• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Embedded Software » Linux » Linux forum » CMOS select for 8127
Share
Linux
  • Forum
Options
  • Subscribe via RSS
This question is answered
Pei Jacky
Posted by Pei Jacky
on Mar 30 2012 20:30 PM
Intellectual600 points
In <Sensor_integration_guide_IPNC_DM812x.pdf>, two CMOS (MN34041 V1.1 and AR0330 V1.2) are listed.
I wonder is there other CMOS supported by 8127, or only those two are supported smoothly?
And, what's the function fo the FPGA? Is there any document that describe it?
Pei Jacky.
8127 CMOS FPGA
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • xiang71740
    Posted by xiang71740
    on Mar 30 2012 21:06 PM
    Intellectual715 points
    Hi Jacky,
               The xp2 FPGA(lattice) on MN34041 sensor board is used to convert lvds data to parallel data,then connect to the parallel interface of DM8127
                By the way,which version are you using with IPNC812x?
    Xiang,
    sensor on DM812x
    Report Abuse
    • Reply
  • Pei Jacky
    Posted by Pei Jacky
    on Mar 30 2012 21:54 PM
    Hi, Xiang
    We used RDK V2.0.0.
    I see in ISS package, there are four sensor device: ar0331, mn34041, mt9j003, mt9p031, and only ar0331 and mn34041 has FPGA binary file.
    But 8127 used mt9j003, does it use the FPGA?
    If only those four CMOS are support by 8127?
    and how if we use other CMOS except those two(ar0331 mn34041)?
    Pei Jacky.
    Report Abuse
    • Reply
  • xiang71740
    on Mar 30 2012 22:23 PM
    Hi Jacky,
                  mt9j003 also use lattice FPGA,from Hispi  to parallel(AR0331 also use Hispi mode)
                  The current GA V2.0 release only support these 4 sensors(however,i didn't try mt9p031)
                   Do you mean adding new sensor driver in GA V2.0  for other sensors?
    Xiang
    sensor on DM812x
    Report Abuse
    • Reply
  • Pei Jacky
    Posted by Pei Jacky
    on Mar 31 2012 01:05 AM
    Hi, Xiang
    yes, I mean add other sensor driver.
    1. Can we get a list of CMOS that 8127 support smoothly, and is there some limitation of that?
    2. What exactly the FPGA does(the exact data format before and after the FPGA)?
    3. Where can we get the FPGA code and document? That would help us to deal with the situation of using other CMOS.
    Pei Jacky.
    Report Abuse
    • Reply
  • xiang71740
    on Mar 31 2012 05:33 AM
    Hi Jacky,
                Contact with the people who provide you RDK V2.0.
    Xiang
    sensor on DM812x
    Report Abuse
    • Reply
  • Pei Jacky
    Posted by Pei Jacky
    on Mar 31 2012 05:50 AM
    Any other suggestion?
    We got no help from them, so we come here.
    B.R.
    Jacky.
    Report Abuse
    • Reply
  • xiang71740
    on Apr 01 2012 00:59 AM
    Hi Jacky,
                 if your new sensor board have parallel output,then connect with parallel interface of DM812X directly,for Hispi and lvds,basiclly we use lattice xp2 to do the conversion to parallel.
                For  MIPI interface ,the hardware did have this port,but current release don't support this driver.
    Xiang,
    sensor on DM812x
    Report Abuse
    • Reply
  • Rajat Sagar
    Posted by Rajat Sagar
    on Apr 02 2012 09:24 AM
    Expert3550 points
    Hi Pei Jacky,
    (1) 8127 device has 16-bit parallel interface and 4-lane CSI2 MIPI interface. The maximum clock rating for parllel interface is 162Mhz and for MIPI (CSI2) its 1Gbps/lane. Any CMOS sensor that adheres to the above limits can be integrated to the soc. In our RDK we provide with reference drivers for only few sensors but, you should be able to use the reference to create drivers for any sensor that you want to integrate.
