• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Embedded Software » BIOS » BIOS forum » Build SysLink 2.2x examples in CCSv5
Share
BIOS
  • Forum
  • Announcements
Options
  • Subscribe via RSS
This question is answered
Valdez V.
Posted by Valdez V.
on Dec 15 2012 07:31 AM
Intellectual610 points
thanks to your help I can run SysLink 2.2x examples on OMAP3530, builded in command line. Now I'd like to use CCSv5 for SysLink project, I supose it could be easier to understand it.
So I have to ask again for your help.Informations presented here  http://processors.wiki.ti.com/index.php/Creating_CCS_Project_for_SysLink_samples are not enough for me, because SysLink 2.2x examples are different from samples in 2.1x and I have not enough advanced to deal with it.
I started with slave DSP side, as it is in mentioned tutorial:
  • I created new CCS Project named Hello_world_DSP,
  • Output type: Executable,
  • Device: Family: C6000; Variant: Generic devices, Generic C64x+
  • Advanced settings: I choosed compiler from filesystem, which I used in command line building (TI v7.2.2) and Output format: eabi(ELF),
  • Project templates: SYS/BIOS > Typical
In the next window I should add RTSC products, but CCS doesn't recognize them. I read in some thread that directory names have to be default. So I added earlier in preferences to discovery path my main directory with installed tools in directories: bios_6_34_03_19, ipc_1_25_01_09, xdctools_3_24_03_33. It doesn't work. I tried also add to discovery path each directory of tools, but it also didn't helped. Selecting tool from filesystem during project creation shows e.g. for XDCtools: No tools selected! Please select a directory that contains the XDCtools installation. Adding SysBios and IPC show in Other Repositories category branch.There was no such a problem with adding CGT in Advanced settings, CCS detected new TI v7.2.2.
Could you help with this step?
syslink ccs
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • raormanrat
    Posted by raormanrat
    on Dec 19 2012 19:10 PM
    Intellectual1155 points
    Hi Valdez,
    Can you tell us what version of CCSv5 you are using?
    Murat
    Report Abuse
    • Reply
  • Valdez V.
    Posted by Valdez V.
    on Dec 20 2012 13:33 PM
    Sure, sorry that I forgot before. My CCSv5 is 5.3.0.00090.
    Report Abuse
    • Reply
  • Valdez V.
    Posted by Valdez V.
    on Dec 30 2012 04:19 AM
    I have installed RTSC products with 'sudo' into directory where CCS keeps default installed tools. Now CCS discovered them.
    Now in the "Rebuilding the slave DSP executable" section I should do --> Right click your project in the C/C++ Projects tab, select "Add files...".
    Which files I should add for ex01_helloworld example of SysLink 2.21.00.03 ? Because that new examples are differently created.
    Report Abuse
    • Reply
  • Valdez V.
    Posted by Valdez V.
    on Jan 04 2013 15:05 PM
    I tried more. Here is what I did when my CCSv5 recognized that products:
    - add files from ex01_helloworld/dsp/ directory: main_dsp.c, Server.c, Server.h, Dsp.cfg;
    - add file from ex01_helloworld/shared/ directory: SystemCfg.h;
    - in Server.c file change from:
    #include "../shared/SystemCfg.h"
    to:
    #include "SystemCfg.h";
    - added SysLink packages directory to XDCPATH;
    - add file config.bld from ex01_helloworld/shared/ directory to "Build configuration file (-b)" in XDCtools advanced options.
    Then I had one error: Cannot read property "base" from undefined Dsp.cfg. It was necessary to change project platform name to "ti.platforms.evm3530:dsp" (or it is possible to edit config.bld file for appropriate name).
    Finally I builded it and got project.out file.
    My last question about DSP side building: how to get output file with .xe64P extension instead of .out?
    Report Abuse
    • Reply
  • Ashish Kapania
    Posted by Ashish Kapania
    on Jan 04 2013 16:12 PM
    Expert3635 points
    Hi Valdez,
    In order to change the output file's extension you need to go to project explorer in CCS and right click. Select "Show Build Settings..." option. The window shown in the screenshot below will open. You need to modify output file name in ARM Linker basic options. I have highlighted the field that needs to be modified.
    Note: After changing the extension, the executable will no longer go to a Binaries/ folder. It is placed in Debug/ or Release/ folder based on your build profile/configuration.
    Ashish
    Don't forget to verify answers to your forum questions by using the green "Verify Answer" button.
    Report Abuse
    • Reply
  • Ashish Kapania
    on Jan 04 2013 16:17 PM
    Expert3635 points
    Hi Valdez,
    Since you are building a C64x application the Build Settings window will look a little different (I used a ARM target screenshot in my previous post). Here's a screenshot for C64x:
    Everything else remains the same.
