• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Embedded Software » BIOS » BIOS forum » CCSV5 CFG XDC
Share
BIOS
  • Forum
  • Announcements
Options
  • Subscribe via RSS
CCSV5 CFG XDC
CCSV5 CFG XDC
This question is answered
Junqing Zhao
Posted by Junqing Zhao
on Apr 13 2012 21:59 PM
Intellectual755 points
Hi,everyone
     Recently, I am migrating CCS3.3 project to CCSV5.1,A  problem is happening.  dm6437_demo.cfg can be built and configured correctly,but in ccsv5,it cant work .
How I can use cfg file in CCSv5?
   Where I can find some useful example about CCSv5 and DM 6437?
    JQ zhao
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Sasha Slijepcevic
    Posted by Sasha Slijepcevic
    on Apr 16 2012 12:35 PM
    Genius15140 points
    You can start a new CCS project, and choose the device family C6000 and the device variant TMS320DM6437 in the project creation window. Then, you can select any of the SYS/BIOS examples under "Project templates and examples".
    What's the problem you see when trying to use dm6437_demo.cfg?
    If my reply answers your question please mark the thread as answered.
    Report Abuse
    • Reply
  • Junqing Zhao
    on Apr 17 2012 00:25 AM
    Thanks.
        In CCSV5, I create the new project,which need *.tcf and *.cfg. The project I have is built successfully in CCS3.3. But now something wrong happened inCCSv5.1.I don‘t know how to solve it。
    The build log in Console is :
    gmake.exe *** No rule to make target 'package/cfg/Video_preview_p64P.xdl',needed by 'linker.cmd',stop.
    js:"C:/ti/xdctools_3_22_04_46/packages/xdc/tools/Cmdr.xs",line 51:Error:xdc.tools.configuro:configuration failed due to earlier errors (status=2);'linker.cmd' deleted.
    gmake.exe *** [configPkg/compiler.opt] Error 1
    gmake:Target 'all' not remade because of errors
    That is to say,the linker.cmd file did not generated automatically.
    At the same time,the *cfg.h file did not generated ,too.
    When I move the linker.cmd that generated in ccs3.3  to  the project folder of CCSv5.1.It can be built correctly.
    How  to solve this problem?
    Regards.
    CCSV5 xdc cfg
    Report Abuse
    • Reply
  • Sasha Slijepcevic
    on Apr 17 2012 12:31 PM
    Genius15140 points
    Are you using --tcf option on the configuro command line? If yes, check these two threads that describe a bug that could be the cause of the error you are getting:
    http://e2e.ti.com/support/embedded/bios/f/355/t/177474.aspx
    http://e2e.ti.com/support/embedded/bios/f/355/t/151321.aspx
    The first thread has a link to the bug report. You can check the report and add your email to the CC list, and you will be informed when the bug is fixed.
    Report Abuse
    • Reply
  • Junqing Zhao
    on Apr 18 2012 05:14 AM
    Thank you for your help.
    As the bug is fixed,the linker.cmd can generate.
    You said"Are you using --tcf option on the configuro command line?",what do you mean?
    As I asked last time,I have used #include<*cfg.h >,the *cfg.h file should be generated by *.tcf,but it didn't.So some errors happen. How can I duel with  this?
    Another question is that I use a xdcpath.dat file to represent the xdc package path in CCS3.3. In CCS5.1,I have to add one and one in package search path.  How to use a xdcpath.dat in CCS5.1?
    In CCS3.3, xdcpath.dat is like this
    DVSDK_INSTALL_DIR = "C:/dvsdk_1_01_00_15";
    BIOS_INSTALL_DIR = "C:/CCStudio_v3.3/bios_5_31_07";
    CE_INSTALL_DIR = "C:/dvsdk_1_01_00_15/codec_engine_1_20_02";
    Then in CCS3.3 project directory,I find a file like this
    load("../xdcpaths.dat");
    xdcpaths = CE_INSTALL_DIR + "/packages;" +
     CE_INSTALL_DIR + "/examples;" +
     XDAIS_INSTALL_DIR + "/packages;" +
     "../common;../packages;" +
    How can I use like this in CCSv5.1,as it's simple?
    Report Abuse
    • Reply
  • Sasha Slijepcevic
    on Apr 18 2012 12:52 PM
    Genius15140 points
    Junqing Zhao
    What's the error that you are seeing? Have you applied the fix descibed in the first thread from my previous post? You have to have a clean build without errors to get all of the files generated.
