• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Embedded Software » Linux » Linux forum » DM3730 GStreamer example Loopback Video error
Share
Linux
  • Forum
Options
  • Subscribe via RSS
This question is answered
jay liyang
Posted by jay liyang
on Aug 14 2012 02:23 AM
Intellectual515 points
Hi,everyone!
I have a DM3730 board, and I want to trasmit some video data to webserver wit GStreamer
the website  is about example GSstreamer pipelines ,http://processors.wiki.ti.com/index.php/Example_GStreamer_Pipelines#OMAP35x
 I have referenced the OMAP35x's  Loopback Video command ,
command as followed :
gst-launch -v videotestsrc ! TIDmaiVideoSink videoStd=VGA videoOutput=LCD accelFrameCopy=FALSE sync=false
at the Ubuntu ,
root@dm37x-evm:/usr/share/ti/dvsdk-demos# gst-launch -v videotestsrc ! TIDmaiVid
Setting pipeline to PAUSED ...
/GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0.GstPad:src: caps = video/x-raw-yuv, format=(fourcc)UYVY, color-matrix=(string)sdtv, chroma-site=(string)mpeg2, width=(int)320, height=(int)240, framerate=(fraction)30/1
Pipeline is PREROLLING ...
/GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0.GstPad:src: caps = video/x-raw-yuv, format=(fourcc)UYVY, color-matrix=(string)sdtv, chroma-site=(string)mpeg2, width=(int)640, height=(int)480, framerate=(fraction)30/1
/GstPipeline:pipeline0/GstTIDmaiVideoSink:tidmaivideosink0.GstPad:sink: caps = video/x-raw-yuv, format=(fourcc)UYVY, color-matrix=(string)sdtv, chroma-site=(string)mpeg2, width=(int)640, height=(int)480, framerate=(fraction)30/1
Pipeline is PREROLLED ...
Setting pipeline to PLAYING ...
New clock: GstSystemClock
delay stream on ....
ERROR: from element /GstPipeline:pipeline0/GstTIDmaiVideoSink:tidmaivideosink0: Failed to get display bufferAdditional debug info:
gsttidmaivideosink.c(1686): gst_tidmaivideosink_render (): /GstPipeline:pipeline0/GstTIDmaiVideoSink:tidmaivideosink0
Execution ended after 30334473 ns.
Setting pipeline to READY ...
/GstPipeline:pipeline0/GstTIDmaiVideoSink:tidmaivideosink0.GstPad:sink: caps = NULL
/GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0.GstPad:src: caps = NULL
Setting pipeline to NULL ...
Freeing pipeline ...
why?
Hope this help!
DM3730 Loopback Video GStreamer
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Pushpa Latha
    Posted by Pushpa Latha
    on Aug 14 2012 02:41 AM
    Verified Answer
    Verified by jay liyang
    Prodigy140 points
    Hi li,
      Try  "tidisplaysink2" instead of  "TIDmaiVideoSink"
    gst-launch -v videotestsrc ! tidisplaysink2
    Pushpa
    Report Abuse
    • Reply
  • jay liyang
    on Aug 14 2012 21:58 PM
    Hi Pushpa!
    You are right! Thank  you for your fast respond!
    but,I just  get a dispaly as shown in figure:
    I want to display the composite camera with PAL , I use the DM3730 chip
    How to do it ?
    Hope help!
    Yang
    Report Abuse
    • Reply
  • Pushpa Latha
    on Aug 15 2012 23:46 PM
    Verified Answer
    Prodigy140 points
    Hi Yang,
      Of course yes, it displays the above video because 'videotestsrc' produces a standard test video which consists of set of colour bars with some random noise.
    If you want to display the captured video, you have to make use of v4l2src instead of videotestsrc.
    gst-launch -v v4l2src device=/dev/video0 ! ffmpegcolorspace ! videoscale ! video/x-raw-yuv,format=\(fourcc\)UYVY, framerate=\(fraction\)30000/1001, width=720, height=576 ! tidisplaysink2 -v
     Pushpa
    Report Abuse
    • Reply
  • jay liyang
    on Aug 16 2012 03:49 AM
    Hi Pushpa,
    Thank you for your fast response ,and I follow you
    but,  the error just a small section display as followed:
    ERROR: Pipeline doesn't want to pause.
    ERROR: from element /GstPipeline:pipeline0/GstV4l2Src:v4l2src0: Device '/dev/video0' cannot capture at 720x576
    Why? how to do about it?
    Thanks!
    Report Abuse
    • Reply
  • Pushpa Latha
    on Aug 16 2012 04:30 AM
    Prodigy140 points
    Hi Jay,
      Check whether your PAL camera works fine.  You can check it by  connecting the camera directly to TV .        Because the same is working fine for me
    Which version of DVSDK are you using?
    Pushpa
    Report Abuse
    • Reply
  • jay liyang
    on Aug 16 2012 19:12 PM
    Hi Pushpa,
    Thank you for your response!
    The DVSDK version is   dvsdk_dm3730-evm_4_02_00_06_setuplinux.
    When  I  do the experience about "ti-dmai-apps" with the execulable file "video_loopback_dm3730.x470MV",
    the camera image  can display on the Seven-inch LCD screen.  so ,my hardware connection  has no problem.
    The bug about the DVSDK version?
    Thanks!
    Report Abuse
    • Reply
  • jay liyang
    on Aug 16 2012 19:32 PM
    Hi Pushpa,
    I connect  the PAL camera to TVP5146M2IPFP pin 80 about VI_1_A .
    is my connect  wrong ?
    Thanks!
    Report Abuse
    • Reply
  • Pushpa Latha
    on Aug 17 2012 04:14 AM
    Prodigy140 points
    Hi Jay,
       If the video loopback is working fine with camera, then there is no problem w.r.t camera and hardware connections.
    Make sure the camera you are using is PAL.
    You can further know what's happening, by enabling the debug traces:
    GST_DEBUG=3 gst-launch -v v4l2src device=/dev/video0 ! ffmpegcolorspace ! videoscale ! video/x-raw-yuv,format=\(fourcc\)UYVY, framerate=\(fraction\)30000/1001, width=720, height=576 ! tidisplaysink2 -v
    Pushpa
    Report Abuse
    • Reply
  • jay liyang
    on Aug 20 2012 19:36 PM
    Hi,Pushpa
    I am sorry , only just I see your respones and thank you for your enthusiasm.
