• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Embedded Software » BIOS » BIOS forum » Conflicting libraries when upgrading ccv3.2 to ccv5
Share
BIOS
  • Forum
  • Announcements
Options
  • Subscribe via RSS
This question is answered
Bryan Hehn
Posted by Bryan Hehn
on Apr 12 2012 08:40 AM
Intellectual410 points
I am trying to upgrade ccsv3.2 to ccvv5 and have had many problems.  The latest is this.
I get these errors when building:
 error #10056: symbol "_MDIO_timerTick" redefined: first defined in
.../Src/TiLteLib/cixcvrProductEC/LTE/lib/csl_3x_C6482_v3_00_10_01/csl_c6482.lib<csl_mdio.o>";
redefined in
.../Src/Ti/ndk/lib/hal/dsk6455/hal_eth_c6455.lib<c6455_mdio.o64P>"
 and about 8 more MDIO related errors.
How do I fix this problem??  I need both of these libraries.
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Steven Connell
    Posted by Steven Connell
    on Apr 12 2012 18:56 PM
    Mastermind20540 points
    Hi Bryan Hehn,
    The C6455 Ethernet driver has its own copy of the file csl_mdio.c (which contains the definition of the function MDIO_timerTick).
    It looks like the CSL library you are also using does as well.
    I'm not how this worked before your upgrade attempt, as this conflict exists independently of CCSv3 vs CCSv5.
    Are you using NDK 2.0?  Do you have the driver sources for the C6455?
    You could rebuild the 6455 Ethernet driver to *exclude* the MDIO_timerTick from the csl_mdio.c (assuming that the function MDIO_timerTick in the Ethernet driver is equivalent to the one in the CSL library ...) and just rely on the one that exists in the CSL library.
    Steve
    Report Abuse
    • Reply
  • Bryan Hehn
    on Apr 13 2012 10:17 AM
    This is the version of ndk taken from an include file:
    *  @(#) TCP/IP_Network_Developers_Kit 1.92.00.22 01-10-2007 (ndk-b22)
    how could I rebuild the library without the mdio?
    Also FYI we are using a c6482.
    Report Abuse
    • Reply
  • Steven Connell
    on Apr 13 2012 15:11 PM
    Ok, you are using a version of NDK that did not ship with sources.  So, my idea to rebuild the driver without MDIO would not work for the version that you have.
    One option is for you to download the NDK 2.00 which does have the driver sources.
    But, I'm still curious about how your original application built.
    Can you attach the original CCSv3 project file?
    Steve
    Report Abuse
    • Reply
  • Bryan Hehn
    on Apr 16 2012 08:36 AM
    Here is my ccv3.2 pjt:
    ; Code Composer Project File, Version 2.0 (do not modify or remove this line)
    [Project Settings]
    ProjectDir="C:\lteStuff\Archive\2011_12_13_faa_drop\Lte\Build\"
    ProjectType=Executable
    CPUFamily=TMS320C64XX
    Tool="Compiler"
    Tool="CustomBuilder"
    Tool="DspBiosBuilder"
    Tool="Linker"
    Config="DSK6482"
    Config="Stingray3"
    [Source Files]
    Source="..\Src\Control\main.cpp"
    Source="..\Src\Control\MsgFilter.cpp"
    Source="..\Src\Control\SystemEventManager.cpp"
    Source="..\Src\DSKTest\CommandControlPort.cpp"
    Source="..\Src\DSKTest\DiagnosticConsole.c"
    Source="..\Src\DSKTest\dsk6455_junk.c"
    Source="..\Src\DSKTest\Ethernet.cpp"
    Source="..\Src\DSKTest\Hpi2Tcp.cpp"
    Source="..\Src\Hardware\Ad5641.cpp"
    Source="..\Src\Hardware\Ad7991.cpp"
    Source="..\Src\Hardware\C64xDma.cpp"
    Source="..\Src\Hardware\C64xEmif.cpp"
    Source="..\Src\Hardware\C64xGpio.cpp"
    Source="..\Src\Hardware\C64xI2C.cpp"
    Source="..\Src\Hardware\C64xMcBsp.cpp"
    Source="..\Src\Hardware\C64xMcBsp0.cpp"
    Source="..\Src\Hardware\C64xMcBsp1.cpp"
    Source="..\Src\Hardware\C64xPll.cpp"
    Source="..\Src\Hardware\C64xProcessor.cpp"
    Source="..\Src\Hardware\C64xSerialPort.cpp"
    Source="..\Src\Hardware\Cy8c9560a.cpp"
    Source="..\Src\Hardware\DspInterrupt.cpp"
    Source="..\Src\Hardware\EeProm.cpp"