    In CCS 5.1, you add repositories to your package path through Project->Properties->CCS General->RTSC->Products and Repositories. Then, click on Add... and chose directories that you want to have on your XDC package path.
    Report Abuse
    • Reply
  • Junqing Zhao
    on Apr 19 2012 10:12 AM
    I have followed the thread(the First and second is same thing). As video_preview.c I used  #include<video_previewcfg.h>,but video_preview.tcf didnot generate video_previewcfg.h file.
    So when I build it( I have already a clean build ),some errors happen. The errors are as bellow:
    **** Build of configuration Debug for project Jpeg_loopback ****
    C:\ti\ccsv5\utils\bin\gmake -k all
    'Building file: ../video_preview.cfg'
    'Invoking: XDCtools'
    "C:/ti/xdctools_3_22_04_46/xs" --xdcpath="C:/dvsdk_1_01_00_15/codec_engine_1_20_02/packages;C:/dvsdk_1_01_00_15/biosutils_1_00_02/packages;C:/dvsdk_1_01_00_15/framework_components_1_20_03/packages;C:/ti/xdais_7_21_01_07/packages;C:/ti/bios_5_41_11_38/packages;D:/zhao_workspace_v5_1/packages;" xdc.tools.configuro -o configPkg -t ti.targets.C64P -p ti.platforms.evmDM6437 -r debug -c "C:/ti/ccsv5/tools/compiler/c6000" --tcf "../video_preview.cfg"
    making package.mak (because of package.bld) ...
    generating interfaces for package configPkg (because package/package.xdc.inc is older than package.xdc) ...
    configuring video_preview.x64P from package/cfg/video_preview_x64P.cfg ...
    ti.sdo.ce.osal.close() ...
    ti.sdo.ce.osal.validate() ...
    warning: xdc.cfg.Program: "C:/ti/xdctools_3_22_04_46/packages/xdc/runtime/package.xs", line 86: xdc.cfg.Program : assignment to Program.system is deprecated
        will link with ti.sdo.ce.image:lib/debug/image.a64P
        will link with ti.sdo.ce:lib/ce_debug.a64P
        will link with ti.sdo.ce.osal:lib/osal_bios.a64P
        will link with ti.bios.utils:lib/utils.a64P
        will link with ti.sdo.fc.dskt2:dskt2.a64P
        will link with ti.sdo.fc.acpy3:acpy3.a64P
        will link with ti.sdo.ce.utils.xdm:lib/XdmUtils.a64P
        will link with ti.sdo.fc.dman3:dman3Cfg.a64P
        will link with ti.sdo.ce.node:lib/node_debug.a64P
        will link with ti.sdo.ce.trace:lib/gt.a64P
    cl64P package/cfg/video_preview_x64P.c ...
    asm64P package/cfg/video_preview_x64Pcfg.s62 ...
    cl64P package/cfg/video_preview_x64Pcfg_c.c ...
    'Finished building: ../video_preview.cfg'
    'Building file: ../src/i2c_params.c'
    'Invoking: C6000 Compiler'
    "C:/ti/ccsv5/tools/compiler/c6000/bin/cl6x" -mv64+ -g --include_path="C:/ti/ccsv5/tools/compiler/c6000/include" --include_path="D:/zhao_workspace_v5_1/Jpeg_loopback" --include_path="C:/ti/bios_5_41_11_38/packages/ti/bios/include" --include_path="C:/dvsdk_1_01_00_15/xdais_5_21/packages" --include_path="C:/dvsdk_1_01_00_15/psp_1_00_02_00/pspdrivers/inc" --include_path="C:/dvsdk_1_01_00_15/psp_1_00_02_00/pspdrivers/soc/dm6437/dsp/inc" --display_error_number --diag_warning=225 --abi=coffabi --preproc_with_compile --preproc_dependency="src/i2c_params.pp" --obj_directory="src" --cmd_file="./configPkg/compiler.opt"  "../src/i2c_params.c"
    'Finished building: ../src/i2c_params.c'
    'Building file: ../src/video_preview.c'
    "C:/ti/ccsv5/tools/compiler/c6000/bin/cl6x" -mv64+ -g --include_path="C:/ti/ccsv5/tools/compiler/c6000/include" --include_path="D:/zhao_workspace_v5_1/Jpeg_loopback" --include_path="C:/ti/bios_5_41_11_38/packages/ti/bios/include" --include_path="C:/dvsdk_1_01_00_15/xdais_5_21/packages" --include_path="C:/dvsdk_1_01_00_15/psp_1_00_02_00/pspdrivers/inc" --include_path="C:/dvsdk_1_01_00_15/psp_1_00_02_00/pspdrivers/soc/dm6437/dsp/inc" --display_error_number --diag_warning=225 --abi=coffabi --preproc_with_compile --preproc_dependency="src/video_preview.pp" --obj_directory="src" --cmd_file="./configPkg/compiler.opt"  "../src/video_preview.c"
    "../src/video_preview.c", line 32: fatal error #5: could not open source file "video_previewcfg.h"
    1 fatal error detected in the compilation of "../src/video_preview.c".
