• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Embedded Software » BIOS » BIOS forum » Linker error
Share
BIOS
  • Forum
  • Announcements
Options
  • Subscribe via RSS
Linker error
Linker error
This question is answered
Taranum Sultana
Posted by Taranum Sultana
on Apr 25 2012 01:34 AM
Intellectual330 points
   I am using TMS320c5515 development kit with ccs version 4. I have used TCF file to create tasks, semaphores and mutex and also using Tcf I am creating a buffer pool of different sizes and trying to allocate the memory from this pool using BUF_alloc. Memory heap has been enabled. Memory model selected is large. While Linking I am getting these warnings and errors.
warning: creating output section ".vector" without a SECTIONS specification
warning: creating output section "vector" without a SECTIONS specification
"./simple_plaincfg.cmd", line 268: error: placement fails for object ".text",
   size 0x20c0b (page 0).  Available ranges:
   DARAM        size: 0xfe40       unused: 0x1808       max hole: 0x1802
"./simple_plaincfg.cmd", line 322: error: placement fails for object "GROUP_1",
   size 0x1227a (page 0).  Available ranges:
warning: entry-point symbol other than "_c_int00" specified:  "reset_isr"
error: errors encountered during linking; "Simple_Application.out" not built
Can anyone please help me out with the answers for it?
Thanks and Regards,
Taranum
.cmd .text .bios _KNL_queues 5515 .cfg
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Steven Connell
    Posted by Steven Connell
    on Apr 25 2012 16:49 PM
    Verified Answer
    Verified by Taranum Sultana
    Mastermind21815 points
    Hi Taranum,
    These errors indicate that the memory segment DARAM is all used up.  According to the message, the ".text" section is size 0xfe40; however there is only 0x1802 bytes left in in DARAM.
    In order to fix this, you should try re-arranging various sections into other memory segments.  This can be done in your *.tcf file in the MEM manager properties:
    (I'm having trouble attaching a screen shot so I'll reply to this post with one...)
    Steve
    Report Abuse
    • Reply
  • Steven Connell
    on Apr 25 2012 17:19 PM
    Report Abuse
    • Reply
  • Taranum Sultana
    on Apr 26 2012 04:25 AM
    Hi Steve,
            Thank you for the answer. It solved the problem of text section. But how about this problem "placement fails for object GROUP1"? Does this also mean the same thing? If so how and which segment should i select for this?
    Thanks and Regards,
    Taranum
    Report Abuse
    • Reply
  • Steven Connell
    on Apr 26 2012 13:58 PM
    Verified Answer
    Taranum,
    I think the GROUP_1 is coming from your linker command file (simple_plaincfg.cmd).  Can you check to see what GROUP_1 shows in that file? (It should list some memory sections inside a block called "GROUP_1").
    Once you see the memory sections listed in it, you can place those ones into a different memory segment in a similar way as you did for .text.
    Steve
    Report Abuse
    • Reply
  • Taranum Sultana
    on Apr 26 2012 23:39 PM
    Hi Steve,
           I selected SARAM section for .CONST and .printf section and this group_1 error was resolved. Thank you so much for your guidance.
    And also what do these warnings represent? For the first warning, should I specify  a memory section for .vector? If yes, then which section should i go for .vector?
    Taranum
    Report Abuse
    • Reply
  • Steven Connell
    on Apr 27 2012 18:15 PM
    Verified Answer
    Taranum,
    Are you using a custom linker command file?  If so, can you please attach it?
    Taranum Sultana
    This is probably caused because your linker command file does not specify which memory segment the ".vector" section should be placed into.
    Taranum Sultana
    Typically the entry point for a program is at the symbol "_c_int00".  This warning is telling you that it has been changed to be the symbol "reset_isr".  Perhaps you made this change intentionally?  If so, this should be OK
    Steve
    Report Abuse
    • Reply
  • Taranum Sultana
    on Apr 29 2012 23:32 PM
    Hi steve,
           Here is the linker command file.
    Taranum
    Report Abuse
    • Reply
  • Steven Connell
    on Apr 30 2012 15:28 PM
    Taranum,
    Thank you for attaching the linker command file.  But, has your problem been resolved?  I see that you marked my previous post as "verified".