    I try your command,as follows:
    root@dm37x-evm:~# GST_DEBUG=3 gst-launch -v v4l2src device=/dev/video0 ! ffmpegc
    0:00:00.151000975  1648    0x15018 INFO                GST_INIT gst.c:599:init_pre: Initializing GStreamer Core Library version 0.10.30
    0:00:00.211425779  1648    0x15018 INFO                GST_INIT gst.c:600:init_pre: Using library installed in /usr/lib
    0:00:00.211639403  1648    0x15018 INFO                GST_INIT gst.c:610:init_pre: Linux dm37x-evm 2.6.32 #7 PREEMPT Tue Aug 7 22:10:33 PDT 2012 armv7l
    0:00:00.447967528  1648    0x15018 INFO                GST_INIT gstquery.c:105:_gst_query_initialize: init queries
    0:00:01.664978026  1648    0x15018 INFO                GST_INIT gstmessage.c:73:_gst_message_initialize: init messages
    0:00:01.665771482  1648    0x15018 INFO      GST_PLUGIN_LOADING gstplugin.c:348:_gst_plugin_initialize: registering 0 static plugins
    0:00:01.667144773  1648    0x15018 INFO      GST_PLUGIN_LOADING gstplugin.c:254:gst_plugin_register_static: registered static plugin "staticelements"
    0:00:01.667327879  1648    0x15018 INFO      GST_PLUGIN_LOADING gstplugin.c:256:gst_plugin_register_static: added static plugin "staticelements", result: 1
    0:00:02.865966795  1648    0x15018 INFO            GST_REGISTRY gstregistry.c:1572:ensure_current_registry: reading registry cache: /home/root/.gstreamer-0.10/registry.arm.bin
    0:00:05.258483885  1648    0x15018 INFO            GST_REGISTRY gstregistrybinary.c:601:gst_registry_binary_read_cache: loaded /home/root/.gstreamer-0.10/registry.arm.bin in 2.392181 seconds
    0:00:05.258972166  1648    0x15018 INFO            GST_REGISTRY gstregistry.c:1442:scan_and_update_registry: Validating plugins from registry cache: /home/root/.gstreamer-0.10/registry.arm.bin
    0:00:07.754852294  1648    0x15018 INFO            GST_REGISTRY gstregistry.c:1534:scan_and_update_registry: Registry cache has not changed
    0:00:07.755126952  1648    0x15018 INFO            GST_REGISTRY gstregistry.c:1601:ensure_current_registry: registry reading and updating done, result = 1
    0:00:07.755218504  1648    0x15018 INFO                GST_INIT gst.c:786:init_post: GLib runtime version: 2.24.1
    0:00:07.755310057  1648    0x15018 INFO                GST_INIT gst.c:788:init_post: GLib headers version: 2.24.1
    0:00:07.755554198  1648    0x15018 INFO            GST_PIPELINE gstparse.c:291:gst_parse_launch_full: parsing pipeline description 'v4l2src device=/dev/video0 ! ffmpegcolorspace ! videoscale ! video/x-raw-yuv,format=(fourcc)UYVY, framerate=(fraction)30000/1001, width=720, height=576 ! tidisplaysink2 '
    0:00:09.140930174  1648    0x15018 INFO      GST_PLUGIN_LOADING gstplugin.c:800:gst_plugin_load_file: plugin "/usr/lib/gstreamer-0.10/libgstvideo4linux2.so" loaded
    0:00:09.141174315  1648    0x15018 INFO     GST_ELEMENT_FACTORY gstelementfactory.c:363:gst_element_factory_create: creating element "v4l2src"
    0:00:09.217620848  1648    0x15018 INFO        GST_ELEMENT_PADS gstelement.c:711:gst_element_add_pad:<GstBaseSrc@0xea048> adding pad 'src'
    0:00:09.390380857  1648    0x15018 INFO      GST_PLUGIN_LOADING gstplugin.c:800:gst_plugin_load_file: plugin "/usr/lib/gstreamer-0.10/libgstffmpegcolorspace.so" loaded
    0:00:09.390624997  1648    0x15018 INFO     GST_ELEMENT_FACTORY gstelementfactory.c:363:gst_element_factory_create: creating element "ffmpegcolorspace"
    0:00:09.396850583  1648    0x15018 INFO        GST_ELEMENT_PADS gstelement.c:711:gst_element_add_pad:<GstBaseTransform@0xea278> adding pad 'sink'
    0:00:09.397247311  1648    0x15018 INFO        GST_ELEMENT_PADS gstelement.c:711:gst_element_add_pad:<GstBaseTransform@0xea278> adding pad 'src'
    0:00:09.990509032  1648    0x15018 INFO      GST_PLUGIN_LOADING gstplugin.c:800:gst_plugin_load_file: plugin "/usr/lib/gstreamer-0.10/libgstvideoscale.so" loaded
    0:00:09.990783690  1648    0x15018 INFO     GST_ELEMENT_FACTORY gstelementfactory.c:363:gst_element_factory_create: creating element "videoscale"
    0:00:09.995025633  1648    0x15018 INFO        GST_ELEMENT_PADS gstelement.c:711:gst_element_add_pad:<GstBaseTransform@0x1040c0> adding pad 'sink'
    0:00:09.995361326  1648    0x15018 INFO        GST_ELEMENT_PADS gstelement.c:711:gst_element_add_pad:<GstBaseTransform@0x1040c0> adding pad 'src'
    0:00:11.968200683  1648    0x15018 INFO      GST_PLUGIN_LOADING gstplugin.c:800:gst_plugin_load_file: plugin "/usr/lib/gstreamer-0.10/libgstti_backup/libgstticodecplugin.so" loaded
    0:00:11.968444823  1648    0x15018 INFO     GST_ELEMENT_FACTORY gstelementfactory.c:363:gst_element_factory_create: creating element "tidisplaysink2"
    0:00:11.969635009  1648    0x15018 INFO        GST_ELEMENT_PADS gstelement.c:711:gst_element_add_pad:<GstBaseSink@0x108090> adding pad 'sink'
    0:00:11.970092772  1648    0x15018 INFO     GST_ELEMENT_FACTORY gstelementfactory.c:363:gst_element_factory_create: creating element "pipeline"
    0:00:11.971099852  1648    0x15018 INFO            GST_PIPELINE ./grammar.y:568:gst_parse_perform_link: linking v4l2src0:(any) to ffmpegcsp0:(any) (0/0) with caps "(nil)"
    0:00:11.971313475  1648    0x15018 INFO        GST_ELEMENT_PADS gstutils.c:1592:gst_element_link_pads_full: trying to link element v4l2src0:(any) to element ffmpegcsp0:(any)
    0:00:11.971496581  1648    0x15018 INFO                GST_PADS gstutils.c:1046:gst_pad_check_link: trying to link v4l2src0:src and ffmpegcsp0:src
    0:00:11.971588134  1648    0x15018 INFO                GST_PADS gstutils.c:1066:gst_pad_check_link: Sink pad ffmpegcsp0:src is not sink pad, failed
    0:00:11.971679686  1648    0x15018 INFO                GST_PADS gstutils.c:1046:gst_pad_check_link: trying to link v4l2src0:src and ffmpegcsp0:sink
    0:00:11.980743407  1648    0x15018 INFO                GST_PADS gstutils.c:1493:prepare_link_maybe_ghosting: v4l2src0 and ffmpegcsp0 in same bin, no need for ghost pads
    0:00:11.981170653  1648    0x15018 INFO                GST_PADS gstpad.c:1906:gst_pad_link_prepare: trying to link v4l2src0:src and ffmpegcsp0:sink
    0:00:11.989166258  1648    0x15018 INFO                GST_PADS gstpad.c:2089:gst_pad_link_full: linked v4l2src0:src and ffmpegcsp0:sink, successful
    0:00:11.989410399  1648    0x15018 INFO            GST_PIPELINE ./grammar.y:568:gst_parse_perform_link: linking ffmpegcsp0:(any) to videoscale0:(any) (0/0) with caps "(nil)"
