• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Embedded Software » BIOS » BIOS forum » Strange issue with the Log_info on OMAP-L138 (ARM) and CCS 5.2.0.00070
Share
BIOS
  • Forum
  • Announcements
Options
  • Subscribe via RSS
  • Mike Geppert
    Posted by Mike Geppert
    on Jul 25 2012 13:42 PM
    Expert1435 points
    CCS 5.2.0.00070
    SYSBIOS 6.33.4.39
    Using a JTAG connection and using the RAW Logs to look at the logs.
    So the loging starts off fine.  I break at main and there are a few logs.  I run some in my code and I get log messages fine.
    Then I run some more and all of a sudden the logs are gone.
    I traced it down to a Log_info2 call.  Just before it I am fine.  Step over it and the logs are gone.  Just before this I setup an EDMA3.  I am debugging an SD driver that was ported from the PSP stuff.
    After that no log messages come out at all.  If I reset, the pattern starts all over again.  Exact same Log_info seems to crash the logging.
    What can I look at or do to debug this issue?
    Report Abuse
    • Reply
    You have posted to a forum that requires a moderator to approve posts before they are publicly available.
  • Tom Kopriva
    Posted by Tom Kopriva
    on Jul 26 2012 14:24 PM
    Expert6350 points
    Hi Mike,
    have you checked to see if ROV is detecting any other issues? Which version of XDCtools are you using? Does this happen with all Log2_info calls or just that particular instance?
    Tom
    Report Abuse
    • Reply
  • Mike Geppert
    on Jul 27 2012 09:16 AM
    Expert1435 points
    I dont see any ROV errors (that doesnt mean I didnt miss any, just nothing obviouse).
    XDCTools 3.23.03.53
    I am not sure how to answer your last question other then to comment out that log_info2 and see if it happens on the next log_info?  I can do that if that is what you are talking about.
    I should add that there is a tab that opens up called Error Log - looks like it is logging a bunch of JAVA errors.  Lots of them.  Maybe it is stricktly a display side issue and the JAVA errors have something to do with it?
    Report Abuse
    • Reply
  • Mike Geppert
    on Jul 27 2012 17:01 PM
    Expert1435 points
    Here is a picture before and after the stepping over the Log_info statement.  Note that after, the Raw Logs are empty and log messages no longer come out.
    Report Abuse
    • Reply
  • Mike Geppert
    on Jul 27 2012 17:07 PM
    Expert1435 points
    If I comment out that Log_info, the problem just occures on the next Log_info.  Happens to be the same file.
    Report Abuse
    • Reply
  • Tom Kopriva
    on Jul 27 2012 17:50 PM
    Expert6350 points
    Hi Mike,
    I'm going to try to reproduce this. I'll keep you posted.
    Tom
    Report Abuse
    • Reply
  • Tom Kopriva
    on Jul 31 2012 14:32 PM
    Expert6350 points
    Mike,
    I simply ran an example on the simlulator and it checked out fine. I'll run it on an actual device now to see if I can reproduce this problem.
    could you post your .cfg file. There may be subtle difference with a big impact.
    Tom
    Report Abuse
    • Reply
  • Tom Kopriva
    on Aug 09 2012 12:14 PM
    Expert6350 points
    Mike,
    I made Log_info0, Log_info1, and Log_info2 statements and they showed up in LoggerBuf. I ran the same setup on the hardware and I wasn't able to see the logs disappear.
    Are you still seeing this problem? Can you see the logs using ROV?
    Tom
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
