I am trying to run appro-mail application in DM368IPNC but i am getting the following output.
# ./appro-mail -tqueue id:0./esmtp user@domain.com.com -f user@domain.com -C /tmp/.esmtprc -X /tmp/log.txtopening config file /tmp/test.cfg===CFG: total 1 files=== 1. /tmp/123.txtSMTP server problem No route to hostAre there any settings which i am missing.
Thanks and Regards,
Mayank
I think you must check system settings:- network settings: default gateway- if you set SMTP-server in printable view, e.g. smtp.domain.com, you must have DNS-server address in /etc/resolv.conf- if you haven't DNS-server you can write ip-address and SMTP-server name in /etc/hosts
Dear Sir,
We reviewed the command such as follow and it is the default SMTP setting.
Please modify the setting about SMTP base on your real local side and then try it again.
For example
# ./appro-mail -tqueue id:0./esmtp lisa@appropho.com -f mark@appropho.com -C /tmp/.esmtprc -X /tmp/log.txtopening config file /tmp/test.cfg
Appro Support Team