    0:00:11.989532469  1648    0x15018 INFO        GST_ELEMENT_PADS gstutils.c:1592:gst_element_link_pads_full: trying to link element ffmpegcsp0:(any) to element videoscale0:(any)
    0:00:11.989654540  1648    0x15018 INFO                GST_PADS gstutils.c:1046:gst_pad_check_link: trying to link ffmpegcsp0:src and videoscale0:src
    0:00:11.989746092  1648    0x15018 INFO                GST_PADS gstutils.c:1066:gst_pad_check_link: Sink pad videoscale0:src is not sink pad, failed
    0:00:11.989837645  1648    0x15018 INFO                GST_PADS gstutils.c:1046:gst_pad_check_link: trying to link ffmpegcsp0:src and videoscale0:sink
    0:00:12.024871824  1648    0x15018 INFO                GST_PADS gstutils.c:1493:prepare_link_maybe_ghosting: ffmpegcsp0 and videoscale0 in same bin, no need for ghost pads
    0:00:12.025115965  1648    0x15018 INFO                GST_PADS gstpad.c:1906:gst_pad_link_prepare: trying to link ffmpegcsp0:src and videoscale0:sink
    0:00:12.060089110  1648    0x15018 INFO                GST_PADS gstpad.c:2089:gst_pad_link_full: linked ffmpegcsp0:src and videoscale0:sink, successful
    0:00:12.060333251  1648    0x15018 INFO            GST_PIPELINE ./grammar.y:568:gst_parse_perform_link: linking videoscale0:(any) to tidisplaysink20:(any) (0/0) with caps "0x6d000"
    0:00:12.702148436  1648    0x15018 INFO      GST_PLUGIN_LOADING gstplugin.c:800:gst_plugin_load_file: plugin "/usr/lib/gstreamer-0.10/libgstcoreelements.so" loaded
    0:00:12.702392577  1648    0x15018 INFO     GST_ELEMENT_FACTORY gstelementfactory.c:363:gst_element_factory_create: creating element "capsfilter"
    0:00:12.703002928  1648    0x15018 INFO        GST_ELEMENT_PADS gstelement.c:711:gst_element_add_pad:<GstBaseTransform@0x113090> adding pad 'sink'
    0:00:12.703247069  1648    0x15018 INFO        GST_ELEMENT_PADS gstelement.c:711:gst_element_add_pad:<GstBaseTransform@0x113090> adding pad 'src'
    0:00:12.703460692  1648    0x15018 INFO              GST_STATES gstbin.c:1710:gst_bin_get_state_func:<pipeline0> getting state
    0:00:12.703674315  1648    0x15018 INFO              GST_STATES gstelement.c:2236:gst_element_continue_state:<capsfilter0> completed state change to NULL
    0:00:12.703887938  1648    0x15018 INFO        GST_ELEMENT_PADS gstutils.c:1592:gst_element_link_pads_full: trying to link element videoscale0:(any) to element capsfilter0:sink
    0:00:12.703979490  1648    0x15018 INFO        GST_ELEMENT_PADS gstelement.c:958:gst_element_get_static_pad: found pad capsfilter0:sink
    0:00:12.704071043  1648    0x15018 INFO                GST_PADS gstutils.c:1493:prepare_link_maybe_ghosting: videoscale0 and capsfilter0 in same bin, no need for ghost pads
    0:00:12.704223631  1648    0x15018 INFO                GST_PADS gstpad.c:1906:gst_pad_link_prepare: trying to link videoscale0:src and capsfilter0:sink
    0:00:12.770690917  1648    0x15018 INFO                GST_PADS gstpad.c:2089:gst_pad_link_full: linked videoscale0:src and capsfilter0:sink, successful
    0:00:12.771026610  1648    0x15018 INFO        GST_ELEMENT_PADS gstutils.c:1592:gst_element_link_pads_full: trying to link element capsfilter0:src to element tidisplaysink20:(any)
    0:00:12.771148680  1[  244.748870] tvp514x 2-005d: tvp5146m2 found at 0xba (OMAP I2C adapter)
    648    0x15018 INFO        GST_ELEMENT_PADS gstelement.c:958:gst_element_get_static_pad: found pad capsfilter0:src
    0:00:12.771240233  1648    0x15018 INFO                GST_PADS gstutils.c:1046:gst_pad_check_link: trying to link capsfilter0:src and tidisplaysink20:sink
    0:00:12.839385984  1648    0x15018 INFO                GST_PADS gstutils.c:1493:prepare_link_maybe_ghosting: capsfilter0 and tidisplaysink20 in same bin, no need for ghost pads
    0:00:12.839691161  1648    0x15018 INFO                GST_PADS gstpad.c:1906:gst_pad_link_prepare: trying to link capsfilter0:src and tidisplaysink20:sink
    0:00:12.908355711  1648    0x15018 INFO                GST_PADS gstpad.c:2089:gst_pad_link_full: linked capsfilter0:src and tidisplaysink20:sink, successful
    0:00:12.909057615  1648    0x15018 INFO              GST_STATES gstelement.c:2236:gst_element_continue_state:<tidisplaysink20> completed state change to READY
    0:00:12.909210203  1648    0x15018 INFO              GST_STATES gstelement.c:2249:gst_element_continue_state:<tidisplaysink20> posting state-changed NULL to READY
    0:00:12.909454344  1648    0x15018 INFO              GST_STATES gstbin.c:2443:gst_bin_change_state_func:<pipeline0> child 'tidisplaysink20' changed state to 2(READY) successfully
    0:00:12.909637449  1648    0x15018 INFO              GST_STATES gstelement.c:2236:gst_element_continue_state:<capsfilter0> completed state change to READY
    0:00:12.909729002  1648    0x15018 INFO              GST_STATES gstelement.c:2249:gst_element_continue_state:<capsfilter0> posting state-changed NULL to READY
    0:00:12.909851072  1648    0x15018 INFO              GST_STATES gstbin.c:2443:gst_bin_change_state_func:<pipeline0> child 'capsfilter0' changed state to 2(READY) successfully
    0:00:12.910034178  1648    0x15018 INFO              GST_STATES gstelement.c:2236:gst_element_continue_state:<videoscale0> completed state change to READY
    0:00:12.910125731  1648    0x15018 INFO              GST_STATES gstelement.c:2249:gst_element_continue_state:<videoscale0> posting state-changed NULL to READY
    0:00:12.910217284  1648    0x15018 INFO              GST_STATES gstbin.c:2443:gst_bin_change_state_func:<pipeline0> child 'videoscale0' changed state to 2(READY) successfully
    0:00:12.910339354  1648    0x15018 INFO              GST_STATES gstelement.c:2236:gst_element_continue_state:<ffmpegcsp0> completed state change to READY
    0:00:12.910430907  1648    0x15018 INFO              GST_STATES gstelement.c:2249:gst_element_continue_state:<ffmpegcsp0> posting state-changed NULL to READY
    0:00:12.910522460  1648    0x15018 INFO              GST_STATES gstbin.c:2443:gst_bin_change_state_func:<pipeline0> child 'ffmpegcsp0' changed state to 2(READY) successfully
    [  247.321044] tvp514x 2-005d: invalid control id -2147483648
    [  247.749267] tvp514x 2-005d: invalid control id 9963780
    [  247.754455] tvp514x 2-005d: invalid control id 9963781
    [  247.760009] tvp514x 2-005d: invalid control id 9963782
    [  247.765441] tvp514x 2-005d: invalid control id 9963783
    [  247.770629] tvp514x 2-005d: invalid control id 9963784
