HI all,
Iam working on UVC camera with Android ICS on Beagle board xM REV-c . I have enabled the default drivers for USB camera.But while booting but my device is not detecting as a camera.
please help me.It will appreciated.
usb 1-2.5: SerialNumber: E1919800
uvcvideo: Found UVC 1.00 device <unnamed> (046d:0825)
input: UVC Camera (046d:0825) as /devices/platform/ehci-omap.0/usb1/1-2/1-2.5/1-2.5:1.0/inp2
4:3:3: cannot get freq at ep 0x86
ehci-omap ehci-omap.0: remove, state 1
usb usb1: USB disconnect, address 1
usb 1-2: USB disconnect, address 2
4:3:4: cannot set freq 48000 to ep 0x86
usb 1-2.1: USB disconnect, address 3
smsc95xx 1-2.1:1.0: usb0: unregister 'smsc95xx' usb-ehci-omap.0-2.1, smsc95xx USB 2.0 Ethert
usb 1-2.5: USB disconnect, address 4
EXT3-fs: barriers not enabled
ehci-omap ehci-omap.0: USB bus 1 deregistered
ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
ehci-omap.0 supply hsusb0 not found, using dummy regulator
ehci-omap.0 supply hsusb1 not found, using dummy regulator
ehci-omap ehci-omap.0: OMAP-EHCI Host Controller
ehci-omap ehci-omap.0: new USB bus registered, assigned bus number 1
ehci-omap ehci-omap.0: irq 77, io mem 0x48064800
ehci-omap ehci-omap.0: USB 2.0 started, EHCI 1.00
usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
usb usb1: Product: OMAP-EHCI Host Controller
usb usb1: Manufacturer: Linux 2.6.37-g06ebbba ehci_hcd
usb usb1: SerialNumber: ehci-omap.0
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 3 ports detected
kjournald starting. Commit interval 5 seconds
EXT3-fs (mmcblk0p2): using internal journal
EXT3-fs (mmcblk0p2): recovery complete
EXT3-fs (mmcblk0p2): mounted filesystem with ordered data mode
VFS: Mounted root (ext3 filesystem) on device 179:2.
Freeing init memory: 204K
init (1): /proc/1/oom_adj is deprecated, please use /proc/1/oom_score_adj instead.
init: cannot open '/initlogo.rle'
init: cannot find '/system/bin/sgx/rc.pvr', disabling 'pvr'
init: cannot find '/system/etc/install-recovery.sh', disabling 'flash_recovery'
enabling adb
adb_open
Ranjith
