Error when installing ADT Plugins on CCSv5
We are trying to install the ADT Plugin to the CCSv5. But it gives the following error:
Cannot complete the install because one or more required items could not be found.
Software being installed: Android Development Tools 21.1.0.v201302060044-569685 (com.android.ide.eclipse.adt.feature.group 21.1.0.v201302060044-569685)
Missing requirement: Android Development Tools 21.1.0.v201302060044-569685 (com.android.ide.eclipse.adt.feature.group 21.1.0.v201302060044-569685) requires 'org.eclipse.wst.xml.core 0.0.0' but it could not be found"
And moreover once we add the site - " http://download.eclipse.org/releases/galileo ". It shows the site is not available.
We have already marked it as Enabled, but still it gives the same error.
Ubuntu release version : 13.04
CCS version                    : 5.3
ADT plugin                       : ADT-21.1.0
Please suggest the resolution.
  • Take a look at this thread:
    http://www.eclipse.org/forums/index.php/m/854123/
    take note the last post which mentions WTP for Eclipse 3.7 Indigo. CCS 5.3 is either based on Eclipse 3.7 or 3.8. I think 3.8, In that case you'd need WTP 3.4
    hope this helps
    ki
    Did you read the CCS Forum Guidelines & FAQ? If not, PLEASE read it. If you haven't read it in awhile, please read it again to see if any updates were made.
    Having CCS problems? Check out the CCS Troubleshooting Guide
    Looking for CCS Training? Check out the CCS Training Site
    Curious about the status of a bug and know the tracking ID? Track it via the public bug tracking portal
  • In reply to Ki-Soo Lee:
    Yes, I downloaded WTP 3.4(wtp4x-R-3.4.2-20130208151217) from the site mentioned and enabled it under "Available Software Sites"
     along with the ADT plugin.  But still I get the same error .
    Software being installed: Android Development Tools 10.0.0.v201102162101-104271 (com.android.ide.eclipse.adt.feature.group 10.0.0.v201102162101-104271)
    Missing requirement: Android Development Tools 10.0.0.v201102162101-104271 (com.android.ide.eclipse.adt.feature.group 10.0.0.v201102162101-104271) requires 'org.eclipse.wst.xml.core 0.0.0' but it could not be found
    Please help
  • In reply to Reshmi Raja:
    This is how I installed ADT 21.1 into my CCSv5.3 installation
    Follow these instructions:
    http://download.eclipse.org/releases/juno/
    Then followed these instructions:
    http://developer.android.com/sdk/index.html#download
    This seemed to work for me.
    ki
    I could still not resolve the ADT dependencies on wst.
    Please tell me if it is dependent on the Ubuntu release version.
    I am using Ubuntu 13.04
    Hi Ki-Soo Lee,
    I have followed the steps mentioned but still not able to successfully install ADT into CCSv5.3
    Please let me know the Ubuntu release version.