    [  247.776062] tvp514x 2-005d: invalid control id 9963785
    [  247.781372] tvp514x 2-005d: invalid control id 9963786
    [  247.786712] tvp514x 2-005d: invalid control id 9963787
    [  247.791870] tvp514x 2-005d: invalid control id 9963788
    [  247.797546] tvp514x 2-005d: invalid control id 9963789
    [  247.802886] tvp514x 2-005d: invalid control id 9963790
    [  247.808044] tvp514x 2-005d: invalid control id 9963791
    [  247.813446] tvp514x 2-005d: invalid control id 9963792
    [  247.818756] tvp514x 2-005d: invalid control id 9963793
    [  247.823944] tvp514x 2-005d: invalid control id 9963795
    [  247.829345] tvp514x 2-005d: invalid control id 9963796
    [  247.834716] tvp514x 2-005d: invalid control id 9963797
    [  247.839904] tvp514x 2-005d: invalid control id 9963798
    [  247.845306] tvp514x 2-005d: invalid control id 9963799
    [  247.850616] tvp514x 2-005d: invalid control id 9963800
    [  247.855773] tvp514x 2-005d: invalid control id 9963801
    [  247.861145] tvp514x 2-005d: invalid control id 9963802
    [  247.866485] tvp514x 2-005d: invalid control id 9963803
    [  247.871643] tvp514x 2-005d: invalid control id 9963804
    [  247.877044] tvp514x 2-005d: invalid control id 9963805
    [  247.882354] tvp514x 2-005d: invalid control id 9963806
    0:00:16.050079344  1648    0x15018 INFO                    v4l2 v4l2_calls.c:558:gst_v4l2_open:<v4l2src0> Opened device 'omap3/tvp514x//' (/dev/video0) successfully
    0:00:16.050476072  1648    0x15018 INFO              GST_STATES gstelement.c:2236:gst_element_continue_state:<v4l2src0> completed state change to READY
    0:00:16.051361083  1648    0x15018 INFO              GST_STATES gstelement.c:2249:gst_element_continue_state:<v4l2src0> posting state-changed NULL to READY
    0:00:16.051544188  1648    0x15018 INFO              GST_STATES gstbin.c:2443:gst_bin_change_state_func:<pipeline0> child 'v4l2src0' changed state to 2(READY) successfully
    0:00:16.051727294  1648    0x15018 INFO              GST_STATES gstelement.c:2209:gst_element_continue_state:<pipeline0> committing state from NULL to READY, pending PAUSED, next PAUSED
    0:00:16.051879881  1648    0x15018 INFO              GST_STATES gstelement.c:2218:gst_element_continue_state:<pipeline0> continue state change READY to PAUSED, final PAUSED
    0:00:16.052215575  1648    0x15018 INFO              GST_STATES gstbin.c:2449:gst_bin_change_state_func:<pipeline0> child 'tidisplaysink20' is changing state asynchronously to PAUSED
    0:00:16.052398680  1648    0x15018 INFO              GST_STATES gstelement.c:2236:gst_element_continue_state:<capsfilter0> completed state change to PAUSED
    0:00:16.052490233  1648    0x15018 INFO              GST_STATES gstelement.c:2249:gst_element_continue_state:<capsfilter0> posting state-changed READY to PAUSED
    0:00:16.052612303  1648    0x15018 INFO              GST_STATES gstbin.c:2443:gst_bin_change_state_func:<pipeline0> child 'capsfilter0' changed state to 3(PAUSED) successfully
    0:00:16.052734374  1648    0x15018 INFO              GST_STATES gstelement.c:2236:gst_element_continue_state:<videoscale0> completed state change to PAUSED
    0:00:16.052825926  1648    0x15018 INFO              GST_STATES gstelement.c:2249:gst_element_continue_state:<videoscale0> posting state-changed READY to PAUSED
    0:00:16.052947997  1648    0x15018 INFO              GST_STATES gstbin.c:2443:gst_bin_change_state_func:<pipeline0> child 'videoscale0' changed state to 3(PAUSED) successfully
    0:00:16.053070067  1648    0x15018 INFO              GST_STATES gstelement.c:2236:gst_element_continue_state:<ffmpegcsp0> completed state change to PAUSED
    0:00:16.053192137  1648    0x15018 INFO              GST_STATES gstelement.c:2249:gst_element_continue_state:<ffmpegcsp0> posting state-changed READY to PAUSED
    0:00:16.053283690  1648    0x15018 INFO              GST_STATES gstbin.c:2443:gst_bin_change_state_func:<pipeline0> child 'ffmpegcsp0' changed state to 3(PAUSED) successfully
    0:00:16.053497313  1648    0x15018 INFO                    v4l2 gstv4l2object.c:956:gst_v4l2_object_fill_format_list:<v4l2src0> got 7 format(s):
    0:00:16.053588866  1648    0x15018 INFO                    v4l2 gstv4l2object.c:962:gst_v4l2_object_fill_format_list:<v4l2src0>   YUYV
    0:00:16.053680418  1648    0x15018 INFO                    v4l2 gstv4l2object.c:962:gst_v4l2_object_fill_format_list:<v4l2src0>   UYVY
    0:00:16.053741453  1648    0x15018 INFO   ivision by zero in kernel.
    m                v4l2 gstv4l2obj[  248.233001] [<c003d988>] (unwind_backtrace+0x0/0xdc) from [<c01e68bc>] (Ldiv0+0x8/0x10)
    ect.c:962:gst_v4l2_object_fill_f[  248.243774] Division by zero in kernel.
    ormat_list:<v4l2src0>   YU1[  248.250396] [<c003d988>] (unwind_backtrace+0x0/0xdc) from [<c01e68bc>] (Ldiv0+0x8/0x10)
    2 (emulated)
    0:00:16.053833006 [  248.261535] Division by zero in kernel.
     1648    0x15018 003d988>] (unwind_backtrace+0x0/0xdc) from [<c01e68bc>] (Ldiv0+0x8/0x10)
    ;01mINFO              [  248.278808] Division by zero in kernel.
          v4l2 gstv4l2object.c:962:g[  248.285247] [<c003d988>] (unwind_backtrace+0x0/0xdc) from [<c01e68bc>] (Ldiv0+0x8/0x10)
    st_v4l2_object_fill_format_list:[  248.296569] Division by zero in kernel.
    <v4l2src0>   YV12 (emulated[  248.302978] [<c003d988>] (unwind_backtrace+0x0/0xdc) from [<c01e68bc>] (Ldiv0+0x8/0x10)
    0:00:16.388671874  1648[  248.313781] Division by zero in kernel.
        0x15018 INFO   [  248.320404] [<c003d988>] (unwind_backtrace+0x0/0xdc) from [<c01e68bc>] (Ldiv0+0x8/0x10)
                     v4l2 [  248.331420] Division by zero in kernel.
    gstv4l2object.c:962:gst_v4l2_obj[  248.337951] [<c003d988>] (unwind_backtrace+0x0/0xdc) from [<c01e68bc>] (Ldiv0+0x8/0x10)
    ect_fill_format_list:<v4l2src0ivision by zero in kernel.
    [00m   BGR3 (emulated)
    0:00:16.[  248.355438] [<c003d988>] (unwind_backtrace+0x0/0xdc) from [<c01e68bc>] (Ldiv0+0x8/0x10)
    388793944  1648    0x[  248.366851] Division by zero in kernel.
    15018 INFO    [  248.372985] [<c003d988>] (unwind_backtrace+0x0/0xdc) from [<c01e68bc>] (Ldiv0+0x8/0x10)
                    v4l2 gstv4l2obje[  248.383819] Division by zero in kernel.
    ct.c:962:gst_v4l2_object_fill_fo[  248.390441] [<c003d988>] (unwind_backtrace+0x0/0xdc) from [<c01e68bc>] (Ldiv0+0x8/0x10)
    rmat_list:<v4l2src0>   RGB3[  248.401306] Division by zero in kernel.
