• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Embedded Software » Linux » Linux forum » Kernel panic - not syncing: Attempted to kill init! DM355EVM
Share
Linux
  • Forum
Options
  • Subscribe via RSS
This question is answered
Pavel Goryunov
Posted by Pavel Goryunov
on Apr 28 2012 07:02 AM
Intellectual425 points
Hello everyone. I have some issues booting 2.6.32.rc2 davinci kernel on my DM355EVM
Here is the output of booting process:
DM355 EVM > tftp uImage
dm9000 i/o: 0x4014000, id: 0x90000a46
DM9000: running in 16 bit mode
MAC: 00:0e:99:02:cd:4a
operating at 100M full duplex mode
TFTP from server 10.0.2.15; our IP address is 10.0.2.17
Filename 'uImage'.
Load address: 0x80700000
Loading: #################################################################
done
Bytes transferred = 2963240 (2d3728 hex)
DM355 EVM > bootm
## Booting kernel from Legacy Image at 80700000 ...
   Image Name:   Linux-2.6.32-rc2-davinci1
   Image Type:   ARM Linux Kernel Image (uncompressed)
   Data Size:    2963176 Bytes =  2.8 MB
   Load Address: 80008000
   Entry Point:  80008000
   Verifying Checksum ... OK
   Loading Kernel Image ... OK
OK
Starting kernel ...
Uncompressing Linux............................................................................................................................................................................................... done, booting the kernel.
[    0.000000] Initializing cgroup subsys cpuset
[    0.000000] Linux version 2.6.32-rc2-davinci1 (root@chapel) (gcc version 4.3.3 (Sourcery G++ Lite 2009q1-203) ) #15 Sat Apr 28 15:56:04 MSK 2012
[    0.000000] CPU: ARM926EJ-S [41069265] revision 5 (ARMv5TEJ), cr=00053177
[    0.000000] CPU: VIVT data cache, VIVT instruction cache
[    0.000000] Machine: DaVinci DM355 EVM
[    0.000000] Memory policy: ECC disabled, Data cache writeback
[    0.000000] DaVinci dm355 variant 0x0
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 24384
[    0.000000] Kernel command line: mem=96M console=ttyS0,115200n8 root=/dev/nfs rw nfsroot=10.0.2.15:/home/spl/filesys ip=dhcp
[    0.000000] PID hash table entries: 512 (order: -1, 2048 bytes)
[    0.000000] Dentry cache hash table entries: 16384 (order: 4, 65536 bytes)
[    0.000000] Inode-cache hash table entries: 8192 (order: 3, 32768 bytes)
[    0.000000] allocated 491520 bytes of page_cgroup
[    0.000000] please try 'cgroup_disable=memory' option if you don't want memory cgroups
[    0.000000] Memory: 96MB = 96MB total
[    0.000000] Memory: 90232KB available (5600K code, 863K data, 160K init, 0K highmem)
[    0.000000] SLUB: Genslabs=11, HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[    0.000000] Hierarchical RCU implementation.
[    0.000000] NR_IRQS:245
[    0.000000] Console: colour dummy device 80x30
[    0.000000] Calibrating delay loop... 107.31 BogoMIPS (lpj=536576)
[    0.230000] Security Framework initialized
[    0.230000] SELinux:  Disabled at boot.