    Compilation terminated.
    >> Compilation failure
    gmake: *** [src/video_preview.obj] Error 1
    gmake: Target `all' not remade because of errors.
    **** Build Finished ****
    The .tcf   property is :
    which is different the project just based on DSP/BIOS(not contain xdc or *.cfg).That can generate *cfg.h correctly.
    How to solve these problems? Thank you for your help in advance.
    Report Abuse
    • Reply
  • Junqing Zhao
    on Apr 19 2012 10:18 AM
    I have followed your  what yousaid in the thread(Both the two thread are same thing). As I used #include<Video_previewcfg,h> in Video_preview.c,which(*cfg.h) should be
    generated by Video_preview.tcf.  However,it is not.
    I have rebuilt the project(I have   a clean build before).Still,some errors are as bellow:
    >> Compilation failure
    I have saw the video_preview.tcf  property:
    Which is different with the project just based on DSP/BIOS(not used xdc or .cfg file).That can generate *cfg.h correctly。
    How to solve these errors?Looking forward your answers.
    Report Abuse
    • Reply
  • Sasha Slijepcevic
    on Apr 19 2012 16:46 PM
    Genius15140 points
    The option --tcf causes the generated files to have a slightly different names from the ones when you use Tconf and DSP/BIOS 5. The file that you are looking for is named video_preview_x64Pcfg.h. But, you don't need to know about that file or include it. You should instead have
    #include <xdc/cfg/global.h>
    and that will include all global symbols.
    Report Abuse
    • Reply
  • Junqing Zhao
    on Apr 20 2012 09:02 AM
    Thank you.
     When I used #include <Debug\configPkg\package\cfg\video_preview_x64Pcfg.h>,then program can built correctly,
    But when I used #include <xdc/cfg/global.h>,errors stills exist.The build log is:
    "../src/video_preview.c", line 437: error #20: identifier "stsDatarate" is undefined
    1 error detected in the compilation of "../src/video_preview.c".
    >> Compilation failure
    The stsDatarate had be defined  in video_preview_x64Pcfg.h file. So your suggestion did not work. The global.h is:
     *  ======== global.h ========
     *  This header is used by C/C++ sources that want to "portably" include a
     *  configuration-specific generated header (which contains extern
     *  declarations of configuration specified global variables).
     *  To use this header you must define the symbol xdc_cfg__header__ to be
     *  the package-qualified name of the configuration header.
     *  For example, to compile sources that reference config values
     *  for a TI C6x target with a generated
     *  configuration header named "package/cfg/mycfg_x62.h" in a package
     *  named "local.examples" the following command line is sufficient:
     *      cl6x -Dxdc_cfg__header__=local/examples/package/cfg/mycfg_x62.h ...
    #ifndef xdc_cfg_global__include
    #define xdc_cfg_global__include
    /* support old compiler option for naming config include file */
    #ifdef xdc_cfg__header__
    #define xdc_cfg__xheader__ <xdc_cfg__header__>
    #endif
    /* if specified, include configuration generated header */
    #ifdef xdc_cfg__xheader__
    #include xdc_cfg__xheader__
    #endif
    #endif
     *  @(#) xdc.cfg; 1, 0, 2, 0,344; 9-14-2011 15:36:07; /db/ztree/library/trees/xdc/xdc-x20x/src/packages/
     What this happens?How to do with it?
    ②Another question is about the Bug.
    Firstly,Why I replace the -p with -x,then the program can run ? Why did this?
    Secondly,
    If I modified package.bld.xdt and package.xs.xdt follow the thread(http://e2e.ti.com/support/embedded/bios/f/355/t/151321.aspx), what potential risks do we face?Here I meet some erros. When I creat a sample application(Generic Example-Hello Example for SYS/BIOS).