     (emulated)
    0:00:16.388854979 003d988>] (unwind_backtrace+0x0/0xdc) from [<c01e68bc>] (Ldiv0+0x8/0x10)
    [335m 1648    0x15018ivision by zero in kernel.
    01mINFO               [  248.425476] [<c003d988>] (unwind_backtrace+0x0/0xdc) from [<c01e68bc>] (Ldiv0+0x8/0x10)
         v4l2 gstv4l2object.c:962:gs[  248.436309] Division by zero in kernel.
    t_v4l2_object_fill_format_list:<[  248.442962] [<c003d988>] (unwind_backtrace+0x0/0xdc) from [<c01e68bc>] (Ldiv0+0x8/0x10)
    v4l2src0>   BA10
    0:00:16.4[  248.453796] Division by zero in kernel.
    23919675  1648    0x1[  248.460754] [<c003d988>] (unwind_backtrace+0x0/0xdc) from [<c01e68bc>] (Ldiv0+0x8/0x10)
    5018 WARN     [  248.471466] Division by zero in kernel.
                   v4l2 gstv4l2objec[  248.478088] [<c003d988>] (unwind_backtrace+0x0/0xdc) from [<c01e68bc>] (Ldiv0+0x8/0x10)
    t.c:1804:gst_v4l2_object_probe_c[  248.488861] Division by zero in kernel.
    aps_for_format:<v4l2src0> C[  248.495483] [<c003d988>] (unwind_backtrace+0x0/0xdc) from [<c01e68bc>] (Ldiv0+0x8/0x10)
    ould not probe minimum capture s[  248.506317] Division by zero in kernel.
    ize for pixelformat YUYV
    0:00:1[  248.512847] [<c003d988>] (unwind_backtrace+0x0/0xdc) from [<c01e68bc>] (Ldiv0+0x8/0x10)
    6.458892821  1648    [  248.523895] Division by zero in kernel.
    0x15018 WARN    003d988>] (unwind_backtrace+0x0/0xdc) from [<c01e68bc>] (Ldiv0+0x8/0x10)
    0m                v4l2 gstv4l2ob[  248.541320] Division by zero in kernel.
    ject.c:1810:gst_v4l2_object_prob[  248.548095] [<c003d988>] (unwind_backtrace+0x0/0xdc) from [<c01e68bc>] (Ldiv0+0x8/0x10)
    e_caps_for_format:<v4l2src0ivision by zero in kernel.
    m Could not probe maximum captur[  248.565521] [<c003d988>] (unwind_backtrace+0x0/0xdc) from [<c01e68bc>] (Ldiv0+0x8/0x10)
    e size for pixelformat YUYV
    0:0[  248.576629] Division by zero in kernel.
    0:16.493804929  1648 [  248.582885] [<c003d988>] (unwind_backtrace+0x0/0xdc) from [<c01e68bc>] (Ldiv0+0x8/0x10)
       0x15018 WARN    [  248.594024] Division by zero in kernel.
                    v4l2 gstv4l[  248.600555] [<c003d988>] (unwind_backtrace+0x0/0xdc) from [<c01e68bc>] (Ldiv0+0x8/0x10)
    2object.c:1804:gst_v4l2_object_p[  248.611389] Division by zero in kernel.
    robe_caps_for_format:<v4l2src0>003d988>] (unwind_backtrace+0x0/0xdc) from [<c01e68bc>] (Ldiv0+0x8/0x10)
    [00m Could not probe minimum cap[  248.628906] Division by zero in kernel.
    ture size for pixelformat UYVY
    [  248.635559] [<c003d988>] (unwind_backtrace+0x0/0xdc) from [<c01e68bc>] (Ldiv0+0x8/0x10)
    0:00:16.529144286  164ivision by zero in kernel.
    0m    0x15018 WARN   003d988>] (unwind_backtrace+0x0/0xdc) from [<c01e68bc>] (Ldiv0+0x8/0x10)
    0m                 v4l2 gst[  248.663940] Division by zero in kernel.
    v4l2object.c:1810:gst_v4l2_objec[  248.670532] [<c003d988>] (unwind_backtrace+0x0/0xdc) from [<c01e68bc>] (Ldiv0+0x8/0x10)
    t_probe_caps_for_format:<v4l2src[  248.681579] Division by zero in kernel.
    0> Could not probe maximum [  248.688232] [<c003d988>] (unwind_backtrace+0x0/0xdc) from [<c01e68bc>] (Ldiv0+0x8/0x10)
    capture size for pixelformat UYV[  248.698944] Division by zero in kernel.
    Y
    0:00:16.633880612  1648[  248.705596] [<c003d988>] (unwind_backtrace+0x0/0xdc) from [<c01e68bc>] (Ldiv0+0x8/0x10)
        0x15018 WARN   [  248.716430] Division by zero in kernel.
                     v4l2 [  248.722930] [<c003d988>] (unwind_backtrace+0x0/0xdc) from [<c01e68bc>] (Ldiv0+0x8/0x10)
    gstv4l2object.c:1804:gst_v4l2_ob[  248.734008] Division by zero in kernel.
    ject_probe_caps_for_format:<v4l2[  248.740875] [<c003d988>] (unwind_backtrace+0x0/0xdc) from [<c01e68bc>] (Ldiv0+0x8/0x10)
    src0> Could not probe minim[  248.751434] Division by zero in kernel.
    um capture size for pixelformat [  248.758087] [<c003d988>] (unwind_backtrace+0x0/0xdc) from [<c01e68bc>] (Ldiv0+0x8/0x10)
    YU12
    0:00:16.[  248.768920] Division by zero in kernel.
    738952635  1648    0x[  248.775573] [<c003d988>] (unwind_backtrace+0x0/0xdc) from [<c01e68bc>] (Ldiv0+0x8/0x10)
    15018 WARN    [  248.786712] Division by zero in kernel.
                    v4l2 gstv4l2obje[  248.792938] [<c003d988>] (unwind_backtrace+0x0/0xdc) from [<c01e68bc>] (Ldiv0+0x8/0x10)
    ct.c:1810:gst_v4l2_object_probe_[  248.804046] Division by zero in kernel.
    caps_for_format:<v4l2src0> [  248.810607] [<c003d988>] (unwind_backtrace+0x0/0xdc) from [<c01e68bc>] (Ldiv0+0x8/0x10)
    Could not probe maximum capture [  248.821441] Division by zero in kernel.
    size for pixelformat YU12
    0:00:[  248.828094] [<c003d988>] (unwind_backtrace+0x0/0xdc) from [<c01e68bc>] (Ldiv0+0x8/0x10)
    16.843963621  1648   [  248.839263] Division by zero in kernel.
    00m                v4l2 gstv4l2o[  248.856445] Division by zero in kernel.
    bject.c:1804:gst_v4l2_object_pro[  248.863067] [<c003d988>] (unwind_backtrace+0x0/0xdc) from [<c01e68bc>] (Ldiv0+0x8/0x10)
    be_caps_for_format:<v4l2src0ivision by zero in kernel.
    0m Could not probe minimum captu[  248.880615] [<c003d988>] (unwind_backtrace+0x0/0xdc) from [<c01e68bc>] (Ldiv0+0x8/0x10)
    re size for pixelformat YV12
    ?62;1;2;6;7;8;9c0:00:16.94900512[  248.898162] [<c003d988>] (unwind_backtrace+0x0/0xdc) from [<c01e68bc>] (Ldiv0+0x8/0x10)
    6  1648    0x15018ivision by zero in kernel.
