
I/ActivityManager( 111): Start proc com.android.camera for activity com.android.camera/.Camera: pid=509 uid=10033 gids={100}
W/NetworkManagementSocketTagger( 111): setKernelCountSet(10033, 1) failed with errno -2
I/ARMAssembler( 61): generated scanline__00000077:03515102_00001001_00000000 [ 71 ipp] (91 ins) at [0x413eb7c8:0x413eb934]s
I/InputReader( 111): Reconfiguring input devices. changes=0x00000004
W/SurfaceFlinger( 61): createScreenshotSurface failed (Function not implemented)
I/ActivityManager( 111): Config changed: {1.0 0mcc0mnc en_US layoutdir=0 sw480dp w480dp h775dp lrg long port -touch -keyb/v}
D/dalvikvm( 241): GREF has increased to 201
D/****CameraHAL( 64): cameraHal BACK 0
D/****CameraHAL( 64): cameraHal 0
V/CameraHolder( 509): open camera 0
I/CameraService( 64): Opening camera 0
I/****CameraHAL( 64): camera_device open
D/CameraHardware( 64): Set Parameter...!!
D/CameraHardware( 64): PreviewFormat yuv422sp
D/CameraHardware( 64): PictureFormat jpeg
D/CameraHardware( 64): preview width:320,height:240
D/CameraHardware( 64): picture width:320,height:240
D/CameraHardware( 64): FRAMERATE 15
D/CameraHardware( 64): Picture Size by CamHAL 320 x 240
D/CameraHardware( 64): Preview Resolution by CamHAL 320 x 240
D/CameraHardware( 64): enableMsgType:1037
I/AwesomePlayer( 64): setDataSource_l('/system/media/audio/ui/camera_click.ogg')
I/AwesomePlayer( 64): setDataSource_l('/system/media/audio/ui/VideoRecord.ogg')
D/dalvikvm( 509): GC_CONCURRENT freed 215K, 5% free 6698K/7047K, paused 4ms+11ms
I/ARMAssembler( 61): generated scanline__00000077:03010102_00008001_00000000 [ 88 ipp] (109 ins) at [0x413eb938:0x413ebaecs
I/ARMAssembler( 61): generated scanline__00000077:03515102_00008001_00000000 [114 ipp] (135 ins) at [0x413ebaf0:0x413ebd0cs
I/ARMAssembler( 61): generated scanline__00000077:03545402_00000000_00000000 [ 30 ipp] (44 ins) at [0x413ebd10:0x413ebdc0]s
D/dalvikvm( 509): GC_FOR_ALLOC freed 26K, 4% free 6962K/7239K, paused 28ms
D/Camera ( 509): app passed NULL surface
D/CameraHardware( 64): preview width:640,height:480
D/CameraHardware( 64): picture width:640,height:480
D/CameraHardware( 64): Picture Size by CamHAL 640 x 480
D/CameraHardware( 64): Preview Resolution by CamHAL 640 x 480
V/camera ( 509): Preview size is 640x480
V/camera ( 509): startPreview
W/****CameraHAL( 64): ----Preview not Enabled----
W/****CameraHAL( 64): window is NULL
W/CameraHardware( 64): Window is Null
D/CameraHardware( 64): startPreview width:640,height:480
D/V4L2Camera( 64): CameraConfigure PreviewFormat: w=640 h=480
V/camera ( 509): surfaceChanged. w=401. h=534
W/****CameraHAL( 64): ----Preview Enabled----
D/****CameraHAL( 64): Exiting the function
I/ActivityManager( 111): Displayed com.android.camera/.Camera: +3s671ms
W/InputManagerService( 111): Starting input on non-focused client com.android.internal.view.IInputMethodClient$Stub$Proxy@4)
W/IInputConnectionWrapper( 241): showStatusIcon on inactive InputConnection
W/OrientationEventListener( 509): Cannot detect sensors. Not enabled
D/CameraStorage( 509): External storage state=mounted
I/Thumbnail( 509): Fail to load bitmap. java.io.FileNotFoundException: /data/data/com.android.camera/files/last_thumb: open)
D/dalvikvm( 111): GC_EXPLICIT freed 320K, 7% free 8714K/9351K, paused 5ms+39ms
D/dalvikvm( 509): GC_CONCURRENT freed 231K, 5% free 7165K/7495K, paused 3ms+45ms
W/ActivityManager( 111): Launch timeout has expired, giving up wake lock!