    The same errors happen:
    **** Build of configuration Debug for project hello ****
    'Building file: ../hello.cfg'
    "C:/ti/xdctools_3_22_04_46/xs" --xdcpath="C:/ti/bios_6_32_05_54/packages;C:/ti/ipc_1_23_05_40/packages;" xdc.tools.configuro -o configPkg -t ti.targets.C64P -p ti.platforms.evmDM6437 -r debug -c "C:/ti/ccsv5/tools/compiler/c6000" --compileOptions "-g --optimize_with_debug" "../hello.cfg"
    gmake.exe: *** No rule to make target `package/cfg/hello_x64P.xdl', needed by `linker.cmd'.  Stop.
    js: "C:/ti/xdctools_3_22_04_46/packages/xdc/tools/Cmdr.xs", line 51: Error: xdc.tools.configuro: configuration failed due to earlier errors (status = 2); 'linker.cmd' deleted.
    Then I modified back as before. That is to say
    package.bld.xdt :replace '.x' with '.p'
    package.xs.xdt :base + '_p' + suffix + '.o' + suffix,
    The errors then eliminate. So the solution for the Bug is not pefect. How to solve this??
    ③ Why can't I use the RTA tool?the CPU Load、print log can't be used.
    ④ when I built efc.c,a error happen inCCSV5.1. Part of efc.c is
    void efs_createfilecb( char *name, INT32 length, UINT8 *pData,
                           EFSFUN pllDestroyFun, UINT32 MemMgrArg )
        FILEHEADER *pfh, *psh;
        // Allocate the file header structure
        pfh = mmAlloc( sizeof(FILEHEADER) );
        if( !pfh )
            return;
        pfh->Type = HTYPE_EFSFILEHEADER;
        // Record the filename, size, and data pointer
        strncpy( pfh->Filename, name, EFS_FILENAME_MAX-1 );
        pfh->Filename[EFS_FILENAME_MAX-1] = 0;
        pfh->Length     = length;
        pfh->RefCount   = 0;
        pfh->pData      = pData;
        pfh->Flags      = 0;
        pfh->pMemMgrCallback = pllDestroyFun;
        pfh->MemMgrArg = MemMgrArg;
        psh = mmAlloc( sizeof(FILEHEADER) );
        if( !psh )
            return;
        pfh->Shadow = psh;
        psh->Type = HTYPE_EFSSHADOWHEADER;
        strncpy( psh->Filename, "_EFS_INTERNAL_shadow", EFS_FILENAME_MAX-1 );
        psh->Filename[EFS_FILENAME_MAX-1] = 0;
        psh->Length     = 0;
        psh->RefCount   = 0;
        psh->pData      = 0;
        psh->Flags      = 0;
        psh->pMemMgrCallback = 0;
        psh->MemMgrArg = 0;
        psh->Shadow = NULL;
        psh->pNext = NULL;
        llEnter();
        // Put it in our list
        pfh->pNext = pRoot;
        pRoot      = pfh;
        llExit();
    Part of built log is
    'Building file: ../os/efs.c'
    "C:/ti/ccsv5/tools/compiler/c6000/bin/cl6x" -mv64+ -g --include_path="C:/ti/ccsv5/tools/compiler/c6000/include" --include_path="D:/zhao_workspace_v5_1/Web_Video" --include_path="C:/ti/bios_5_41_11_38/packages/ti/bios/include" --include_path="C:/dvsdk_1_01_00_15/ndk_1_92_00_22_eval/packages/ti/ndk/example/tools" --include_path="C:/dvsdk_1_01_00_15/psp_1_00_02_00/pspdrivers/inc" --include_path="C:/dvsdk_1_01_00_15/psp_1_00_02_00/pspdrivers/soc/dm6437/dsp/inc" --include_path="C:/CCStudio_v3.3/boards/evmdm6437_v2/include" --include_path="C:/dvsdk_1_01_00_15/ndk_1_92_00_22_eval/packages/ti/ndk/inc" --display_error_number --diag_warning=225 --abi=coffabi --preproc_with_compile --preproc_dependency="os/efs.pp" --obj_directory="os" --cmd_file="./configPkg/compiler.opt"  "../os/efs.c"
    "../os/efs.c", line 186: error #20: identifier "HTYPE_EFSSHADOWHEADER" is undefined
    1 error detected in the compilation of "../os/efs.c".
