I am trying to run this moduletest, standalone test codes that is available with the RDK.
Basically trying to implement a standalone code to just capture and display bypassing the AVCAPTURE.
Module test code that is present in the RDK is implemented considering input from IPIPE+RSZ. But my flow of data is Analog Video Signal -> TVP5158 -> Capture-> Display
PAL 720 x 576 input resolution.
Have modified the DRV_capturetest.c file accordingly the following way and i see it gives me following error.
root@DM365_IPNC:/opt/ipnc# root@DM365_IPNC:/opt/ipnc# sync ./modroot@DM365_IPNC:/opt/ipnc# ./moduletroot@DM365_IPNC:/opt/ipnc# ./moduletest.out drv_capture
CLK Hz,
ARM Hz = 216000000
DDR Hz = 171789472
VPSS Hz = 171789472
IMCOP Hz = 171789472
CAPTURE: Opening display.
ERROR (drv_captureTest.c|DRV_ca8168.drv_captureTest.cptureTestOpen|164): Open failed
CAPTURE: Exiting.
Segmentation fault
Can somebody please go through the code below and see if my implementation is correct or if am missing something.
Thanks & Regards,
Swathi
#include <drv_captureTestPriv.h>
static DRV_CaptureTestCtrl gDRV_testCtrl;
int DRV_captureTestOpen()
int status;
gDRV_testCtrl.captureConfig.imgsConfig.sensorMode = DRV_CAPTURE_TEST_SENSOR_MODE;
gDRV_testCtrl.captureConfig.imgsConfig.binEnable = FALSE;
gDRV_testCtrl.captureConfig.imgsConfig.fps = 30;
gDRV_testCtrl.captureConfig.isifConfig.sensorMode = gDRV_testCtrl.captureConfig.imgsConfig.sensorMode;
gDRV_testCtrl.captureConfig.isifConfig.alawEnable = FALSE;
gDRV_testCtrl.captureConfig.isifConfig.dpcmEnable = FALSE;
gDRV_testCtrl.captureConfig.isifConfig.numBuf = DRV_CAPTURE_TEST_NUM_BUF;
gDRV_testCtrl.captureConfig.isifConfig.numLscBuf = 0;
#ifdef DRV_CAPTURE_TEST_ENABLE_LSC
gDRV_testCtrl.captureConfig.isifConfig.numLscBuf = DRV_CAPTURE_TEST_NUM_BUF;
#endif
gDRV_testCtrl.captureConfig.isifConfig.lscConfig.paxelWidth = 16;
gDRV_testCtrl.captureConfig.isifConfig.lscConfig.paxelHeight = 8;
gDRV_testCtrl.captureConfig.isifConfig.lscConfig.gainFormat = 0;
gDRV_testCtrl.captureConfig.isifConfig.lscConfig.offsetEnable = TRUE;
gDRV_testCtrl.captureConfig.isifConfig.lscConfig.offsetScale = 0x80;
gDRV_testCtrl.captureConfig.isifConfig.lscConfig.offsetShift = 0;
gDRV_testCtrl.captureConfig.isifConfig.lscConfig.initX = 0;
gDRV_testCtrl.captureConfig.isifConfig.lscConfig.initY = 0;
gDRV_testCtrl.captureConfig.h3aConfig.sensorMode = gDRV_testCtrl.captureConfig.imgsConfig.sensorMode;
gDRV_testCtrl.captureConfig.h3aConfig.numBufAewb = DRV_CAPTURE_TEST_NUM_BUF;
gDRV_testCtrl.captureConfig.h3aConfig.numBufAf = DRV_CAPTURE_TEST_NUM_BUF;
gDRV_testCtrl.captureConfig.h3aConfig.aewbVendor = APPRO_2A;
gDRV_testCtrl.captureConfig.ipipeConfig.sensorMode = gDRV_testCtrl.captureConfig.imgsConfig.sensorMode;