W/ActivityManager( 111): Activity idle timeout for ActivityRecord{411a2da8 com.android.camera/.Camera}
W/NetworkManagementSocketTagger( 111): setKernelCountSet(10030, 0) failed with errno -2
I/InputDispatcher( 111): Application is not responding: Window{412736b0 com.android.camera/com.android.camera.Camera pausedd
I/WindowManager( 111): Input event dispatching timed out sending to com.android.camera/com.android.camera.Camera
I/Process ( 111): Sending signal. PID: 509 SIG: 3
I/dalvikvm( 509): threadid=3: reacting to signal 3
I/dalvikvm( 509): Wrote stack traces to '/data/anr/traces.txt'
I/Process ( 111): Sending signal. PID: 111 SIG: 3
I/dalvikvm( 111): threadid=3: reacting to signal 3
I/dalvikvm( 111): Wrote stack traces to '/data/anr/traces.txt'
I/Process ( 111): Sending signal. PID: 183 SIG: 3
I/dalvikvm( 183): threadid=3: reacting to signal 3
I/dalvikvm( 183): Wrote stack traces to '/data/anr/traces.txt'
I/Process ( 111): Sending signal. PID: 230 SIG: 3
I/dalvikvm( 230): threadid=3: reacting to signal 3
I/dalvikvm( 230): Wrote stack traces to '/data/anr/traces.txt'
D/dalvikvm( 111): GC_CONCURRENT freed 864K, 11% free 8469K/9415K, paused 4ms+57ms
D/dalvikvm( 111): GC_EXPLICIT freed 15K, 11% free 8454K/9415K, paused 4ms+14ms
E/ActivityManager( 111): ANR in com.android.camera (com.android.camera/.Camera)
E/ActivityManager( 111): Reason: keyDispatchingTimedOut
E/ActivityManager( 111): Load: 0.83 / 0.44 / 0.18
E/ActivityManager( 111): CPU usage from 5608ms to 0ms ago with 99% awake:
E/ActivityManager( 111): 28% 61/surfaceflinger: 28% user + 0.1% kernel
E/ActivityManager( 111): 2.8% 111/system_server: 0.7% user + 2.1% kernel / faults: 3 minor
E/ActivityManager( 111): 1% 38/kworker/u:1: 0% user + 1% kernel
E/ActivityManager( 111): 88% TOTAL: 84% user + 3.6% kernel + 0.1% iowait
E/ActivityManager( 111): CPU usage from 1181ms to 1740ms later:
E/ActivityManager( 111): 90% 61/surfaceflinger: 90% user + 0% kernel
E/ActivityManager( 111): 90% 97/SurfaceFlinger: 90% user + 0% kernel
E/ActivityManager( 111): 7.4% 111/system_server: 5.5% user + 1.8% kernel / faults: 2 minor
E/ActivityManager( 111): 5.5% 142/InputDispatcher: 3.7% user + 1.8% kernel
E/ActivityManager( 111): 3.7% 115/GC: 3.7% user + 0% kernel
E/ActivityManager( 111): 1.8% 143/InputReader: 1.8% user + 0% kernel
E/ActivityManager( 111): 98% TOTAL: 96% user + 1.7% kernel
D/dalvikvm( 111): GC_FOR_ALLOC freed 227K, 10% free 8527K/9415K, paused 111ms
I/ARMAssembler( 61): generated scanline__00000077:03515102_00000000_00000000 [ 34 ipp] (48 ins) at [0x413ebdc8:0x413ebe88]s
after this trace screen display "camera is not responing"
Can somebody help me!
