Hello everyone,
I use dsplink1.61.01. I read xxxx_flags.txt and I don't know which files define macros such as DA8XXGEM, MAXDSP, ZCPY_LINK etc.
Hi David,
Take a look at the files 'xxxx_defines.txt'. They should contain the macros that need to be defined during compilation, if that is what you are looking for.
Vincent
Hi Vincent,
Maybe my question is not clear. I've already found xxxx_defines.txt in "xx/export/BIN/Linux(DspBios)/DEBUG(RELEASE)"; however, it is an exported file rather than input file . I want to know if want to change some macros where should I edit. Thanks!
These macros are autogenerated based on your DSPLINK configuration that you select when you run the perl configuration script 'dsplinkcfg.pl'. It generates a file called config/BUILD/CURRENTCFG.MK which records all the relevant flags/macros. Why do you need to make change to the macros? Maybe a better way would be to simply re-run the configuration script.
Thank you Vincent!
As I'm not familiar with perl and don't know how to use it, I often change the macro directly. It may be better to rerun the script and I'll try it.