    >> Compilation failure
    gmake: *** [os/efs.obj] Error 1
    'Building file: ../os/efs_orig.c'
    "C:/ti/ccsv5/tools/compiler/c6000/bin/cl6x" -mv64+ -g --include_path="C:/ti/ccsv5/tools/compiler/c6000/include" --include_path="D:/zhao_workspace_v5_1/Web_Video" --include_path="C:/ti/bios_5_41_11_38/packages/ti/bios/include" --include_path="C:/dvsdk_1_01_00_15/ndk_1_92_00_22_eval/packages/ti/ndk/example/tools" --include_path="C:/dvsdk_1_01_00_15/psp_1_00_02_00/pspdrivers/inc" --include_path="C:/dvsdk_1_01_00_15/psp_1_00_02_00/pspdrivers/soc/dm6437/dsp/inc" --include_path="C:/CCStudio_v3.3/boards/evmdm6437_v2/include" --include_path="C:/dvsdk_1_01_00_15/ndk_1_92_00_22_eval/packages/ti/ndk/inc" --display_error_number --diag_warning=225 --abi=coffabi --preproc_with_compile --preproc_dependency="os/efs_orig.pp" --obj_directory="os" --cmd_file="./configPkg/compiler.opt"  "../os/efs_orig.c"
    'Finished building: ../os/efs_orig.c'
    How to solve this Compilation failure?
    Thank you for reading all this,I am looking forward your reply.
    Regards.
    Report Abuse
    • Reply
  • Junqing Zhao
    on Apr 20 2012 09:07 AM
    Thank you.
    >> Compilation failure
    #endif
    #endif
    #endif
    Secondly,
        if( !pfh )
            return;
        pfh->RefCount   = 0;
        pfh->pData      = pData;
        pfh->Flags      = 0;
        if( !psh )
            return;
        pfh->Shadow = psh;
        psh->Length     = 0;
        psh->RefCount   = 0;
        psh->pData      = 0;
        psh->Flags      = 0;
        psh->MemMgrArg = 0;
        psh->Shadow = NULL;
        psh->pNext = NULL;
        llEnter();
        pfh->pNext = pRoot;
        pRoot      = pfh;
        llExit();
    >> Compilation failure
    Regards.
    Report Abuse
    • Reply
  • Junqing Zhao
    on Apr 20 2012 09:09 AM
    Thank you.
    >> Compilation failure
    #endif
    #endif
    #endif
    Secondly,
        if( !pfh )
            return;
        pfh->RefCount   = 0;
        pfh->pData      = pData;
        pfh->Flags      = 0;
        if( !psh )
            return;
        pfh->Shadow = psh;
        psh->Length     = 0;
        psh->RefCount   = 0;
        psh->pData      = 0;
        psh->Flags      = 0;
        psh->MemMgrArg = 0;
        psh->Shadow = NULL;
        psh->pNext = NULL;
        llEnter();
        pfh->pNext = pRoot;
        pRoot      = pfh;
        llExit();
    >> Compilation failure
    Regards.
    Report Abuse
    • Reply
  • Sasha Slijepcevic
    on Apr 20 2012 13:05 PM
    Verified Answer
    Verified by David Friedland
    Genius15140 points
    Junqing Zhao
    Thank you.
    I think you actually need both. The first one includes global symbols from your TCF script, and the second one includes globals from your CFG script. It's possible that you are not using any globals created in your CFG script, so not including <xdc/cfg/global.h> does not make any difference. But, you should be including both in case you decide to use globals from the CFG script later.
    Junqing Zhao
    Firstly,Why I replace the -p with -x,then the program can run ? Why did this?Secondly,
    The replacements suggested in that thread are a workaround for a specific error, and they are not really tested so it's possible that they cause errors in some other use cases. When you switch to another project you may need to revert the changes. When we develop a solution that's tested against all use cases, then we will release it as an official bug fix.
    Your 3rd and 4th question should go to new threads. I don't know where HTYPE_EFSSHADOWHEADER is coming from and why it's not found.
    Report Abuse
    • Reply
  • Junqing Zhao
    on Jun 28 2012 04:18 AM
    Sasha Slijepcevic
    When I use SYS/BIOS,the bugs have to modified as before. The CCS has update to CCSv5.2. I want to know whether the bug roblems solved thoroughly?
    Thank you
    JQ Zhao
    Report Abuse
    • Reply
  • Sasha Slijepcevic
    on Jun 28 2012 12:30 PM
    Genius15140 points
    The complete fix for that bug will be available in XDCtools 3.23.04, which will be released in two weeks or so. When it's released, you'll be able to add that release to your CCSv5.2 installation.
    Here is the Web page where we publish XDCtools releases: http://software-dl.ti.com/dsps/dsps_public_sw/sdo_sb/targetcontent/rtsc/.
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
