• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Embedded Software » BIOS » BIOS forum » use evm6678le as a isp
Share
BIOS
  • Forum
  • Announcements
Options
  • Subscribe via RSS
This question is answered
Noe Thalheim
Posted by Noe Thalheim
on Aug 15 2012 11:24 AM
Prodigy70 points
Hey,
As the topic says i want the use my evm6678le as a isp for sniffing the hole traffic in my network. i searched and read a lot in this forum but found nothing that solve my problem.
My biggest problem actually is that other PC can see the traffic of my board (i use a hub and the emacExample) but i can't receive traffic.  I don't know what i have to do i hope you can help me.
Kind regards
Noe Thalheim
320C6678 NETCP emacExample Sniffing
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • RandyP
    Posted by RandyP
    on Aug 15 2012 22:04 PM
    Guru60130 points
    Noe,
    Not being an expert on 802.3, I do not know what ISP means in this context. But I do know what a sniffer is.
    Our NDK was written to support normal Ethernet traffic, so you may not have much success by just using what we supply. It makes sense to me that if the bus traffic is coming to the EMAC pins then the peripheral can probably capture it. But that is not something that I expect TI to support in terms of supplying software drivers.
    If you would like to get a more informed opinion, I could put in a request to move this thread to the BIOS Forum under Embedded Software. That is where the NDK experts would be. Just let me know. Otherwise you can wait for someone else on this forum who knows more about it than I do.
    RandyP
    Search for answers, Ask a question, click  Verify  when complete, Help others, Learn more.
    Report Abuse
    • Reply
  • Noe Thalheim
    on Aug 17 2012 03:01 AM
    Prodigy70 points
    Hey Randy,
    Thanks for your answer, i wasn't quite sure which is the right forum to post my question.
    Noe Thalheim
    Report Abuse
    • Reply
  • ToddMullanix
    Posted by ToddMullanix
    on Aug 17 2012 11:57 AM
    Genius15570 points
    Hi Noe,
    What version of the NDK are you using? What version of BIOS also.
    I want to make sure I have your question correct...For the evm6678, you want to receive all the traffic (UDP, TCP, ICMP, etc.) on the network (regardless of MAC address) in your application...correct?
    Todd
    Report Abuse
    • Reply
  • Noe Thalheim
    on Aug 20 2012 02:46 AM
    Prodigy70 points
    Hey Todd,
    nkd_2_21_00_32 and bios_6_33_04_39.
    yes this is exactly what i want.
    Noe
    Report Abuse
    • Reply
  • Steven Connell
    Posted by Steven Connell
    on Aug 20 2012 12:26 PM
    Mastermind20560 points
    Noe,
    It sounds like what you want is promiscuous mode.  I remember a customer a while back (year or so ago) was doing this for the C674x.  It's all tracked in a forum thread, please check that out:
    http://e2e.ti.com/support/embedded/bios/f/355/t/106536.aspx#387782
    Steve
    Report Abuse
    • Reply
  • Noe Thalheim
    on Aug 22 2012 02:48 AM
    Prodigy70 points
    Steve,
    Thank you for the link it gave me exactly the info I needed. But on my system i can't find a file called "ethdriver.c" and when i want compile the "nimu_eth_evmc6678l" project it doesn't has a output file (like nimu.out)
    Noe
    edit:
    in the properties for the "nimu_eth_evmc6678l" project i saw that there is a archive output sorry for that question. Other queston tdoes this solution also work with a 6678 board because the pdf is for TMS320C674x/OMAP-L1x.
    Report Abuse
    • Reply
  • Steven Connell
    on Aug 22 2012 11:31 AM
    Noe,
    Yes, you are correct, that customer was working on the evm6748 (OMAPL138) hardware so that guide may not apply to you.
    I googled around for a similar guide for the evm6678le EMAC but didn't have much luck.  I'm going to ask that the MCSDK team help you with getting the driver into promiscuous mode (and for any documentation on that).
    Steve
    Report Abuse
    • Reply
  • Steven Connell
    on Aug 22 2012 14:18 PM
    Noe,
    Here's the response from the MCSDK team:
    "Customer can download portfolio from below link for this device:
    http://www.ti.com/product/tms320c6678
     that portfolio has the user’s guide for Ethernet Switch sub-system which should be able to answer the question of promiscuous mode."
    Steve
    Report Abuse
    • Reply
  • Noe Thalheim
    on Aug 27 2012 00:39 AM
    Prodigy70 points
    Hey Steve,
    Can you please help me where in this document is something about the way i can put my board in the promiscuous mode. The only things i found was about frame statistic, pleas correct me if i'm wrong.
    Noe
    Report Abuse
    • Reply
  • Steven Connell
    on Aug 27 2012 15:43 PM
    Noe,
    I think this may be the information that you're looking for:
    Steve
    Report Abuse
    • Reply
  • Noe Thalheim
    on Aug 29 2012 02:25 AM
    Prodigy70 points
    Steven,
    Just one question is this also for the TMS320C6678?
    Noe
    Report Abuse
    • Reply
  • Steven Connell
    on Aug 29 2012 13:08 PM
    Noe,
    Yes, as far as I was informed this is the correct document. However, I can double check for you.
    Was there a problem that you've hit with it?  Or are you just unsure because the title says "6655/57"?
    Steve
    Report Abuse
    • Reply
  • Noe Thalheim
    on Aug 31 2012 03:33 AM
    Prodigy70 points
    Steve,
    Yes I was unsure because of the title. How can i change the bit value at this hex address?
    Sorry if this question is stupid but i haven't done something before.
    Noe
    Report Abuse
    • Reply
  • RandyP
    Posted by RandyP
    on Aug 31 2012 22:41 PM
    Verified Answer
    Verified by David Friedland
    Guru60130 points
    Noe,
    The C6678 and C6657 have different Ethernet modules. You will need to refer to the documents for the Gigabit Ethernet (GbE) Switch Subsystem and the Network Co-Processor module.
    Since the word "promiscuous" shows up in the GbE User's Guide only in reference to status bits, it is not supported the same way as the previous devices. It is not mentioned in the MCSDK documents or source files for the C6678 GbE use, so I doubt that our drivers were written to support that mode.
    Perhaps someone from the driver team will join the conversation to say that there is support available, but my recommendation is to study these two documents (GbE and NetCP) to learn in detail how they operate and figure out how to write this feature in a driver yourself. In other words I do not expect you to find support in our drivers since this is not a normal communication operation that is needed for most use of the peripheral.
    The device may be capable, and if your studies bring you to have specific questions about logic in the GbE or NetCP modules, please ask those in the device forum.
    You may also want to review some of the training material available. In the Training section of TI.com, there is a training video set for the C66x SOC architecture. It may be helpful for you to review all of the modules. There is a training video on the NetCP, but I did not notice one for the GbE. You can find the complete video set here.
    RandyP
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
