I've already configured Linux-3.2.0 framebuffer for 320x240 TFT LCD in 16bits RGB mode, and the framebuffer works
properly.
For the Linux-3.8.13 I've used follow DTS file but it doesn't work:
BB-BONE-ILI9341-00A0.dts
/* * Copyright (C) 2012 Texas Instruments Incorporated - http://www.ti.com/ * * This program is free software; you can redistribute it and/or modify * it under the terms of the GNU General Public License version 2 as * published by the Free Software Foundation. */ /dts-v1/; /plugin/; / { compatible = "ti,beaglebone", "ti,beaglebone-black"; /* identification */ part-number = "BB-BONE-ILI9341"; version = "00A0"; /* state the resources this cape uses */ exclusive-use = /* the pin header uses */ "P8.45", /* lcd: lcd_data0 */ "P8.46", /* lcd: lcd_data1 */ "P8.43", /* lcd: lcd_data2 */ "P8.44", /* lcd: lcd_data3 */ "P8.41", /* lcd: lcd_data4 */ "P8.42", /* lcd: lcd_data5 */ "P8.39", /* lcd: lcd_data6 */ "P8.40", /* lcd: lcd_data7 */ "P8.37", /* lcd: lcd_data8 */ "P8.38", /* lcd: lcd_data9 */ "P8.36", /* lcd: lcd_data10 */ "P8.34", /* lcd: lcd_data11 */ "P8.35", /* lcd: lcd_data12 */ "P8.33", /* lcd: lcd_data13 */ "P8.31", /* lcd: lcd_data14 */ "P8.32", /* lcd: lcd_data15 */ "P8.27", /* lcd: lcd_vsync */ "P8.29", /* lcd: lcd_hsync */ "P8.28", /* lcd: lcd_pclk */ "P8.30", /* lcd: lcd_ac_bias_en */ "P9.16", /* tsc: gpio1_19 */ "P9.14", /* led: gpio1_18 */ /* the hardware IP uses */ "gpio1_19", "gpio1_18", "lcd", "tps-bl"; fragment@0 { target = <&am33xx_pinmux>; __overlay__ { bone_lcd4_cape_led_00A0_pins: pinmux_bone_lcd4_cape_led_00A0_pins { pinctrl-single,pins = < 0x48 0x07 /* gpmc_a2.gpio1_18, OUTPUT | MODE7 */ >; }; bone_lcd4_cape_lcd_pins: pinmux_bone_lcd4_cape_lcd_pins { pinctrl-single,pins = < 0xa0 0x08 /* lcd_data0.lcd_data0, OMAP_MUX_MODE0 | AM33XX_PIN_OUTPUT | AM33XX_PULL_DISA */ 0xa4 0x08 /* lcd_data1.lcd_data1, OMAP_MUX_MODE0 | AM33XX_PIN_OUTPUT | AM33XX_PULL_DISA */ 0xa8 0x08 /* lcd_data2.lcd_data2, OMAP_MUX_MODE0 | AM33XX_PIN_OUTPUT | AM33XX_PULL_DISA */ 0xac 0x08 /* lcd_data3.lcd_data3, OMAP_MUX_MODE0 | AM33XX_PIN_OUTPUT | AM33XX_PULL_DISA */ 0xb0 0x08 /* lcd_data4.lcd_data4, OMAP_MUX_MODE0 | AM33XX_PIN_OUTPUT | AM33XX_PULL_DISA */ 0xb4 0x08 /* lcd_data5.lcd_data5, OMAP_MUX_MODE0 | AM33XX_PIN_OUTPUT | AM33XX_PULL_DISA */ 0xb8 0x08 /* lcd_data6.lcd_data6, OMAP_MUX_MODE0 | AM33XX_PIN_OUTPUT | AM33XX_PULL_DISA */ 0xbc 0x08 /* lcd_data7.lcd_data7, OMAP_MUX_MODE0 | AM33XX_PIN_OUTPUT | AM33XX_PULL_DISA */ 0xc0 0x08 /* lcd_data8.lcd_data8, OMAP_MUX_MODE0 | AM33XX_PIN_OUTPUT | AM33XX_PULL_DISA */ 0xc4 0x08 /* lcd_data9.lcd_data9, OMAP_MUX_MODE0 | AM33XX_PIN_OUTPUT | AM33XX_PULL_DISA */ 0xc8 0x08 /* lcd_data10.lcd_data10, OMAP_MUX_MODE0 | AM33XX_PIN_OUTPUT | AM33XX_PULL_DISA */ 0xcc 0x08 /* lcd_data11.lcd_data11, OMAP_MUX_MODE0 | AM33XX_PIN_OUTPUT | AM33XX_PULL_DISA */ 0xd0 0x08 /* lcd_data12.lcd_data12, OMAP_MUX_MODE0 | AM33XX_PIN_OUTPUT | AM33XX_PULL_DISA */ 0xd4 0x08 /* lcd_data13.lcd_data13, OMAP_MUX_MODE0 | AM33XX_PIN_OUTPUT | AM33XX_PULL_DISA */ 0xd8 0x08 /* lcd_data14.lcd_data14, OMAP_MUX_MODE0 | AM33XX_PIN_OUTPUT | AM33XX_PULL_DISA */ 0xdc 0x08 /* lcd_data15.lcd_data15, OMAP_MUX_MODE0 | AM33XX_PIN_OUTPUT | AM33XX_PULL_DISA */ 0xe0 0x00 /* lcd_vsync.lcd_vsync, OMAP_MUX_MODE0 | AM33XX_PIN_OUTPUT */ 0xe4 0x00 /* lcd_hsync.lcd_hsync, OMAP_MUX_MODE0 | AM33XX_PIN_OUTPUT */ 0xe8 0x00 /* lcd_pclk.lcd_pclk, OMAP_MUX_MODE0 | AM33XX_PIN_OUTPUT */ 0xec 0x00 /* lcd_ac_bias_en.lcd_ac_bias_en, OMAP_MUX_MODE0 | AM33XX_PIN_OUTPUT */ 0x4c 0x27 /* TSC_INT gpmc_a3.gpio1_19, INPUT | MODE7 */ >; }; }; }; fragment@1 { target = <&tps>; __overlay__ { backlight { compatible = "not-tps65217-backlight"; isel = <1>; fdim = <200>; brightness = <100>; tps = <&tps>; }; }; }; fragment@2 { target = <&ocp>; __overlay__ { /* avoid stupid warning */ #address-cells = <1>; #size-cells = <1>; tscadc { compatible = "ti,ti-tscadc"; reg = <0x44e0d000 0x1000>; interrupt-parent = <&intc>; interrupts = <16>; ti,hwmods = "adc_tsc"; status = "okay"; tsc { ti,wires = <4>; ti,x-plate-resistance = <200>; ti,coordinate-readouts = <5>; ti,wire-config = <0x00 0x11 0x22 0x33>; }; adc { ti,adc-channels = <4 5 6 7>; }; }; gpio-leds-cape-lcd4 { compatible = "gpio-leds"; pinctrl-names = "default"; pinctrl-0 = <&bone_lcd4_cape_led_00A0_pins>; lcd4-led0 { label = "lcd4:green:usr0"; gpios = <&gpio2 18 0>; linux,default-trigger = "heartbeat"; default-state = "off"; }; }; /* Settings for ILI9341 cape: */ panel { compatible = "tilcdc,panel"; pinctrl-names = "default"; pinctrl-0 = <&bone_lcd4_cape_lcd_pins>; panel-info { ac-bias = <255>; ac-bias-intrpt = <0>; dma-burst-sz = <16>; bpp = <16>; fdd = <0x80>; tft-alt-mode = <0>; stn-565-mode = <0>; mono-8bit-mode = <0>; sync-edge = <0>; sync-ctrl = <1>; raster-order = <0>; fifo-th = <0>; }; display-timings { native-mode = <&timing0>; timing0: 320x240 { hactive = <320>; vactive = <240>; hback-porch = <21>; hfront-porch = <58>; hsync-len = <47>; vback-porch = <11>; vfront-porch = <23>; vsync-len = <2>; clock-frequency = <8000000>; hsync-active = <0>; vsync-active = <0>; }; }; }; fb { compatible = "ti,am33xx-tilcdc"; reg = <0x4830e000 0x1000>; interrupt-parent = <&intc>; interrupts = <36>; ti,hwmods = "lcdc"; }; }; }; };