    I am using Ubuntu 13 release version and Eclipse 3.8
    The error I  get now is :-
    Software currently installed: JavaScript Development Tools 1.4.0.v201111090639-7H7DFeHFC7sRemSZgYbe4 (org.eclipse.wst.jsdt.feature.feature.group 1.4.0.v201111090639-7H7DFeHFC7sRemSZgYbe4)
    Missing requirement: Eclipse XML Editors and Tools 1.1.2.v201001222130 (org.eclipse.wst.xml.ui 1.1.2.v201001222130) requires 'bundle org.eclipse.wst.sse.ui [1.1.0,1.2.0)' but it could not be found
    Only one of the following can be installed at once:
    Structured Source Editor 1.3.100.v201204260100 (org.eclipse.wst.sse.ui 1.3.100.v201204260100)
    Structured Source Editor 1.2.3.v201102102045 (org.eclipse.wst.sse.ui 1.2.3.v201102102045)
    Cannot satisfy dependency:
    From: Android Development Tools 21.1.0.v201302060044-569685 (com.android.ide.eclipse.adt.feature.group 21.1.0.v201302060044-569685)
    To: org.eclipse.wst.xml.ui 0.0.0
    From: JavaScript Debug UI 1.0.200.v201203071952 (org.eclipse.wst.jsdt.debug.ui 1.0.200.v201203071952)
    To: bundle org.eclipse.wst.sse.ui 1.3.100
    From: JavaScript Development Tools 1.4.0.v201111090639-7H7DFeHFC7sRemSZgYbe4 (org.eclipse.wst.jsdt.feature.feature.group 1.4.0.v201111090639-7H7DFeHFC7sRemSZgYbe4)
    To: org.eclipse.wst.jsdt.debug.ui [1.0.200.v201203071952]
    From: Eclipse XML Editors and Tools 1.1.103.v201101122108 (org.eclipse.wst.xml.ui 1.1.103.v201101122108)
    To: bundle org.eclipse.wst.sse.ui [1.2.0,1.3.0)
     Please help me proceed in the right direction
    Sorry for the delay. i am trying this out on a Ubuntu 13 machine.
    i also found this wiki which covers installing ADT in CCSv5. You way want to check this out also:
    http://processors.wiki.ti.com/index.php/TI-Android-CCSv5SetupGuide
    ki
    Hi ,
    Thank you for the reply.
    I am following the exact CCSv5 Setup Guide from TI, but no luck..
    I am unable to install ADT though,  I could install Android DDMS, Android Heirarchy Viewer and Android Traceview under the Developer Tools.
    Please suggest as to  how  I can overcome this issue.
    Thanks in advance,
    Reshmi
    Hi Reshmi,
    I am going to move this thread to the Android forum. There should me more experience there with people trying to use the ADT plugin with Eclipse/CCS. Hopefully you will find the answers your seek there.
    ki
    A direct link to how to install Android SDK in CCSv5 is in
    http://e2e.ti.com/support/embedded/android/f/509/p/197149/703456.aspx#703456
    Check the last post in previous link about jumping the message that appears when installing CCSv5, it is present only the first time when installing CCSv5, you may need to reinstall it to see the message.
    Other situation could be that Java is not installed but it is required to run Eclipse then it should not be the issue, but check that you installed the correct version either 32bits or 64bits, sometime is required specific version number but downloading latest should be ok. If you are working in Linux machine check that Java SDK dependencies or environment variables  are correctly redirected to Java installation path, check the version of javac from command line to be correct.
    http://e2e.ti.com/support/embedded/android/f/509/p/202090/718395.aspx#718395
    I created next file contains the steps I followed when installing regular Eclipse + Android SDK not using CCSv5 but I already mentioned possible differences and information about it, this file should help you it contain some tips on how to install the plugins, try to follow it in parallel with the link in the first post.
    Please click the Verify Answer button on this post if it answers your question
    _______________________________________________________
    Be sure to read the OMAP4 and OMAP5 Forum Guidelines and FAQ
  • In reply to Manuel Contreras:
    I have re installed the CCSv5.
    Run the ti-sdk-am335x-evm-05.06.00-Linux-x86-Install along with CCSv5. but again could not succeed in installing the ADT plugin for CCSv5.
    Please help where I am going wrong.
    System Details :-
    Ubuntu 13.04
    jdk 1.6.0_35
    ADT 10.0.0
    Work around done are :-
    1. run the checker and installed 32 bit library support ,  Referring http://processors.wiki.ti.com/index.php/Linux_Host_Support
    2. set the environment variables to Java installation path
    The error message I get is as below :-
    "Cannot complete the install because one or more required items could not be found.
    Missing requirement: Android Development Tools 10.0.0.v201102162101-104271 (com.android.ide.eclipse.adt.feature.group 10.0.0.v201102162101-104271) requires 'org.eclipse.jdt 0.0.0' but it could not be found"