    33;01mWARN            [  248.915649] [<c003d988>] (unwind_backtrace+0x0/0xdc) from [<c01e68bc>] (Ldiv0+0x8/0x10)
            v4l2 gstv4l2object.c:181[  248.926483] Division by zero in kernel.
    0:gst_v4l2_object_probe_caps_for[  248.933441] [<c003d988>] (unwind_backtrace+0x0/0xdc) from [<c01e68bc>] (Ldiv0+0x8/0x10)
    _format:<v4l2src0> Could no[  248.944000] Division by zero in kernel.
    t probe maximum capture size for[  248.950622] [<c003d988>] (unwind_backtrace+0x0/0xdc) from [<c01e68bc>] (Ldiv0+0x8/0x10)
     pixelformat YV12
    ;8;9c0:00:17.054107664  16[  248.968139] [<c003d988>] (unwind_backtrace+0x0/0xdc) from [<c01e68bc>] (Ldiv0+0x8/0x10)
    48    0x15018 WARN [  248.978973] Division by zero in kernel.
                       v4l[  248.985626] [<c003d988>] (unwind_backtrace+0x0/0xdc) from [<c01e68bc>] (Ldiv0+0x8/0x10)
    2 gstv4l2object.c:1804:gst_v4l2_[  248.996734] Division by zero in kernel.
    object_probe_caps_for_format:<v4[  249.003204] [<c003d988>] (unwind_backtrace+0x0/0xdc) from [<c01e68bc>] (Ldiv0+0x8/0x10)
    l2src0> Could not probe min[  249.014038] Division by zero in kernel.
    imum capture size for pixelforma[  249.020507] [<c003d988>] (unwind_backtrace+0x0/0xdc) from [<c01e68bc>] (Ldiv0+0x8/0x10)
    t BGR3
    0:00:17.159057614 [  249.031890] Division by zero in kernel.
     1648    0x15018 WA[  249.038146] [<c003d988>] (unwind_backtrace+0x0/0xdc) from [<c01e68bc>] (Ldiv0+0x8/0x10)
    RN                    [  249.049011] Division by zero in kernel.
    v4l2 gstv4l2object.c:1810:gst_v4[  249.055664] [<c003d988>] (unwind_backtrace+0x0/0xdc) from [<c01e68bc>] (Ldiv0+0x8/0x10)
    l2_object_probe_caps_for_format:[  249.066497] Division by zero in kernel.
    <v4l2src0> Could not probe [  249.073150] [<c003d988>] (unwind_backtrace+0x0/0xdc) from [<c01e68bc>] (Ldiv0+0x8/0x10)
    maximum capture size for pixelfo[  249.084014] Division by zero in kernel.
    rmat BGR3
    [  249.090515] [<c003d988>] (unwind_backtrace+0x0/0xdc) from [<c01e68bc>] (Ldiv0+0x8/0x10)
    0:00:17.262298583  164ivision by zero in kernel.
    0m                 v4l2 gst[  249.117614] Division by zero in kernel.
    v4l2object.c:1804:gst_v4l2_objec[  249.124511] [<c003d988>] (unwind_backtrace+0x0/0xdc) from [<c01e68bc>] (Ldiv0+0x8/0x10)
    t_probe_caps_for_format:<v4l2src[  249.135131] Division by zero in kernel.
    0> Could not probe minimum [  249.141693] [<c003d988>] (unwind_backtrace+0x0/0xdc) from [<c01e68bc>] (Ldiv0+0x8/0x10)
    capture size for pixelformat RGB[  249.152557] Division by zero in kernel.
    3
    [  249.159210] [<c003d988>] (unwind_backtrace+0x0/0xdc) from [<c01e68bc>] (Ldiv0+0x8/0x10)
    [  249.169067] Division by zero in kernel.
    [  249.173095] [<c003d988>] (unwind_backtrace+0x0/0xdc) from [<c01e68bc>] (Ldiv0+0x8/0x10)
    [  249.181274] Division by zero in kernel.
    [  249.185302] [<c003d988>] (unwind_backtrace+0x0/0xdc) from [<c01e68bc>] (Ldiv0+0x8/0x10)
    0:00:17.356079100  1648    0x15018 WARN                    v4l2 gstv4l2object.c:1810:gst_v4l2_object_probe_caps_for_format:<v4l2src0> Could not probe maximum [  249.208923] Division by zero in kernel.
    capture size for pixelformat RGB[  249.214324] [<c003d988>] (unwind_backtrace+0x0/0xdc) from [<c01e68bc>] (Ldiv0+0x8/0x10)
    3
    0:00:17.356292723  1648[  249.225891] Division by zero in kernel.
        0x15018 INFO   [  249.231994] [<c003d988>] (unwind_backtrace+0x0/0xdc) from [<c01e68bc>] (Ldiv0+0x8/0x10)
                  v4l2src gstv4l2src.c:631:gst_v4l2src_get_caps:<v4l2src0> probed caps: 0x6cf00
    0:00:17.405487059  1648    0x15018 WARN                    v4l2 gstv4l2object.c:2082:gst_v4l2_object_set_format:<v4l2src0> error: Device '/dev/video0' cannot capture at 720x576
    0:00:17.405639647  1648    0x15018 WARN                    v4l2 gstv4l2object.c:2082:gst_v4l2_object_set_format:<v4l2src0> error: Call to S_FMT failed for UYVY @ 720x576: Invalid argument
    0:00:17.405853270  1648    0x15018 INFO        GST_ERROR_SYSTEM gstelement.c:1761:gst_element_message_full:<v4l2src0> posting message: Device '/dev/video0' cannot capture at 720x576
    0:00:17.406036375  1648    0x15018 INFO        GST_ERROR_SYSTEM gstelement.c:1784:gst_element_message_full:<v4l2src0> posted error message: Device '/dev/video0' cannot capture at 720x576
    0:00:17.406158445  1648    0x15018 WARN                 basesrc gstbasesrc.c:2755:gst_base_src_start:<v4l2src0> error: Could not negotiate format
    0:00:17.406249998  1648    0x15018 WARN                 basesrc gstbasesrc.c:2755:gst_base_src_start:<v4l2src0> error: Check your filtered caps, if any
    0:00:17.406372069  1648    0x15018 INFO        GST_ERROR_SYSTEM gstelement.c:1761:gst_element_message_full:<v4l2src0> posting message: Could not negotiate format
    0:00:17.406494139  1648    0x15018 INFO        GST_ERROR_SYSTEM gstelement.c:1784:gst_element_message_full:<v4l2src0> posted error message: Could not negotiate format
    0:00:17.406616209  1648    0x15018 WARN                 basesrc gstbasesrc.c:2951:gst_base_src_activate_push:<v4l2src0> Failed to start in push mode
    0:00:17.406677244  1648    0x15018 INFO                GST_PADS gstpad.c:960:gst_pad_activate_push:<v4l2src0:src> failed to activate in push mode
    0:00:17.406768797  1648    0x15018 WARN                GST_PADS gstpad.c:712:gst_pad_set_active:<v4l2src0:src> Failed to activate pad
    0:00:17.406860350  1648    0x15018 INFO              GST_STATES gstelement.c:2553:gst_element_change_state:<v4l2src0> have FAILURE change_state return
    0:00:17.406951903  1648    0x15018 INFO              GST_STATES gstelement.c:2130:gst_element_abort_state:<v4l2src0> aborting state from READY to PAUSED
    0:00:17.407043455  1648    0x15018 INFO              GST_STATES gstbin.c:2459:gst_bin_change_state_func:<pipeline0> child 'v4l2src0' failed to go to state 3(PAUSED)
    0:00:17.407135008  1648    0x15018 INFO              GST_STATES gstelement.c:2553:gst_element_change_state:<pipeline0> have FAILURE change_state return
    gstv4l2object.c(2082): gst_v4l2_object_set_format (): /GstPipeline:pipeline0/GstV4l2Src:v4l2src0:
