• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Embedded Software » BIOS » BIOS forum » How to browse the javascript config file in CCSV5 IDE?
Share
BIOS
  • Forum
  • Announcements
Options
  • Subscribe via RSS
This question is answered
ma lingshen
Posted by ma lingshen
on Dec 15 2012 05:26 AM
Prodigy250 points
Here, I just want to know How to browse the source code when there are so many javascipts config files in a RTSC package?
I want to browse the javascipts config and source code at the same GUI ide. How could I ??
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • ToddMullanix
    Posted by ToddMullanix
    on Dec 17 2012 09:39 AM
    Genius15570 points
    Hi Ma,
    You can edit any of the javascripts files with a standard text editor.
    Todd
    Report Abuse
    • Reply
  • ma lingshen
    on Dec 17 2012 23:09 PM
    Prodigy250 points
    I want to browser the javascripts config file with other C source files, and want to see the js configs how to influence the global module as what GCONF in CCS3.3 show before us. How could I do?
    Report Abuse
    • Reply
  • ToddMullanix
    on Dec 18 2012 10:14 AM
    Genius15570 points
    What version of BIOS are you using?
    Report Abuse
    • Reply
  • ma lingshen
    on Dec 21 2012 18:04 PM
    Prodigy250 points
    Now, We do development on dm8168 RDK platform.
    the SYS/BIOS version is "bios_6_33_05_46"
    CCS version is
    "Code Composer Studio
    Version: 5.3.0.00090
    (c) Copyright Texas Instruments, 2011. All rights reserved.
    Visit http://www.ti.com"
    Report Abuse
    • Reply
  • ToddMullanix
    on Dec 21 2012 18:23 PM
    Genius15570 points
    Are you asking which files are generated by the .cfg file?
    Report Abuse
    • Reply
  • ma lingshen
    on Dec 22 2012 08:46 AM
    Prodigy250 points
    In CCS3.3 IDE, I could use GCONF to browse each module of DSP/BIOS.
    And in the javascripts config files from a RTSC project, there are many sentences as following:
    var Task = xdc.useModule("ti.sysbios.knl.Task");
    var Idle = xdc.useModule("ti.sysbios.knl.Idle");
    var BIOS = xdc.useModule("ti.sysbios.BIOS");
    var Startup = xdc.useModule("xdc.runtime.Startup");
    var SysStd = xdc.useModule("xdc.runtime.SysStd");
    var System = xdc.useModule("xdc.runtime.System");
    var Log = xdc.useModule("xdc.runtime.Log");
    var Assert = xdc.useModule("xdc.runtime.Assert");
    I want to browse these modules in one RTSC project with GUI tools like GCONF in "DSP/BIOS".
     I believe that SYS/BIOS(DSP/BIOS) also is a RTSC package in dm8168 ezsdk, but there is no GUI tools liking GCONF to browse these modules(or packages) of RTSC, how could people accept the reality?
    Report Abuse
    • Reply
  • ma lingshen
    on Dec 25 2012 08:13 AM
    Prodigy250 points
    could any one give any advice?
    Report Abuse
    • Reply
  • Sasha Slijepcevic
    Posted by Sasha Slijepcevic
    on Dec 26 2012 16:02 PM
    Genius15070 points
    Ma,
    it seems you are asking is there a GUI environment for SYS/BIOS. If that's correct, then we do have a GUI for SYS/BIOS and it's called XGCONF. In CCS, you can right-click on the cfg file in your project and one of the menu selections is "Open With" and then there is a submenu where you can select XGCONF. After that, you can just double-click on a cfg file, and it will be opened in XGCONF by default.
    If my reply answers your question please mark the thread as answered.
    Report Abuse
    • Reply
  • ma lingshen
    on Dec 27 2012 08:02 AM
    Prodigy250 points
    dear Sasha Slijepcevic
    I know and have used gconf on CCS3.3 for DSP/BIOS.
    I have posted this question before, but got no answer.
    http://e2e.ti.com/support/development_tools/code_composer_studio/f/81/p/119236/811181.aspx#811181
    http://e2e.ti.com/support/development_tools/code_composer_studio/f/81/p/130627/468865.aspx#468865
    There should be a GUI tool to parse javascript config files in RTSC packages, and show each module in one GUI interface,
    The module could be designed by
    "var Task = xdc.useModule("ti.sysbios.knl.Task");".
    And the modules May be SYS/BIOS and also Could be Other RTSC packages.
    Many thanks .
    Report Abuse
    • Reply
  • Sasha Slijepcevic
    on Dec 27 2012 11:09 AM
    Genius15070 points
    Ma,
    as I said there is such a tool and it's called XGCONF. It's different from GCONF. GCONF is for DSP/BIOS 5, XGCONF is for SYS/BIOS 6.
    Have you tried following the steps from my previous email?
    Report Abuse
    • Reply
  • ma lingshen
    on Jan 03 2013 09:24 AM
    Prodigy250 points
    I installed  CCS, Version: 5.3.0.00090.
    While under the install dir, I can't find the "XGCONF", as following picture show:
    The keyword I used while searching is "xgconf*", Is there anything wrong?
    What I still want to say is that there should be one GUI tool to parse all javascripts files of one RTSC package and show us the dependence between the modules that this RTSC package used.
    Please note that the RTSC package is not limited to "SYS/BIOS", and the javascripts files are not only "*.cfg" files but also other javascripts files such as "*.xdc", "*.xs"...
    Report Abuse
    • Reply
  • Sasha Slijepcevic
    on Jan 03 2013 17:05 PM
    Verified Answer
    Verified by ma lingshen
    Genius15070 points
    Ma,
    the best way to learn how to start XGCONF is to read SYS/BIOS Getting Started Guide, which you can open if you click on Help in CCS, then open SYS/BIOS folder, and then click on Getting Started Guide. You should probably read through all of it, or at least be sure to read the section titled "Using XGCONF to Configure SYS/BIOS Modules and Objects". You can also try to follow the instructions from one of my previous posts.
    Both XGCONF and GCONF do not show you the content of all files related to a module. A module producer decides what should be in a module's GUI representation, and in general a module's GUI contains public configuration parameters. The rest of the content is mostly internal implementation.
    As for parsing all files, there is no such tool, but each package contains an XML file package/package.rel.xml, which displays all other packages referenced from that package. The dependencies between modules within a package are not tracked because that's a part of the internal implementation of a package.
    Report Abuse
    • Reply
  • ma lingshen
    on Jan 03 2013 23:12 PM
    Prodigy250 points
    I see, thanks a lot.
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
