• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Embedded Software » Linux » Linux forum » How to get DSP address - OMAP L138
Share
Linux
  • Forum
Options
  • Subscribe via RSS
This question is answered
Kiran Kumar
Posted by Kiran Kumar
on Aug 03 2012 02:14 AM
Prodigy150 points
Dear All,
I am trying to edit the DVSDK loop sample to find out the dsp address on the OMAPL138 SOC. I tried by using PROC_GetSymbolAddress() api but it never returned success and I also tried using pointer concept on the dsp side of the sample code (tskLoop.c) no luck.
Please help me on how to get the dsp address.
Kiran Kumar
OMAPl138
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Rahul Prabhu
    Posted by Rahul Prabhu
    on Aug 03 2012 17:04 PM
    Genius15575 points
    Kiran,
    Are you trying to figure out the DSP address in the memory map of the DVSDK? While compiling the DSP side code you can generate a map file using linker options and can see the exact location where each section of your DSP binary gets loaded. In general the DVSDK for OMAPL138 follows the memory map that is mentioned here:
    http://processors.wiki.ti.com/index.php/DVSDK_4.x_MemoryMap
    It wasn`t very clear to me which example you were referring to inside the DVSDK. Perhaps if you provide the path to the example, I can provide you some pointers.
    Rahul
    Please click the
    Verify Answer button on this post if it answers your question.
    Report Abuse
    • Reply
  • Kiran Kumar
    on Aug 06 2012 10:05 AM
    Prodigy150 points
    Hi Rahul,
    My basic requirement is to get data from a specific memory location in the DSP address space.
    These memory location could be the addresses of global variables, function start address, some buffer address etc. which are defined in my DSP code.
    I know that i can use PROC_read/PROC_write to access any specific memory location in DSP.
    Now i am trying to use the PROC_GetSymbolAddress() function to get the DSP address of some symbol which is part of the DSP code. Let me know if this is the right thing to do for the above mentioned scenario.
    Looks like I am not able to figure out how to use the PROC_GetSymbolAddress() function probably. There dont seem to be any example code available in DVSDK for this. Can you point me to some reference code on its usage.
    Kiran Kumar
    Report Abuse
    • Reply
  • GAnthony
    Posted by GAnthony
    on Aug 06 2012 20:19 PM
    Intellectual2580 points
    Hi Kiran:
       1) Getting the DSP address of a symbol:
           As Rahul mentioned, you could either
           a)  generate the DSP .map file and look up the address from the .map, or
           b) call PROC_getSymbolAddress().   If PROC_getSymbolAddress() is failing, what error code do you get?  What trace messages are generated?
    http://processors.wiki.ti.com/index.php/Enabling_trace_in_DSPLink
         Assuming symbols aren't stripped from the executable (See: http://processors.wiki.ti.com/index.php/Using_a_symbol_stripped_DSP_executable_with_DSPLink ), the COFF symbol table should be available after loading.
         Also, what version of DSPLINK are you using?
       2) Example.
         I wasn't able to find an explicit example for your scenario, but it seems PROC_read() should do the job (once you have the address).
    - Gil
    Report Abuse
    • Reply
  • Kiran Kumar
    on Aug 08 2012 10:49 AM
    Prodigy150 points
    Hi Gil/Rahul,
    Thanks for the reply.
    I am able to read the data content of the symbol address using PROC_read(). However I am unable to see the function symbol addresses in the *.map file.
    How will I find the function addresses? so that I can get the control of the DSP program counter and try to jump to that particular location, is this possible? if yes, please let me know the steps/API's to be used.
    Kiran Kumar
    Report Abuse
    • Reply
  • GAnthony
    Posted by GAnthony
    on Aug 08 2012 18:41 PM
    Hi Kiran:
       So, it seems you have succeeded to get a (global variable) symbol's address using PROC_getSymbolAddress() and read its data using PROC_read(), correct?
       If so, you should be able to get the (function) symbol's address as well.
       Ensure the symbol address is global (not declared static), so it will show up in the .map file.  Then you should be able to successfully reference the function symbol from another C file with an extern <type> global_func() declaration.
        However, I don't think you can control the DSP PC directly from the ARM side.  One could poke a new boot address and then reset the DSP to start from that new address, but it's not very efficient.
       Allow me to suggest another design: Since we already know the address on the DSP side, you could write a small DSP server that the ARM notifies with a command payload to jump to any address (i.e., call a DSP function), from the DSP side.
       For example, you could load a DSP server that waits for a function ID payload from an ARM side notification (see NOTIFY_notify), then calls the associated function from an <funcID, functionPtr> look up table.
    - Gil
    Report Abuse
    • Reply
  • Kiran Kumar
    on Aug 13 2012 01:50 AM
    Prodigy150 points
    Hi Gil,
    Thanks for the suggestions.
