Remote System Explorer problem
Hi
I am working with CCS 5.2 with a TI ARM Cortex A8 target.  I am trying to connect to the target using Remote System Explorer (RSE) and have followed the instructions here:
http://processors.wiki.ti.com/index.php/Sitara_Linux_Training:_Hands_on_with_the_SDK#Configuring_Remote_System_Explorer_.28RSE.29
I have got to the last step, where I am to “Right-Click the My Target EVM node and select Connect”. I should then see the target's RSA key fingerprint.  However, instead I see:
Failed to connect sshd on "<snip>": ProxyHTTP: java.io.IOException: proxy error: Service Unavailable
How can I fix this please?
BR
David
  • Hi
    I have progressed a little with this.  I have added the EVM to the proxy bypass list in CCS.  Now when I attempt to connect to the EVM using RSE I get:
    Failed to connect SFTP subsystem: Remote host may not have sftp-server installed : java.io.IOException: inputstream is closed
    How should I proceed?
    BR
    David
  • In reply to David Aldrich:
    The lab that is mentioned was developed with version 5.1 of  CCS. Here is a link to download that version of CCS.
    http://software-dl.ti.com/dsps/dsps_public_sw/am_bu/sdk/AM335xSDK/latest/index_FDS.html
    The 5.1 version has RSE support in it.
  • In reply to Schuyler Patton:
    Hi
    It turned out that the openssh packages were not included in my kernel image. I added those and RSE now connects to the target correctly.
    David
  • In reply to David Aldrich92784:
    Hi david,
    what do you mean openssh packages in your kernel images?
    mre