    Source="..\Src\Hardware\ErrorReporter.cpp"
    Source="..\Src\Hardware\ExternalRam.cpp"
    Source="..\Src\Hardware\Fpga.cpp"
    Source="..\Src\Hardware\Hardware.cpp"
    Source="..\Src\Hardware\Lms6002d.cpp"
    Source="..\Src\Hardware\RefOsc1PpsAlgorithm.cpp"
    Source="..\Src\Hardware\RfCard.cpp"
    Source="..\Src\Hardware\Si5338.cpp"
    Source="..\Src\LteHardware\LteHardware.cpp"
    Source="..\Src\LteHardware\SelfTest.cpp"
    Source="..\Src\LTELIB_Override\table_sin_cos.c"
    Source="..\Src\LteUtil\BitBufReadUtil.cpp"
    Source="..\Src\LteUtil\BitBufWriteUtil.cpp"
    Source="..\Src\LteUtil\EarfcnUtil.cpp"
    Source="..\Src\LteUtil\FftUtil.cpp"
    Source="..\Src\LteUtil\LteDebugMenu.cpp"
    Source="..\Src\LteUtil\LteUtil.cpp"
    Source="..\Src\LteUtil\TBSizeUtil.cpp"
    Source="..\Src\NeoKernel\DspMbx.cpp"
    Source="..\Src\NeoKernel\DspMem.cpp"
    Source="..\Src\NeoKernel\DspSem.cpp"
    Source="..\Src\NeoKernel\DspTsk.cpp"
    Source="..\Src\NeoKernel\NeoBuild.cpp"
    Source="..\Src\NeoKernel\NeoMbx.cpp"
    Source="..\Src\NeoKernel\NeoQue.cpp"
    Source="..\Src\NeoKernel\NeoSys.cpp"
    Source="..\Src\NeoKernel\NeoTime.cpp"
    Source="..\Src\NeoKernel\NeoTimer.cpp"
    Source="..\Src\NeoKernel\NeoTimerManager.cpp"
    Source="..\Src\NeoKernel\NeoVersion.cpp"
    Source="..\Src\NeoKernel\Observer.cpp"
    Source="..\Src\NeoKernel\ObserverNode.cpp"
    Source="..\Src\NeoKernel\Queue.cpp"
    Source="..\Src\NeoKernel\QueueNode.cpp"
    Source="..\Src\NeoKernel\Subject.cpp"
    Source="..\Src\NeoKernel\TimeUnit.cpp"
    Source="..\Src\NeoKernel\TypeUtils.cpp"
    Source="..\Src\NeoProtocol\Application.cpp"
    Source="..\Src\NeoProtocol\Layer.cpp"
    Source="..\Src\NeoProtocol\LayerGroup.cpp"
    Source="..\Src\NeoProtocol\LayerId.cpp"
    Source="..\Src\NeoProtocol\MsgTrx.cpp"
    Source="..\Src\NeoProtocol\MsgTrxNeo.cpp"
    Source="..\Src\NeoProtocol\Physical.cpp"
    Source="..\Src\NeoProtocol\PhysicalHpi.cpp"
    Source="..\Src\NeoProtocol\ProtocolManager.cpp"
    Source="..\Src\NeoProtocol\ProtocolStack.cpp"
    Source="..\Src\NeoProtocol\Transaction.cpp"
    Source="..\Src\NeoProtocol\Transport.cpp"
    Source="..\Src\NeoProtocol\TransportNeo.cpp"
    Source="..\Src\Protocol\Bcch.cpp"
    Source="..\Src\Protocol\Dci.cpp"
    Source="..\Src\Protocol\DciFormat0.cpp"
    Source="..\Src\Protocol\DciFormat1A.cpp"
    Source="..\Src\Protocol\DciFormat1C.cpp"
    Source="..\Src\Protocol\DirectedSurveyMgr.cpp"
    Source="..\Src\Protocol\DownlinkScheduler.cpp"
    Source="..\Src\Protocol\LteLayer2.cpp"
    Source="..\Src\Protocol\LteLayer3.cpp"
    Source="..\Src\Protocol\LteQueue.cpp"
    Source="..\Src\Protocol\Mac.cpp"
    Source="..\Src\Protocol\ProtocolLayer.cpp"
    Source="..\Src\Protocol\Rach.cpp"
    Source="..\Src\Protocol\Rlc.cpp"
    Source="..\Src\Protocol\UEList.cpp"
    Source="..\Src\Protocol\UplinkScheduler.cpp"
    Source="..\Src\Protocol\UserEquipment.cpp"
    Source="..\Src\SigProc\ChannelScan\Algorithms\CPPeakSearch.cpp"
    Source="..\Src\SigProc\ChannelScan\Algorithms\DelayCorrelateRecursive.cpp"
    Source="..\Src\SigProc\ChannelScan\ChannelScanAlgorithm.cpp"
    Source="..\Src\SigProc\ChannelScan\CPOffsetList.cpp"
    Source="..\Src\SigProc\ChannelScan\CPSearcher.cpp"
    Source="..\Src\SigProc\ChannelScan\ENodeBInfoList.cpp"
    Source="..\Src\SigProc\ChannelScan\PssList.cpp"
    Source="..\Src\SigProc\ChannelScan\PssSearcher.cpp"
    Source="..\Src\SigProc\ChannelScan\RxMeasAlgorithm.cpp"
    Source="..\Src\SigProc\ChannelScan\SssList.cpp"
    Source="..\Src\SigProc\ChannelScan\SssSearcher.cpp"
    Source="..\Src\SigProc\ChannelScan\UnitTest_CPSearcher.cpp"
    Source="..\Src\SigProc\ChannelScan\UnitTest_RxMeasAlgorithm.cpp"
    Source="..\Src\SigProc\ChannelScanManager.cpp"
    Source="..\Src\SigProc\DlRxManager.cpp"
    Source="..\Src\SigProc\DownlinkRx\Algorithms\DecimateAndFilter.cpp"