gDRV_testCtrl.captureConfig.ipipeConfig.inputSrc = DRV_IPIPE_INPUT_SRC_ISIF;
gDRV_testCtrl.captureConfig.ipipeConfig.boxcarBlockSize = DRV_IPIPE_BOXCAR_BLOCK_SIZE_NONE;
gDRV_testCtrl.captureConfig.ipipeConfig.boxcarInShift = 0;
gDRV_testCtrl.captureConfig.ipipeConfig.histogramMode = DRV_IPIPE_HISTO_MODE_NONE;
gDRV_testCtrl.captureConfig.ipipeConfig.bscNumVectorsRow = 0;
#ifdef DRV_CAPTURE_TEST_ENABLE_BSC
gDRV_testCtrl.captureConfig.ipipeConfig.bscNumVectorsRow = 3;
#endif
#ifdef DRV_CAPTURE_TEST_ENABLE_BOXCAR
gDRV_testCtrl.captureConfig.ipipeConfig.boxcarBlockSize = DRV_IPIPE_BOXCAR_BLOCK_SIZE_8x8;
#endif
gDRV_testCtrl.captureConfig.ipipeConfig.bscNumVectorsCol = gDRV_testCtrl.captureConfig.ipipeConfig.bscNumVectorsRow;
gDRV_testCtrl.captureConfig.ipipeConfig.rszValidDataStartOffset = 0;
gDRV_testCtrl.captureConfig.ipipeConfig.rszOutConfig[0].enable = FALSE;
gDRV_testCtrl.captureConfig.ipipeConfig.rszOutConfig[0].outFormat = DRV_CAPTURE_TEST_DATA_FORMAT;
gDRV_testCtrl.captureConfig.ipipeConfig.rszOutConfig[0].width = 720;//1280;
gDRV_testCtrl.captureConfig.ipipeConfig.rszOutConfig[0].height = 576;//720;
gDRV_testCtrl.captureConfig.ipipeConfig.rszOutConfig[0].flipH = FALSE;
gDRV_testCtrl.captureConfig.ipipeConfig.rszOutConfig[0].flipV = FALSE;
gDRV_testCtrl.captureConfig.ipipeConfig.rszOutConfig[0].numBuf = DRV_CAPTURE_TEST_NUM_BUF;
gDRV_testCtrl.captureConfig.ipipeConfig.rszOutConfig[1].enable = FALSE;
gDRV_testCtrl.captureConfig.ipipeConfig.rszOutConfig[1].outFormat = gDRV_testCtrl.captureConfig.ipipeConfig.rszOutConfig[0].outFormat;
gDRV_testCtrl.captureConfig.ipipeConfig.rszOutConfig[1].width = 720;//640;
gDRV_testCtrl.captureConfig.ipipeConfig.rszOutConfig[1].height = 576;//480;
gDRV_testCtrl.captureConfig.ipipeConfig.rszOutConfig[1].flipH = gDRV_testCtrl.captureConfig.ipipeConfig.rszOutConfig[0].flipH;
gDRV_testCtrl.captureConfig.ipipeConfig.rszOutConfig[1].flipV = gDRV_testCtrl.captureConfig.ipipeConfig.rszOutConfig[0].flipV;
gDRV_testCtrl.captureConfig.ipipeConfig.rszOutConfig[1].numBuf = gDRV_testCtrl.captureConfig.ipipeConfig.rszOutConfig[0].numBuf;
gDRV_testCtrl.displayConfig.winId = DRV_DISPLAY_VID_WIN_0;
gDRV_testCtrl.displayConfig.numBuf = DRV_CAPTURE_TEST_NUM_BUF;
gDRV_testCtrl.displayConfig.dataFormat = gDRV_testCtrl.captureConfig.ipipeConfig.rszOutConfig[0].outFormat;
gDRV_testCtrl.displayConfig.startX = 0;
gDRV_testCtrl.displayConfig.startY = 0;
gDRV_testCtrl.displayConfig.width = 720;
gDRV_testCtrl.displayConfig.height = 576;
gDRV_testCtrl.displayConfig.offsetH = OSA_align(gDRV_testCtrl.displayConfig.width, 32);
gDRV_testCtrl.displayConfig.offsetV = gDRV_testCtrl.displayConfig.height;
gDRV_testCtrl.displayConfig.zoomH = 0;
gDRV_testCtrl.displayConfig.zoomV = 0;
gDRV_testCtrl.displayConfig.bufFlag = 0;