    Yes, I am able to get the function addresses using PROC_GetsymbolAddress().
    Can you please help me with a sample program? or the set of API's which can be used for implementing the above.
    Kiran Kumar
    Report Abuse
    • Reply
  • GAnthony
    Posted by GAnthony
    on Aug 14 2012 16:50 PM
    Kiran:
         If you need to stay with DSPLink, there is an example in: /dsplink/dsp/src/samples/message/tskMessage.c, which implements a loop in TSKMESSAGE_execute() which can be adapted to receive a message from the host, carrying a function index into a function pointer table, and call the function.   If you need to pass arguments to the function, you could also place them in the message, and return results in the return message back to the host.
        If you just need IPC, and don't need to stick with the DVSDK, you could also upgrade to SysLink 2 (the successor of DSPLink): http://processors.wiki.ti.com/index.php/SysLink_FAQs
         There is an example in the SysLink product, in examples/archive/OMAPL138_linux_elf/ex02_messageq/dsp/Server.c, which shows essentially the same thing: how to await a message from the host, process it (see adaptation below ), and return a result to the host.
          This is just the DSP side, and just a suggestion assuming all you want is a simple server:
          You could do the same thing with DSPLink MSGQ as well...
    ==== Server.c====
    /* import your known DSP functions: */
    extern  int myFunc1(void);
    extern  int myFunc2(void);
    extern  int myFunc3(void);
    typedef int (*MyFxnType)(void);
    /* Set up a function table */
    static MyFxnType funcTable[NUMFUNCS] = {
         myFunc1, myFunc2, myFunc3,
     *  ======== Server_exec ========
    Int Server_exec()
        Int                    status;
        Bool                running = TRUE;
        App_Msg *     msg;
        MessageQ_QueueId    queId;
        MyFxnType    fptr;
        Log_print0(Diags_ENTRY | Diags_INFO, "--> Server_exec:");
        while (running) {
            /* wait for inbound message */
            status = MessageQ_get(Module.videoQue, (MessageQ_Msg *)&msg, MessageQ_FOREVER);
            /* process the message */
          if ('msg->cmd is valid') {
         fptr = funcTable[msg->cmd];
    msg->result = (*fptr)();
    Log_print1(Diags_INFO, "Server_exec: processed cmd=0x%x", msg->cmd);
            /* send message back */
            queId = MessageQ_getReplyQueue(msg); /* type-cast not needed */
            MessageQ_put(queId, (MessageQ_Msg)msg);
        } /* while (running) */
    Report Abuse
    • Reply
  • Kiran Kumar
    on Aug 25 2012 11:09 AM
    Prodigy150 points
    Hello Gil,
    Thanks for the reply, I took sometime to come back was doing some development.
    I am trying to change a global variable on DSP and I am stuck since the change in variable data is not taking effect. I am trying to write a small piece of code to blink the LED on DSP side, wherein I will change the value for number of times LED to Blink from ARM side application.
    Below is the code:
    volatile char src[2]={1,10};
    Void main(Int argc, Char *argv[])
        int i, j;
        char count;
        /* TSK based loopback */
        TSK_Handle tskLoopTask;
        /* Initialize DSP/BIOS LINK. */
        DSPLINK_init () ;
    LedInit();
        while(1)
            if(src[0] == 1){
            led_blink(src[1])
    I am changing the src[ ] array values from GPP(ARM) side but I see the values are changing when read back but dont see the led blinking as expected.
    Please help me.
    one more thing to add:
    Can I use the DVSDK compiling source code to CCS?. I tried but there are lot of library mis-matches. Please clarify on how to compile the code on CCS and then load output files on OMAPL138 without JTAG?.
    Kiran Kumar
    OMAPl138
    Report Abuse
    • Reply
  • GAnthony
    Posted by GAnthony
    on Aug 28 2012 12:43 PM
    Kiran:
        First Question:
        It seems your DSP side is cached.   You may need to flush the cache to see the actual value of your shared variable.
        See this link: http://processors.wiki.ti.com/index.php/Cache_Management
        You can either 1) Disable cache for the memory region in which your shared variable resides; or 2) perform Cache operations on the Sys/BIOS side.
        See the BIOS User's Guide, Section 6.6 Cache Configuration:
        http://www.ti.com/lit/ug/spruex3k/spruex3k.pdf
        You can also search these e2e forum posts:  Google  "site:e2e.ti.com OMAPL138 MAR bits cache" for more hints.
        For your second question, could you be more specific on what you're trying to do?  In general, it should be possible to compile any application in CCS, and load using for example the SysLink SlaveLoader application.