    Source="..\Src\SigProc\DownlinkRx\Algorithms\UnitTest_DecimateAndFilter.cpp"
    Source="..\Src\SigProc\DownlinkRx\DlRxAcqAlgorithm.cpp"
    Source="..\Src\SigProc\DownlinkRx\DlRxAcqFreq.cpp"
    Source="..\Src\SigProc\DownlinkRx\DlRxAcqSss.cpp"
    Source="..\Src\SigProc\DownlinkRx\DlRxAcqTime.cpp"
    Source="..\Src\SigProc\DownlinkRx\DlRxFineTimingAlgorithm.cpp"
    Source="..\Src\SigProc\DownlinkRx\DlRxSubframeRxAlgorithm.cpp"
    Source="..\Src\SigProc\DownlinkRx\PcfichDemod.cpp"
    Source="..\Src\SigProc\DownlinkRx\PdcchDemod.cpp"
    Source="..\Src\SigProc\DownlinkRx\PdschDemod.cpp"
    Source="..\Src\SigProc\DownlinkRx\PssFd.cpp"
    Source="..\Src\SigProc\DownlinkRx\UnitTest_DlRxFineTimingAlgorithm.cpp"
    Source="..\Src\SigProc\DownlinkRx\UnitTest_PcfichDemod.cpp"
    Source="..\Src\SigProc\DownlinkRx\UnitTest_PdcchDemod.cpp"
    Source="..\Src\SigProc\DownlinkRx\UnitTest_PdschDemod.cpp"
    Source="..\Src\SigProc\DownlinkTx\DlMapperForCntrlCh.cpp"
    Source="..\Src\SigProc\DownlinkTx\DlTxAlgorithm.cpp"
    Source="..\Src\SigProc\DownlinkTx\LteConvCoder.cpp"
    Source="..\Src\SigProc\DownlinkTx\PbchGen.cpp"
    Source="..\Src\SigProc\DownlinkTx\PcfichGen.cpp"
    Source="..\Src\SigProc\DownlinkTx\PdcchGen.cpp"
    Source="..\Src\SigProc\DownlinkTx\PdschGen.cpp"
    Source="..\Src\SigProc\DownlinkTx\PhichGen.cpp"
    Source="..\Src\SigProc\DownlinkTx\PssGen.cpp"
    Source="..\Src\SigProc\DownlinkTx\ReferenceSignalGen.cpp"
    Source="..\Src\SigProc\DownlinkTx\SssGen.cpp"
    Source="..\Src\SigProc\DownlinkTx\UnitTest_DlMapperForCntrlCh.cpp"
    Source="..\Src\SigProc\DownlinkTx\UnitTest_LteConvCoder.cpp"
    Source="..\Src\SigProc\DownlinkTx\UnitTest_PbchGen.cpp"
    Source="..\Src\SigProc\DownlinkTx\UnitTest_PcfichGen.cpp"
    Source="..\Src\SigProc\DownlinkTx\UnitTest_PdcchGen.cpp"
    Source="..\Src\SigProc\DownlinkTx\UnitTest_PdschGen.cpp"
    Source="..\Src\SigProc\DownlinkTx\UnitTest_PhichGen.cpp"
    Source="..\Src\SigProc\ENodeBManager.cpp"
    Source="..\Src\SigProc\FpgaDataThread.cpp"
    Source="..\Src\SigProc\IQSampleCollector.cpp"
    Source="..\Src\SigProc\IQSampleDistributor.cpp"
    Source="..\Src\SigProc\LteSigProcCommon\Algorithms\FreqRotate.cpp"
    Source="..\Src\SigProc\LteSigProcCommon\Algorithms\PssPeakSearch.cpp"
    Source="..\Src\SigProc\LteSigProcCommon\CplxUtil.cpp"
    Source="..\Src\SigProc\LteSigProcCommon\DeLayerMapPrecoder.cpp"
    Source="..\Src\SigProc\LteSigProcCommon\DlChanEst.cpp"
    Source="..\Src\SigProc\LteSigProcCommon\DlDemapperForCntrlCh.cpp"
    Source="..\Src\SigProc\LteSigProcCommon\DlMapDemapper.cpp"
    Source="..\Src\SigProc\LteSigProcCommon\DlMapDemapperForPdsch.cpp"
    Source="..\Src\SigProc\LteSigProcCommon\LteInterleaver.cpp"
    Source="..\Src\SigProc\LteSigProcCommon\LteSigProcAlgPool.cpp"
    Source="..\Src\SigProc\LteSigProcCommon\Mib.cpp"
    Source="..\Src\SigProc\LteSigProcCommon\PbchDemod.cpp"
    Source="..\Src\SigProc\LteSigProcCommon\PbchReceiver.cpp"
    Source="..\Src\SigProc\LteSigProcCommon\RefSignalUtil.cpp"
    Source="..\Src\SigProc\LteSigProcCommon\SoftSliceUtil.cpp"
    Source="..\Src\SigProc\LteSigProcCommon\SssRxUtil.cpp"
    Source="..\Src\SigProc\LteSigProcCommon\TCP2_EDMA.c"
    Source="..\Src\SigProc\LteSigProcCommon\TurboDecode.cpp"
    Source="..\Src\SigProc\LteSigProcCommon\UnitTest_DeLayerMapPrecoder.cpp"
    Source="..\Src\SigProc\LteSigProcCommon\UnitTest_DlDemapperForCntrlCh.cpp"
    Source="..\Src\SigProc\LteSigProcCommon\UnitTest_DlMapDemapperForPdsch.cpp"
    Source="..\Src\SigProc\LteSigProcCommon\UnitTest_LteInterleaver.cpp"
    Source="..\Src\SigProc\LteSigProcCommon\UnitTest_Mib.cpp"
    Source="..\Src\SigProc\LteSigProcCommon\UnitTest_TurboDecoder.cpp"
    Source="..\Src\SigProc\LteSigProcCommon\UnitTest_ViterbiDecoder.cpp"
    Source="..\Src\SigProc\LteSigProcCommon\ViterbiDecoder.cpp"
