Hello
We have custom ANDROID device of AM335x. Its have SD card. Currently i'm having problem with booting due corrupted OS. I need to flash my OS into Memory Card.
Advice me how do flash the OS in Memory Card and bootable option as well?
Hello
Hi Anthony,
flashing the android BSP is described in this document: processors.wiki.ti.com/.../TI-Android-JB-4.2.2-DevKit-4.1.1_UserGuide
Basically, you should use the provide script to:
- partition the SD Card
- format it properly
- copy files to it at the right location
The mkmmc script is available in the TI Android BSP: external/ti_android_utilities/am335x/mk-mmc/mkmmc-android.sh
If no parameter is used, it expects all files to be flashed to be located in a folder named Boot_Images/ in the current path.
- Required files are: MLO, u-boot.img, uImage, uEnv.txt, rootfs.tar.bz2
- Optional files are: Media_Clips, START_HERE folder