I'm not familiar with DTS file, after insert overlay I got the error message :
root@android:/ # echo BB-BONE-ILI9341 > /sys/devices/bone_capemgr.*/slots [ 701.652683] bone-capemgr bone_capemgr.9: part_number 'BB-BONE-ILI9341', version 'N/A' [ 701.661054] bone-capemgr bone_capemgr.9: slot #7: generic override [ 701.667552] bone-capemgr bone_capemgr.9: bone: Using override eeprom data at slot 7 [ 701.675558] bone-capemgr bone_capemgr.9: slot #7: 'Override Board Name,00A0,Override Manuf,BB-BONE-ILI9341' [ 701.685842] bone-capemgr bone_capemgr.9: slot #7: Requesting part number/version based 'BB-BONE-ILI9341-00A0.dtbo [ 701.696577] bone-capemgr bone_capemgr.9: slot #7: Requesting firmware 'BB-BONE-ILI9341-00A0.dtbo' for board-name 'Override Board Name', version '00A0' [ 701.710656] bone-capemgr bone_capemgr.9: slot #7: dtbo 'BB-BONE-ILI9341-00A0.dtbo' loaded; converting to live tree [ 701.722039] bone-capemgr bone_capemgr.9: slot #7: #3 overlays [ 701.732082] input: ti-tsc as /devices/ocp.3/44e0d000.tscadc/tsc/input/input1 [ 701.743495] panel panel.14: panel: No power control GPIO [ 701.749372] platform 4830e000.fb: alias fck already exists [ 701.757166] tilcdc 4830e000.fb: No power control GPIO [ 701.763113] [drm] Supports vblank timestamp caching Rev 1 (10.10.2010). [ 701.770075] [drm] No driver support for vblank timestamp query. [ 701.777617] ------------[ cut here ]------------ [ 701.777643] WARNING: at drivers/gpu/drm/tilcdc/tilcdc_crtc.c:248 tilcdc_crtc_mode_set+0x53b/0x554() [ 701.777650] Modules linked in: [ 701.777678] [<c001125d>] (unwind_backtrace+0x1/0x98) from [<c002edb3>] (warn_slowpath_common+0x33/0x48) [ 701.777689] [<c002edb3>] (warn_slowpath_common+0x33/0x48) from [<c002edd9>] (warn_slowpath_null+0x11/0x14) [ 701.777699] [<c002edd9>] (warn_slowpath_null+0x11/0x14) from [<c029f69f>] (tilcdc_crtc_mode_set+0x53b/0x554) [ 701.777720] [<c029f69f>] (tilcdc_crtc_mode_set+0x53b/0x554) from [<c028d423>] (drm_crtc_helper_set_mode+0x14f/0x258) [ 701.777732] [<c028d423>] (drm_crtc_helper_set_mode+0x14f/0x258) from [<c028dc15>] (drm_crtc_helper_set_config+0x615/0x6c4) [ 701.777744] [<c028dc15>] (drm_crtc_helper_set_config+0x615/0x6c4) from [<c028ca03>] (drm_fb_helper_set_par+0x3b/0x80) [ 701.777759] [<c028ca03>] (drm_fb_helper_set_par+0x3b/0x80) from [<c0259465>] (fbcon_init+0x365/0x3a4) [ 701.777780] [<c0259465>] (fbcon_init+0x365/0x3a4) from [<c027b4f3>] (visual_init+0x6f/0xb4) [ 701.777794] [<c027b4f3>] (visual_init+0x6f/0xb4) from [<c027cbf7>] (do_bind_con_driver+0xdb/0x254) [ 