    Ashish
    Report Abuse
    • Reply
  • Valdez V.
    Posted by Valdez V.
    on Jan 05 2013 09:23 AM
    Thank you Ashish :)
    Now I get stuck in cross-compiler options. Here is what I get from standalone building in debug configuration:
    /home/valdez/workspace/cross-compiler/bin/arm-none-linux-gnueabi-gcc -c -MD -MF bin/debug/obj/main_host.ov5T.dep -march=armv5t -D_REENTRANT -Dxdc_target_name__=GCArmv5T -Dxdc_target_types__=gnu/targets/arm/std.h -Wall -ffloat-store  -fPIC -Wunused -Dfar= -ggdb -D DEBUG -I. -I/home/valdez/workspace/dspv1/syslink_2_21_01_05/packages -I/home/valdez/CCS/bios_6_34_03_19/packages -I/home/valdez/CCS/ipc_1_25_01_09/packages -o bin/debug/obj/main_host.ov5T main_host.c
    Red are the settings which I don't know where to set. I ask you for help with them.
    All -D I set in Cross GCC Compiler -> Symbols.
    -Wall I set in Cross GCC Compiler -> Warnings.
    -c -ffloat-store and -fPIC I set in Cross GCC Compiler -> Miscellaneous.
    -ggdb I set in Cross GCC Compiler -> Debugging.
    And all -I in Cross GCC Compiler -> Includes.
    ------ EDIT:
    Just realized that I can set -march=armv5t also in Cross GCC Compiler -> Miscellaneous -> Other flags.
    Report Abuse
    • Reply
  • Ashish Kapania
    on Jan 05 2013 22:28 PM
    Expert3635 points
    Hi Valdez,
    I did not quite get your question. Are you trying to build a BIOS ARM9 application using gcc tool chain in CCS ?
    Ashish
    Report Abuse
    • Reply
  • Valdez V.
    Posted by Valdez V.
    on Jan 06 2013 03:24 AM
    Hi Ashish,
    sorry I didn't mention it in my last post. I have builded DSP executable. Now I'm trying to build Cortex-A8 Linux executable (host side of SysLink application). Here is what I'm trying to follow http://processors.wiki.ti.com/index.php/Creating_CCS_Project_for_SysLink_samples
    Valdez
    Report Abuse
    • Reply
  • Ashish Kapania
    on Jan 07 2013 15:43 PM
    Expert3635 points
    Hi Valdez,
    You can add the compiler flags that dont show up in the settings by editing the ToolSettings->Cross GCC Compiler->Miscellaneous->Other flags text box. Similarly, if there are any linker flags that you want to add and are not present in settings, you can edit the ToolSettings->Cross GCC Linker->Miscellaneous->Linker flags text box to add them.
    Ashish
    Report Abuse
    • Reply
  • Valdez V.
    Posted by Valdez V.
    on Jan 08 2013 02:04 AM
    Thank you Ashish again,
    if you could only tell me something about that -MD -MF bin/debug/obj/main_host.ov5T.dep. I can't find what does it mean, so don't know if I need this and if I should add it always like this (of course with changed file name).
    -march is obvious. -Wunused is turned on also by -Wall so I think I don't have to use both. With -o bin/debug/obj/main_host.ov5T I'm not sure, but hope that this file will be found in further building.
    Valdez
    Report Abuse
    • Reply
  • Ashish Kapania
    on Jan 08 2013 03:51 AM
    Verified Answer
    Verified by Valdez V.
    Expert3635 points
    Hi Valdez,
    A "-MD" option is used to capture all source file dependencies into an output file when the source is compiled (The dependencies are listed in the output file in the form of make rules). I am not sure if you need this option in the CCS project. The wiki link you had posted earlier does not mention this option. Are you referring another wiki ?
    The "-MF filename" option specifies the file to which the dependency rules are to be written. Typically, "-MD" is enough and based on the output filename will create a dependency file with a ".d" suffix. However, in your case it looks like it is desired that the dependency file have a ".ov5T.dep" suffix and hence the "-MF" option is used.
    The "-o bin/debug/obj/main_host.ov5T" is used to specify the output object file's path and name. This is the object file that will be generated at the end of the compile phase.
    Ashish
    Report Abuse
    • Reply
  • Valdez V.
    Posted by Valdez V.
    on Jan 09 2013 04:40 AM
    Hi Ashish,
    thank you for that clarification. I'm referring to that posted wiki site. I'm asking for these options because there is a point in wiki guide: "Observe compiler invocations to find out build flags." My command-line building with Verbose building option gives me that what I posted previously here in 8. post. It is different than on the wiki site, but I suppose I should use that if it works in command-line. Maybe it is different because of another SysLink version.
    Valdez
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