    Source="..\Src\SigProc\RxProcThread.cpp"
    Source="..\Src\SigProc\SignalProcLayer.cpp"
    Source="..\Src\SigProc\TxProcThread.cpp"
    Source="..\Src\SigProc\UplinkRx\PrachDetectAlgorithm.cpp"
    Source="..\Src\SigProc\UplinkRx\PucchRxAlgorithm.cpp"
    Source="..\Src\SigProc\UplinkRx\PuschRxAlgorithm.cpp"
    Source="..\Src\SigProc\UplinkRx\UEUlSchedList.cpp"
    Source="..\Src\Ti\ndk\lib\c64plus\hal\hal_ser_stub.lib"
    Source="..\Src\Ti\ndk\lib\c64plus\hal\hal_timer_bios.lib"
    Source="..\Src\Ti\ndk\lib\c64plus\netctrl.lib"
    Source="..\Src\Ti\ndk\lib\c64plus\nettool.lib"
    Source="..\Src\Ti\ndk\lib\c64plus\os.lib"
    Source="..\Src\Ti\ndk\lib\c64plus\stk.lib"
    Source="..\Src\Ti\ndk\lib\hal\dsk6455\hal_eth_c6455.lib"
    Source="..\Src\Ti\ndk\lib\hal\dsk6455\hal_userled_c6455.lib"
    Source="..\Src\TiLteLib\cixcvrProductEC\LTE\lib\C64xplusDSPLIB_v100\lib\dsp64plus.lib"
    Source="..\Src\TiLteLib\cixcvrProductEC\LTE\lib\C64xplusDSPLIB_v100\support\fft\gen_twiddle_fft16x16.c"
    Source="..\Src\TiLteLib\cixcvrProductEC\LTE\lib\C64xplusDSPLIB_v100\support\fft\gen_twiddle_ifft16x16.c"
    Source="..\Src\TiLteLib\cixcvrProductEC\LTE\lib\csl_3x_C6482_v3_00_10_01\csl_c6482.lib"
    Source="..\Src\TiLteLib\cixcvrProductEC\LTE\LTElib\chanDeint\LTELIB_chanDeint.c"
    Source="..\Src\TiLteLib\cixcvrProductEC\LTE\LTElib\Channel_Estimation_BPT\LTELIB_Ch_Est_BPT.c"
    Source="..\Src\TiLteLib\cixcvrProductEC\LTE\LTElib\Channel_Estimation_TD\LTELIB_Ch_Est_TD.c"
    Source="..\Src\TiLteLib\cixcvrProductEC\LTE\LTElib\CodeBlkSegmentRule\LTELIB_segmentationRule.c"
    Source="..\Src\TiLteLib\cixcvrProductEC\LTE\LTElib\CRC\LTELIB_crc.c"
    Source="..\Src\TiLteLib\cixcvrProductEC\LTE\LTElib\deRateMatchingCC\LTELIB_deRateMatchingCC.c"
    Source="..\Src\TiLteLib\cixcvrProductEC\LTE\LTElib\DeRMSoftBitPos\LTELIB_deRMSoftBitPos.c"
    Source="..\Src\TiLteLib\cixcvrProductEC\LTE\LTElib\descrChanDeintDemux\LTELIB_demuxAckOrRank.c"
    Source="..\Src\TiLteLib\cixcvrProductEC\LTE\LTElib\descrChanDeintDemux\LTELIB_demuxDataCtrl.c"
    Source="..\Src\TiLteLib\cixcvrProductEC\LTE\LTElib\descrChanDeintDemux\LTELIB_descrChanDeintDemux.c"
    Source="..\Src\TiLteLib\cixcvrProductEC\LTE\LTElib\descrChanDeintDemux\LTELIB_zeroOutAck.c"
    Source="..\Src\TiLteLib\cixcvrProductEC\LTE\LTElib\DFT_IDFT\LTELIB_DFT.c"
    Source="..\Src\TiLteLib\cixcvrProductEC\LTE\LTElib\DFT_IDFT\LTELIB_DFT_init.c"
    Source="..\Src\TiLteLib\cixcvrProductEC\LTE\LTElib\DFT_IDFT\LTELIB_IDFT.c"
    Source="..\Src\TiLteLib\cixcvrProductEC\LTE\LTElib\FFT\iw_512_le.c"
    Source="..\Src\TiLteLib\cixcvrProductEC\LTE\LTElib\FFT\w_1024_le.c"
    Source="..\Src\TiLteLib\cixcvrProductEC\LTE\LTElib\FFT\w_128_le.c"
    Source="..\Src\TiLteLib\cixcvrProductEC\LTE\LTElib\FFT\w_2048_le.c"
    Source="..\Src\TiLteLib\cixcvrProductEC\LTE\LTElib\FFT\w_512_le.c"
    Source="..\Src\TiLteLib\cixcvrProductEC\LTE\LTElib\FFTShift\LTELIB_fftShift.c"
    Source="..\Src\TiLteLib\cixcvrProductEC\LTE\LTElib\FreqShift\LTELIB_FreqShift.c"
    Source="..\Src\TiLteLib\cixcvrProductEC\LTE\LTElib\genCtcInterleaver\LTELIB_genCtcInterleaver.c"
    Source="..\Src\TiLteLib\cixcvrProductEC\LTE\LTElib\genDLPSync\LTELIB_genDLPSync.c"
    Source="..\Src\TiLteLib\cixcvrProductEC\LTE\LTElib\genDLRefSignal\LTELIB_genDLRefSignal.c"
    Source="..\Src\TiLteLib\cixcvrProductEC\LTE\LTElib\genDLSSync\LTELIB_genDLSSync.c"
    Source="..\Src\TiLteLib\cixcvrProductEC\LTE\LTElib\genPseudoRandSeq\LTELIB_genPseudoRandSeq.c"
    Source="..\Src\TiLteLib\cixcvrProductEC\LTE\LTElib\genUL_PUSCH_demodRS\LTELIB_genUL_PUSCH_demodRS.c"
    Source="..\Src\TiLteLib\cixcvrProductEC\LTE\LTElib\LTELIB_bitProcUtil.c"
    Source="..\Src\TiLteLib\cixcvrProductEC\LTE\LTElib\MRCEqualizer\LTELIB_ulMrcEqualizer.c"
    Source="..\Src\TiLteLib\cixcvrProductEC\LTE\LTElib\PRACHreceiver\LTELIB_prachMatchFilter.c"