    - Gil
    Report Abuse
    • Reply
  • Kiran Kumar
    on Sep 04 2012 00:52 AM
    Verified Answer
    Verified by Kiran Kumar
    Prodigy150 points
    Dear Gil,
    The cache issue is been fixed I am able to change the values of DSP side global variables. by using one of the cache invalidate API's.
    For my second question, I am trying to compile the application files in CCS, however the same applications are successfully compiled on Linux dsplink and working. May I know is there any way where I can compile the application in both CCS and Linux dsplink and run on OMAPL138?.
    For example, the dsplink_samples like POOL is compiled using DVSDK on Linux and running on OMAPL138. How can I compile the same on CCS?
    Kiran Kumar
    Report Abuse
    • Reply
  • GAnthony
    Posted by GAnthony
    on Sep 04 2012 12:57 PM
    Verified Answer
    Kiran:
       I'm glad the cache issue is resolved.
       For DSPLink CCS project files, here are some links:
       http://processors.wiki.ti.com/index.php/Building_DSPLink_Applications#Method_3:_Building_a_DSPLink_application_using_a_CCS_project_file
       http://processors.wiki.ti.com/index.php/CCS_Project_OMAP-L137_HelloDSP_DSPLINK_example
       There is also a forum post here, giving more details on doing the same with CCS v4 instead of CCS v3, and some ways to resolve the inability to find libraries during build:  http://e2e.ti.com/support/embedded/linux/f/354/t/72421.aspx
    - Gil
    Report Abuse
    • Reply
  • Kiran Kumar
    on Sep 10 2012 09:29 AM
    Prodigy150 points
    Dear Gil,
    Now I am trying to build the DSPLINK examples using CCS. However I have set of questions to ask.. :(
    1. Which CCS version is been supported for OMAPL138?. I am using CCS Version: 4.0.2.01003.
    2. I am unable to compile with the links provided by you, I get the below error.  I tried to compile by using the dsplink libraries of OMAP-L138_dsp_1_00_00_11 version, downloaded from http://software-dl.ti.com/dsps/dsps_public_sw/sdo_sb/targetcontent/omap_l138/1_00/latest/index_FDS.html.
    "../swiLoop.c", line 51: fatal error: could not open source file "std.h"
    1 fatal error detected in the compilation of "../swiLoop.c".
    Compilation terminated.
    "../loop_config.c", line 44: fatal error: could not open source file "dsplink.h"
    1 fatal error detected in the compilation of "../loop_config.c".
    Please help me on compiling the dsplink applications from CCS, I dont know where I am going wrong I am newbie to this CCS, dont mind if I am asking basic questions.
    Kiran Kumar
    Report Abuse
    • Reply
  • GAnthony
    Posted by GAnthony
    on Sep 12 2012 17:19 PM
    Kiran:
       Your compiler include path is missing the "-I <include>" option pointing to where those header files are.
       Did you use Method 1 or Method 2 in these instructions?  http://processors.wiki.ti.com/index.php/Building_DSPLink_Applications#Method_3:_Building_a_DSPLink_application_using_a_CCS_project_file
       If Method 1, then you take the value of TI_DSPLINK_DSP0_INC_PATH from the $DSPLINK/config/BUILD/CURRENTCFG.MK file after having run the dsplinkcfg script, in insert it into your build options.
       Any version of CCS should work, though the location of the Build Options dialog box changes in CCS from version to version.
       Did you try to import the existing CCS v3 project into CCS v4 and then update the search path options?
       You can consult the CCS help file to see how to add search paths to the compiler.
    - Gil
       The last link in my last post had some good advice:
                    "5.2  After this I clicked on the "Include Options" under the C600 Compiler tab on the left.  Then I inserted all the include files based on all the paths specified in
                         the   TI_DSPLINK_DSP0_INC_PATH variable in CURRENTCFG file (${DSPLINK Directory)\config\BUILD)"
    Report Abuse
    • Reply
  • Kiran Kumar
    on Sep 26 2012 07:56 AM
    Prodigy150 points
    Hi Gil,
    I am trying to compile the dsp example located at "C:\OMAP-L138_dsp_1_00_00_11\dsplink_linux_1_65_00_02\dsplink\dsp\src\samples\readwrite" using Method-1
    I tried the link suggested in your last post, and included all the paths (TI_DSPLINK_DSP0_INC_PATH) specified in CURRENTCFG.MK
    But, below list of files were missing from my "C:\OMAP-L138_dsp_1_00_00_11\dsplink_linux_1_65_00_02\dsplink" path which were mentioned in CURRENTCFG.MK
    ${DSPLINK}/dsp/inc/DspBios/DA8XXGEM
    ${DSPLINK}/dsp/src/base/hal/DspBios/5.XX
    ${DSPLINK}/dsp/src/base/hal/DspBios/5.XX/DA8XXGEM
    ${DSPLINK}/dsp/src/base/drv/DspBios/5.XX
    and so on for all the path for 5.XX
    I, any how compiled it by defining  TI_DSPLINK_DSP0_DEFINES and TI_DSPLINK_DSP_COMMON_DEFINES also.