gDRV_testCtrl.displayBufId=0;
OSA_printf(" CAPTURE: Opening display.\n");
status = DRV_displayOpen(&gDRV_testCtrl.displayHndl, &gDRV_testCtrl.displayConfig);
OSA_printf(" %d , %d \n",status, OSA_SOK);
if(status!=OSA_SOK)
goto error_exit;
status = DRV_displaySetMode(DRV_DISPLAY_MODE_PAL);
if(status!=OSA_SOK)
goto error_exit;
OSA_printf(" DRV_DisaplayMode executed \n");
DRV_displayGetBufInfo(&gDRV_testCtrl.displayHndl, &gDRV_testCtrl.displayInfo);
OSA_printf(" CAPTURE: Opening capture on imager %s.\n", DRV_imgsGetImagerName());
status = DRV_captureOpen(&gDRV_testCtrl.captureConfig, &gDRV_testCtrl.captureInfo);
if(status!=OSA_SOK)
goto capture_exit;
return OSA_SOK;
alloc_exit:
#ifdef DRV_CAPTURE_TEST_ENABLE_FD
DRV_faceDetectClose();
#endif
fd_exit:
#endif
DRV_captureClose();
capture_exit:
DRV_displayClose(&gDRV_testCtrl.displayHndl);
error_exit:
OSA_ERROR("Open failed\n");
return OSA_EFAIL;
int DRV_captureTestH3aRun(int count)
int status;
int bufIdAewb;
OSA_BufInfo *pBufInfo;
int accValue[4];
CSL_H3aAewbOutSumModeOverlay *pAewbWinData;
Uint8 *curAewbAddr;
int numWin, i, j, avgG, aGain;
DRV_IpipeWb wb;
status = DRV_h3aGetBuf(DRV_H3A_MOD_AEWB, &bufIdAewb, OSA_TIMEOUT_FOREVER);
if(status!=OSA_SOK) {
OSA_ERROR("DRV_h3aGetBuf()\n");
return status;
pBufInfo = DRV_h3aGetBufInfo(DRV_H3A_MOD_AEWB, bufIdAewb);
if(pBufInfo) {
#ifdef DRV_CAPTURE_TEST_SAVE_H3A_DATA
if(count>1) {
static char filename[80];
if(count%100==0) {
sprintf(filename, "H3A_%04d_%dx%d.BIN", count, gDRV_testCtrl.captureInfo.h3aInfo.aewbNumWinH, gDRV_testCtrl.captureInfo.h3aInfo.aewbNumWinV);
OSA_fileWriteFile(filename, pBufInfo->virtAddr, pBufInfo->size);
#endif
if(count%(30*5)==0) {
curAewbAddr = pBufInfo->virtAddr;
numWin=0;
accValue[0]=accValue[1]=accValue[2]=accValue[3]=0;
for(i=0; i<gDRV_testCtrl.captureInfo.h3aInfo.aewbNumWinV; i++) {
for(j=0; j<gDRV_testCtrl.captureInfo.h3aInfo.aewbNumWinH; j++) {
pAewbWinData = (CSL_H3aAewbOutSumModeOverlay *)curAewbAddr;
accValue[0] += pAewbWinData->subSampleAcc[0];
accValue[1] += pAewbWinData->subSampleAcc[1];
accValue[2] += pAewbWinData->subSampleAcc[2];
accValue[3] += pAewbWinData->subSampleAcc[3];
#if 0
OSA_printf(" (%2d:%2d) %5d, %5d, %5d, %5d\n", i, j,
pAewbWinData->subSampleAcc[0], pAewbWinData->subSampleAcc[1],
pAewbWinData->subSampleAcc[2], pAewbWinData->subSampleAcc[3]
#endif
curAewbAddr += sizeof(CSL_H3aAewbOutSumModeOverlay);
numWin++;
if(numWin%8==0)
curAewbAddr += sizeof(CSL_H3aAewbOutUnsatBlkCntOverlay);
curAewbAddr = (Uint8*)OSA_align( (Uint32)curAewbAddr, 32);
accValue[0] /= numWin*gDRV_testCtrl.captureInfo.h3aInfo.aewbNumSamplesPerColorInWin;
accValue[1] /= numWin*gDRV_testCtrl.captureInfo.h3aInfo.aewbNumSamplesPerColorInWin;
accValue[2] /= numWin*gDRV_testCtrl.captureInfo.h3aInfo.aewbNumSamplesPerColorInWin;
