• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Embedded Software » Linux » Linux forum » C66x and uCLinux MCSDK
Share
Linux
  • Forum
Options
  • Subscribe via RSS
Resources
  • Keystone II MCSDK (A15 Linux) Download
  • C66x and uCLinux MCSDK
    This question is not answered
    Jason Bakos
    Posted by Jason Bakos
    on May 03 2012 13:48 PM
    Prodigy15 points
    Hello everyone!
    We're trying to install the new uCLinux MCSDK (linux-c6x-2.0.0.63) onto the TMDSEVM6678LE (rev 1.0) with on-board Blackhawk XDS560v2 emulator.
    Specifically, we're trying to load the IBL into I2C PROM 0x51 and load the Linux kernel into NAND Flash. When we try to boot, code in the BROM appears to become hung waiting on a status register in an I2C register.
    The original single-core Linux system (linux-c6x-2.0-alpha1) included on the CD bundled with the board (as well its corresponding IBL) works fine using the same method.  In this case, we could see the booting information and operate the board with UART terminal.
    Are we doing something wrong with the new Linux release?  I am pretty sure all the on-board switches are in correct position during the different stages (flashing or booting).
    Also worth noting is that the power on self test code(from the original CD) in I2C PROM 0x50 fails for some reason and nothing is printed out when booting.
    Any advise is appreciated, and thank you in advance!
    -Jason D. Bakos
    Report Abuse
    • Reply
    You have posted to a forum that requires a moderator to approve posts before they are publicly available.
    All Replies
    • Rex Chang
      Posted by Rex Chang
      on May 04 2012 08:30 AM
      Intellectual2485 points
      Hi, Jason,
      Is your 6678L a single core or 4-core EVM? If it is a single core, are you using program_evm.js with steps described in User's Guide to burn the kernel to the flash? I am not sure that the same method being used for 2.0-alpha1 means the setup or the way of burning the flash. If you are not using program_evm.js, could you give it a try? Thanks!
      Rex
      Linux-C6x
      Report Abuse
      • Reply
    • Yang Gao
      Posted by Yang Gao
      on May 07 2012 10:45 AM
      Prodigy45 points
      I am with Jason.
      Let me answer your questions.
      Do you mean the single core as single chip? Our board is one chip(C6678) with 8 cores.
      When we burning the roms, we do follow the user guide carefully using the "program_evm.js" script.
      To be honest, we actually don't know any alternative ways to burn the roms without that script.
      And that script works very well. Nothing error or failing are reported; it passed all the verify procedure.
      The "program_evm.js" for 2.0-alpha1 is slightly different with the one in linux-c6x-2.0.0.63.
      However, we thought it should do the similar things. That works very well too. Nothing abnormal is reported.
      We also tried to compile the IBL without using the existing binary and burned it into 0x51 I2C rom.
      It won't work either. It stuck at the same place as the pre-compiled one.
      Any suggestion?
      Thank you!
      Report Abuse
      • Reply
    • Rex Chang
      Posted by Rex Chang
      on May 07 2012 16:17 PM
      Hi, Yang,
      Thanks for your info. I would also like to verify your emulator.  From the description, it is a onboard xds560 Mezzanine, correct? I double checked 2.0.0.63 and I have no problem downloading and does a NAND boot using pre-build image. Please try the script below and see if it works for you, but replace the directories corresponding to your setup. I have a 6678.bat in 2.0.0.63/program_evm directory. Its content is
      cd M:\mnt\sda1\work\pre-build\linux-c6x-2.0.0.63\program_evm
      set DSS_SCRIPT_DIR="C:\Program Files\Texas Instruments\ccsv5\ccs_base_5.0.3.00028\scripting\bin"
      set PROGRAM_EVM_TARGET_CONFIG_FILE=M:\mnt\sda1\work\pre-build\linux-c6x-2.0.0.63\program_evm\configs\evm6678l\evm6678le-linuxhost.ccxml
      %DSS_SCRIPT_DIR%\dss.bat program_evm.js TMDXEVM6678LE
      My M drive maps to the system where the 2.0.0.63 package was downloaded.  The steps I did was
      (1) open a command window on my Window PC (2) change directory to where the program_evm is (3) execute the 6678.bat in the command window of the PC.  Assuming the dip switches are set according to that in "Hardware setup for c66x EVMs" "Programming the EVM" section. Once completed, set the dip switch according to that in the section of "DIP Switch Settings to Boot from NAND".