701.777807] [<c027cbf7>] (do_bind_con_driver+0xdb/0x254) from [<c027cdc5>] (do_take_over_console+0x25/0x28) [ 701.777817] [<c027cdc5>] (do_take_over_console+0x25/0x28) from [<c02594d9>] (do_fbcon_takeover+0x35/0x80) [ 701.777833] [<c02594d9>] (do_fbcon_takeover+0x35/0x80) from [<c04949bb>] (notifier_call_chain+0x3f/0x50) [ 701.777855] [<c04949bb>] (notifier_call_chain+0x3f/0x50) from [<c00488ed>] (__blocking_notifier_call_chain+0x29/0x38) [ 701.777868] [<c00488ed>] (__blocking_notifier_call_chain+0x29/0x38) from [<c004890d>] (blocking_notifier_call_chain+0x11/0x14) [ 701.777890] [<c004890d>] (blocking_notifier_call_chain+0x11/0x14) from [<c02539c7>] (register_framebuffer+0xff/0x1b0) [ 701.777903] [<c02539c7>] (register_framebuffer+0xff/0x1b0) from [<c028cb2b>] (drm_fb_helper_single_fb_probe+0xe3/0x220) [ 701.777915] [<c028cb2b>] (drm_fb_helper_single_fb_probe+0xe3/0x220) from [<c028cdf3>] (drm_fb_helper_initial_config+0xf7/0x160) [ 701.777927] [<c028cdf3>] (drm_fb_helper_initial_config+0xf7/0x160) from [<c028e44f>] (drm_fbdev_cma_init+0x4b/0xa4) [ 701.777944] [<c028e44f>] (drm_fbdev_cma_init+0x4b/0xa4) from [<c02a0ff9>] (tilcdc_load+0x321/0x464) [ 701.778037] [<c02a0ff9>] (tilcdc_load+0x321/0x464) from [<c0295377>] (drm_get_platform_dev+0xa7/0x150) [ 701.778057] [<c0295377>] (drm_get_platform_dev+0xa7/0x150) from [<c02a5ab9>] (platform_drv_probe+0xd/0x10) [ 701.778070] [<c02a5ab9>] (platform_drv_probe+0xd/0x10) from [<c02a4f65>] (driver_probe_device+0x4d/0x168) [ 701.778081] [<c02a4f65>] (driver_probe_device+0x4d/0x168) from [<c02a3fcb>] (bus_for_each_drv+0x23/0x4c) [ 701.778091] [<c02a3fcb>] (bus_for_each_drv+0x23/0x4c) from [<c02a4eef>] (device_attach+0x47/0x58) [ 701.778101] [<c02a4eef>] (device_attach+0x47/0x58) from [<c02a48e3>] (bus_probe_device+0x57/0x70) [ 701.778110] [<c02a48e3>] (bus_probe_device+0x57/0x70) from [<c02a3a95>] (device_add+0x375/0x3e0) [ 701.778133] [<c02a3a95>] (device_add+0x375/0x3e0) from [<c03a073f>] (of_platform_device_create_pdata+0x37/0x50) [ 701.778148] [<c03a073f>] (of_platform_device_create_pdata+0x37/0x50) from [<c03a17ef>] (of_overlay_device_entry_change.isra.0+0x67/0xd0) [ 701.778158] [<c03a17ef>] (of_overlay_device_entry_change.isra.0+0x67/0xd0) from [<c03a1a59>] (of_overlay+0x6d/0x144) [ 701.778180] [<c03a1a59>] (of_overlay+0x6d/0x144) from [<c02b5743>] (bone_capemgr_load+0x307/0x45c) [ 701.778194] [<c02b5743>] (bone_capemgr_load+0x307/0x45c) from [<c02b6405>] (slots_store+0x191/0x29c) [ 701.778207] [<c02b6405>] (slots_store+0x191/0x29c) from [<c02a29f3>] (dev_attr_store+0xb/0x14) [ 