    0:00:17.409118651  1648    0x15018 INFO              GST_STATES gstelement.c:2209:gst_element_continue_state:<tidisplaysink20> committing state from READY to READY, pending NULL, next NULL
    0:00:17.409301756  1648    0x15018 INFO              GST_STATES gstelement.c:2218:gst_element_continue_state:<tidisplaysink20> continue state change READY to NULL, final NULL
    0:00:17.409454344  1648    0x15018 INFO              GST_STATES gstelement.c:2236:gst_element_continue_state:<tidisplaysink20> completed state change to NULL
    0:00:17.409545897  1648    0x15018 INFO              GST_STATES gstelement.c:2249:gst_element_continue_state:<tidisplaysink20> posting state-changed READY to NULL
    0:00:17.743743895  1648    0x15018 INFO              GST_STATES gstbin.c:2443:gst_bin_change_state_func:<pipeline0> child 'tidisplaysink20' changed state to 1(NULL) successfully
    0:00:17.743957518  1648    0x15018 INFO              GST_STATES gstelement.c:2209:gst_element_continue_state:<capsfilter0> committing state from PAUSED to READY, pending NULL, next NULL
    0:00:17.744079588  1648    0x15018 INFO              GST_STATES gstelement.c:2218:gst_element_continue_state:<capsfilter0> continue state change READY to NULL, final NULL
    0:00:17.744201658  1648    0x15018 INFO              GST_STATES gstelement.c:2236:gst_element_continue_state:<capsfilter0> completed state change to NULL
    0:00:17.744293211  1648    0x15018 INFO              GST_STATES gstelement.c:2249:gst_element_continue_state:<capsfilter0> posting state-changed READY to NULL
    0:00:17.744415281  1648    0x15018 INFO              GST_STATES gstbin.c:2443:gst_bin_change_state_func:<pipeline0> child 'capsfilter0' changed state to 1(NULL) successfully
    0:00:17.744567869  1648    0x15018 INFO              GST_STATES gstelement.c:2209:gst_element_continue_state:<videoscale0> committing state from PAUSED to READY, pending NULL, next NULL
    0:00:17.744689939  1648    0x15018 INFO              GST_STATES gstelement.c:2218:gst_element_continue_state:<videoscale0> continue state change READY to NULL, final NULL
    0:00:17.744781492  1648    0x15018 INFO              GST_STATES gstelement.c:2236:gst_element_continue_state:<videoscale0> completed state change to NULL
    0:00:17.744873045  1648    0x15018 INFO              GST_STATES gstelement.c:2249:gst_element_continue_state:<videoscale0> posting state-changed READY to NULL
    0:00:17.744995115  1648    0x15018 INFO              GST_STATES gstbin.c:2443:gst_bin_change_state_func:<pipeline0> child 'videoscale0' changed state to 1(NULL) successfully
    0:00:17.745147703  1648    0x15018 INFO              GST_STATES gstelement.c:2209:gst_element_continue_state:<ffmpegcsp0> committing state from PAUSED to READY, pending NULL, next NULL
    0:00:17.745239256  1648    0x15018 INFO              GST_STATES gstelement.c:2218:gst_element_continue_state:<ffmpegcsp0> continue state change READY to NULL, final NULL
    0:00:17.745361326  1648    0x15018 INFO              GST_STATES gstelement.c:2236:gst_element_continue_state:<ffmpegcsp0> completed state change to NULL
    0:00:17.745452879  1648    0x15018 INFO              GST_STATES gstelement.c:2249:gst_element_continue_state:<ffmpegcsp0> posting state-changed READY to NULL
    0:00:17.745574949  1648    0x15018 INFO              GST_STATES gstbin.c:2443:gst_bin_change_state_func:<pipeline0> child 'ffmpegcsp0' changed state to 1(NULL) successfully
    0:00:17.746215819  1648    0x15018 INFO              GST_STATES gstelement.c:2236:gst_element_continue_state:<v4l2src0> completed state change to NULL
    0:00:17.746368407  1648    0x15018 INFO              GST_STATES gstelement.c:2249:gst_element_continue_state:<v4l2src0> posting state-changed READY to NULL
    0:00:18.082489012  1648    0x15018 INFO              GST_STATES gstbin.c:2443:gst_bin_change_state_func:<pipeline0> child 'v4l2src0' changed state to 1(NULL) successfully
    0:00:18.082824706  1648    0x15018 INFO              GST_STATES gstelement.c:2236:gst_element_continue_state:<pipeline0> completed state change to NULL
    0:00:18.082946776  1648    0x15018 INFO              GST_STATES gstelement.c:2249:gst_element_continue_state:<pipeline0> posting state-changed READY to NULL
    0:00:18.083068846  1648    0x15018 INFO              GST_STATES gstbin.c:1710:gst_bin_get_state_func:<pipeline0> getting state
    0:00:18.083251952  1648    0x15018 INFO        GST_ELEMENT_PADS gstpad.c:1686:gst_pad_unlink: unlinking capsfilter0:src(0xec588) and tidisplaysink20:sink(0xec3f8)
    0:00:18.083404540  1648    0x15018 INFO        GST_ELEMENT_PADS gstpad.c:1729:gst_pad_unlink: unlinked capsfilter0:src and tidisplaysink20:sink
    0:00:18.083557128  1648    0x15018 INFO        GST_ELEMENT_PADS gstpad.c:1686:gst_pad_unlink: unlinking videoscale0:src(0xec330) and capsfilter0:sink(0xec4c0)
    0:00:18.083679198  1648    0x15018 INFO        GST_ELEMENT_PADS gstpad.c:1729:gst_pad_unlink: unlinked videoscale0:src and capsfilter0:sink
    0:00:18.083831786  1648    0x15018 INFO           GST_PARENTAGE gstbin.c:1388:gst_bin_remove_func:<pipeline0> removed child "capsfilter0"
    0:00:18.083953856  1648    0x15018 INFO         GST_REFCOUNTING gstelement.c:2850:gst_element_dispose:<capsfilter0> dispose
    0:00:18.084075926  1648    0x15018 INFO        GST_ELEMENT_PADS gstelement.c:830:gst_element_remove_pad:<capsfilter0> removing pad 'src'
    0:00:18.084259032  1648    0x15018 INFO        GST_ELEMENT_PADS gstelement.c:830:gst_element_remove_pad:<capsfilter0> removing pad 'sink'
    0:00:18.084381102  1648    0x15018 INFO         GST_REFCOUNTING gstelement.c:2874:gst_element_dispose:<capsfilter0> parent class dispose
    0:00:18.084472655  1648    0x15018 INFO         GST_REFCOUNTING gstelement.c:2905:gst_element_finalize:<capsfilter0> finalize
    0:00:18.084564207  1648    0x15018 INFO         GST_REFCOUNTING gstelement.c:2916:gst_element_finalize:<capsfilter0> finalize parent
    0:00:18.084686278  1648    0x15018 INFO           GST_PARENTAGE gstbin.c:1388:gst_bin_remove_func:<pipeline0> removed child "tidisplaysink20"