[    0.230000] Mount-cache hash table entries: 512
[    0.230000] Initializing cgroup subsys ns
[    0.230000] Initializing cgroup subsys cpuacct
[    0.230000] Initializing cgroup subsys memory
[    0.230000] Initializing cgroup subsys devices
[    0.230000] Initializing cgroup subsys freezer
[    0.230000] CPU: Testing write buffer coherency: ok
[    0.240000] DaVinci: 104 gpio irqs
[    0.240000] regulator: core version 0.5
[    0.240000] NET: Registered protocol family 16
[    0.310000] bio: create slab <bio-0> at 0
[    0.310000] DM355 IPIPE intialized in Single Shot mode
[    0.320000] SCSI subsystem initialized
[    0.320000] vpss vpss: dm355_vpss vpss probed
[    0.320000] vpss vpss: dm355_vpss vpss probe success
[    0.320000] ch0 default output "COMPOSITE", mode "NTSC"
[    0.320000] ch1 default output "", mode ""
[    0.320000] VPBE Encoder Initialized
[    0.320000] NetLabel: Initializing
[    0.320000] NetLabel:  domain hash size = 128
[    0.320000] NetLabel:  protocols = UNLABELED CIPSOv4
[    0.330000] NetLabel:  unlabeled traffic allowed by default
[    0.330000] LogicPD encoder initialized
[    0.330000] Avnetlcd encoder initialized
[    0.330000] Switching to clocksource timer0_1
[    0.360000] musb_hdrc: version 6.0, cppi-dma, peripheral, debug=0
[    0.380000] musb_hdrc: USB Peripheral mode controller at fec64000 using DMA, IRQ 12
[    0.380000] NET: Registered protocol family 2
[    0.380000] IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
[    0.390000] TCP established hash table entries: 4096 (order: 3, 32768 bytes)
[    0.390000] TCP bind hash table entries: 4096 (order: 2, 16384 bytes)
[    0.390000] TCP: Hash tables configured (established 4096 bind 4096)
[    0.390000] TCP reno registered
[    0.390000] NET: Registered protocol family 1
[    0.390000] RPC: Registered udp transport module.
[    0.390000] RPC: Registered tcp transport module.
[    0.390000] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.390000] audit: initializing netlink socket (disabled)
[    0.390000] type=2000 audit(0.390:1): initialized
[    0.550000] VFS: Disk quotas dquot_6.5.2
[    0.550000] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[    0.590000] NTFS driver 2.1.29 [Flags: R/W].
[    0.590000] JFFS2 version 2.2. (NAND) �© 2001-2006 Red Hat, Inc.
[    0.600000] ROMFS MTD (C) 2007 Red Hat, Inc.
[    0.600000] fuse init (API version 7.13)
[    0.600000] msgmni has been set to 176
[    0.610000] alg: No test for stdrng (krng)
[    0.620000] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
[    0.620000] io scheduler noop registered
[    0.620000] io scheduler anticipatory registered
[    0.620000] io scheduler deadline registered
[    0.620000] io scheduler cfq registered (default)
[    0.670000] imp serializer initialized
[    0.670000] davinci_previewer initialized
[    0.670000] davinci_resizer initialized
[    0.670000] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[    0.670000] serial8250.0: ttyS0 at MMIO 0x1c20000 (irq = 40) is a 16550A
[    1.080000] console [ttyS0] enabled
[    1.090000] serial8250.0: ttyS1 at MMIO 0x1c20400 (irq = 41) is a 16550A
[    1.100000] serial8250.0: ttyS2 at MMIO 0x1e06000 (irq = 14) is a 16550A
[    1.110000] nbd: registered device at major 43
[    1.150000] SCSI Media Changer driver v0.25
[    1.160000] slram: not enough parameters.
[    1.180000] NAND device: Manufacturer ID: 0x2c, Chip ID: 0xd3 (Micron NAND 1GiB 3,3V 8-bit)
[    1.190000] 2 NAND chips detected
[    1.200000] Creating 5 MTD partitions on "davinci_nand.0":
[    1.210000] 0x000000000000-0x000000f00000 : "bootloader"
[    1.210000] 0x000000f00000-0x000001000000 : "params"
[    1.220000] 0x000001000000-0x000001400000 : "kernel"
[    1.220000] 0x000001400000-0x000021400000 : "filesystem1"
[    1.230000] 0x000021400000-0x000080000000 : "filesystem2"
[    1.250000] davinci_nand davinci_nand.0: controller rev. 2.3
[    1.270000] Fixed MDIO Bus: probed
[    1.270000] PPP generic driver version 2.4.2
[    1.280000] SLIP: version 0.8.4-NET3.019-NEWTTY (dynamic channels, max=256) (6 bit encapsulation enabled).
[    1.290000] CSLIP: code copyright 1989 Regents of the University of California.