      Let me know if you still have problem with the batch script above. If you still have problem with it, we can try to set up a webex session to resolve it if you would.
      Rex
      Linux-C6x
      Report Abuse
      • Reply
    • Yang Gao
      Posted by Yang Gao
      on May 09 2012 12:20 PM
      Prodigy45 points
      Hi Rex,
      Thank you for your reply!
      I have several questions.
      1. I can't use the configuration file:
      It will show me some error which I would post later. We had similar problem before when we use a configuration file generated by a different version of CCS.
      But if I use the ccxml generated by our CCS. No error is reported. I believe there is some compatibility issue between CCS versions.
      Anyway, for my understanding, that file is just an emulator configuration and if it works when I use it to debug my code, it should also work to burn flash.
      2. We actually worked with linux version CCS(5.1.0.09000). Does that matter?
      Error in our linux system:
      neutron@neutron:~/Dsp/linux-c6x-2.0.0.63/program_evm$ $DSS_SCRIPT_DIR/dss.sh program_evm.js evm6678le-le “eeprom51,nand”
      board: evm6678l
      endian: Little
      emulation: XDS560 mezzanine
      binaries: /home/neutron/Dsp/linux-c6x-2.0.0.63/program_evm/binaries/evm6678l/
      ccxml: /home/neutron/Dsp/linux-c6x-2.0.0.63/program_evm/configs/evm6678l/evm6678le-linuxhost.ccxml
      SEVERE: Can't generate board data file /home/neutron/.TI/3205019477/0/1/BrdDat/ccBoard0.dat
      An invalid processor ID has been found.
      SEVERE: Could not start server: DebugServer.1: Can't generate board data file /home/neutron/.TI/3205019477/0/1/BrdDat/ccBoard0.dat
      org.mozilla.javascript.WrappedException: Wrapped com.ti.ccstudio.scripting.environment.ScriptingException: Could not start server: DebugServer.1: Can't generate board data file /home/neutron/.TI/3205019477/0/1/BrdDat/ccBoard0.dat
       (program_evm.js#269)
          at org.mozilla.javascript.Context.throwAsScriptRuntimeEx(Context.java:1705)
          at org.mozilla.javascript.MemberBox.invoke(MemberBox.java:157)
          at org.mozilla.javascript.NativeJavaMethod.call(NativeJavaMethod.java:201)
          at org.mozilla.javascript.optimizer.OptRuntime.call2(OptRuntime.java:74)
          at org.mozilla.javascript.gen.c1._c0(program_evm.js:269)
          at org.mozilla.javascript.gen.c1.call(program_evm.js)
          at org.mozilla.javascript.ContextFactory.doTopCall(ContextFactory.java:337)
          at org.mozilla.javascript.ScriptRuntime.doTopCall(ScriptRuntime.java:2755)
          at org.mozilla.javascript.gen.c1.exec(program_evm.js)
          at org.mozilla.javascript.tools.shell.Main.evaluateScript(Main.java:500)
          at org.mozilla.javascript.tools.shell.Main.processFileSecure(Main.java:422)
          at org.mozilla.javascript.tools.shell.Main.processFile(Main.java:388)
          at org.mozilla.javascript.tools.shell.Main.processSource(Main.java:379)
          at org.mozilla.javascript.tools.shell.Main.processFiles(Main.java:176)
          at org.mozilla.javascript.tools.shell.Main$IProxy.run(Main.java:97)
          at org.mozilla.javascript.Context.call(Context.java:540)
          at org.mozilla.javascript.ContextFactory.call(ContextFactory.java:447)
          at org.mozilla.javascript.tools.shell.Main.exec(Main.java:159)
          at org.mozilla.javascript.tools.shell.Main.main(Main.java:137)
      Caused by: com.ti.ccstudio.scripting.environment.ScriptingException: Could not start server: DebugServer.1: Can't generate board data file /home/neutron/.TI/3205019477/0/1/BrdDat/ccBoard0.dat
          at com.ti.debug.engine.scripting.DebugServer$SessionFactory.<init>(DebugServer.java:155)
          at com.ti.debug.engine.scripting.DebugServer.openSession(DebugServer.java:1314)
          at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
          at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
          at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
          at java.lang.reflect.Method.invoke(Unknown Source)
          at org.mozilla.javascript.MemberBox.invoke(MemberBox.java:142)
          ... 18 more
      3. In order to match your working environment, I reinstalled the CCS (5.0.3.00028) windows version and it also have some problem to accept the evm6678le-linuxhost.ccxml.