    Steve
    Report Abuse
    • Reply
  • Taranum Sultana
    on May 01 2012 10:54 AM
    Hi Steve,
          I am extremely sorry that. That problem is not yet resolved.
    Taranum
    Report Abuse
    • Reply
  • Taranum Sultana
    on May 03 2012 06:42 AM
    Hi Steve,
          Can you please guide me for those .vector section warnings?
    Taranum
    Report Abuse
    • Reply
  • Steven Connell
    on May 03 2012 19:19 PM
    Taranum,
    I'm not sure what the .vector section is, but this warning means that you need to ensure that the .vector section is being placed into a memory segment.
    For example, the TMS320C55x Assembly Language Tools v 4.4
    User's Guide (http://www.ti.com/lit/ug/spru280i/spru280i.pdf)
    shows this example of default placement.  I suspect you need something similar.
    Example 9-18. Default Allocation for TMS320C55x Devices
    MEMORY
    ROM (RIX) : origin = 0100h, length = 0FEFFh
    VECTOR (RIX) : origin = 0FFFF00h, length = 0100h
    RAM (RWIX) : origin = 010100h, length = 0FFFFh
    SECTIONS
    .text > ROM
    .switch > ROM
    .const > ROM
    .cinit > ROM
    .vectors > VECTOR
    .data > RAM
    .bss > RAM
    .sysmem > RAM
    .stack > RAM
    .sysstack > RAM
    .cio > RAM
    It may be helpful to attach your *.map file at this point, as well.
    Steve
    Report Abuse
    • Reply
  • Taranum Sultana
    on May 07 2012 10:22 AM
    Hi Steve,
    Here is the *.map file.
    Taranum
    Report Abuse
    • Reply
  • Steven Connell
    on May 07 2012 17:12 PM
    Taranum,
    Are you building for the MSP430?  I see from the map file that the .vector coming from from an msp430 UART file:
    SECTION ALLOCATION MAP
    (Addresses surrounded by []'s are displayed for convenience only!)
    output                                                          attributes/
    section   page  orgn(bytes) orgn(words) len(bytes) len(words)   input sections
    .vector      0     0000e6fe  [ 0000737f ] 000005d7          *
                       0000e6fe  [ 0000737f ] 000005d6          *   msp430_uart.obj (.vector:_isr)
                       0000ecd4  [ 0000766a ] 00000001          *   --HOLE-- [fill = 20]
    vector       0     0000ed00  [ 00007680 ] 00000100          *
                       0000ed00  [ 00007680 ] 00000100          *   vector.obj (vector)
    .hwi_vec     0     0000ff00  [ 00007f80 ] 00000100          *
                       0000ff00  [ 00007f80 ] 00000100          *   simple_plaincfg.obj (.hwi_vec)
    Do you know where that file is coming from?
    Steve
    Report Abuse
    • Reply
  • Taranum Sultana
    on May 08 2012 22:55 PM
    Hi Steve,
     I am using vector.asm file for uart isr. And that MSP430_uart.c file is replaced for c5515 functionality. Now when I am trying to debug the code (single step) I am getting JVM heap detected low ( You can Increase the JVM heap by changing the XMX option in eclips.ini file, after which the ccsv4 stops responding. Earlier it was xmx256m, now I have changed it to xmx512m. Is that correct?
    Thanks and Regards,
    Taranum
    Report Abuse
    • Reply
  • Steven Connell
    on May 10 2012 17:12 PM
    Verified Answer
    Taranum,
    I think you just need to add a SECTIONS specification to your linker command file that places the ".vector" section into the memory segment that you want in order to get rid of the warning.
    For more information about linker command files, please refer to the following doc in Section 7.5:
    http://www.ti.com/general/docs/lit/getliterature.tsp?baseLiteratureNumber=spru186&fileType=pdf,
    Regarding the JVM heap issue, yes I believe you have changed the heap size correctly.  Note that I saw another post a customer recommnded the following website for tuning eclipse:
    http://www.eclipsezone.com/eclipse/forums/t61618.html
    Steve
    Report Abuse
    • Reply
12
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