[    1.290000] SLIP linefill/keepalive option.
[    1.300000] tun: Universal TUN/TAP device driver, 1.6
[    1.300000] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[    1.310000] dm9000 Ethernet Driver, V1.31
[    1.440000] eth0: dm9000a at c6ca6000,c6caa002 IRQ 65 MAC: 00:0e:99:02:cd:4a (eeprom)
[    1.450000] console [netcon0] enabled
[    1.450000] netconsole: network logging started
[    1.460000] g_file_storage gadget: no file given for LUN0
[    1.470000] mice: PS/2 mouse device common for all mice
[    1.470000] i2c /dev entries driver
[    1.480000] Linux video capture interface: v2.00
[    1.480000] af major#: 250, minor# 0
[    1.490000] aew major#: 249, minor# 0
[    1.490000] watchdog watchdog: heartbeat 60 sec
[    1.500000] cpuidle: using governor ladder
[    1.500000] cpuidle: using governor menu
[    1.520000] TCP cubic registered
[    1.520000] Initializing XFRM netlink socket
[    1.530000] NET: Registered protocol family 17
[    1.530000] NET: Registered protocol family 33
[    1.540000] registered taskstats version 1
[    1.550000] drivers/rtc/hctosys.c: unable to open rtc device (rtc0)
[    2.100000] eth0: link down
[    2.460000] eth0: link up, 100Mbps, full-duplex, lpa 0xCDE1
[    3.110000] Sending DHCP requests ., OK
[    3.340000] IP-Config: Got DHCP answer from 10.0.2.15, my address is 10.0.2.17
[    3.340000] IP-Config: Complete:
[    3.350000]      device=eth0, addr=10.0.2.17, mask=255.0.0.0, gw=255.255.255.255,
[    3.350000]      host=10.0.2.17, domain=example.org, nis-domain=(none),
[    3.360000]      bootserver=10.0.2.15, rootserver=10.0.2.15, rootpath=
[    3.370000] Looking up port of RPC 100003/2 on 10.0.2.15
[    3.390000] Looking up port of RPC 100005/1 on 10.0.2.15
[    3.410000] VFS: Mounted root (nfs filesystem) on device 0:14.
[    3.420000] Freeing init memory: 160K
[    3.520000] Kernel panic - not syncing: Attempted to kill init!
[    3.520000] Backtrace:
[    3.530000] [<c00346c0>] (dump_backtrace+0x0/0x114) from [<c0458b78>] (dump_stack+0x20/0x24)
[    3.540000]  r6:c05e12dc r5:c05b26b0 r4:c05b26b0
[    3.540000] [<c0458b58>] (dump_stack+0x0/0x24) from [<c0458bd0>] (panic+0x54/0x134)
[    3.550000] [<c0458b7c>] (panic+0x0/0x134) from [<c004f634>] (do_exit+0x6cc/0x700)
[    3.560000]  r3:60000013 r2:c4023e38 r1:c4023c0c r0:c0522cf4
[    3.560000] [<c004ef68>] (do_exit+0x0/0x700) from [<c004f6b4>] (do_group_exit+0x4c/0xcc)
[    3.570000] [<c004f668>] (do_group_exit+0x0/0xcc) from [<c005e888>] (get_signal_to_deliver+0x1c8/0x380)
[    3.580000]  r4:c4022000
[    3.580000] [<c005e6c0>] (get_signal_to_deliver+0x0/0x380) from [<c0032f24>] (do_notify_resume+0xc8/0x5c0)
[    3.590000] [<c0032e5c>] (do_notify_resume+0x0/0x5c0) from [<c0030a68>] (work_pending+0x1c/0x20)
So everything goes fine before userspace attachment. Any suggestions?
Im using filesystem from dvsdk 3.10 "arago-demo-image-dm355-evm.tar.gz" , is it right?
Best regards. Pavel Goryunov.
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Pavel Goryunov
    on May 02 2012 04:43 AM
    Verified Answer
    Verified by Pavel Goryunov
    So, problem was in this option "Kernel Features ->Use the ARM EABI to compile the kernel".
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