      The error is like following:
      X:\Dsp\linux-c6x-2.0.0.63\program_evm>"C:\Program Files\Texas Instruments\ccsv5
      ccs_base_5.0.3.00028\scripting\bin"\dss.bat program_evm.js TMDXEVM6678LE
      board: evm6678l
      endian: Little
      binaries: X:\Dsp\linux-c6x-2.0.0.63\program_evm/binaries/evm6678l/
      ccxml: X:\Dsp\linux-c6x-2.0.0.63\program_evm\configs\evm6678l\evm6678le-linuxho
      t.ccxml
      SEVERE: Cannot read System Setup data from XML file X:\Dsp\linux-c6x-2.0.0.63\p
      Error parsing file:
      Fatal Error at (0, 0): An exception occurred! Type:RuntimeException, Message:Th
       primary document entity could not be opened. Id=X:\Dsp\linux-c6x-2.0.0.63\prog
      am_evm\configs\evm6678l\devices\C6678.xml while parsing file: X:\Dsp\linux-c6x-
      .0.0.63\program_evm\configs\evm6678l\devices\C6678.xml
      SEVERE: Can not initialize DebugServer. Cannot read System Setup data from XML
      ile X:\Dsp\linux-c6x-2.0.0.63\program_evm\configs\evm6678l\evm6678le-linuxhost.
      cxml
      Error parsing file:
      SEVERE: Could not start server: DebugServer.1: Can not initialize DebugServer.
      annot read System Setup data from XML file X:\Dsp\linux-c6x-2.0.0.63\program_ev
      Error parsing file:
      onment.ScriptingException: Could not start server: DebugServer.1: Can not initi
      lize DebugServer. Cannot read System Setup data from XML file X:\Dsp\linux-c6x-
      Error parsing file:
      .0.0.63\program_evm\configs\evm6678l\devices\C6678.xml (program_evm.js#269)
      05)
      1)
      37)
      5)
      22)
      tart server: DebugServer.1: Can not initialize DebugServer. Cannot read System
      etup data from XML file X:\Dsp\linux-c6x-2.0.0.63\program_evm\configs\evm6678l\
      Error parsing file:
      Server.java:148)
      a:1337)
              ... 18 more
      Thank you!
      Report Abuse
      • Reply
    • Rex Chang
      Posted by Rex Chang
      on May 21 2012 15:01 PM
      Hi, Yang,
      You can use CCSv5.1 but to work around the issue, you would need to do the following:
      1) create the target config ccxml file using CCSv5.1
      2) In the Advanced Target configuration window, click TMS320C6678_0 -> IcePick_D -> subpath_0 -> C66xx_0 and in the initializatin script box on the right side of the window, enter gel file for c6678 from the CCSv5.1 package. That is to enter "../../emulation/boards/evmc6678l/gel/evmc6678l.gel".
      For some reason, CCSv5.1 does not link the target configuration to the corresponding GEL file by default. By explicitly setting it, I am able to use CCSv5.1 to burn the flash and board comes up fine.
      Please give it a try when you have time and if it works for you, please set the issue status to close. Thanks!
      Rex
      Report Abuse
      • Reply
    TI E2E™ Community
    • Support Forums
    • Blogs
    • Videos
    • Groups
    • Site Support & Feedback
    • Settings
    TI E2E™ Community Groups
    • TI University Program
    • Make the Switch
    • Microcontroller Projects
    • Motor Drive & Control
    Other Communities
    • Deyisupport
    • Designsomething.org
    • beagleboard.org
    • TI on Element 14
    • TI on TechXchangeSM
    Other Technical & Support Resources
    • WEBENCH® Design Center
    • Product Information Centers
    • Technical Documents
    • TI Design Network
    • TI Technical Articles
    • TI Training
    All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
    Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
    Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
    TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
    TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
    embedded processors, along with software, tools and the industry’s largest sales/support staff.
    © Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
    Trademarks | Privacy Policy | Terms of Use