    Source="..\Src\TiLteLib\cixcvrProductEC\LTE\LTElib\PRACHreceiver\LTELIB_prachPeakSearch.c"
    Source="..\Src\TiLteLib\cixcvrProductEC\LTE\LTElib\PRACHreceiver\LTELIB_prachPowerUpInit.c"
    Source="..\Src\TiLteLib\cixcvrProductEC\LTE\LTElib\PRACHreceiver\LTELIB_prachPreambleInit.c"
    Source="..\Src\TiLteLib\cixcvrProductEC\LTE\LTElib\PRACHreceiver\LTELIB_prachPreProc.c"
    Source="..\Src\TiLteLib\cixcvrProductEC\LTE\LTElib\PUCCHreceiver\LTELIB_pucchDecodeF1.c"
    Source="..\Src\TiLteLib\cixcvrProductEC\LTE\LTElib\PUCCHreceiver\LTELIB_pucchF1DTXthreshCalc.c"
    Source="..\Src\TiLteLib\cixcvrProductEC\LTE\LTElib\PUCCHreceiver\LTELIB_pucchInit.c"
    Source="..\Src\TiLteLib\cixcvrProductEC\LTE\LTElib\PUCCHreceiver\LTELIB_pucchInitFmt1.c"
    Source="..\Src\TiLteLib\cixcvrProductEC\LTE\LTElib\PUCCHreceiver\LTELIB_pucchPreProcess.c"
    Source="..\Src\TiLteLib\cixcvrProductEC\LTE\LTElib\PUCCHreceiver\LTELIB_pucchTables.c"
    Source="..\Src\TiLteLib\cixcvrProductEC\LTE\LTElib\RateMatching\LTELIB_rateMatching.c"
    Source="..\Src\TiLteLib\cixcvrProductEC\LTE\LTElib\RateMatching\LTELIB_rateMatchOutputCopy.c"
    Source="..\Src\TiLteLib\cixcvrProductEC\LTE\LTElib\RateMatchingCC\LTELIB_rateMatching_CC.c"
    Source="..\Src\TiLteLib\cixcvrProductEC\LTE\LTElib\ScramblerConstMapper\LTELIB_scrConstMapper.c"
    Source="..\Src\TiLteLib\cixcvrProductEC\LTE\LTElib\SoftDeScrambler\LTELIB_SoftDeScrambler.c"
    Source="..\Src\TiLteLib\cixcvrProductEC\LTE\LTElib\SoftSlicer\LTELIB_softSlicer.c"
    Source="..\Src\TiLteLib\cixcvrProductEC\LTE\LTElib\SubBlkDeint\LTELIB_subBlkDeint.c"
    Source="..\Src\TiLteLib\cixcvrProductEC\LTE\LTElib\tcp2DataPrep\LTELIB_tcp2DataPrep.c"
    Source="..\Src\TiLteLib\cixcvrProductEC\LTE\LTElib\TurboEncoder\LTELIB_turboEncoder.c"
    Source="..\Src\TiLteLib\cixcvrProductEC\LTE\LTElib\TurboEncoder\LTELIB_unpackbits.c"
    Source="..\Src\Utility\Crc16.cpp"
    Source="..\Src\Utility\DebugTextString.cpp"
    Source="..\Src\Utility\DspDebugMenu.cpp"
    Source="..\Src\Utility\ExtMemPool.cpp"
    Source="..\Src\Utility\Fifo.cpp"
    Source="..\Src\Utility\FifoBuffer.cpp"
    Source="..\Src\Utility\Identifier.cpp"
    Source="..\Src\Utility\LogUtil.cpp"
    Source="..\Src\Utility\Manager.cpp"
    Source="..\Src\Utility\StateMachine.cpp"
    Source="..\Src\Utility\StateMachineNode.cpp"
    Source="..\Src\Utility\Utilities.cpp"
    Source="LteDsp.tcf"
    Source="LteDsp.cmd"
    [Generated Files]
    Source="LteDspcfg.s62"
    Source="LteDspcfg_c.c"
    ["DSK6482" Settings]
    InitialBuildCmd=del *.s62 /F
    InitialBuildCmd=del *.h62 /F
    FinalBuildCmd=del *.cdb /F
    ["Stingray3" Settings]
    FinalBuildCmd=makesrec
    ["Compiler" Settings: "DSK6482"]
    Options=-g -o3 -fr"$(Proj_dir)\..\bin\DSK6482" -i"$(BIOS_INSTALL_DIR)\" -i"$(Proj_dir)\..\Src\LTELIB_Override" -i"$(Proj_dir)\..\Src\NeoKernel" -i"$(Proj_dir)\..\Src\NeoProtocol" -i"$(Proj_dir)\..\Src\DSKTest" -i"$(Proj_dir)\..\Src\Utility" -i"$(Proj_dir)\..\Src\Hardware" -i"$(Proj_dir)\..\Src\FrameworkMessages" -i"$(Proj_dir)\..\Src\LteUtil" -i"$(Proj_dir)\..\Src\Control" -i"$(Proj_dir)\..\Src\LteHardware" -i"$(Proj_dir)\..\Src\Protocol" -i"$(Proj_dir)\..\Src\ProtocolMessages" -i"$(Proj_dir)\..\Src\SigProc" -i"$(Proj_dir)\..\Src\SigProcMessages" -i"$(Proj_dir)\..\Src\SigProc\LteSigProcCommon" -i"$(Proj_dir)\..\Src\TiLteLib\cixcvrCommon\api\c64plus" -i"$(Proj_dir)\..\Src\TiLteLib\cixcvrProductEC\LTE\LTElib" -i"$(Proj_dir)\..\Src\TiLteLib\cixcvrProductEC\LTE\lib" -i"$(Proj_dir)\..\Src\TiLteLib\cixcvrProductEC\LTE\LTElib\PuschUciDecoder" -i"$(Proj_dir)\..\Src\TiLteLib\cixcvrProductEC\LTE\LTElib\deRateMatchingCC" -i"$(Proj_dir)\..\Src\TiLteLib\cixcvrProductEC\LTE\LTElib\CRC" -i"$(Proj_dir)\..\Src\TiLteLib\cixcvrProductEC\LTE\lib\C64xplusDSPLIB_v100\include" -i"$(Proj_dir)\..