    0:00:18.084777830  1648    0x15018 INFO         GST_REFCOUNTING gstelement.c:2850:gst_element_dispose:<tidisplaysink20> dispose
    0:00:18.084869383  1648    0x15018 INFO        GST_ELEMENT_PADS gstelement.c:830:gst_element_remove_pad:<tidisplaysink20> removing pad 'sink'
    0:00:18.084991453  1648    0x15018 INFO         GST_REFCOUNTING gstelement.c:2874:gst_element_dispose:<tidisplaysink20> parent class dispose
    0:00:18.085083006  1648    0x15018 INFO         GST_REFCOUNTING gstelement.c:2905:gst_element_finalize:<tidisplaysink20> finalize
    0:00:18.085174559  1648    0x15018 INFO         GST_REFCOUNTING gstelement.c:2916:gst_element_finalize:<tidisplaysink20> finalize parent
    0:00:18.421020506  1648    0x15018 INFO        GST_ELEMENT_PADS gstpad.c:1686:gst_pad_unlink: unlinking ffmpegcsp0:src(0xec1a0) and videoscale0:sink(0xec268)
    0:00:18.421203612  1648    0x15018 INFO        GST_ELEMENT_PADS gstpad.c:1729:gst_pad_unlink: unlinked ffmpegcsp0:src and videoscale0:sink
    0:00:18.421386717  1648    0x15018 INFO           GST_PARENTAGE gstbin.c:1388:gst_bin_remove_func:<pipeline0> removed child "videoscale0"
    0:00:18.421508787  1648    0x15018 INFO         GST_REFCOUNTING gstelement.c:2850:gst_element_dispose:<videoscale0> dispose
    0:00:18.421600340  1648    0x15018 INFO        GST_ELEMENT_PADS gstelement.c:830:gst_element_remove_pad:<videoscale0> removing pad 'src'
    0:00:18.421722410  1648    0x15018 INFO        GST_ELEMENT_PADS gstelement.c:830:gst_element_remove_pad:<videoscale0> removing pad 'sink'
    0:00:18.421844481  1648    0x15018 INFO         GST_REFCOUNTING gstelement.c:2874:gst_element_dispose:<videoscale0> parent class dispose
    0:00:18.421936033  1648    0x15018 INFO         GST_REFCOUNTING gstelement.c:2905:gst_element_finalize:<videoscale0> finalize
    0:00:18.422027586  1648    0x15018 INFO         GST_REFCOUNTING gstelement.c:2916:gst_element_finalize:<videoscale0> finalize parent
    0:00:18.422119139  1648    0x15018 INFO        GST_ELEMENT_PADS gstpad.c:1686:gst_pad_unlink: unlinking v4l2src0:src(0xec010) and ffmpegcsp0:sink(0xec0d8)
    0:00:18.422271727  1648    0x15018 INFO        GST_ELEMENT_PADS gstpad.c:1729:gst_pad_unlink: unlinked v4l2src0:src and ffmpegcsp0:sink
    0:00:18.422393797  1648    0x15018 INFO           GST_PARENTAGE gstbin.c:1388:gst_bin_remove_func:<pipeline0> removed child "ffmpegcsp0"
    0:00:18.422515867  1648    0x15018 INFO         GST_REFCOUNTING gstelement.c:2850:gst_element_dispose:<ffmpegcsp0> dispose
    0:00:18.422607420  1648    0x15018 INFO        GST_ELEMENT_PADS gstelement.c:830:gst_element_remove_pad:<ffmpegcsp0> removing pad 'src'
    0:00:18.422729490  1648    0x15018 INFO        GST_ELEMENT_PADS gstelement.c:830:gst_element_remove_pad:<ffmpegcsp0> removing pad 'sink'
    0:00:18.422821043  1648    0x15018 INFO         GST_REFCOUNTING gstelement.c:2874:gst_element_dispose:<ffmpegcsp0> parent class dispose
    0:00:18.422912596  1648    0x15018 INFO         GST_REFCOUNTING gstelement.c:2905:gst_element_finalize:<ffmpegcsp0> finalize
    0:00:18.423004149  1648    0x15018 INFO         GST_REFCOUNTING gstelement.c:2916:gst_element_finalize:<ffmpegcsp0> finalize parent
    0:00:18.423095701  1648    0x15018 INFO           GST_PARENTAGE gstbin.c:1388:gst_bin_remove_func:<pipeline0> removed child "v4l2src0"
    0:00:18.423217772  1648    0x15018 INFO         GST_REFCOUNTING gstelement.c:2850:gst_element_dispose:<v4l2src0> dispose
    0:00:18.423309324  1648    0x15018 INFO        GST_ELEMENT_PADS gstelement.c:830:gst_element_remove_pad:<v4l2src0> removing pad 'src'
    0:00:18.756683348  1648    0x15018 INFO         GST_REFCOUNTING gstelement.c:2874:gst_element_dispose:<v4l2src0> parent class dispose
    0:00:18.756896971  1648    0x15018 INFO         GST_REFCOUNTING gstelement.c:2905:gst_element_finalize:<v4l2src0> finalize
    0:00:18.757019041  1648    0x15018 INFO         GST_REFCOUNTING gstelement.c:2916:gst_element_finalize:<v4l2src0> finalize parent
    0:00:18.757110594  1648    0x15018 INFO         GST_REFCOUNTING gstelement.c:2850:gst_element_dispose:<pipeline0> dispose
    0:00:18.757232664  1648    0x15018 INFO         GST_REFCOUNTING gstelement.c:2874:gst_element_dispose:<pipeline0> parent class dispose
    0:00:18.757324217  1648    0x15018 INFO         GST_REFCOUNTING gstelement.c:2905:gst_element_finalize:<pipeline0> finalize
    0:00:18.757415770  1648    0x15018 INFO         GST_REFCOUNTING gstelement.c:2916:gst_element_finalize:<pipeline0> finalize parent
    0:00:18.757507323  1648    0x15018 INFO                GST_INIT gst.c:1004:gst_deinit: deinitializing GStreamer
    0:00:18.766082762  1648    0x15018 INFO                GST_INIT gst.c:1107:gst_deinit: deinitialized GStreamer
    root@dm37x-evm:~#
    root@dm37x-evm:~# 62;1;2;6;7;8;9c62;1;2;6;7;8;9c62;1;2;6;7;8;9c62;1;2;6;7;8;9c
    Report Abuse
    • Reply
  • jay liyang
    on Aug 20 2012 19:46 PM
    Hi
    When I use this command on the ti-dmai-apps application:
    the path  is   "usr/share/ti/ti-dmai-apps"
    ./video_loopback_dm3730.x470MV -O lcd
     The PAL camera(CCD) can display on the LCD screen,and then execute your command
    gst-launch -v v4l2src device=/dev/video0 ! ffmpegcolorspace ! videoscale ! video/x-raw-yuv,format=\(fourcc\)UYVY, width=720, height=576 ! tidisplaysink2 -v
    successfully, and I can see the video image in the LCD screen.
    But I must execute the first command ,or else your commad is reported error
    Why?
    Hope help!
    jay yang
    Report Abuse
    • Reply
  • jay liyang
    on Aug 20 2012 19:51 PM
    Hi
    I have already  found that this command just support the resolution about "width=720, height=576",
    if I repair the width or height to other value ,for example  "width=320, height=240",  it will turn out the same eror
    Have you encountered this strange problem?
    jay yang
    Report Abuse
    • Reply
  • fang zhang
    Posted by fang zhang
    on May 06 2013 03:30 AM
    Prodigy20 points
    videoscale had a problem, you should use TIVidResize replace it.
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