    (2) MT9J003 or AR331 sensors have a HiSPI interface. Since 8127 does not support HiSPI interface the FPGA is put to convert from HiSPI to parallel bus. We are also planning to offer HiSPI to parallel converter chip as option. Please sync up with a local FAE at your end for more details.
    (3) You need to check with local FAE at your end to get the NDA in place before we can share more information on this.
    Rajat Sagar
    Please click the Verify Answer button on this post if it answers the question.
    Report Abuse
    • Reply
  • Mingda Shen
    Posted by Mingda Shen
    on Apr 03 2012 05:28 AM
    Prodigy410 points
    Hi, Pei jacky,
    Let me add some more information,
    we provided CMOS sensor driver of Mt9j003 AR0331 and MN34041,  these code shows you typical way to control
    sensor registers through I2C bus, or SPI(now is simulated by GIO) bus,  you could take these codes for reference if
    you want to add new CMOS sensor support.
    For AR0331,MN34041 sensor,We'll provide improved tuned 2A than GA2.0.in next RDK Release
    YUV sensor support will be provided in this release too .
    Christian.
    Report Abuse
    • Reply
  • Pei Jacky
    Posted by Pei Jacky
    on Apr 05 2012 05:10 AM
    Hi, Sagar
    Besides parallel convert, does the FPGA do other things, for example, convert RGB to YUV?
    That is to say, If the CMOS has parallel interface but out data is RGB, needed FPGA to convert it to YUV?
    and which YUVs does the 8127 support?
    Jacky.
    Report Abuse
    • Reply
  • Rajat Sagar
    on Apr 05 2012 08:46 AM
    Expert3550 points
    Hi Jacky,
    FPGA is only for HiSPI interface protocol to parallel 16-bit video port interface protocol. It does not do any color conversion.
    8127 is capable of capturing RGB, YUV, BAYER formats. In case of DM8127 IPNC example the MT9J003 outputs BAYER format (HiSPI) which is converted into BAYER (parallel port) format - which is captured by parallel port on ISS and then given to ISP for color conversion to YUV.
    Rajat
    Report Abuse
    • Reply
  • Pei Jacky
    Posted by Pei Jacky
    on Apr 08 2012 21:19 PM
    Hi, Rajat
    Thanks for reply.
    We saw that 8127 use Vcam but not Vcap, and in MCFW defined
    VCAM_MODE_E
    {VCAM_MODE_YUV422,
    VCAM_MODE_YUV420}; //16-bit Embedded sync YUV422/420 mode.
    If we use Vcam, the CMOS should give above format data, others we should use FPGA to do a convert, right?
    What's the difference between Vcam and Vcap?
    and, What is the data format the MT9J003 gives(If FPGA Do not convert RGB to YUV, the MT9J003 gives YUV?)?
    Best Regards.
    Pei Jacky.
    Report Abuse
    • Reply
  • Rajat Sagar
    on Apr 08 2012 23:48 PM
    Expert3550 points
    Hello PeiJinkai,
    MT9J003 gives our RAW (BAYER RGGB) format of data. The FPGA does not do any data (color) conversion, it simply changes the HiSPI (MIPI) protocol to video port parallel bus.
    THe ISS port captures the RAW data and does the color conversion (BAYER to YUV) int he ISP.
    Rajat Sagar
    Report Abuse
    • Reply
  • Pei Jacky
    Posted by Pei Jacky
    on Apr 10 2012 07:32 AM
    Hi, Rajat
    I found few information about the ISS and ISP in the RDK.
    Where can we find some detailed documents about it?
    We need to know the exact data forma that the ISS captured from the 16-bit parallel port and how the ISP convert it.
    Thank you very much for help.
    Best Regards.
    Pei Jacky.
    Report Abuse
    • Reply
  • Rajat Sagar
    on Apr 17 2012 00:07 AM
    Verified Answer
    Verified by Pei Jacky
    Expert3550 points
    Hi Pei Jacky,
    The data format that is captured from the 16-bit parallel port is actually dependent on the sensor which is connected.
    ISS documentation is released after an NDA. Can you check with local FAE at your end on the NDA and how to get the ISS TRM documentation?
    Rajat
    Report Abuse
    • Reply
12
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