\Src\TiLteLib\cixcvrProductEC\LTE\lib\csl_3x_C6482_v3_00_10_01\api" -i"$(Proj_dir)\..\Src\TiLteLib\cixcvrProductEC\LTE\LTElib\tcp2DataPrep" -i"$(Proj_dir)\..\Src\TiLteLib\cixcvrProductEC\LTE\lib\C64xplusBEDSPLIB_v100\support\fft" -i"$(Proj_dir)\..\Src\TiLteLib\cixcvrProductEC\LTE\LTElib\DFT_IDFT" -i"$(Proj_dir)\..\Src\TiLteLib\cixcvrProductEC\LTE\LTElib\genPseudoRandSeq" -i"$(Proj_dir)\..\Src\TiLteLib\cixcvrProductEC\LTE\LTElib\chanDeint" -i"$(Proj_dir)\..\Src\TiLteLib\cixcvrProductEC\LTE\LTElib\SoftDeScrambler" -i"$(Proj_dir)\..\Src\Ti\ndk\inc" -i"$(Proj_dir)\..\Src\Ti\csl\inc" -i"$(Proj_dir)\..\Src\CSN" -i"$(Proj_dir)\..\Src\CSN\LTE" -i"$(Proj_dir)\..\Src\CSN\src" -d"_DSK_BUILD" -d"_USE_ETHERNET" -d"_cplusplus" -d"_DSP" -d"TI_DSP_64X" -d"CACHE_LARGE" -d"COMPOSER_64X" -d"VCP_IN_USE" -d"_SNR_" -ms0 -mv6400+
    ["Compiler" Settings: "Stingray3"]
    Options=-g -o3 -fr"$(Proj_dir)\..\bin\Stingray3" -i"$(Proj_dir)\..\Src\LTELIB_Override" -i"$(Proj_dir)\..\Src\NeoKernel" -i"$(Proj_dir)\..\Src\NeoProtocol" -i"$(Proj_dir)\..\Src\DSKTest" -i"$(Proj_dir)\..\Src\Utility" -i"$(Proj_dir)\..\Src\Hardware" -i"$(Proj_dir)\..\Src\FrameworkMessages" -i"$(Proj_dir)\..\Src\LteUtil" -i"$(Proj_dir)\..\Src\Control" -i"$(Proj_dir)\..\Src\LteHardware" -i"$(Proj_dir)\..\Src\Protocol" -i"$(Proj_dir)\..\Src\ProtocolMessages" -i"$(Proj_dir)\..\Src\SigProc" -i"$(Proj_dir)\..\Src\SigProcMessages" -i"$(Proj_dir)\..\Src\SigProc\LteSigProcCommon" -i"$(Proj_dir)\..\Src\TiLteLib\cixcvrCommon\api\c64plus" -i"$(Proj_dir)\..\Src\TiLteLib\cixcvrProductEC\LTE\LTElib" -i"$(Proj_dir)\..\Src\TiLteLib\cixcvrProductEC\LTE\lib" -i"$(Proj_dir)\..\Src\TiLteLib\cixcvrProductEC\LTE\LTElib\PuschUciDecoder" -i"$(Proj_dir)\..\Src\TiLteLib\cixcvrProductEC\LTE\LTElib\deRateMatchingCC" -i"$(Proj_dir)\..\Src\TiLteLib\cixcvrProductEC\LTE\LTElib\CRC" -i"$(Proj_dir)\..\Src\TiLteLib\cixcvrProductEC\LTE\lib\C64xplusDSPLIB_v100\include" -i"$(Proj_dir)\..\Src\TiLteLib\cixcvrProductEC\LTE\lib\csl_3x_C6482_v3_00_10_01\api" -i"$(Proj_dir)\..\Src\TiLteLib\cixcvrProductEC\LTE\LTElib\tcp2DataPrep" -i"$(Proj_dir)\..\Src\TiLteLib\cixcvrProductEC\LTE\lib\C64xplusBEDSPLIB_v100\support\fft" -i"$(Proj_dir)\..\Src\TiLteLib\cixcvrProductEC\LTE\LTElib\DFT_IDFT" -i"$(Proj_dir)\..\Src\TiLteLib\cixcvrProductEC\LTE\LTElib\genPseudoRandSeq" -i"$(Proj_dir)\..\Src\TiLteLib\cixcvrProductEC\LTE\LTElib\chanDeint" -i"$(Proj_dir)\..\Src\TiLteLib\cixcvrProductEC\LTE\LTElib\SoftDeScrambler" -i"$(Proj_dir)\..\Src\Ti\ndk\inc" -i"$(Proj_dir)\..\Src\Ti\csl\inc" -i"$(Proj_dir)\..\Src\CSN" -i"$(Proj_dir)\..\Src\CSN\LTE" -i"$(Proj_dir)\..\Src\CSN\src" -d"_cplusplus" -d"_DSP" -d"TI_DSP_64X" -d"CACHE_LARGE" -d"COMPOSER_64X" -d"VCP_IN_USE" -d"_SNR_" -ms0 -mv6400+
    ["DspBiosBuilder" Settings: "DSK6482"]
    Options=-Dconfig.importPath="..\\src\\TI_DSK" -DIncludeNDK=1
    ["DspBiosBuilder" Settings: "Stingray3"]
    Options=-Dconfig.importPath="..\\src\\TI_DSK" -DIncludeNDK=0
    ["Linker" Settings: "DSK6482"]
    Options=-m"$(Proj_dir)\..\bin\DSK6482\LteDsp.map" -o"$(Proj_dir)\..\bin\DSK6482\LteDsp.out" -w -x --ram_model
    Report Abuse
    • Reply
  • Steven Connell
    on Apr 16 2012 14:59 PM
    Bryan,
    Thanks for attaching the project.  I still find it strange that these errors didn't happen when building the above project, since it also links both the 6455 hal library and the 6482 CSL library.
    I found some more information on this issue ... looks like someone has run into it before.  Do you have a "csl_6455.lib" file?  From the below, it seems that the 6455 version of the CSL did not define these MDIO functions.  Another point to take from the below is that you should stick with the NDK driver versions of the MDIO* functions as these are tried and true with the NDK.
    The issue here is that the linker finds that MDIO routines are defined multiple times – both in <hal_eth_6455.lib> and in the library <csl_6482.lib>.