701.778225] [<c02a29f3>] (dev_attr_store+0xb/0x14) from [<c00fb0b9>] (sysfs_write_file+0xe5/0x10c) [ 701.778244] [<c00fb0b9>] (sysfs_write_file+0xe5/0x10c) from [<c00b9b57>] (vfs_write+0x5f/0xf8) [ 701.778256] [<c00b9b57>] (vfs_write+0x5f/0xf8) from [<c00b9d5d>] (sys_write+0x29/0x4c) [ 701.778272] [<c00b9d5d>] (sys_write+0x29/0x4c) from [<c000c741>] (ret_fast_syscall+0x1/0x46) [ 701.778277] ---[ end trace 81e72b18dc850117 ]--- [ 701.778294] [drm:drm_crtc_helper_set_config] *ERROR* failed to set mode on [CRTC:3] [ 701.778307] fbcon_init: detected unhandled fb_set_par error, error code -22 [ 701.778394] ------------[ cut here ]------------ [ 701.778405] WARNING: at drivers/gpu/drm/tilcdc/tilcdc_crtc.c:248 tilcdc_crtc_mode_set+0x53b/0x554() [ 701.778410] Modules linked in: [ 701.778425] [<c001125d>] (unwind_backtrace+0x1/0x98) from [<c002edb3>] (warn_slowpath_common+0x33/0x48) [ 701.778435] [<c002edb3>] (warn_slowpath_common+0x33/0x48) from [<c002edd9>] (warn_slowpath_null+0x11/0x14) [ 701.778445] [<c002edd9>] (warn_slowpath_null+0x11/0x14) from [<c029f69f>] (tilcdc_crtc_mode_set+0x53b/0x554) [ 701.778458] [<c029f69f>] (tilcdc_crtc_mode_set+0x53b/0x554) from [<c028d423>] (drm_crtc_helper_set_mode+0x14f/0x258) [ 701.778470] [<c028d423>] (drm_crtc_helper_set_mode+0x14f/0x258) from [<c028dc15>] (drm_crtc_helper_set_config+0x615/0x6c4) [ 701.778482] [<c028dc15>] (drm_crtc_helper_set_config+0x615/0x6c4) from [<c028bd7d>] (drm_fb_helper_pan_display+0x4d/0x74) [ 701.778495] [<c028bd7d>] (drm_fb_helper_pan_display+0x4d/0x74) from [<c0252a07>] (fb_pan_display+0x77/0xc0) [ 701.778508] [<c0252a07>] (fb_pan_display+0x77/0xc0) from [<c025be35>] (bit_update_start+0x11/0x24) [ 701.778519] [<c025be35>] (bit_update_start+0x11/0x24) from [<c025a30f>] (fbcon_switch+0x1e7/0x35c) [ 701.778530] [<c025a30f>] (fbcon_switch+0x1e7/0x35c) from [<c027c68d>] (redraw_screen+0xc5/0x164) [ 701.778541] [<c027c68d>] (redraw_screen+0xc5/0x164) from [<c02590a1>] (fbcon_prepare_logo+0x241/0x2a0) [ 701.778550] [<c02590a1>] (fbcon_prepare_logo+0x241/0x2a0) from [<c025934f>] (fbcon_init+0x24f/0x3a4) [ 701.778560] [<c025934f>] (fbcon_init+0x24f/0x3a4) from [<c027b4f3>] (visual_init+0x6f/0xb4) [ 701.778571] [<c027b4f3>] (visual_init+0x6f/0xb4) from [<c027cbf7>] (do_bind_con_driver+0xdb/0x254) [ 701.778583] [<c027cbf7>] (do_bind_con_driver+0xdb/0x254) from [<c027cdc5>] (do_take_over_console+0x25/0x28) [ 701.778593] [<c027cdc5>] (do_take_over_console+0x25/0x28) from [<c02594d9>] (do_fbcon_takeover+0x35/0x80) [ 701.778605] [<c02594d9>] (do_fbcon_takeover+0x35/0x80) from [<c04949bb>] (notifier_call_chain+0x3f/0x50) [ 