accValue[3] /= numWin*gDRV_testCtrl.captureInfo.h3aInfo.aewbNumSamplesPerColorInWin;
#ifdef DRV_CAPTURE_TEST_APPLY_2A
// do simple AWB
wb.gainGr = 0x200;
wb.gainGb = 0x200;
wb.gainR = (wb.gainGr*accValue[0])/accValue[1];
wb.gainB = (wb.gainGb*accValue[3])/accValue[2];
DRV_ipipeSetWb(&wb);
// do simple AE
avgG = (accValue[0]+accValue[3])/2;
aGain = 8000 - (avgG*4000)/512;
DRV_imgsSetAgain(aGain, 0);
#ifdef DRV_CAPTURE_TEST_PRINT_H3A_INFO
OSA_printf(" AEWB Avg Color: %5d, %5d, %5d, %5d (AE aGain = %d)\n", accValue[0], accValue[1], accValue[2], accValue[3], aGain);
#endif
#endif
DRV_h3aPutBuf(DRV_H3A_MOD_AEWB, bufIdAewb);
return status;
int DRV_captureTestBscRun(int count)
int status, i, j;
int bufIdBsc;
int rowSum[10], colSum[10];
Uint16 *curAddr;
status = DRV_ipipeGetBscBuf(&bufIdBsc, OSA_TIMEOUT_FOREVER);
return status;
pBufInfo = DRV_ipipeGetBscBufInfo(bufIdBsc);
if(pBufInfo) {
#ifdef DRV_CAPTURE_TEST_SAVE_BSC_DATA
if(count>1) {
if(count%100==0) {
sprintf(filename, "BSC_%04d.BIN", count);
#endif
#ifdef DRV_CAPTURE_TEST_ENABLE_VS
ALG_VstabRunPrm vsPrm;
vsPrm.bscDataVirtAddr = pBufInfo->virtAddr;
vsPrm.bscDataPhysAddr = pBufInfo->physAddr;
OSA_prfBegin(&gDRV_testCtrl.vsPrf);
status = ALG_vstabRun(gDRV_testCtrl.vsHndl, &vsPrm, &gDRV_testCtrl.vsStatus);
OSA_prfEnd(&gDRV_testCtrl.vsPrf, 1);
OSA_ERROR("ALG_vstabRun()\n");
OSA_prfPrint(&gDRV_testCtrl.vsPrf, "VS", 0);
#endif
if(count%(30*3)==0) {
curAddr = (Uint16*)pBufInfo->virtAddr;
for(i=0; i<gDRV_testCtrl.captureInfo.ipipeInfo.bscInfo.rowNumVectors; i++) {
rowSum[i] = 0;
for(j=0; j<gDRV_testCtrl.captureInfo.ipipeInfo.bscInfo.rowNumV; j++) {
rowSum[i] += *curAddr;
curAddr++;
rowSum[i] /= gDRV_testCtrl.captureInfo.ipipeInfo.bscInfo.rowNumV;
curAddr = (Uint16*)(pBufInfo->virtAddr + DRV_IPIPE_BSC_BUFFER_MAX/2);
for(i=0; i<gDRV_testCtrl.captureInfo.ipipeInfo.bscInfo.colNumVectors; i++) {
colSum[i] = 0;
for(j=0; j<gDRV_testCtrl.captureInfo.ipipeInfo.bscInfo.colNumH; j++) {
colSum[i] += *curAddr;
curAddr++;
colSum[i] /= gDRV_testCtrl.captureInfo.ipipeInfo.bscInfo.colNumH;
#ifdef DRV_CAPTURE_TEST_PRINT_BSC_INFO
OSA_printf(" BSC: Row [%8d, %8d, %8d] Col [%8d, %8d, %8d]\n",
rowSum[0], rowSum[1], rowSum[2],
colSum[0], colSum[1], colSum[2]
#endif
DRV_ipipePutBscBuf(bufIdBsc);
return status;
int DRV_captureTestRun()
int status, rawBufId;
// int bufIdRszA, bufIdRszB;
DRV_FrameCopyPrm frameCopy;
OSA_BufInfo *pRawBufInfo, *pBufInfo;
static int count=0;
status = DRV_isifGetOutBuf(&rawBufId, OSA_TIMEOUT_FOREVER);
OSA_ERROR("DRV_isifGetOutBuf()\n");
return status;
#ifdef AVSERVER_DEBUG_VIDEO_CAPTURE_THR
#ifdef AVSERVER_DEBUG_RUNNING
OSA_printf("CAPTURE: Isif Buf %d\n", rawBufId);
#endif
#endif
pBufInfo = DRV_isifGetOutBufInfo(rawBufId);