    "This seems to be an issue that comes from the entire CSL functional/register entanglement; the C6455 only had register layer CSL and does not have any pre-defined initialization routines, but C6482 has a functional layer CSL with everything. When the C6482 CSL is included, it carries over all the initialization routines.
    In this case you can try two things:
    -          Include all the C6455 HAL device driver source code into your customer project. In this case the source files would override any calls from the C6482 CSL library;
    -          Comment out all the conflicting functions in the file <c6455_mdio.c> and rebuild the HAL libraries using the newer CSL library. The command line batch file would be broken, but you can create a project in CCS to do this for you;
    The first method will maintain all the settings and parameters from the original NSP HAL device driver, therefore you would keep the proven functionality. In other words, your customer should try the second method at their own risk.
    I haven’t tested step-by-step all the procedures above, but I don’t see a reason why they shouldn’t work. Anyways, please let me know their feedback, ok?
    I would also recommend trying the first method.  The only issue with that is your version of the NDK does not have driver sources.  So, I will recommend that you get the latest version of the 6455 Ethernet driver.  It's found here, within the NDK 2.0.0 product:
    http://software-dl.ti.com/dsps/dsps_public_sw/sdo_sb/targetcontent/ndk/index.html
    Then you can try linking the NDK 2.0.0 version of the Ethernet driver into your app and also copying the sources as recommended above, to override the CSL defined MDIO functions.
    Steve
    Report Abuse
    • Reply
  • Bryan Hehn
    on Apr 16 2012 15:19 PM
    Should I go with the newest NDK or just 2.0.0?
    Report Abuse
    • Reply
  • Bryan Hehn
    on Apr 16 2012 16:25 PM
    I went with ndk_2_0_0.  now I get the error that it can not find stk.lib.  Can I use the old one?
    Report Abuse
    • Reply
  • Steven Connell
    on Apr 16 2012 19:42 PM
    Verified Answer
    Verified by David Friedland
    Bryan,
    Yes, you should still stick with the old (1.92) NDK stk.lib for now.  I only meant to use the driver from NDK 2.0.0, so that you can use the sources for it in your project.
    Having said that, you may want to consider moving to a later NDK, as there have been many releases since 1.92 containt bug fixes and new features.  But, I would just consider this for now.  First, I think it's better not to change too much at once ... just try the new driver code and keep using the old NDK and verify that everything is working, one step at a time.
    Steve
    Report Abuse
    • Reply
  • Bryan Hehn
    on Apr 24 2012 07:38 AM
    I'm getting closer.
    I now have this error.  Where do I get the ECM?
    <Linking>
    undefined first referenced
    symbol in file
    _ECM_dispatchTab C:/ti/bios_5_41_11_38/packages/ti/bios/lib/bios.a64P<ecm_dispatchPlug.o64P>
    error #10234-D: unresolved symbols remain
    error #10010: errors encountered during linking;
    Report Abuse
    • Reply
  • Bryan Hehn
    on Apr 24 2012 07:49 AM
    Another thread with the same problem noted that the wrong xdc (whatever that is) path was used.
    I am using bios 5.41.11.38 and my system env variable XDC_CG_ROOT is set to /ti/xdctools_3_22_04_46
    Where is my appropriate xdc tools?
    Report Abuse
    • Reply
  • Steven Connell
    on Apr 24 2012 13:54 PM
    Bryan Hehn,
    Which thread did you see that in?  Can you please post the link to it here?
    Your XDC tools installation is probably in C:/ti/xdctools_3_22_04_46.
    You can verify the version and location by inspecting the build output of your program.  Actually, can you post the full build output of your program here? It should also display the XDCPATH information.
    Steve
    Report Abuse
    • Reply
  • Bryan Hehn
    on Apr 24 2012 16:42 PM
    I actually can't find that thread anymore.  But I searched for ECM_dispatchTab and found these:
    http://e2e.ti.com/support/dsp/davinci_digital_media_processors/f/99/p/6671/496729.aspx
    http://e2e.ti.com/support/embedded/bios/f/355/t/184383.aspx
    Report Abuse
    • Reply
  • Steven Connell
    on Apr 24 2012 19:30 PM
    Bryan,
    Actually another customer had the same question earlier today.
    Can you make sure that your *.tcf file has the following code?
    bios.ECM.ENABLE = 1;
    Steve
    Report Abuse
    • Reply
  • Bryan Hehn
    on Apr 26 2012 13:36 PM
    I can now compile!!!
    Now my problem is I can not connect to my target because there is no configuration file for the DSK tci6482.  I guess I'll open a new thread under code composer.