701.778619] [<c04949bb>] (notifier_call_chain+0x3f/0x50) from [<c00488ed>] (__blocking_notifier_call_chain+0x29/0x38) [ 701.778630] [<c00488ed>] (__blocking_notifier_call_chain+0x29/0x38) from [<c004890d>] (blocking_notifier_call_chain+0x11/0x14) [ 701.778642] [<c004890d>] (blocking_notifier_call_chain+0x11/0x14) from [<c02539c7>] (register_framebuffer+0xff/0x1b0) [ 701.778655] [<c02539c7>] (register_framebuffer+0xff/0x1b0) from [<c028cb2b>] (drm_fb_helper_single_fb_probe+0xe3/0x220) [ 701.778667] [<c028cb2b>] (drm_fb_helper_single_fb_probe+0xe3/0x220) from [<c028cdf3>] (drm_fb_helper_initial_config+0xf7/0x160) [ 701.778679] [<c028cdf3>] (drm_fb_helper_initial_config+0xf7/0x160) from [<c028e44f>] (drm_fbdev_cma_init+0x4b/0xa4) [ 701.778691] [<c028e44f>] (drm_fbdev_cma_init+0x4b/0xa4) from [<c02a0ff9>] (tilcdc_load+0x321/0x464) [ 701.778702] [<c02a0ff9>] (tilcdc_load+0x321/0x464) from [<c0295377>] (drm_get_platform_dev+0xa7/0x150) [ 701.778714] [<c0295377>] (drm_get_platform_dev+0xa7/0x150) from [<c02a5ab9>] (platform_drv_probe+0xd/0x10) [ 701.778725] [<c02a5ab9>] (platform_drv_probe+0xd/0x10) from [<c02a4f65>] (driver_probe_device+0x4d/0x168) [ 701.778734] [<c02a4f65>] (driver_probe_device+0x4d/0x168) from [<c02a3fcb>] (bus_for_each_drv+0x23/0x4c) [ 701.778744] [<c02a3fcb>] (bus_for_each_drv+0x23/0x4c) from [<c02a4eef>] (device_attach+0x47/0x58) [ 701.778753] [<c02a4eef>] (device_attach+0x47/0x58) from [<c02a48e3>] (bus_probe_device+0x57/0x70) [ 701.778762] [<c02a48e3>] (bus_probe_device+0x57/0x70) from [<c02a3a95>] (device_add+0x375/0x3e0) [ 701.778775] [<c02a3a95>] (device_add+0x375/0x3e0) from [<c03a073f>] (of_platform_device_create_pdata+0x37/0x50) [ 701.778787] [<c03a073f>] (of_platform_device_create_pdata+0x37/0x50) from [<c03a17ef>] (of_overlay_device_entry_change.isra.0+0x67/0xd0) [ 701.778797] [<c03a17ef>] (of_overlay_device_entry_change.isra.0+0x67/0xd0) from [<c03a1a59>] (of_overlay+0x6d/0x144) [ 701.778811] [<c03a1a59>] (of_overlay+0x6d/0x144) from [<c02b5743>] (bone_capemgr_load+0x307/0x45c) [ 701.778821] [<c02b5743>] (bone_capemgr_load+0x307/0x45c) from [<c02b6405>] (slots_store+0x191/0x29c) [ 701.778832] [<c02b6405>] (slots_store+0x191/0x29c) from [<c02a29f3>] (dev_attr_store+0xb/0x14) [ 701.778844] [<c02a29f3>] (dev_attr_store+0xb/0x14) from [<c00fb0b9>] (sysfs_write_file+0xe5/0x10c) [ 701.778856] [<c00fb0b9>] (sysfs_write_file+0xe5/0x10c) from [<c00b9b57>] (vfs_write+0x5f/0xf8) [ 701.778866] [<c00b9b57>] (vfs_write+0x5f/0xf8) from [<c00b9d5d>] (sys_write+0x29/0x4c) [ 701.778876] [<c00b9d5d>] (sys_write+0x29/0x4c) from [<c000c741>] (ret_fast_syscall+0x1/0x46) [ 701.778880] ---[ end trace 81e72b18dc850118 ]--- [ 701.778889] [drm:drm_crtc_helper_set_config] *ERROR* failed to set mode on [CRTC:3] [ 701.780054] Console: switching to colour frame buffer device 80x40 [ 701.780093] ------------[ cut here ]------------ [ 701.780107] WARNING: at drivers/gpu/drm/tilcdc/tilcdc_crtc.c:248 tilcdc_crtc_mode_set+0x53b/0x554() [ 701.780111] Modules linked in: [ 701.780125] [<c001125d>] (unwind_backtrace+0x1/0x98) from [<c002edb3>] (warn_slowpath_common+0x33/0x48) [ 701.780135] [<c002edb3>] (warn_slowpath_common+0x33/0x48) from [<c002edd9>] (warn_slowpath_null+0x11/0x14) [ 701.780144] [<c002edd9>] (warn_slowpath_null+0x11/0x14) from [<c029f69f>] (tilcdc_crtc_mode_set+0x53b/0x554) [ 701.780157] [<c029f69f>] (tilcdc_crtc_mode_set+0x53b/0x554) from [<c028d423>] (drm_crtc_helper_set_mode+0x14f/0x258) [ 701.780169] [<c028d423>] (drm_crtc_helper_set_mode+0x14f/0x258) from [<c028dc15>] (drm_crtc_helper_set_config+0x615/0x6c4) [ 701.780180] [<c028dc15>] (drm_crtc_helper_set_config+0x615/0x6c4) from [<c028bd7d>] (drm_fb_helper_pan_display+0x4d/0x74) [ 701.780193] [<c028bd7d>] (drm_fb_helper_pan_display+0x4d/0x74) from [<c0252a07>] (fb_pan_display+0x77/0xc0) [ 701.780205] [<c0252a07>] (fb_pan_display+0x77/0xc0) from [<c025be35>] (bit_update_start+0x11/0x24) [ 701.780215] [<c025be35>] (bit_update_start+0x11/0x24) from [<c025a30f>] (fbcon_switch+0x1e7/0x35c) [ 701.780226] [<c025a30f>] (fbcon_switch+0x1e7/0x35c) from [<c027c68d>] (redraw_screen+0xc5/0x164) [ 701.780238] [<c027c68d>] (redraw_screen+0xc5/0x164) from [<c027cd29>] (do_bind_con_driver+0x20d/0x254) [ 701.780249] [<c027cd29>] (do_bind_con_driver+0x20d/0x254) from [<c027cdc5>] (do_take_over_console+0x25/0x28) [ 701.780260] [<c027cdc5>] (do_take_over_console+0x25/0x28) from [<c02594d9>] (do_fbcon_takeover+0x35/0x80) [ 701.780271] [<c02594d9>] (do_fbcon_takeover+0x35/0x80) from [<c04949bb>] (notifier_call_chain+0x3f/0x50) [ 701.780284] [<c04949bb>] (notifier_call_chain+0x3f/0x50) from [<c00488ed>] (__blocking_notifier_call_chain+0x29/0x38) [ 701.780296] [<c00488ed>] (__blocking_notifier_call_chain+0x29/0x38) from [<c004890d>] (blocking_notifier_call_chain+0x11/0x14) [ 701.780308] [<c004890d>] (blocking_notifier_call_chain+0x11/0x14) from [<c02539c7>] (register_framebuffer+0xff/0x1b0) [ 701.780321] [<c02539c7>] (register_framebuffer+0xff/0x1b0) from [<c028cb2b>] (drm_fb_helper_single_fb_probe+0xe3/0x220) [ 701.780332] [<c028cb2b>] (drm_fb_helper_single_fb_probe+0xe3/0x220) from [<c028cdf3>] (drm_fb_helper_initial_config+0xf7/0x160) [ 701.780343] [<c028cdf3>] (drm_fb_helper_initial_config+0xf7/0x160) from [<c028e44f>] (drm_fbdev_cma_init+0x4b/0xa4) [ 701.780355] [<c028e44f>] (drm_fbdev_cma_init+0x4b/0xa4) from [<c02a0ff9>] (tilcdc_load+0x321/0x464) [ 701.780366] [<c02a0ff9>] (tilcdc_load+0x321/0x464) from [<c0295377>] (drm_get_platform_dev+0xa7/0x150) [ 701.780378] [<c0295377>] (drm_get_platform_dev+0xa7/0x150) from [<c02a5ab9>] (platform_drv_probe+0xd/0x10) [ 701.780389] [<c02a5ab9>] (platform_drv_probe+0xd/0x10) from [<c02a4f65>] (driver_probe_device+0x4d/0x168) [ 701.780399] [<c02a4f65>] (driver_probe_device+0x4d/0x168) from [<c02a3fcb>] (bus_for_each_drv+0x23/0x4c) [ 701.780408] [<c02a3fcb>] (bus_for_each_drv+0x23/0x4c) from [<c02a4eef>] (device_attach+0x47/0x58) [ 701.780418] [<c02a4eef>] (device_attach+0x47/0x58) from [<c02a48e3>] (bus_probe_device+0x57/0x70) [ 701.780427] [<c02a48e3>] (bus_probe_device+0x57/0x70) from [<c02a3a95>] (device_add+0x375/0x3e0) [ 701.780439] [<c02a3a95>] (device_add+0x375/0x3e0) from [<c03a073f>] (of_platform_device_create_pdata+0x37/0x50) [ 701.780451] [<c03a073f>] (of_platform_device_create_pdata+0x37/0x50) from [<c03a17ef>] (of_overlay_device_entry_change.isra.0+0x67/0xd0) [ 701.780460] [<c03a17ef>] (of_overlay_device_entry_change.isra.0+0x67/0xd0) from [<c03a1a59>] (of_overlay+0x6d/0x144) [ 701.780475] [<c03a1a59>] (of_overlay+0x6d/0x144) from [<c02b5743>] (bone_capemgr_load+0x307/0x45c) [ 701.780486] [<c02b5743>] (bone_capemgr_load+0x307/0x45c) from [<c02b6405>] (slots_store+0x191/0x29c) [ 701.780496] [<c02b6405>] (slots_store+0x191/0x29c) from [<c02a29f3>] (dev_attr_store+0xb/0x14) [ 701.780508] [<c02a29f3>] (dev_attr_store+0xb/0x14) from [<c00fb0b9>] (sysfs_write_file+0xe5/0x10c) [ 701.780520] [<c00fb0b9>] (sysfs_write_file+0xe5/0x10c) from [<c00b9b57>] (vfs_write+0x5f/0xf8) [ 701.780530] [<c00b9b57>] (vfs_write+0x5f/0xf8) from [<c00b9d5d>] (sys_write+0x29/0x4c) [ 701.780541] [<c00b9d5d>] (sys_write+0x29/0x4c) from [<c000c741>] (ret_fast_syscall+0x1/0x46) [ 701.780545] ---[ end trace 81e72b18dc850119 ]--- [ 701.780554] [drm:drm_crtc_helper_set_config] *ERROR* failed to set mode on [CRTC:3] [ 703.047317] tilcdc 4830e000.fb: fb0: frame buffer device [ 703.052968] tilcdc 4830e000.fb: registered panic notifier [ 703.058950] [drm] Initialized tilcdc 1.0.0 20121205 on minor 0 [ 703.065157] bone-capemgr bone_capemgr.9: slot #7: Applied #3 overlays.
Please show me how to configure 320x240 TFT LCD in Linux-3.8.13 ? For the AM3352 should we use da8xx-fb or ticdc ? Are there any reference DTS files ?
