• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Embedded Software » BIOS » BIOS forum » how to enable jumbo frame reception
Share
BIOS
  • Forum
  • Announcements
Options
  • Subscribe via RSS
This question is answered
pratik jain
Posted by pratik jain
on May 27 2012 07:47 AM
Intellectual285 points
hi
 i am tring to enable jumo frame packet reception in "hello wold example :" of  NDK 2.21. can you tell me how to do this.
i am using CCSv5.1 and my target device is TMS320C6678 processor
                       pratik jain
ndk
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • David Friedland
    Posted by David Friedland
    on May 29 2012 18:36 PM
    Verified Answer
    Verified by David Friedland
    Genius13430 points
    Looking at this thread, it appears that jumbo frames is not supported by the EMAC driver yet.  I'll ask the MCUSDK team to respond further if they can.
    http://e2e.ti.com/support/embedded/bios/f/355/t/149900.aspx
    Report Abuse
    • Reply
  • pratik jain
    on Jun 19 2012 01:26 AM
    hi
               can u tell me how i cam modify the drive to enable jumoframe reception for TMS320C6678 device.
    Pratik jain
    Report Abuse
    • Reply
  • Steven Connell
    Posted by Steven Connell
    on Jun 19 2012 16:01 PM
    Verified Answer
    Verified by pratik jain
    Mastermind20600 points
    Hi Pratik jain,
    Jumbo frames are not supported in the driver.  As previously mentioned, you would have to modify the driver in order to add such support yourself.
    In addition to what was already mentioned in this post and linked posts, I found a couple of notes about this in an email regarding the issue:
    1. The size of the framebuf in NDK must be large enough to hold the jumbo packet. See pbm.c.
    2. The size of the packet for NIMU needs to be raised to the same value.
    3. We config the switch with the max packet size we can receive. Right now 1514. That will need to be bumped as well.
    For number 1, I think jumbo_pbm.c should be looked at as well...
    Steve
    Report Abuse
    • Reply
  • pratik jain
    on Jun 20 2012 01:43 AM
    hi steven
     can u tell me which all files in MCSDK i need to modify
     pratik jain
    Report Abuse
    • Reply
  • Varada Bellary
    Posted by Varada Bellary
    on Jun 20 2012 19:52 PM
    Verified Answer
    Expert5750 points
    In the MCSDK, changes are needed in NIMU.
    One place would be  nimu_eth.c, where the packet buffer is allocated.  But it is not tested and there may be more changes needed in other locations/packages
    Hence in MCSDK, jumbo-frame is not supported yet.
    http://e2e.ti.com/support/dsp/c6000_multi-core_dsps/f/639/p/192066/687970.aspx#687970
    Varada
    Kindly click the Verify Answer button on this post, if it answers your question.
    Report Abuse
    • Reply
  • ankit jain
    Posted by ankit jain
    on Jun 26 2012 00:28 AM
    Prodigy190 points
    Hello Steven,
    I am working on C6670 device and have created a GTP fast path (using netcp) to send and receive packets from the EMAC. When the application needs to send any packet outside it directly pushes the descriptor in the transmit queue of GBeTth switch using netcp. Also, when a GTP packet is received  that is directly forwarded to the application bypassing the L3 processing. I need support of jumbo frames such that ethernet is able to receive/transmit frames of size >1500.
    What i could observe is that EMAC is able to transmit jumbo frames properly but is not able to receives frames of size >1514 bytes.
    As you pointed out in your reply earlier, can you please let me know how to configure the switch to receive packet size >1514 bytes.
    "We config the switch with the max packet size we can receive. Right now 1514. That will need to be bumped as well."
    Ankit
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