    Report Abuse
    • Reply
  • Bryan Hehn
    on Apr 26 2012 15:12 PM
    OK - I take it back.  It did compile once but I connected to the target and it did not run correctly.  I tried to recompile and now I get linker errors:
    <Linking>
    "C:/svn/uav_working/software/2011_12_13_faa_drop/Lte/Build/LteDsp/../../Build/./LteDspcfg.cmd", line 449: error #10099-D:
    placement fails for object ".trace", size 0x200 (page 0). Available ranges:
    IRAM size: 0x1f75f0 unused: 0x224 max hole: 0x1ec
    "C:/svn/uav_working/software/2011_12_13_faa_drop/Lte/Build/LteDsp/../../Build/./LteDspcfg.cmd", line 483: error #10099-D:
    run placement fails for object ".pip", size 0xc8 (page 0). Available
    ranges:
    IRAM size: 0x1f75f0 unused: 0xec max hole: 0xb4
    "C:/svn/uav_working/software/2011_12_13_faa_drop/Lte/Build/LteDsp/../../Build/./LteDspcfg.cmd", line 372: error #10099-D:
    run placement fails for object ".mbx", size 0x6c (page 0). Available
    ranges:
    IRAM size: 0x1f75f0 unused: 0x7c max hole: 0x44
    "C:/svn/uav_working/software/2011_12_13_faa_drop/Lte/Build/LteDsp/../../Build/./LteDspcfg.cmd", line 398: error #10099-D:
    placement fails for object ".gblinit", size 0x64 (page 0). Available
    ranges:
    "C:/svn/uav_working/software/2011_12_13_faa_drop/Lte/Build/LteDsp/../../Build/./LteDspcfg.cmd", line 316: error #10099-D:
    run placement fails for object ".swi", size 0x58 (page 0). Available
    ranges:
    "C:/svn/uav_working/software/2011_12_13_faa_drop/Lte/Build/LteDsp/../../Build/./LteDspcfg.cmd", line 473: error #10099-D:
    placement fails for object ".log", size 0x30 (page 0). Available ranges:
    IRAM size: 0x1f75f0 unused: 0x40 max hole: 0x1e
    "C:/svn/uav_working/software/2011_12_13_faa_drop/Lte/Build/LteDsp/../../Build/./LteDspcfg.cmd", line 336: error #10099-D:
    run placement fails for object ".idl", size 0x20 (page 0). Available
    ranges:
    "C:/svn/uav_working/software/2011_12_13_faa_drop/Lte/Build/LteDsp/../../Build/./LteDspcfg.cmd", line 294: error #10099-D:
    run placement fails for object ".prd", size 0x20 (page 0). Available
    ranges:
    "C:/svn/uav_working/software/2011_12_13_faa_drop/Lte/Build/LteDsp/../../Build/./LteDspcfg.cmd", line 388: error #10099-D:
    run placement fails for object ".sys", size 0x10 (page 0). Available
    ranges:
    IRAM size: 0x1f75f0 unused: 0x18 max hole: 0xc
    "C:/svn/uav_working/software/2011_12_13_faa_drop/Lte/Build/LteDsp/../../Build/./LteDspcfg.cmd", line 402: error #10099-D:
    placement fails for object ".trcdata", size 0xc (page 0). Available ranges:
    IRAM size: 0x1f75f0 unused: 0xc max hole: 0x8
    "C:/svn/uav_working/software/2011_12_13_faa_drop/Lte/Build/LteDsp/../../Build/./LteDspcfg.cmd", line 439: error #10099-D:
    placement fails for object ".args", size 0x4 (page 0). Available ranges:
    IRAM size: 0x1f75f0 unused: 0x4 max hole: 0x2
    "C:/svn/uav_working/software/2011_12_13_faa_drop/Lte/Build/LteDsp/../../Build/./LteDspcfg.cmd", line 376: error #10099-D:
    run placement fails for object ".mem", size 0x4 (page 0). Available ranges:
    "C:/svn/uav_working/software/2011_12_13_faa_drop/Lte/Build/LteDsp/../../Build/./LteDspcfg.cmd", line 455: error #10099-D:
    run placement fails for object ".stack", size 0x2000 (page 0). Available
    ranges:
    "C:/svn/uav_working/software/2011_12_13_faa_drop/Lte/Build/LteDsp/../../Build/./LteDspcfg.cmd", line 416: error #10099-D:
    run placement fails for object ".TSK_commandPort$stk", size 0x1000 (page 0).
    Available ranges:
    "C:/svn/uav_working/software/2011_12_13_faa_drop/Lte/Build/LteDsp/../../Build/./LteDspcfg.cmd", line 412: error #10099-D:
    run placement fails for object ".TSK_ethernet$stk", size 0x1000 (page 0).
    Available ranges:
    "C:/svn/uav_working/software/2011_12_13_faa_drop/Lte/Build/LteDsp/../../Build/./LteDspcfg.cmd", line 406: error #10099-D:
    placement fails for object ".rtdx_text", size 0xfc0 (page 0). Available
    ranges:
    "C:/svn/uav_working/software/2011_12_13_faa_drop/Lte/Build/LteDsp/../../Build/./LteDspcfg.cmd", line 396: error #10099-D:
    placement fails for object ".switch", size 0xb94 (page 0). Available
    ranges:
    "C:/svn/uav_working/software/2011_12_13_faa_drop/Lte/Build/LteDsp/../../Build/./LteDspcfg.cmd", line 400: error #10099-D:
    placement fails for object ".sysinit", size 0x620 (page 0). Available
    ranges:
    "C:/svn/uav_working/software/2011_12_13_faa_drop/Lte/Build/LteDsp/../../Build/./LteDspcfg.cmd", line 426: error #10099-D:
    run placement fails for object ".rtdx_data", size 0x4f4 (page 0). Available
    ranges:
    "C:/svn/uav_working/software/2011_12_13_faa_drop/Lte/Build/LteDsp/../../Build/./LteDspcfg.cmd", line 408: error #10099-D:
    run placement fails for object ".TSK_idle$stk", size 0x400 (page 0).
    Available ranges:
    "C:/svn/uav_working/software/2011_12_13_faa_drop/Lte/Build/LteDsp/../../Build/./LteDspcfg.cmd", line 380: error #10099-D:
    run placement fails for object ".cio", size 0x120 (page 0). Available
    ranges:
    "C:/svn/uav_working/software/2011_12_13_faa_drop/Lte/Build/LteDsp/../../Build/./LteDspcfg.cmd", line 421: error #10099-D:
    run placement fails for object ".LOG_system$buf", size 0x100 (page 0).
    Available ranges:
    "C:/svn/uav_working/software/2011_12_13_faa_drop/Lte/Build/LteDsp/../../Build/./LteDspcfg.cmd", line 432: error #10099-D:
    run placement fails for object ".hst0", size 0x100 (page 0). Available
    >> Compilation failure
    ranges:
    "C:/svn/uav_working/software/2011_12_13_faa_drop/Lte/Build/LteDsp/../../Build/./LteDspcfg.cmd", line 424: error #10099-D:
    run placement fails for object ".trace$buf", size 0x100 (page 0). Available
    ranges:
    "C:/svn/uav_working/software/2011_12_13_faa_drop/Lte/Build/LteDsp/../../bin/
    DSK6482/LteDsp.out" not built
    gmake: ***
    Report Abuse
    • Reply
12
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