    Now i get an error in the Linking stage (seen below).
    Can you please give me some pointers on what could be the problem and how i can resolve this issue.
    Kiran Kumar
    warning: creating output section ".bss" without a SECTIONS specification
    warning: creating output section ".cinit" without a SECTIONS specification
    warning: creating output section ".const" without a SECTIONS specification
    warning: creating output section ".far" without a SECTIONS specification
    warning: creating output section ".stack" without a SECTIONS specification
    warning: creating output section ".text" without a SECTIONS specification
    warning: creating ".stack" section with default size of 0x400; use the -stack
       option to change the default size
    "../DspBios/6.XX/DA8XXGEM/readwrite.cmd", line 48: warning: memory range not
       found: SDRAM on page 0
    "../DspBios/6.XX/DA8XXGEM/readwrite.cmd", line 48: error: program will not fit
       into available memory.  placement with alignment fails for section
       ".data:DSPLINK_shmBaseAddress" size 0x0
    "../DspBios/6.XX/DA850GEM/readwrite.cmd", line 48: warning: memory range not
    "../DspBios/6.XX/DA850GEM/readwrite.cmd", line 48: error: program will not fit
    "../DspBios/5.XX/OMAPL1XXGEM/readwrite.cmd", line 48: warning: memory range not
    "../DspBios/5.XX/OMAPL1XXGEM/readwrite.cmd", line 48: error: program will not
       fit into available memory.  placement with alignment fails for section
    "../DspBios/5.XX/OMAPL138GEM/readwrite.cmd", line 48: warning: memory range not
       found: DDR on page 0
    "../DspBios/5.XX/OMAPL138GEM/readwrite.cmd", line 48: error: program will not
     undefined                                   first referenced
      symbol                                         in file
     _BCACHE_inv                                 ./tskReadwrite.obj
     _BCACHE_wbInv                               ./tskReadwrite.obj
     _DDR                                        ./tskReadwrite.obj
     _DSPLINK_init                               ./main.obj
     _FXN_F_nop                                  ./readwrite_config.obj
     _LOG_printf                                 ./tskReadwrite.obj
     _MEM_calloc                                 ./tskReadwrite.obj
     _MEM_free                                   ./tskReadwrite.obj
     _MSGQ_ATTRS                                 ./tskReadwrite.obj
     _MSGQ_close                                 ./tskReadwrite.obj
     _MSGQ_get                                   ./tskReadwrite.obj
     _MSGQ_locate                                ./tskReadwrite.obj
     _MSGQ_open                                  ./tskReadwrite.obj
     _MSGQ_put                                   ./tskReadwrite.obj
     _SMAPOOL_FXNS                               ./readwrite_config.obj
     _SMAPOOL_init                               ./readwrite_config.obj
     _TSK_create                                 ./main.obj
     _ZCPYMQT_FXNS                               ./readwrite_config.obj
     _ZCPYMQT_init                               ./readwrite_config.obj
     _ti_sysbios_ipc_Semaphore_Object__create__S ./tskReadwrite.obj
     _ti_sysbios_ipc_Semaphore_pend__E           ./tskReadwrite.obj
     _ti_sysbios_ipc_Semaphore_post__E           ./tskReadwrite.obj
     _ti_sysbios_knl_Task_sleep__E               ./tskReadwrite.obj
     _trace                                      ./tskReadwrite.obj
    error: unresolved symbols remain
    error: errors encountered during linking; "readwrite.out" not built
    C:\Program Files\Texas Instruments\ccsv4\utils\gmake\gmake: *** [readwrite.out] Error 1
    C:\Program Files\Texas Instruments\ccsv4\utils\gmake\gmake: Target `all' not remade because of errors.
    Report Abuse
    • Reply
  • GAnthony
    Posted by GAnthony
    on Sep 26 2012 12:50 PM
    Kiran:
       It appears some macros are not being defined properly in the configuration of DSPLink, which is causing you to add some wrong libraries and paths to the CCS Build options.
       The unresolved symbol errors imply the BIOS v 6 libraries are getting set in the Linker tab, and DSPLink libraries are missing.
       The memory map errors may also be the result of choosing the wrong platform.
       Maybe you have a "--dspos_0=DSPBIOS6XX" defined somewhere in the configuration?
       I would clean out the DSPLink build configuration files, and follow carefully the instructions in the DSPLink UserGuide, Section 9.3, on   "DSPLink Build Configuration".
       Additionally, look at the Build Option paths and libraries, to make sure you are getting the right libraries in.   See the detailed steps here also:
    - Gil
    Report Abuse
    • Reply
12
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
