General issues faced while setting up TRACE32 for linux debug with Lauterbach on an Ubuntu/Linux PC
Issue 1.
PCF/Bitmap fonts not enabled.
Error reported: "FATAL ERROR from X-windows: XFT available, but not working with PCF bitmap fonts.
Please check your FontCOnfig configuration, possibly bitmap fonts are explicitly disabled.
Solution:
step 1: Enable bitmpa fonts, sudo rm /etc/fonts/conf.d/70-no-bitmaps.conf
step 2: CLear the old font cache
sudo fc-cache -f -v <path to t32, usually /opt>/t32/fonts
step 3: restart your PC.
  • Issue 2:
    Connection is not detected. You might have connected the lauterbach to you PC via USB cable and powered on but still doesn't get detected by PC/T32.
    Error reported: "FATAL ERROR from PODBUS, TRACE32 not connected or could not be accessed"
    Solution:
    step 1: Check if "SLECT" led is flshing on the hardware (Lauterbach Jtag debugger) if yes then it means the self test is successfully completed.
    step 2: You might be missing the udev rules file / is not copied correctly to udev directory.
      Copy the 10-lauterbach.rues file ound in <pathto t32 instalaltion, generally /opt>/t32/bin/pc_linux/udev.conf/10-lauterbach.rules to /etc/udev/rules.d/ directory
    sudo cp <pathto t32 instalaltion, generally /opt>/t32/bin/pc_linux/udev.conf/10-lauterbach.rules /etc/udev/rules.d/
    step 3: Restart your system.
  • Issue 3:
    Error reported: Unable to find shared object library libjpeg.so.62
    Solution:
    You might be missing the shared library file so install Libjpeg
    sudo apt-get install libjpeg62
    Additional information on General issues and help can be found here:
    http://www.anyclub.org/2012/03/faqs-for-trace32.html
    http://www2.lauterbach.com/pdf/icd_quick_installation.pdf
    http://www2.lauterbach.com/pdf/installation.pdf
  • Hello Ravikumar,
    Same scenario :  FATAL ERROR from PODBUS-driver  : TRACE32 not connected for accessible
     I have install the of centos 7 (64 bit) , And i completed on installation part  , after install the lauter bach i'm trying to sourcing on below command
    source  /opt/t32/trace32.sh
    in that trace32.sh file content
    export T32SYS=/tools/t32
    export T32TMP=/tmp
    export T32ID=T32
    export PATH=$PATH:/opt/t32/bin/pc_linux/
    Error
    I  have done  the above post root cause  (step1 and step2 ) till the issue is persist , Kindly post your conclusion for this scenario
    Many Thanks
    Golden John S