OSA_printf("Rawbuf->Virtual address = %d, Rawbuf->Physical address = %d, Rawbuf-> width =%d, Rawbuf->height = %d\n",pBufInfo->virtAddr,pBufInfo->physAddr,pBufInfo->width,pBufInfo->height);
if(pBufInfo) {
#if 1
count++;
if(count%100==0) {
sprintf(filename, "\mnt\mmc\IMG_%04d_720x576.PPM", count);
OSA_fileWriteFile(filename, pBufInfo->virtAddr,720*576*1.5);
#endif
frameCopy.srcPhysAddr = pBufInfo->physAddr;
frameCopy.srcVirtAddr = pBufInfo->virtAddr;
frameCopy.dstPhysAddr = gDRV_testCtrl.displayInfo.physAddr[gDRV_testCtrl.displayBufId];
frameCopy.dstVirtAddr = gDRV_testCtrl.displayInfo.virtAddr[gDRV_testCtrl.displayBufId];
frameCopy.srcOffsetH = OSA_align(720, 32);
frameCopy.srcOffsetV = 576;
frameCopy.dstOffsetH = gDRV_testCtrl.displayInfo.offsetH;
frameCopy.dstOffsetV = gDRV_testCtrl.displayInfo.offsetV;
frameCopy.copyWidth = gDRV_testCtrl.displayInfo.width;
frameCopy.copyHeight = gDRV_testCtrl.displayInfo.height;
frameCopy.dataFormat = gDRV_testCtrl.displayInfo.dataFormat;
frameCopy.srcStartX = 0;//(gDRV_testCtrl.captureInfo.ipipeInfo.rszInfo[DRV_IPIPE_RSZ_A].width-gDRV_testCtrl.displayInfo.width)/2;
frameCopy.srcStartY = 0;//(gDRV_testCtrl.captureInfo.ipipeInfo.rszInfo[DRV_IPIPE_RSZ_A].height-gDRV_testCtrl.displayInfo.height)/2;
frameCopy.srcStartX += gDRV_testCtrl.vsStatus.startX;
frameCopy.srcStartY += gDRV_testCtrl.vsStatus.startY;
#endif
frameCopy.dstStartX = 0;
frameCopy.dstStartY = 0;
status = DRV_frameCopy(NULL, &frameCopy);
OSA_ERROR("DRV_frameCopy(A)\n");
// DRV_ipipePutRszBuf(DRV_IPIPE_RSZ_A, bufIdRszA);
// DRV_ipipePutRszBuf(DRV_IPIPE_RSZ_B, bufIdRszB);
DRV_displaySwitchBuf( &gDRV_testCtrl.displayHndl, &gDRV_testCtrl.displayBufId, 0, NULL);
return status;
void DRV_captureTestSignalHandler(int signum)
gDRV_testCtrl.testQuit=1;
int DRV_captureTestMain(int argc, char **argv)
int status;
memset(&gDRV_testCtrl, 0, sizeof(gDRV_testCtrl));
gDRV_testCtrl.testQuit = 0;
OSA_attachSignalHandler(SIGINT, DRV_captureTestSignalHandler);
status = DRV_init();
if(status!=OSA_SOK)
return status;
status = DRV_captureTestOpen();
if(status!=OSA_SOK)
goto open_exit;
status = DRV_captureStart(FALSE, TRUE);
if(status!=OSA_SOK)
goto start_exit;
OSA_printf(" CAPTURE: Running.\n");
status = OSA_SOK;
while(!gDRV_testCtrl.testQuit && status==OSA_SOK)
status = DRV_captureTestRun();
DRV_captureStop();
start_exit:
OSA_printf(" CAPTURE: Closing capture.\n");
DRV_captureClose();
OSA_printf(" CAPTURE: Closing display.\n");
#endif
ALG_vstabDelete(gDRV_testCtrl.vsHndl);
#endif
if(gDRV_testCtrl.tmpBufSize) {
// OSA_fileWriteFile("DATA_DUMP.YUV", gDRV_testCtrl.tmpBufVirtAddr, gDRV_testCtrl.tmpBufSize);
OSA_cmemFree(gDRV_testCtrl.tmpBufVirtAddr);
open_exit:
OSA_printf(" CAPTURE: Exiting.\n");
DRV_exit();
OSA_printf(" CAPTURE: Bye Bye !!!\n");
return status;
